chef 3811 Posted April 11, 2022 Posted April 11, 2022 26 minutes ago, GiGo said: No problem, this is what is happening; The files are being moved to G:\Shared Drives\Backup1\emby-primary\ instead of; G:\Shared Drives\Backup1\emby-primary\TV\Blake's 7\ Cool. What is shown in the File Organizer, as options in the "Root Folder" drop down?
chef 3811 Posted April 11, 2022 Posted April 11, 2022 oh boy. This are getting difficult. This is going to take a moment to fix. I have to take into account all types of file systems => "\\", "\", "/", "//" Unix, windows etc. It's okay though. I got it!
GiGo 108 Posted April 11, 2022 Posted April 11, 2022 2 hours ago, chef said: Cool. What is shown in the File Organizer, as options in the "Root Folder" drop down? Sorry for my slow response, had the electric out for new meter installs. The Root folder options are correct, they correspond with the libraries.
chef 3811 Posted April 11, 2022 Posted April 11, 2022 Got called into work early today. But, while I was cooking, I was think about why the method is broken, and it occured to me that the path are being figured out in the wrong place. So with that, I am going to change how and where in the code, we figure out the new path.
chef 3811 Posted April 12, 2022 Posted April 12, 2022 Holy working with paths in the file system is quite difficult. Someone might have a path like: "C:\TV\series\season 1\episode.mkv" And also: "R:\Television\series\episode.mkv" So you can just strip the root folder and replace it because the paths are very different.
chef 3811 Posted April 12, 2022 Posted April 12, 2022 Oh! I fixed the movie sorting problem. Thank goodness! I think I fixed a bunch of things.
norbo80 2 Posted April 12, 2022 Posted April 12, 2022 quick question- how do you install the new version of the plugin - just replace the plugin file in plugin directory and restart emby or do you also deleting fileorganise.db ?
daedalus 434 Posted April 12, 2022 Posted April 12, 2022 39 minutes ago, norbo80 said: quick question- how do you install the new version of the plugin - just replace the plugin file in plugin directory and restart emby or do you also deleting fileorganise.db ? yes, just replace the one in .\Emby-Server\programdata\plugins and some version here required deleting the fileorganise.db, so this won't hurt
GiGo 108 Posted April 12, 2022 Posted April 12, 2022 1 hour ago, norbo80 said: quick question- how do you install the new version of the plugin - just replace the plugin file in plugin directory and restart emby or do you also deleting fileorganise.db ? It may be in a different place if you are not using the Windows Server version
chef 3811 Posted April 12, 2022 Posted April 12, 2022 I have something new here. I let it run over night, and things seemed to sort okay. The question is, does the ability to force a sort to a new folder work properly. @GiGo I think I have figured it out. However, I'm not super satisfied with how the code is finding the episode path. It is depending on a folder structure of "Series/Season/episode". I know that most of us do infact use this structure, but can you think of situations where that structure is different for TV? Do people use different path structures?
GiGo 108 Posted April 12, 2022 Posted April 12, 2022 12 minutes ago, chef said: I have something new here. I let it run over night, and things seemed to sort okay. The question is, does the ability to force a sort to a new folder work properly. @GiGo I think I have figured it out. However, I'm not super satisfied with how the code is finding the episode path. It is depending on a folder structure of "Series/Season/episode". I know that most of us do infact use this structure, but can you think of situations where that structure is different for TV? Do people use different path structures? That's the structure I use, but as you say not everyone uses that, but most will, I doubt there would be many that wouldn't use it and want the functionaility of the 2 root folder system. So if someone does I imagine it would be a very very small amount of people.
chef 3811 Posted April 12, 2022 Posted April 12, 2022 9 minutes ago, GiGo said: That's the structure I use, but as you say not everyone uses that, but most will, I doubt there would be many that wouldn't use it and want the functionaility of the 2 root folder system. So if someone does I imagine it would be a very very small amount of people. I agree. I think then, I have fixed many of the issues we had come across, the last couple days. One of issues I've been facing with this plugin is code, is how easy it is to change one thing, and break something somewhere else in the code. It' been difficult to find the condition, and then fix it. Hence all the issues. I've just been able to sort a new series. I'm about to do one more test of an Existing episode, and placing it in a new location. I also fixed the movie sorting error that @TheUrbanXplorer mentioned earlier. I definitely don't want to be a critic, but there is some code in the javascript that needs to be refactored. The file organizer is holding redundant global variables, when it could just query the page for the information. I'll fix it later... I'm just running a finale check on skip existing items now.
chef 3811 Posted April 12, 2022 Posted April 12, 2022 version 1.6.2.6 fix - movies alerted " No TV libraries are configured in Emby library setup." when attempting to sort the file. What a silly alert! TODO: stop holding global variables based on data that can be queried in the page. Check the "Root Folder" select-box options count instead of holding the count in the global variable "mediasLocationsCount". fix - sorting existing items into new location caused strange path resolutions. Stripping the root of the path wasn't enough. The path had to be rebuilt. TODO: possible issues when users have folder structures that break Emby's recommendations. Should most likely have a link ready to post that directs them to the "Recommended folder structure" Wiki on Github" lol. That is a rabbit hole that we should think twice about going down. Emby.AutoOrganize_v1.6.2.6.zip It works for me... but, as I have learned... that means nothing. 1
GiGo 108 Posted April 12, 2022 Posted April 12, 2022 THANK YOU @chef this works great! Files are going to the right place now, great job! 1
GiGo 108 Posted April 13, 2022 Posted April 13, 2022 A new day and a new issue perhaps? Trying organise a new show called "Joe (2013)" I have enabled 'Auto create new shows', however as you can see from the screenshot it's trying to sort it to a recognised show "The Job Lot (2013)" This is after organizing the files, before any user intervention; Trying to identify one of the unidentified files; Results in no sorting dispite selecting the root folder; This is also the same result with a wrongfully identified file. This results on me not being able to sort these files at all? Part of the log below; 2022-04-13 06:00:58.699 Info App: Sorting file G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv into series G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013) 2022-04-13 06:00:58.700 Info App: Sorting file G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv to new path G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013)\Season1\The Job Lot.S01E01 - Under Pressure.mkv 2022-04-13 06:00:58.819 Info App: Plugin options: no overwrite episode 2022-04-13 06:00:58.820 Info App: File 'G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv' already exists as 'G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013)\Season1\The Job Lot.S01E01 - Under Pressure.mkv', stopping organization 2022-04-13 06:00:58.875 Error Server: Error processing request *** Error Report *** Version: 4.7.0.34 Command line: C:\Users\giles\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/giles/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\giles\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\giles\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: File 'G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv' already exists as 'G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013)\Season1\The Job Lot.S01E01 - Under Pressure.mkv', stopping organization at Emby.AutoOrganize.Core.InternalFileOrganizationService.PerformOrganization(EpisodeFileOrganizationRequest request) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 06:00:58.894 Info Server: http/1.1 Response 500 to host1. Time: 264ms. http://192.168.1.67:8096/emby/Library/FileOrganizations/aed5d3baf2c1824fbf2a946e67504150/Episode/Organize?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json 2022-04-13 06:01:14.384 Info LibraryMonitor: The 70s Greatest... (2021) (G:\Shared drives\Backup1\emby-primary\TV\The 70s Greatest... (2021)) will be refreshed. 2022-04-13 06:01:16.424 Info Server: http/1.1 DELETE http://192.168.1.67:8096/emby/Library/FileOrganizations/Completed?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36 2022-04-13 06:01:16.433 Info Server: http/1.1 Response 204 to host1. Time: 9ms. http://192.168.1.67:8096/emby/Library/FileOrganizations/Completed?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34 2022-04-13 06:01:27.109 Info Server: http/1.1 POST http://192.168.1.67:8096/emby/Items/RemoteSearch/Series?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36 2022-04-13 06:01:27.111 Info HttpClient: GET https://api4.thetvdb.com/v4/search?type=series&q=Jo&year=2013 2022-04-13 06:01:28.600 Info App: MovieDbProvider: Finding id for item: Jo 2022-04-13 06:01:28.600 Info HttpClient: GET https://api.themoviedb.org/3/search/tv?api_key=x_secret1_x&query=Jo&language=en&first_air_date_year=2013 2022-04-13 06:01:29.106 Info HttpClient: GET https://private.omdbapi.com?apikey=x_secret2_x&plot=full&r=json&y=2013&s=Jo&type=series 2022-04-13 06:01:29.647 Info Server: http/1.1 Response 200 to host1. Time: 2538ms. http://192.168.1.67:8096/emby/Items/RemoteSearch/Series?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json 2022-04-13 06:01:37.698 Info LibraryMonitor: Derry Girls (G:\Shared drives\Backup1\emby-primary\TV\Derry Girls (2018)) will be refreshed. 2022-04-13 06:01:40.327 Info Server: http/1.1 POST http://192.168.1.67:8096/emby/Library/FileOrganizations/e72ceaacfcea57cc852a824937de4c1a/Episode/Organize?