horstepipe 423 Posted August 3, 2020 Posted August 3, 2020 (edited) hello On my Beelink GT-King with Android TV rom, movies with Dolby Digital Plus have no audio. So as I don't want serverside transcode/conversion at all, I'm wondering whether it's possible to do a e-ac3 to ac3 conversion on the device? "Downmix to stereo" is not really an option as it would also affect other formats which work fine and I'd like to keep the surround channels. Has anybody made the same experience on the GT-King? Stats for nerds show audio codec: Dolby+ (direct) Edited August 3, 2020 by horstepipe
ebr 16338 Posted August 3, 2020 Posted August 3, 2020 It isn't possible right now but we'd like to try and make it so. However, are you not getting audio because you turned off the option to allow audio conversion on the server? 1
horstepipe 423 Posted August 4, 2020 Author Posted August 4, 2020 (edited) 19 hours ago, ebr said: are you not getting audio because you turned off the option to allow audio conversion on the server? yes. Edited August 4, 2020 by horstepipe
horstepipe 423 Posted August 4, 2020 Author Posted August 4, 2020 (edited) 18 hours ago, clarkss12 said: Which ATV mod are you running? Hey This one: https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s922x/others-s922x/firmware-roms-tools-dq/784806-rom-beelink-gt-king-alvatech-android-tv-atv-9-0-pie-s922x Edited August 4, 2020 by horstepipe
horstepipe 423 Posted August 4, 2020 Author Posted August 4, 2020 19 hours ago, ebr said: It isn't possible right now but we'd like to try and make it so. Thanks. But at this point (after recognizing a server conversion is not allowed) shouldn't Emby detect that the device is not capable of playing dd+ and downmix it to stereo even if down mix to stereo is not enabled?
clarkss12 304 Posted August 4, 2020 Posted August 4, 2020 Will the same file under Kodi, down mix it to stereo? Just curious.
Solution ebr 16338 Posted August 4, 2020 Solution Posted August 4, 2020 4 hours ago, horstepipe said: Thanks. But at this point (after recognizing a server conversion is not allowed) shouldn't Emby detect that the device is not capable of playing dd+ and downmix it to stereo even if down mix to stereo is not enabled? No, the app isn't aware of the fact you disabled server conversion. There is a warning under that option telling you it can cause playback problems. 1
horstepipe 423 Posted August 4, 2020 Author Posted August 4, 2020 1 hour ago, clarkss12 said: Will the same file under Kodi, down mix it to stereo? Just curious. Pretty sure Kodi got an option to convert to ac3
horstepipe 423 Posted August 4, 2020 Author Posted August 4, 2020 On 03/08/2020 at 16:44, ebr said: It isn't possible right now but we'd like to try and make it so. Thanks, then I‘ll keep my fingers crossed you‘ll be able to implement that feature.
