neik 874 Posted September 6, 2021 Posted September 6, 2021 22 minutes ago, chef said: If you inspect element in the browser and look at the console, are there any errors? A page refresh apparently solved the issue, strange... I will keep an eye on it and in case it happens again trying to narrow it down. 1
chef 3811 Posted September 6, 2021 Posted September 6, 2021 (edited) On 8/5/2021 at 5:38 PM, Ryan_vl said: That worked perfectly, thanks so much for this!!!! @Ryan_vl, there is a file on your machine here: "Emby-Server\programdata\config\autoorganize.xml" Inside the config xml there is a node for " <MovieOptions>". Under MovieOptions is a node called: " <WatchLocations>", which should have a child node called "String". Looks like this: <MovieOptions> <IsEnabled></IsEnabled> <MinFileSizeMb></MinFileSizeMb> <LeftOverFileExtensionsToDelete> <string /> </LeftOverFileExtensionsToDelete> <WatchLocations> <string>RIGHT_HERE!!!</string> </WatchLocations> <MoviePattern></MoviePattern> <OverwriteExistingFiles></OverwriteExistingFiles> <DeleteEmptyFolders></DeleteEmptyFolders> <ExtendedClean></ExtendedClean> <CopyOriginalFile></CopyOriginalFile> <AutoDetectMovie></AutoDetectMovie> <DefaultMovieLibraryPath /> <IgnoredFileNameContains /> <CreateMovieInFolder></CreateMovieInFolder> <MovieFolderPattern></MovieFolderPattern> </MovieOptions> Does that node exist for you? If so, does the node (I've marked 'RIGHT_HERE!!!' in the example) contain the proper path to the watched folder for your movies? I just tested and it seems okay on my machine... but ... that means nothing Edited September 6, 2021 by chef
chef 3811 Posted September 6, 2021 Posted September 6, 2021 1 hour ago, neik said: A page refresh apparently solved the issue, strange... I will keep an eye on it and in case it happens again trying to narrow it down. Excellent! Thank you @neik. Keep me up to date if anything happens that is out of the ordinary ... or doesn't happen
GOTCHA_SA 8 Posted September 6, 2021 Posted September 6, 2021 26 minutes ago, chef said: @Ryan_vl, there is a file on your machine here: "Emby-Server\programdata\config\autoorganize.xml" Inside the config xml there is a node for " <MovieOptions>". Under MovieOptions is a node called: " <WatchLocations>", which should have a child node called "String". Looks like this: <MovieOptions> <IsEnabled></IsEnabled> <MinFileSizeMb></MinFileSizeMb> <LeftOverFileExtensionsToDelete> <string /> </LeftOverFileExtensionsToDelete> <WatchLocations> <string>RIGHT_HERE!!!</string> </WatchLocations> <MoviePattern></MoviePattern> <OverwriteExistingFiles></OverwriteExistingFiles> <DeleteEmptyFolders></DeleteEmptyFolders> <ExtendedClean></ExtendedClean> <CopyOriginalFile></CopyOriginalFile> <AutoDetectMovie></AutoDetectMovie> <DefaultMovieLibraryPath /> <IgnoredFileNameContains /> <CreateMovieInFolder></CreateMovieInFolder> <MovieFolderPattern></MovieFolderPattern> </MovieOptions> Does that node exist for you? If so, does the node (I've marked 'RIGHT_HERE!!!' in the example) contain the proper path to the watched folder for your movies? I just tested and it seems okay on my machine... but ... that means nothing Hi @chef It does exist and the path is correct <WatchLocations> <string>\\<ServerName>\Downloads\Emby Movies Monitor</string> </WatchLocations>
chef 3811 Posted September 6, 2021 Posted September 6, 2021 57 minutes ago, Ryan_vl said: Hi @chef It does exist and the path is correct <WatchLocations> <string>\\<ServerName>\Downloads\Emby Movies Monitor</string> </WatchLocations> Okay. Before I post this version with some extra logging, is there any way I could see a log for when this is happening?