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36 2022-04-13 06:01:40.330 Info App: Beginning file organization with corrections: Jo to G:\Shared drives\Backup1\emby-primary\TV 2022-04-13 06:01:40.440 Error ProviderManager: Error searching *** Error Report *** Version: 4.7.0.34 Command line: C:\Users\giles\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/giles/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\giles\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\giles\AppData\Roaming\Emby-Server\system System.NotImplementedException: System.NotImplementedException: The method or operation is not implemented. at MovieDb.MovieDbEpisodeProvider.GetMetadata(EpisodeInfo info, CancellationToken cancellationToken) at MovieDb.MovieDbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: MovieDb TargetSite: System.Threading.Tasks.Task`1[MediaBrowser.Controller.Providers.MetadataResult`1[MediaBrowser.Controller.Entities.TV.Episode]] GetMetadata(MediaBrowser.Controller.Providers.EpisodeInfo, System.Threading.CancellationToken) 2022-04-13 06:01:40.440 Info HttpClient: GET https://private.omdbapi.com?apikey=x_secret2_x&plot=full&r=json&i=tt2885556&Episode=8&Season=1 2022-04-13 06:01:40.656 Warn App: No provider metadata found for The Job Lot season 1 episode 8 2022-04-13 06:01:40.663 Error Server: Error processing request *** Error Report *** Version: 4.7.0.34 Command line: C:\Users\giles\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/giles/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\giles\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\giles\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: No provider metadata found for The Job Lot season 1 episode 8 at Emby.AutoOrganize.Core.InternalFileOrganizationService.PerformOrganization(EpisodeFileOrganizationRequest request) Source: Emby.AutoOrganize TargetSite: Void MoveNext()
neik 874 Posted April 13, 2022 Posted April 13, 2022 chef, I just installed the latest plugin and seem to be having an issue when a file has more than one destination folder. The plugin is detecting it and stops sorting the file but whenever I try to bring up the fileorganizer pop-up nothing happens. I can see lots of these in the logs, might be unrelated though: 2022-04-13 07:52:43.228 Error Server: Error processing request *** Error Report *** Version: 4.7.0.33 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-88-generic (buildd@lgw01-amd64-008) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #99-Ubuntu SMP Thu Sep 23 17:29:00 UTC 2021 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamWithDirectStreamProvider(String id, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetState(StreamRequest request, Boolean requiresOutputPath, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() And also this in the console:
TheUrbanXplorer 36 Posted April 13, 2022 Posted April 13, 2022 For me, unfortunately, everything is the same. It says it moves the file, but unfortunately nothing happens. 2022-04-13 07:47:36.849 Info App: Beginning Episode Organization 2022-04-13 07:47:36.849 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E15-FKKTV\Unsere.kleine.Farm.S02E15.Die.Blutvergiftung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:36.850 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E15-FKKTV\Unsere.kleine.Farm.S02E15.Die.Blutvergiftung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E15 - Die Blutvergiftung.mkv 2022-04-13 07:47:38.237 Info App: Beginning Episode Organization 2022-04-13 07:47:38.237 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E13-FKKTV\Unsere.kleine.Farm.S04E13.Flucht.in.die.Freiheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:38.237 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E13-FKKTV\Unsere.kleine.Farm.S04E13.Flucht.in.die.Freiheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E13 - Flucht in die Freiheit.mkv 2022-04-13 07:47:38.842 Info App: Beginning Episode Organization 2022-04-13 07:47:38.842 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E11-FKKTV\Unsere.kleine.Farm.S01E11.Eine.Glocke.fuer.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:38.843 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E11-FKKTV\Unsere.kleine.Farm.S01E11.Eine.Glocke.fuer.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E11 - Eine Glocke für Walnut Grove.mkv 2022-04-13 07:47:39.470 Info App: Beginning Episode Organization 2022-04-13 07:47:39.470 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E19-FKKTV\Unsere.kleine.Farm.S06E19.Feuersbrunst.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:39.470 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E19-FKKTV\Unsere.kleine.Farm.S06E19.Feuersbrunst.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E19 - Die Feuersbrunst (2).mkv 2022-04-13 07:47:40.080 Info App: Beginning Episode Organization 2022-04-13 07:47:40.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E07-FKKTV\Unsere.kleine.Farm.S08E07.Die.Moechtegern-Ganoven.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:40.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E07-FKKTV\Unsere.kleine.Farm.S08E07.Die.Moechtegern-Ganoven.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E07 - Die Möchtegern-Ganoven.mkv 2022-04-13 07:47:40.683 Info App: Beginning Episode Organization 2022-04-13 07:47:40.683 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E09-FKKTV\Unsere.kleine.Farm.S02E09.Eine.neue.Familie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:40.684 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E09-FKKTV\Unsere.kleine.Farm.S02E09.Eine.neue.Familie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E09 - Der Ausflug.mkv 2022-04-13 07:47:40.975 Info App: Beginning Episode Organization 2022-04-13 07:47:40.975 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E02-FKKTV\Unsere.kleine.Farm.S06E02.Schulanfang.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:40.976 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E02-FKKTV\Unsere.kleine.Farm.S06E02.Schulanfang.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E02 - Schulanfang (2).mkv 2022-04-13 07:47:41.251 Info App: Beginning Episode Organization 2022-04-13 07:47:41.251 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E06-FKKTV\Unsere.kleine.Farm.S01E06.Geburtstagsfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:41.251 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E06-FKKTV\Unsere.kleine.Farm.S01E06.Geburtstagsfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E06 - Geburtstagsfeier.mkv 2022-04-13 07:47:41.514 Info App: Beginning Episode Organization 2022-04-13 07:47:41.514 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E15-FKKTV\Unsere.kleine.Farm.S07E15.Ein.Lied.fuer.Hester.Sue.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:41.515 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E15-FKKTV\Unsere.kleine.Farm.S07E15.Ein.Lied.fuer.Hester.Sue.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E15 - Ein Lied für Hester Sue.mkv 2022-04-13 07:47:42.169 Info App: Beginning Episode Organization 2022-04-13 07:47:42.169 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E03-FKKTV\Unsere.kleine.Farm.S05E03.Der.beste.Spieler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:42.171 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E03-FKKTV\Unsere.kleine.Farm.S05E03.Der.beste.Spieler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E03 - Der beste Spieler.mkv 2022-04-13 07:47:42.778 Info App: Beginning Episode Organization 2022-04-13 07:47:42.778 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E04-FKKTV\Unsere.kleine.Farm.S04E04.Ein.unerwarteter.Helfer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:42.778 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E04-FKKTV\Unsere.kleine.Farm.S04E04.Ein.unerwarteter.Helfer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E04 - Ein unerwarteter Helfer.mkv 2022-04-13 07:47:43.070 Info App: Beginning Episode Organization 2022-04-13 07:47:43.070 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E20-FKKTV\Unsere.kleine.Farm.S03E20.Klassensprecherwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:43.070 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E20-FKKTV\Unsere.kleine.Farm.S03E20.Klassensprecherwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E20 - Klassensprecherwahl.mkv 2022-04-13 07:47:43.685 Info App: Beginning Episode Organization 2022-04-13 07:47:43.685 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E09-FKKTV\Unsere.kleine.Farm.S07E09.Der.Zweikampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:43.686 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E09-FKKTV\Unsere.kleine.Farm.S07E09.Der.Zweikampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E09 - Der Zweikampf.mkv 2022-04-13 07:47:43.946 Info App: Beginning Episode Organization 2022-04-13 07:47:43.946 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E01-FKKTV\Unsere.kleine.Farm.S08E01.Die.neue.Nellie.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:43.946 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E01-FKKTV\Unsere.kleine.Farm.S08E01.Die.neue.Nellie.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E01 - Die neue Nellie (1).mkv 2022-04-13 07:47:44.226 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/77921/all/de.zip 2022-04-13 07:47:44.742 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/1/episode/0?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:47:44.880 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=0&Season=1 2022-04-13 07:47:45.403 Warn App: No provider metadata found for Unsere kleine Farm season 1 episode 0 2022-04-13 07:47:45.404 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 1 episode 0 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:47:45.662 Info App: Beginning Episode Organization 2022-04-13 07:47:45.662 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E12-FKKTV\Unsere.kleine.Farm.S03E12.Ich.reite.mit.dem.Wind.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:45.662 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E12-FKKTV\Unsere.kleine.Farm.S03E12.Ich.reite.mit.dem.Wind.