BuzStringer 33 Posted February 14, 2023 Posted February 14, 2023 \\URSERVER\Movies\Alita Battle Angel (2019)
Happy2Play 9800 Posted February 14, 2023 Posted February 14, 2023 (edited) 3 minutes ago, BuzStringer said: \\URSERVER\Movies\Alita Battle Angel (2019) There is your (part) issue as filenames must match folder name, then space hyphen space then your version. Each version must begin with the folder name, followed by " - ". Alita Battle Angel (2019) Alita Battle Angel (2019) - version 1.ext Alita Battle Angel (2019) - version 2.ext Edited February 14, 2023 by Happy2Play example 1
Happy2Play 9800 Posted February 14, 2023 Posted February 14, 2023 @BuzStringerOr utilize the plugin and name/organize how you like.
BuzStringer 33 Posted February 14, 2023 Posted February 14, 2023 4 minutes ago, Happy2Play said: There is your issue as filenames must match folder name, then space hyphen space then your version. Each version must begin with the folder name, followed by " - ". thanks, but I just tried that, Copy and pasted the folder name, refreshed the libary Still the same
Happy2Play 9800 Posted February 14, 2023 Posted February 14, 2023 1 minute ago, BuzStringer said: thanks, but I just tried that, Copy and pasted the folder name, refreshed the libary Still the same Both versions need the same format so your Proper is incorrect. 1
BuzStringer 33 Posted February 14, 2023 Posted February 14, 2023 3 minutes ago, Happy2Play said: Both versions need the same format so your Proper is incorrect. That got it, thanks i was starting to pull my hair out
BuzStringer 33 Posted February 14, 2023 Posted February 14, 2023 Follow up question if i rename my entire libary to for the correct naming scheme will i loose all of my playcounts / status?
Happy2Play 9800 Posted February 14, 2023 Posted February 14, 2023 5 minutes ago, BuzStringer said: Follow up question if i rename my entire libary to for the correct naming scheme will i loose all of my playcounts / status? No as they are tracked by providerid not path/naming. Note the is no distinction between versions when it comes to played state.