GOTCHA_SA 8 Posted September 6, 2021 Posted September 6, 2021 embyserver.txt Here is the Log File. So i did do a Test with the below 2 movies Stay Tuned - Already exists in my library and does appear in the activity log Nativity 2 - new Movie - seems to be found in the log but does not appear in the Activity log
chef 3811 Posted September 6, 2021 Posted September 6, 2021 (edited) 15 minutes ago, Ryan_vl said: embyserver.txt 3.76 MB · 0 downloads Here is the Log File. So i did do a Test with the below 2 movies Stay Tuned - Already exists in my library and does appear in the activity log Nativity 2 - new Movie - seems to be found in the log but does not appear in the Activity log Oh! that is exactly what I needed! excellent. I tested on a movie that already existed, which is probably why I didn't break. I will brb! Edited September 6, 2021 by chef
chef 3811 Posted September 7, 2021 Posted September 7, 2021 @Ryan_vl I found the code that was causing this. @neik If you guys find any other strange behavior in the plugin, let me know. Here is the fix. Emby.AutoOrganize.zip 1 1
Skopin 10 Posted September 8, 2021 Posted September 8, 2021 On 8/22/2021 at 2:29 PM, chef said: That folder structure is complex. I did read people wanted the plugin to handle a more complex file system. I suppose it could be possible to create a regular expression to handle complex folder structure. But, how complex? I'm not entirely sure. What if instead of having it auto handle those, you changed it to allow more than one watch folder and destination to be set up? So if I put a file into watch folder 1, it goes to destination folder 1. If I put it in watch folder 2, it goes to destination 2. This would be ideal for me personally. I have multiple libraries for both shows and movies with my files separated into folders based on resolution. It looks like this: Movies Library Folders: 4K, HD, SD Kids Movies Library Folders: 4K, HD, SD I would love to be able to set up a watch folder for each of those folders and have auto-organize move them to their respective library folders. So if I drop a file into KidsMovies4KReady, it moves it into Kids Movies/4K. Currently I have to manually change the Default Movie Library every time I have a different type to add. 2
chef 3811 Posted September 8, 2021 Posted September 8, 2021 (edited) 1 hour ago, Skopin said: What if instead of having it auto handle those, you changed it to allow more than one watch folder and destination to be set up? So if I put a file into watch folder 1, it goes to destination folder 1. If I put it in watch folder 2, it goes to destination 2. This would be ideal for me personally. I have multiple libraries for both shows and movies with my files separated into folders based on resolution. It looks like this: Movies Library Folders: 4K, HD, SD Kids Movies Library Folders: 4K, HD, SD I would love to be able to set up a watch folder for each of those folders and have auto-organize move them to their respective library folders. So if I drop a file into KidsMovies4KReady, it moves it into Kids Movies/4K. Currently I have to manually change the Default Movie Library every time I have a different type to add. It doesn't say it in the UI, and I haven't tested it myself, but if you put a comma delimited set of paths in the watched folder input, I think you can have more then one for both episodes and movies. It is setup to be an array of paths, but it is untested. As far as a more complex sort, I'll see what it can do. Edited September 8, 2021 by chef
Skopin 10 Posted September 9, 2021 Posted September 9, 2021 1 hour ago, chef said: It doesn't say it in the UI, and I haven't tested it myself, but if you put a comma delimited set of paths in the watched folder input, I think you can have more then one for both episodes and movies. It is setup to be an array of paths, but it is untested. As far as a more complex sort, I'll see what it can do. Oh, that's good to know. I'll give that a try. Even that would speed up my workflow so I only need to change the destination instead of both the source and destination.
chef 3811 Posted September 9, 2021 Posted September 9, 2021 4 minutes ago, Skopin said: Oh, that's good to know. I'll give that a try. Even that would speed up my workflow so I only need to change the destination instead of both the source and destination. I'd be interested to know, I haven't tried it either.
chef 3811 Posted September 9, 2021 Posted September 9, 2021 I just noticed something interesting that needs attention. When the file is in use (direct streaming) from emby, and you want to sort a new version of the file into the library, the plugin will show 'Not Enough Disk Space' error. this is because we assume the IO error at that point of sorting will be not enough disk space. Apparently, we need to have another status, 'File In Use', and put the sorting of the file into a 'Waiting' state.