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E12 - Ich reite mit dem Wind.mkv 2022-04-13 07:47:45.904 Info App: Beginning Episode Organization 2022-04-13 07:47:45.904 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E21-FKKTV\Unsere.kleine.Farm.S02E21.Der.verlorene.Sohn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:45.905 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E21-FKKTV\Unsere.kleine.Farm.S02E21.Der.verlorene.Sohn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E21 - Der verlorene Sohn.mkv 2022-04-13 07:47:46.158 Info App: Beginning Episode Organization 2022-04-13 07:47:46.159 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E16-FKKTV\Unsere.kleine.Farm.S04E16.Erinnerungen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.159 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E16-FKKTV\Unsere.kleine.Farm.S04E16.Erinnerungen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E16 - Erinnerungen.mkv 2022-04-13 07:47:46.412 Info App: Beginning Episode Organization 2022-04-13 07:47:46.412 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E13-FKKTV\Unsere.kleine.Farm.S08E13.Lauras.Obstgarten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.412 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E13-FKKTV\Unsere.kleine.Farm.S08E13.Lauras.Obstgarten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E13 - Lauras Obstgarten.mkv 2022-04-13 07:47:46.689 Info App: Beginning Episode Organization 2022-04-13 07:47:46.689 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E21-FKKTV\Unsere.kleine.Farm.S07E21.Die.Waisenkinder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.690 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E21-FKKTV\Unsere.kleine.Farm.S07E21.Die.Waisenkinder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E21 - Die Waisenkinder (1).mkv 2022-04-13 07:47:46.957 Info App: Beginning Episode Organization 2022-04-13 07:47:46.957 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E18-FKKTV\Unsere.kleine.Farm.S05E18.Kinderstimmen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E18-FKKTV\Unsere.kleine.Farm.S05E18.Kinderstimmen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E18 - Kinderstimmen.mkv 2022-04-13 07:47:47.245 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/10/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:47:47.366 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=5&Season=10 2022-04-13 07:47:47.884 Warn App: No provider metadata found for Unsere kleine Farm season 10 episode 5 2022-04-13 07:47:47.886 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 10 episode 5 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:47:48.115 Info App: Beginning Episode Organization 2022-04-13 07:47:48.115 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E13-FKKTV\Unsere.kleine.Farm.S02E13.Die.Sprechmaschine.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.116 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E13-FKKTV\Unsere.kleine.Farm.S02E13.Die.Sprechmaschine.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E13 - Die Sprechmaschine.mkv 2022-04-13 07:47:48.361 Info App: Beginning Episode Organization 2022-04-13 07:47:48.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E06-FKKTV\Unsere.kleine.Farm.S05E06.Heimweh.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E06-FKKTV\Unsere.kleine.Farm.S05E06.Heimweh.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E06 - Heimweh (2).mkv 2022-04-13 07:47:48.627 Info App: Beginning Episode Organization 2022-04-13 07:47:48.627 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E10-FKKTV\Unsere.kleine.Farm.S04E10.Der.Preisboxer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.628 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E10-FKKTV\Unsere.kleine.Farm.S04E10.Der.Preisboxer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E10 - Der Preisboxer.mkv 2022-04-13 07:47:48.897 Info App: Beginning Episode Organization 2022-04-13 07:47:48.897 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E04-FKKTV\Unsere.kleine.Farm.S08E04.Der.schwarze.Gelehrte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.898 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E04-FKKTV\Unsere.kleine.Farm.S08E04.Der.schwarze.Gelehrte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E04 - Der schwarze Gelehrte.mkv 2022-04-13 07:47:49.141 Info App: Beginning Episode Organization 2022-04-13 07:47:49.141 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E13-FKKTV\Unsere.kleine.Farm.S07E13.Nellies.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.142 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E13-FKKTV\Unsere.kleine.Farm.S07E13.Nellies.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E13 - Nellies Baby.mkv 2022-04-13 07:47:49.384 Info App: Beginning Episode Organization 2022-04-13 07:47:49.384 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E02-FKKTV\Unsere.kleine.Farm.S04E02.Die.Zeiten.aendern.sich.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.385 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E02-FKKTV\Unsere.kleine.Farm.S04E02.Die.Zeiten.aendern.sich.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E02 - Die Zeiten ändern sich.mkv 2022-04-13 07:47:49.627 Info App: Beginning Episode Organization 2022-04-13 07:47:49.627 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E15-FKKTV\Unsere.kleine.Farm.S05E15.Der.Kunsttischler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.628 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E15-FKKTV\Unsere.kleine.Farm.S05E15.Der.Kunsttischler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E15 - Der Kunsttischler.mkv 2022-04-13 07:47:49.906 Info App: Beginning Episode Organization 2022-04-13 07:47:49.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E23-FKKTV\Unsere.kleine.Farm.S01E23.Die.grosse.weite.Welt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e23.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E23-FKKTV\Unsere.kleine.Farm.S01E23.Die.grosse.weite.Welt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e23.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E23 - Die große, weite Welt.mkv 2022-04-13 07:47:50.167 Info App: Beginning Episode Organization 2022-04-13 07:47:50.167 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E21-FKKTV\Unsere.kleine.Farm.S04E21.Mary.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.168 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E21-FKKTV\Unsere.kleine.Farm.S04E21.Mary.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E21 - Mary (1).mkv 2022-04-13 07:47:50.437 Info App: Beginning Episode Organization 2022-04-13 07:47:50.437 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E21-FKKTV\Unsere.kleine.Farm.S06E21.Mr.Olesons.zweiter.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.438 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E21-FKKTV\Unsere.kleine.Farm.S06E21.Mr.Olesons.zweiter.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E21 - Mr. Olesons zweiter Frühling.mkv 2022-04-13 07:47:50.700 Info App: Beginning Episode Organization 2022-04-13 07:47:50.700 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E16-FKKTV\Unsere.kleine.Farm.S02E16.Abenteuerliche.Fahrt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.701 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E16-FKKTV\Unsere.kleine.Farm.S02E16.Abenteuerliche.Fahrt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E16 - Abenteuerliche Fahrt.mkv 2022-04-13 07:47:50.943 Info App: Beginning Episode Organization 2022-04-13 07:47:50.943 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E12-FKKTV\Unsere.kleine.Farm.S01E12.Der.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.943 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E12-FKKTV\Unsere.kleine.Farm.S01E12.Der.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E12 - Der Preis.mkv 2022-04-13 07:47:51.254 Info App: Beginning Episode Organization 2022-04-13 07:47:51.254 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E07-FKKTV\Unsere.kleine.Farm.S03E07.Grossvater.kehrt.heim.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:51.255 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E07-FKKTV\Unsere.kleine.Farm.S03E07.Grossvater.kehrt.heim.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E07 - Großvater kehrt heim (2).mkv 2022-04-13 07:47:51.503 Info App: Beginning Episode Organization 2022-04-13 07:47:51.503 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E10-FKKTV\Unsere.kleine.Farm.S08E10.Die.Restaurantkette.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:51.504 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E10-FKKTV\Unsere.kleine.Farm.S08E10.Die.Restaurantkette.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E10 - Die Restaurantkette.mkv 2022-04-13 07:47:51.779 Info App: Beginning Episode Organization 2022-04-13 07:47:51.779 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E10-FKKTV\Unsere.kleine.Farm.S02E10.Am.Ende.des.Regenbogens.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:51.780 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E10-FKKTV\Unsere.kleine.Farm.S02E10.Am.Ende.des.Regenbogens.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E10 - Am Ende des Regenbogens.mkv 2022-04-13 07:47:52.053 Info App: Beginning Episode Organization 2022-04-13 07:47:52.053 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E16-FKKTV\Unsere.kleine.Farm.S07E16.Auf.Wiedersehen.Mrs.Wilder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.054 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E16-FKKTV\Unsere.kleine.Farm.S07E16.Auf.Wiedersehen.Mrs.Wilder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E16 - Auf Wiedersehen Mrs. Wilder.mkv 2022-04-13 07:47:52.303 Info App: Beginning Episode Organization 2022-04-13 07:47:52.303 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E01-FKKTV\Unsere.kleine.Farm.S03E01.Der.Mann.des.Himmels.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.355 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E01-FKKTV\Unsere.kleine.Farm.S03E01.Der.Mann.des.Himmels.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E01 - Der Mann des Himmels.mkv 2022-04-13 07:47:52.611 Info App: Beginning Episode Organization 2022-04-13 07:47:52.611 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E02-FKKTV\Unsere.kleine.Farm.S08E02.Die.neue.Nellie.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.612 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E02-FKKTV\Unsere.kleine.Farm.S08E02.Die.neue.Nellie.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E02 - Die neue Nellie (2).mkv 2022-04-13 07:47:52.866 Info App: Beginning Episode Organization 2022-04-13 07:47:52.866 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E24-FKKTV\Unsere.kleine.Farm.S06E24.Er.liebt.mich.er.liebt.mich.nicht.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e24.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.867 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E24-FKKTV\Unsere.kleine.Farm.S06E24.Er.liebt.mich.er.liebt.mich.nicht.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e24.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E24 - Er liebt mich, er liebt mich nicht (2).mkv 2022-04-13 07:47:53.135 Info App: Beginning Episode Organization 2022-04-13 07:47:53.135 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E17-FKKTV\Unsere.kleine.Farm.S06E17.Freundschaft.ohne.Worte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.135 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E17-FKKTV\Unsere.kleine.Farm.S06E17.Freundschaft.ohne.Worte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E17 - Freundschaft ohne Worte.mkv 2022-04-13 07:47:53.376 Info App: Beginning Episode Organization 2022-04-13 07:47:53.376 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E10-FKKTV\Unsere.kleine.Farm.S07E10.Das.Licht.des.Himmels.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.376 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E10-FKKTV\Unsere.kleine.Farm.S07E10.Das.Licht.des.Himmels.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E10 - Das Licht des Himmels (1).mkv 2022-04-13 07:47:53.646 Info App: Beginning Episode Organization 2022-04-13 07:47:53.646 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E13-FKKTV\Unsere.kleine.Farm.S05E13.Die.Reise.nach.Walnut.Grove.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.647 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E13-FKKTV\Unsere.kleine.Farm.S05E13.Die.Reise.nach.Walnut.Grove.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E13 - Die Reise nach Walnut Grove (2).mkv 2022-04-13 07:47:53.880 Info App: Beginning Episode Organization 2022-04-13 07:47:53.880 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E07-FKKTV\Unsere.kleine.Farm.S02E07.Der.Fruehlingstanz.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.881 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E07-FKKTV\Unsere.kleine.Farm.S02E07.Der.Fruehlingstanz.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E07 - Mit einem Lächeln.mkv 2022-04-13 07:47:54.125 Info App: Beginning Episode Organization 2022-04-13 07:47:54.125 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E22-FKKTV\Unsere.kleine.Farm.S02E22.Zurueck.nach.Wisconsin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.126 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E22-FKKTV\Unsere.kleine.Farm.S02E22.Zurueck.nach.Wisconsin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E22 - Zurück nach Wisconsin.mkv 2022-04-13 07:47:54.398 Info App: Beginning Episode Organization 2022-04-13 07:47:54.398 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E20-FKKTV\Unsere.kleine.Farm.S01E20.Graham.hat.Sorgen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.399 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E20-FKKTV\Unsere.kleine.Farm.S01E20.Graham.hat.Sorgen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E20 - Graham hat Sorgen.mkv 2022-04-13 07:47:54.672 Info App: Beginning Episode Organization 2022-04-13 07:47:54.672 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E07-FKKTV\Unsere.kleine.Farm.S07E07.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.672 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E07-FKKTV\Unsere.kleine.Farm.S07E07.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E07 - Lauras Eifersucht.mkv 2022-04-13 07:47:54.923 Info App: Beginning Episode Organization 2022-04-13 07:47:54.923 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E11-FKKTV\Unsere.kleine.Farm.S06E11.Der.Grossvater.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.923 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E11-FKKTV\Unsere.kleine.Farm.S06E11.Der.Grossvater.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E11 - Der Großvater.mkv 2022-04-13 07:47:55.199 Info App: Beginning Episode Organization 2022-04-13 07:47:55.200 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E22-FKKTV\Unsere.kleine.Farm.S07E22.Die.Waisenkinder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.200 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E22-FKKTV\Unsere.kleine.Farm.S07E22.Die.Waisenkinder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E22 - Die Waisenkinder (2).mkv 2022-04-13 07:47:55.441 Info App: Beginning Episode Organization 2022-04-13 07:47:55.441 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E01-FKKTV\Unsere.kleine.Farm.S02E01.Der.reichste.Mann.in.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.442 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E01-FKKTV\Unsere.kleine.Farm.S02E01.Der.reichste.Mann.in.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E01 - Der reichste Mann in Walnut Grove.mkv 2022-04-13 07:47:55.709 Info App: Beginning Episode Organization 2022-04-13 07:47:55.709 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E09-FKKTV\Unsere.kleine.Farm.S01E09.Die.Aushilfslehrerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.709 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E09-FKKTV\Unsere.kleine.Farm.S01E09.Die.Aushilfslehrerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E09 - Die Aushilfslehrerin.mkv 2022-04-13 07:47:55.972 Info App: Beginning Episode Organization 2022-04-13 07:47:55.972 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E04-FKKTV\Unsere.kleine.Farm.S03E04.Ein.kleines.Maedchen.geht.verloren.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.973 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E04-FKKTV\Unsere.kleine.Farm.S03E04.Ein.kleines.Maedchen.geht.verloren.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E04 - Ein kleines Mädchen geht verloren.mkv 2022-04-13 07:47:56.254 Info App: Beginning Episode Organization 2022-04-13 07:47:56.254 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E01-FKKTV\Unsere.kleine.Farm.S07E01.Laura.und.Almanzo.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:56.254 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E01-FKKTV\Unsere.kleine.Farm.S07E01.Laura.und.Almanzo.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E01 - Laura und Almanzo (1).mkv 2022-04-13 07:47:56.530 Info App: Beginning Episode Organization 2022-04-13 07:47:56.530 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E21-FKKTV\Unsere.kleine.Farm.S05E21.Licht.und.Schatten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:56.531 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E21-FKKTV\Unsere.kleine.Farm.S05E21.Licht.und.Schatten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E21 - Licht und Schatten.mkv 2022-04-13 07:47:56.802 Info App: Beginning Episode Organization 2022-04-13 07:47:56.802 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E16-FKKTV\Unsere.kleine.Farm.S05E16.Der.kleine.Schwindler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:56.802 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E16-FKKTV\Unsere.kleine.Farm.S05E16.Der.kleine.Schwindler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E16 - Der kleine Schwindler.mkv 2022-04-13 07:47:57.081 Info App: Beginning Episode Organization 2022-04-13 07:47:57.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E22-FKKTV\Unsere.kleine.Farm.S04E22.Mary.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.082 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E22-FKKTV\Unsere.kleine.Farm.S04E22.Mary.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E22 - Mary (2).mkv 2022-04-13 07:47:57.345 Info App: Beginning Episode Organization 2022-04-13 07:47:57.345 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E22-FKKTV\Unsere.kleine.Farm.S06E22.Mit.16.faengt.das.Leben.an.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.345 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E22-FKKTV\Unsere.kleine.Farm.S06E22.Mit.16.faengt.das.Leben.an.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E22 - Mit 16 fängt das Leben an.mkv 2022-04-13 07:47:57.593 Info App: Beginning Episode Organization 2022-04-13 07:47:57.593 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E14-FKKTV\Unsere.kleine.Farm.S06E14.Der.Werwolf.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.594 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E14-FKKTV\Unsere.kleine.Farm.S06E14.Der.Werwolf.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E14 - Der Werwolf von Walnut Grove.mkv 2022-04-13 07:47:57.863 Info App: Beginning Episode Organization 2022-04-13 07:47:57.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E19-FKKTV\Unsere.kleine.Farm.S04E19.Glueckliches.Landleben.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E19-FKKTV\Unsere.kleine.Farm.S04E19.Glueckliches.Landleben.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E19 - Glückliches Landleben.mkv 2022-04-13 07:47:58.171 Info App: Beginning Episode Organization 2022-04-13 07:47:58.171 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E10-FKKTV\Unsere.kleine.Farm.S05E10.Vaeter.und.Soehne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.171 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E10-FKKTV\Unsere.kleine.Farm.S05E10.Vaeter.und.Soehne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E10 - Väter und Söhne.mkv 2022-04-13 07:47:58.403 Info App: Beginning Episode Organization 2022-04-13 07:47:58.403 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E04-FKKTV\Unsere.kleine.Farm.S02E04.Walnut.Grove.gegen.Sleepy.Eye.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.403 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E04-FKKTV\Unsere.kleine.Farm.S02E04.Walnut.Grove.gegen.Sleepy.Eye.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E04 - Walnut Grove gegen Sleepy Eye.mkv 2022-04-13 07:47:58.658 Info App: Beginning Episode Organization 2022-04-13 07:47:58.658 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E08-FKKTV\Unsere.kleine.Farm.S06E08.Zeig.mir.den.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.658 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E08-FKKTV\Unsere.kleine.Farm.S06E08.Zeig.mir.den.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E08 - Zeig mir den Weg.mkv 2022-04-13 07:47:58.920 Info App: Beginning Episode Organization 2022-04-13 07:47:58.920 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E04-FKKTV\Unsere.kleine.Farm.S07E04.Der.Football.Trainer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.921 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E04-FKKTV\Unsere.kleine.Farm.S07E04.Der.Football.Trainer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E04 - Der Football-Trainer.mkv 2022-04-13 07:47:59.209 Info App: Beginning Episode Organization 2022-04-13 07:47:59.209 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E09-FKKTV\Unsere.kleine.Farm.S05E09.Die.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:59.209 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E09-FKKTV\Unsere.kleine.Farm.S05E09.Die.