Skopin 10 Posted September 9, 2021 Posted September 9, 2021 12 hours ago, chef said: I'd be interested to know, I haven't tried it either. Unfortunately, it didn't work. I tried both with and without quotes around the folder paths, but it never picked up the files I put in either folder.
chef 3811 Posted September 9, 2021 Posted September 9, 2021 Just now, Skopin said: Unfortunately, it didn't work. I tried both with and without quotes around the folder paths, but it never picked up the files I put in either folder. Ah, looking at the code I can see why it wasn't completely implemented. It looks as though the ground work is there. Perhaps getting multiple watch folders is the first step in a more complex sorting. We definitely want to keep things as straight forward as possible. But, let's see what can be arranged, in any case. 1
rbjtech 5345 Posted September 9, 2021 Posted September 9, 2021 Does it pick up any (a single) folders ? If yes, then you can cheat and just put symbolic links into that single Folder which actually point to multiple (unlimited) folders. 1
GrimReaper 4906 Posted September 9, 2021 Posted September 9, 2021 (edited) 15 hours ago, Skopin said: Currently I have to manually change the Default Movie Library every time I have a different type to add. I still think current workflow where you change both the source and destination is safer approach, until multiple watch/destination pairs are introduced, else you'll ever be able to import only single movie (or all within a single subfolder) and be particulary cautious not to have movies in two or more subfolders at the same time otherwise they might easily end up in wrong library. Changing source as you currently do is just additional safety switch. Edit: Or run multiple Radarr instances. Edited September 9, 2021 by GrimReaper Append
neik 874 Posted September 9, 2021 Posted September 9, 2021 Hi chef, I have some weird behavior. I added two or three files to the watched folder but one is not being shown in the UI although the plugin sees the file and writes it in the log - will send it to you via PM. Another point: I hope it's not too much to ask but could you use some sort of versioning please? Currently it's difficult to determine whether I'm on the latest version or not.
chef 3811 Posted September 10, 2021 Posted September 10, 2021 15 hours ago, neik said: Hi chef, I have some weird behavior. I added two or three files to the watched folder but one is not being shown in the UI although the plugin sees the file and writes it in the log - will send it to you via PM. Another point: I hope it's not too much to ask but could you use some sort of versioning please? Currently it's difficult to determine whether I'm on the latest version or not. Yes, thank you. I have a day off of work today, and the kids are at school! Sweet! That gives me quite a bit of time to find out what is making the UI miss new items. Thank you for the log. Much appreciated! I'll also update the versioning. Thanks @neik 1
chef 3811 Posted September 10, 2021 Posted September 10, 2021 On 9/3/2021 at 1:57 AM, neik said: chef, the black action buttons are not visible on the black theme any chance you can adapt that to a different color? Yes, I can make them the theme colour. Won't take long. 1
chef 3811 Posted September 11, 2021 Posted September 11, 2021 here you go @neik I think I grabbed the correct color, and it should change with the different themes correctly. You'll want to clear browser data to show the changes. Emby.AutoOrganize_v1.6.0.2.zip Let me know if you still have an issue with that movie not showing up. 1
neik 874 Posted September 11, 2021 Posted September 11, 2021 That did the trick with the buttons, thanks for that. I am still running into the other issue though not seeing some files in the UI and therefore not being able to organize them. Anything you can do about that or anything you need from me?
chef 3811 Posted September 11, 2021 Posted September 11, 2021 2 hours ago, neik said: That did the trick with the buttons, thanks for that. I am still running into the other issue though not seeing some files in the UI and therefore not being able to organize them. Anything you can do about that or anything you need from me? It is a movie file right?
neik 874 Posted September 12, 2021 Posted September 12, 2021 (edited) 18 hours ago, chef said: It is a movie file right? That's correct, until now it only happened with movies, tv shows have always been shown so far. Edit: Need to correct that, just have an episode that it's not showing up in the UI. If you need anything from me then let me know. Edited September 12, 2021 by neik
neik 874 Posted September 14, 2021 Posted September 14, 2021 Chef, the files organized by the plugin used to show up in the library without needing to run the scan task - probably the plugin did some sort of trigger. Now I have to always start the scan task for the new items to show up. Just to let you know, definitely no biggy...