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E09 - Die Hochzeit.mkv 2022-04-13 07:47:59.472 Info App: Beginning Episode Organization 2022-04-13 07:47:59.472 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E13E14-FKKTV\Unsere.kleine.Farm.S01E13E14.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e13e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:59.473 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E13E14-FKKTV\Unsere.kleine.Farm.S01E13E14.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e13e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E13-E14 - Lauras Eifersucht (1), Lauras Eifersucht (2).mkv 2022-04-13 07:47:59.729 Info App: Beginning Episode Organization 2022-04-13 07:47:59.729 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E24-FKKTV\Unsere.kleine.Farm.S05E24.Die.Reise.ans.Meer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e24.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:59.729 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E24-FKKTV\Unsere.kleine.Farm.S05E24.Die.Reise.ans.Meer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e24.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E24 - Die Reise ans Meer.mkv 2022-04-13 07:48:00.021 Info App: Beginning Episode Organization 2022-04-13 07:48:00.021 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E02-FKKTV\Unsere.kleine.Farm.S03E02.Mein.Pferd.Bunny.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.022 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E02-FKKTV\Unsere.kleine.Farm.S03E02.Mein.Pferd.Bunny.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E02 - Mein Pferd Bunny.mkv 2022-04-13 07:48:00.277 Info App: Beginning Episode Organization 2022-04-13 07:48:00.277 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E05-FKKTV\Unsere.kleine.Farm.S06E05.Annabelle.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.278 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E05-FKKTV\Unsere.kleine.Farm.S06E05.Annabelle.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E05 - Annabelle.mkv 2022-04-13 07:48:00.526 Info App: Beginning Episode Organization 2022-04-13 07:48:00.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E18-FKKTV\Unsere.kleine.Farm.S03E18.Solomons.Weisheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.527 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E18-FKKTV\Unsere.kleine.Farm.S03E18.Solomons.Weisheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E18 - Solomons Weisheit.mkv 2022-04-13 07:48:00.776 Info App: Beginning Episode Organization 2022-04-13 07:48:00.776 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E19-FKKTV\Unsere.kleine.Farm.S02E19.Ein.Geschenk.fuer.Mutter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.777 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E19-FKKTV\Unsere.kleine.Farm.S02E19.Ein.Geschenk.fuer.Mutter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E19 - Ein Geschenk für Mutter.mkv 2022-04-13 07:48:01.021 Info App: Beginning Episode Organization 2022-04-13 07:48:01.021 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E12-FKKTV\Unsere.kleine.Farm.S06E12.Falsch.verbunden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.021 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E12-FKKTV\Unsere.kleine.Farm.S06E12.Falsch.verbunden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E12 - Falsch verbunden.mkv 2022-04-13 07:48:01.270 Info App: Beginning Episode Organization 2022-04-13 07:48:01.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E02-FKKTV\Unsere.kleine.Farm.S02E02.Brillenschlange.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E02-FKKTV\Unsere.kleine.Farm.S02E02.Brillenschlange.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E02 - Brillenschlange.mkv 2022-04-13 07:48:01.538 Info App: Beginning Episode Organization 2022-04-13 07:48:01.538 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E15-FKKTV\Unsere.kleine.Farm.S03E15.Indianerfreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.540 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E15-FKKTV\Unsere.kleine.Farm.S03E15.Indianerfreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E15 - Indianerfreunde.mkv 2022-04-13 07:48:01.771 Info App: Beginning Episode Organization 2022-04-13 07:48:01.771 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E19-FKKTV\Unsere.kleine.Farm.S07E19.Adam.in.Not.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.771 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E19-FKKTV\Unsere.kleine.Farm.S07E19.Adam.in.Not.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E19 - Adam in Not.mkv 2022-04-13 07:48:02.006 Info App: Beginning Episode Organization 2022-04-13 07:48:02.006 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E02-FKKTV\Unsere.kleine.Farm.S07E02.Laura.und.Almanzo.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.007 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E02-FKKTV\Unsere.kleine.Farm.S07E02.Laura.und.Almanzo.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E02 - Laura und Almanzo (2).mkv 2022-04-13 07:48:02.272 Info App: Beginning Episode Organization 2022-04-13 07:48:02.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E08-FKKTV\Unsere.kleine.Farm.S04E08.Die.Kopfgeldjaeger.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E08-FKKTV\Unsere.kleine.Farm.S04E08.Die.Kopfgeldjaeger.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E08 - Die Kopfgeldjäger.mkv 2022-04-13 07:48:02.538 Info App: Beginning Episode Organization 2022-04-13 07:48:02.538 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E22-FKKTV\Unsere.kleine.Farm.S05E22.Ein.kleines.bisschen.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.539 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E22-FKKTV\Unsere.kleine.Farm.S05E22.Ein.kleines.bisschen.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E22 - Ein kleines bißchen Liebe.mkv 2022-04-13 07:48:02.804 Info App: Beginning Episode Organization 2022-04-13 07:48:02.804 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E03-FKKTV\Unsere.kleine.Farm.S06E03.Der.Stammbaum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.805 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E03-FKKTV\Unsere.kleine.Farm.S06E03.Der.Stammbaum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E03 - Der Stammbaum.mkv 2022-04-13 07:48:03.080 Info App: Beginning Episode Organization 2022-04-13 07:48:03.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E07-FKKTV\Unsere.kleine.Farm.S01E07.Meine.Party.deine.Party.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E07-FKKTV\Unsere.kleine.Farm.S01E07.Meine.Party.deine.Party.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E07 - Meine Party - deine Party.mkv 2022-04-13 07:48:03.333 Info App: Beginning Episode Organization 2022-04-13 07:48:03.333 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E05-FKKTV\Unsere.kleine.Farm.S04E05.Ein.Welpe.fuer.Andy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.333 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E05-FKKTV\Unsere.kleine.Farm.S04E05.Ein.Welpe.fuer.Andy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E05 - Ein Welpe für Andy.mkv 2022-04-13 07:48:03.577 Info App: Beginning Episode Organization 2022-04-13 07:48:03.577 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E18-FKKTV\Unsere.kleine.Farm.S01E18.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.577 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E18-FKKTV\Unsere.kleine.Farm.S01E18.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E18 - Die Seuche.mkv 2022-04-13 07:48:03.850 Info App: Beginning Episode Organization 2022-04-13 07:48:03.850 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E01-FKKTV\Unsere.kleine.Farm.S01E01.Das.neue.Land.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.850 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E01-FKKTV\Unsere.kleine.Farm.S01E01.Das.neue.Land.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E01 - Das neue Land.mkv 2022-04-13 07:48:04.118 Info App: Beginning Episode Organization 2022-04-13 07:48:04.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E08-FKKTV\Unsere.kleine.Farm.S08E08.Chicago.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E08-FKKTV\Unsere.kleine.Farm.S08E08.Chicago.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E08 - Chicago.mkv 2022-04-13 07:48:04.349 Info App: Beginning Episode Organization 2022-04-13 07:48:04.349 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E13-FKKTV\Unsere.kleine.Farm.S03E13.Die.Epidemie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.349 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E13-FKKTV\Unsere.kleine.Farm.S03E13.Die.Epidemie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E13 - Die Epidemie.mkv 2022-04-13 07:48:04.598 Info App: Beginning Episode Organization 2022-04-13 07:48:04.598 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E17-FKKTV\Unsere.kleine.Farm.S04E17.Zwei.Muetter.fuer.ein.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.598 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E17-FKKTV\Unsere.kleine.Farm.S04E17.Zwei.Muetter.fuer.ein.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E17 - Zwei Mütter für ein Baby.mkv 2022-04-13 07:48:04.845 Info App: Beginning Episode Organization 2022-04-13 07:48:04.845 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E15-FKKTV\Unsere.kleine.Farm.S01E15.Tausche.Pony.gegen.Ofen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.846 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E15-FKKTV\Unsere.kleine.Farm.S01E15.Tausche.Pony.gegen.Ofen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E15 - Tausche Pony gegen Ofen.mkv 2022-04-13 07:48:05.078 Info App: Beginning Episode Organization 2022-04-13 07:48:05.078 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E19-FKKTV\Unsere.kleine.Farm.S05E19.Das.Seeungeheuer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.079 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E19-FKKTV\Unsere.kleine.Farm.S05E19.Das.Seeungeheuer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E19 - Das Seeungeheuer.mkv 2022-04-13 07:48:05.337 Info App: Beginning Episode Organization 2022-04-13 07:48:05.337 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E06-FKKTV\Unsere.kleine.Farm.S06E06.Kirchliche.Trauung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.337 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E06-FKKTV\Unsere.kleine.Farm.S06E06.Kirchliche.Trauung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E06 - Kirchliche Trauung.mkv 2022-04-13 07:48:05.585 Info App: Beginning Episode Organization 2022-04-13 07:48:05.585 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E07-FKKTV\Unsere.kleine.Farm.S05E07.Mein.Kaelbchen.Fagin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.586 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E07-FKKTV\Unsere.kleine.Farm.S05E07.Mein.Kaelbchen.Fagin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E07 - Mein Kälbchen Fagin.mkv 2022-04-13 07:48:05.834 Info App: Beginning Episode Organization 2022-04-13 07:48:05.834 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E11-FKKTV\Unsere.kleine.Farm.S04E11.Das.Volksfest.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.835 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E11-FKKTV\Unsere.kleine.Farm.S04E11.Das.Volksfest.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E11 - Das Volksfest.mkv 2022-04-13 07:48:06.109 Info App: Beginning Episode Organization 2022-04-13 07:48:06.109 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E05-FKKTV\Unsere.kleine.Farm.S08E05.Die.Bildungsreise.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.110 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E05-FKKTV\Unsere.kleine.Farm.S08E05.Die.Bildungsreise.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E05 - Die Bildungsreise.mkv 2022-04-13 07:48:06.362 Info App: Beginning Episode Organization 2022-04-13 07:48:06.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E03-FKKTV\Unsere.kleine.Farm.S04E03.Der.Badeunfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.363 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E03-FKKTV\Unsere.kleine.Farm.S04E03.Der.Badeunfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E03 - Der Badeunfall.mkv 2022-04-13 07:48:06.613 Info App: Beginning Episode Organization 2022-04-13 07:48:06.613 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E04-FKKTV\Unsere.kleine.Farm.S01E04.Der.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.613 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E04-FKKTV\Unsere.kleine.Farm.S01E04.Der.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E04 - Der Freund.mkv 2022-04-13 07:48:06.859 Info App: Beginning Episode Organization 2022-04-13 07:48:06.859 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E01-FKKTV\Unsere.kleine.Farm.S05E01.Die.Stadt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.860 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E01-FKKTV\Unsere.kleine.Farm.S05E01.Die.Stadt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E01 - Die Stadt (1).mkv 2022-04-13 07:48:07.139 Info App: Beginning Episode Organization 2022-04-13 07:48:07.139 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E16-FKKTV\Unsere.kleine.Farm.S03E16.Die.Bedrohung.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.139 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E16-FKKTV\Unsere.kleine.Farm.S03E16.Die.Bedrohung.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E16 - Die Bedrohung (1).mkv 2022-04-13 07:48:07.400 Info App: Beginning Episode Organization 2022-04-13 07:48:07.401 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E17-FKKTV\Unsere.kleine.Farm.S02E17.Der.Stoerenfried.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.401 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E17-FKKTV\Unsere.kleine.Farm.S02E17.Der.Stoerenfried.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E17 - Der Störenfried.mkv 2022-04-13 07:48:07.636 Info App: Beginning Episode Organization 2022-04-13 07:48:07.636 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E10-FKKTV\Unsere.kleine.Farm.S03E10.Verletzt.in.der.Wildnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.637 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E10-FKKTV\Unsere.kleine.Farm.S03E10.Verletzt.in.der.Wildnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E10 - Verletzt in der Wildnis.mkv 2022-04-13 07:48:07.901 Info App: Beginning Episode Organization 2022-04-13 07:48:07.901 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E14-FKKTV\Unsere.kleine.Farm.S04E14.Rivalinnen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.901 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E14-FKKTV\Unsere.kleine.Farm.S04E14.Rivalinnen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E14 - Rivalinnen.mkv 2022-04-13 07:48:08.147 Info App: Beginning Episode Organization 2022-04-13 07:48:08.147 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E11-FKKTV\Unsere.kleine.Farm.S08E11.Eine.unvergessliche.Weihnacht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.147 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E11-FKKTV\Unsere.kleine.Farm.S08E11.Eine.unvergessliche.Weihnacht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E11 - Eine unvergessliche Weihnacht.mkv 2022-04-13 07:48:08.402 Info App: Beginning Episode Organization 2022-04-13 07:48:08.402 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E11-FKKTV\Unsere.kleine.Farm.S02E11.Die.Wundermedizin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.403 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E11-FKKTV\Unsere.kleine.Farm.S02E11.Die.Wundermedizin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E11 - Die Wundermedizin.mkv 2022-04-13 07:48:08.670 Info App: Beginning Episode Organization 2022-04-13 07:48:08.670 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E17-FKKTV\Unsere.kleine.Farm.S07E17.Sylvia.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.670 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E17-FKKTV\Unsere.kleine.Farm.S07E17.Sylvia.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E17 - Sylvia (1).mkv 2022-04-13 07:48:08.947 Info App: Beginning Episode Organization 2022-04-13 07:48:08.947 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E06-FKKTV\Unsere.kleine.Farm.S04E06.Der.Dieb.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.948 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E06-FKKTV\Unsere.kleine.Farm.S04E06.Der.Dieb.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E06 - Der Dieb von Walnut Grove.mkv 2022-04-13 07:48:09.221 Info App: Beginning Episode Organization 2022-04-13 07:48:09.221 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E04-FKKTV\Unsere.kleine.Farm.S05E04.Der.dicke.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:09.224 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E04-FKKTV\Unsere.kleine.Farm.S05E04.Der.dicke.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E04 - Der dicke Mann.mkv 2022-04-13 07:48:09.503 Info App: Beginning Episode Organization 2022-04-13 07:48:09.503 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E03-FKKTV\Unsere.kleine.Farm.S08E03.Kein.Platz.fuer.James.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:09.504 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E03-FKKTV\Unsere.kleine.Farm.S08E03.Kein.Platz.fuer.James.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E03 - Kein Platz für James.mkv 2022-04-13 07:48:09.676 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:48:09.679 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:48:09.695 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:48:09.698 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:48:09.780 Info App: Beginning Episode Organization 2022-04-13 07:48:09.780 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E02-FKKTV\Unsere.kleine.Farm.S01E02.Der.erste.Schultag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:09.780 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E02-FKKTV\Unsere.kleine.Farm.S01E02.Der.erste.Schultag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E02 - Der erste Schultag.mkv 2022-04-13 07:48:10.052 Info App: Beginning Episode Organization 2022-04-13 07:48:10.052 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E11-FKKTV\Unsere.kleine.Farm.S07E11.Das.Licht.des.Himmels.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.053 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E11-FKKTV\Unsere.kleine.Farm.S07E11.Das.Licht.des.Himmels.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E11 - Das Licht des Himmels (2).mkv 2022-04-13 07:48:10.305 Info App: Beginning Episode Organization 2022-04-13 07:48:10.305 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E08-FKKTV\Unsere.kleine.Farm.S03E08.Fred.der.Ziegenbock.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.305 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E08-FKKTV\Unsere.kleine.Farm.S03E08.Fred.der.Ziegenbock.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E08 - Fred, der Ziegenbock.mkv 2022-04-13 07:48:10.547 Info App: Beginning Episode Organization 2022-04-13 07:48:10.547 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E21-FKKTV\Unsere.kleine.Farm.S01E21.Goldene.Saat.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.548 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E21-FKKTV\Unsere.kleine.Farm.S01E21.Goldene.Saat.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E21 - Goldene Saat.mkv 2022-04-13 07:48:10.769 Info App: Beginning Episode Organization 2022-04-13 07:48:10.769 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E16-FKKTV\Unsere.kleine.Farm.S01E16.Ehekrach.bei.Oleson.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.770 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E16-FKKTV\Unsere.kleine.Farm.S01E16.Ehekrach.bei.Oleson.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E16 - Ehekrach bei Oleson.mkv 2022-04-13 07:48:11.013 Info App: Beginning Episode Organization 2022-04-13 07:48:11.013 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E14-FKKTV\Unsere.kleine.Farm.S02E14.Nur.Zweite.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.013 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E14-FKKTV\Unsere.kleine.Farm.S02E14.Nur.Zweite.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E14 - Nur Zweite.mkv 2022-04-13 07:48:11.261 Info App: Beginning Episode Organization 2022-04-13 07:48:11.261 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E12-FKKTV\Unsere.kleine.Farm.S04E12.Ein.Hoch.auf.die.Braeute.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.263 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E12-FKKTV\Unsere.kleine.Farm.S04E12.Ein.Hoch.auf.die.Braeute.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E12 - Ein Hoch auf die Bräute.mkv 2022-04-13 07:48:11.480 Info App: Beginning Episode Organization 2022-04-13 07:48:11.480 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E21E22-FKKTV\Unsere.kleine.Farm.S03E21E22.Goldsucher.unterwegs.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e21e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.481 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E21E22-FKKTV\Unsere.kleine.Farm.S03E21E22.Goldsucher.unterwegs.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e21e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E21-E22 - Goldsucher unterwegs (1), Goldsucher unterwegs (2).mkv 2022-04-13 07:48:11.740 Info App: Beginning Episode Organization 2022-04-13 07:48:11.740 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E10-FKKTV\Unsere.kleine.Farm.S01E10.Der.Waschbaer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.741 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E10-FKKTV\Unsere.kleine.Farm.S01E10.Der.Waschbaer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E10 - Der Waschbär.mkv 2022-04-13 07:48:12.011 Info App: Beginning Episode Organization 2022-04-13 07:48:12.011 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E05-FKKTV\Unsere.kleine.Farm.S03E05.Geisterstunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.011 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E05-FKKTV\Unsere.kleine.Farm.S03E05.Geisterstunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E05 - Geisterstunde.mkv 2022-04-13 07:48:12.288 Info App: Beginning Episode Organization 2022-04-13 07:48:12.288 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E18-FKKTV\Unsere.kleine.Farm.S06E18.Feuersbrunst.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.288 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E18-FKKTV\Unsere.kleine.Farm.S06E18.Feuersbrunst.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E18 - Die Feuersbrunst (1).mkv 2022-04-13 07:48:12.578 Info App: Beginning Episode Organization 2022-04-13 07:48:12.578 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E06-FKKTV\Unsere.kleine.Farm.S08E06.Der.grosse.Gambini.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.578 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E06-FKKTV\Unsere.kleine.Farm.S08E06.Der.grosse.Gambini.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E06 - Der große Gambini.mkv 2022-04-13 07:48:12.870 Info App: Beginning Episode Organization 2022-04-13 07:48:12.870 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E08-FKKTV\Unsere.kleine.Farm.S02E08.Mit.einem.Laecheln.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.871 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E08-FKKTV\Unsere.kleine.Farm.S02E08.Mit.einem.Laecheln.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E08 - Eine neue Familie.mkv 2022-04-13 07:48:13.157 Info App: Beginning Episode Organization 2022-04-13 07:48:13.157 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E14-FKKTV\Unsere.kleine.Farm.S07E14.Die.Neffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.158 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E14-FKKTV\Unsere.kleine.Farm.S07E14.Die.Neffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E14 - Die Neffen.mkv 2022-04-13 07:48:13.384 Info App: Beginning Episode Organization 2022-04-13 07:48:13.384 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E02-FKKTV\Unsere.kleine.Farm.S05E02.Die.Stadt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.384 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E02-FKKTV\Unsere.kleine.Farm.S05E02.Die.Stadt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E02 - Die Stadt (2).mkv 2022-04-13 07:48:13.631 Info App: Beginning Episode Organization 2022-04-13 07:48:13.631 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E17-FKKTV\Unsere.kleine.Farm.S05E17.Tobys.Romanze.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.632 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E17-FKKTV\Unsere.kleine.Farm.S05E17.Tobys.Romanze.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E17 - Tobys Romanze.mkv 2022-04-13 07:48:13.863 Info App: Beginning Episode Organization 2022-04-13 07:48:13.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E08-FKKTV\Unsere.kleine.Farm.S07E08.Brieffreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.864 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E08-FKKTV\Unsere.kleine.Farm.S07E08.Brieffreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E08 - Brieffreunde.mkv 2022-04-13 07:48:14.139 Info App: Beginning Episode Organization 2022-04-13 07:48:14.139 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E24-FKKTV\Unsere.kleine.Farm.S01E24.Gruendungstag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e24.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.140 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E24-FKKTV\Unsere.kleine.Farm.S01E24.Gruendungstag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e24.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E24 - Gründungstag.mkv 2022-04-13 07:48:14.390 Info App: Beginning Episode Organization 2022-04-13 07:48:14.390 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E23-FKKTV\Unsere.kleine.Farm.S06E23.Er.liebt.mich.er.liebt.mich.nicht.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e23.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.391 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E23-FKKTV\Unsere.kleine.Farm.S06E23.Er.liebt.mich.er.liebt.mich.nicht.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e23.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E23 - Er liebt mich, er liebt mich nicht (1).mkv 2022-04-13 07:48:14.645 Info App: Beginning Episode Organization 2022-04-13 07:48:14.645 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E15-FKKTV\Unsere.kleine.Farm.S06E15.Das.verdorbene.Klassentreffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.645 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E15-FKKTV\Unsere.kleine.Farm.S06E15.Das.verdorbene.Klassentreffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E15 - Das verdorbene Klassentreffen.mkv 2022-04-13 07:48:14.929 Info App: Beginning Episode Organization 2022-04-13 07:48:14.929 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E11-FKKTV\Unsere.kleine.Farm.S05E11.Schummeleien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E11-FKKTV\Unsere.kleine.Farm.S05E11.Schummeleien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E11 - Schummeleien.mkv 2022-04-13 07:48:15.194 Info App: Beginning Episode Organization 2022-04-13 07:48:15.194 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E05-FKKTV\Unsere.kleine.Farm.S02E05.Das.verwunschene.Haus.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.194 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E05-FKKTV\Unsere.kleine.Farm.S02E05.Das.verwunschene.Haus.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E05 - Das verwunschene Haus.mkv 2022-04-13 07:48:15.439 Info App: Beginning Episode Organization 2022-04-13 07:48:15.439 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E09-FKKTV\Unsere.kleine.Farm.S06E09.Milos.letzter.Kampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.439 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E09-FKKTV\Unsere.kleine.Farm.S06E09.Milos.letzter.Kampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E09 - Milos letzter Kampf.mkv 2022-04-13 07:48:15.705 Info App: Beginning Episode Organization 2022-04-13 07:48:15.705 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E20-FKKTV\Unsere.kleine.Farm.S02E20.Die.Jahrhundertfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.706 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E20-FKKTV\Unsere.kleine.Farm.S02E20.Die.Jahrhundertfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E20 - Die Jahrhundertfeier.mkv 2022-04-13 07:48:15.930 Info App: Beginning Episode Organization 2022-04-13 07:48:15.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E05-FKKTV\Unsere.kleine.Farm.S07E05.Der.stumme.Schrei.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E05-FKKTV\Unsere.kleine.Farm.S07E05.Der.stumme.Schrei.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E05 - Der stumme Schrei.mkv 2022-04-13 07:48:16.189 Info App: Beginning Episode Organization 2022-04-13 07:48:16.189 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E12-FKKTV\Unsere.kleine.Farm.S08E12.Ein.echter.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.190 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E12-FKKTV\Unsere.kleine.Farm.S08E12.Ein.echter.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E12 - Ein echter Freund.mkv 2022-04-13 07:48:16.431 Info App: Beginning Episode Organization 2022-04-13 07:48:16.431 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E20-FKKTV\Unsere.kleine.Farm.S07E20.Die.zweite.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.432 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E20-FKKTV\Unsere.kleine.Farm.S07E20.Die.zweite.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E20 - Die zweite Hochzeit.mkv 2022-04-13 07:48:16.684 Info App: Beginning Episode Organization 2022-04-13 07:48:16.684 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E12-FKKTV\Unsere.kleine.Farm.S02E12.Das.Jagdgewehr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.684 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E12-FKKTV\Unsere.kleine.Farm.S02E12.Das.Jagdgewehr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E12 - Das Jagdgewehr.mkv 2022-04-13 07:48:16.922 Info App: Beginning Episode Organization 2022-04-13 07:48:16.922 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E03-FKKTV\Unsere.kleine.Farm.S03E03.Das.Rennen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.923 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E03-FKKTV\Unsere.kleine.Farm.S03E03.Das.Rennen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E03 - Das Rennen.mkv 2022-04-13 07:48:17.205 Info App: Beginning Episode Organization 2022-04-13 07:48:17.205 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E19-FKKTV\Unsere.kleine.Farm.S03E19.Die.Spieluhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.206 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E19-FKKTV\Unsere.kleine.Farm.S03E19.Die.Spieluhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E19 - Die Spieluhr.mkv 2022-04-13 07:48:17.478 Info App: Beginning Episode Organization 2022-04-13 07:48:17.478 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E12-FKKTV\Unsere.kleine.Farm.S07E12.Aufstand.der.Frauen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.478 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E12-FKKTV\Unsere.kleine.Farm.S07E12.Aufstand.der.Frauen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E12 - Aufstand der Frauen.mkv 2022-04-13 07:48:17.755 Info App: Beginning Episode Organization 2022-04-13 07:48:17.755 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E14-FKKTV\Unsere.kleine.Farm.S05E14.Die.Maerchenschwester.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.756 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E14-FKKTV\Unsere.kleine.Farm.S05E14.Die.Maerchenschwester.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E14 - Die Märchenschwester.mkv 2022-04-13 07:48:17.983 Info App: Beginning Episode Organization 2022-04-13 07:48:17.983 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E22-FKKTV\Unsere.kleine.Farm.S01E22.Schneesturm.im.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.984 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E22-FKKTV\Unsere.kleine.Farm.S01E22.Schneesturm.im.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E22 - Schneesturm im Frühling.mkv 2022-04-13 07:48:18.229 Info App: Beginning Episode Organization 2022-04-13 07:48:18.229 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E20-FKKTV\Unsere.kleine.Farm.S04E20.Das.schoenste.Geschenk.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:18.229 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E20-FKKTV\Unsere.kleine.Farm.S04E20.Das.schoenste.Geschenk.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E20 - Das schönste Geschenk.mkv 2022-04-13 07:48:18.491 Info App: Beginning Episode Organization 2022-04-13 07:48:18.491 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E20-FKKTV\Unsere.kleine.Farm.S06E20.Almanzos.Bruder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:18.491 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E20-FKKTV\Unsere.kleine.Farm.S06E20.Almanzos.Bruder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E20 - Almanzos Bruder.mkv 2022-04-13 07:48:18.763 Info App: Beginning Episode Organization 2022-04-13 07:48:18.763 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E13-FKKTV\Unsere.kleine.Farm.S06E13.Die.gestohlene.Uhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:18.764 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E13-FKKTV\Unsere.kleine.Farm.S06E13.Die.gestohlene.Uhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E13 - Die gestohlene Uhr.mkv 2022-04-13 07:48:19.015 Info App: Beginning Episode Organization 2022-04-13 07:48:19.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E03-FKKTV\Unsere.kleine.Farm.S02E03.Der.Geizhals.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E03-FKKTV\Unsere.kleine.Farm.S02E03.Der.Geizhals.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E03 - Der Geizhals.mkv 2022-04-13 07:48:19.265 Info App: Beginning Episode Organization 2022-04-13 07:48:19.265 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E06-FKKTV\Unsere.kleine.Farm.S03E06.Grossvater.kehrt.heim.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.265 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E06-FKKTV\Unsere.kleine.Farm.S03E06.Grossvater.kehrt.heim.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E06 - Großvater kehrt heim (1).mkv 2022-04-13 07:48:19.536 Info App: Beginning Episode Organization 2022-04-13 07:48:19.536 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E03-FKKTV\Unsere.kleine.Farm.S07E03.Hilfssheriff.wider.Willen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.537 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E03-FKKTV\Unsere.kleine.Farm.S07E03.Hilfssheriff.wider.Willen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E03 - Hilfssheriff wider Willen.mkv 2022-04-13 07:48:19.789 Info App: Beginning Episode Organization 2022-04-13 07:48:19.789 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E09-FKKTV\Unsere.kleine.Farm.S04E09.Ein.hoher.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.790 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E09-FKKTV\Unsere.kleine.Farm.S04E09.Ein.hoher.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E09 - Ein hoher Preis.mkv 2022-04-13 07:48:20.036 Info App: Beginning Episode Organization 2022-04-13 07:48:20.036 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E23-FKKTV\Unsere.kleine.Farm.S05E23.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e23.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.037 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E23-FKKTV\Unsere.kleine.Farm.S05E23.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e23.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E23 - Die Seuche.mkv 2022-04-13 07:48:20.270 Info App: Beginning Episode Organization 2022-04-13 07:48:20.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E16-FKKTV\Unsere.kleine.Farm.S06E16.Der.Ueberfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E16-FKKTV\Unsere.kleine.Farm.S06E16.Der.Ueberfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E16 - Der Überfall.mkv 2022-04-13 07:48:20.502 Info App: Beginning Episode Organization 2022-04-13 07:48:20.502 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E19-FKKTV\Unsere.kleine.Farm.S01E19.Der.Gaukler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.503 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E19-FKKTV\Unsere.kleine.Farm.S01E19.Der.Gaukler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E19 - Der Gaukler.mkv 2022-04-13 07:48:20.790 Info App: Beginning Episode Organization 2022-04-13 07:48:20.790 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E12-FKKTV\Unsere.kleine.Farm.S05E12.Die.Reise.nach.Walnut.Grove.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.791 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E12-FKKTV\Unsere.kleine.Farm.S05E12.Die.Reise.nach.Walnut.Grove.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E12 - Die Reise nach Walnut Grove (1).mkv 2022-04-13 07:48:21.035 Info App: Beginning Episode Organization 2022-04-13 07:48:21.035 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E06-FKKTV\Unsere.kleine.Farm.S02E06.Der.Ausflug.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.035 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E06-FKKTV\Unsere.kleine.Farm.S02E06.Der.Ausflug.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E06 - Der Frühlingstanz.mkv 2022-04-13 07:48:21.315 Info App: Beginning Episode Organization 2022-04-13 07:48:21.315 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E06-FKKTV\Unsere.kleine.Farm.S07E06.Die.blinde.Malerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.318 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E06-FKKTV\Unsere.kleine.Farm.S07E06.Die.blinde.Malerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E06 - Die blinde Malerin.mkv 2022-04-13 07:48:21.557 Info App: Beginning Episode Organization 2022-04-13 07:48:21.557 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E10-FKKTV\Unsere.kleine.Farm.S06E10.Der.Wunderheiler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.558 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E10-FKKTV\Unsere.kleine.Farm.S06E10.Der.Wunderheiler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E10 - Der Wunderheiler.mkv 2022-04-13 07:48:21.844 Info App: Beginning Episode Organization 2022-04-13 07:48:21.844 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E09-FKKTV\Unsere.kleine.Farm.S08E09.Aus.Liebe.zu.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.844 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E09-FKKTV\Unsere.kleine.Farm.S08E09.Aus.Liebe.zu.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E09 - Aus Liebe zu Nancy.mkv 2022-04-13 07:48:22.083 Info App: Beginning Episode Organization 2022-04-13 07:48:22.083 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E08-FKKTV\Unsere.kleine.Farm.S01E08.Mutter.macht.Ferien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.084 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E08-FKKTV\Unsere.kleine.Farm.S01E08.Mutter.macht.Ferien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E08 - Mutter macht Ferien.mkv 2022-04-13 07:48:22.351 Info App: Beginning Episode Organization 2022-04-13 07:48:22.351 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E07-FKKTV\Unsere.kleine.Farm.S06E07.Alberts.Indianertraum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.352 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E07-FKKTV\Unsere.kleine.Farm.S06E07.Alberts.Indianertraum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E07 - Alberts Indianertraum.mkv 2022-04-13 07:48:22.614 Info App: Beginning Episode Organization 2022-04-13 07:48:22.614 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E20-FKKTV\Unsere.kleine.Farm.S05E20.Spaetes.Gestaendnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.615 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E20-FKKTV\Unsere.kleine.Farm.S05E20.Spaetes.Gestaendnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E20 - Spätes Geständnis.mkv 2022-04-13 07:48:22.866 Info App: Beginning Episode Organization 2022-04-13 07:48:22.866 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E01-FKKTV\Unsere.kleine.Farm.S06E01.Schulanfang.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.867 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E01-FKKTV\Unsere.kleine.Farm.S06E01.Schulanfang.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E01 - Schulanfang (1).mkv 2022-04-13 07:48:23.101 Info App: Beginning Episode Organization 2022-04-13 07:48:23.101 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E05-FKKTV\Unsere.kleine.Farm.S01E05.Erste.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.102 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E05-FKKTV\Unsere.kleine.Farm.S01E05.Erste.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E05 - Erste Liebe.mkv 2022-04-13 07:48:23.388 Info App: Beginning Episode Organization 2022-04-13 07:48:23.388 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E18-FKKTV\Unsere.kleine.Farm.S04E18.Die.Erbschaft.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.389 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E18-FKKTV\Unsere.kleine.Farm.S04E18.Die.Erbschaft.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E18 - Die Erbschaft.mkv 2022-04-13 07:48:23.608 Info App: Beginning Episode Organization 2022-04-13 07:48:23.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E17-FKKTV\Unsere.kleine.Farm.S03E17.Die.Bedrohung.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E17-FKKTV\Unsere.kleine.Farm.S03E17.Die.Bedrohung.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E17 - Die Bedrohung (2).mkv 2022-04-13 07:48:23.863 Info App: Beginning Episode Organization 2022-04-13 07:48:23.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E08-FKKTV\Unsere.kleine.Farm.S05E08.Harriets.Klatschzeitung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E08-FKKTV\Unsere.kleine.Farm.S05E08.Harriets.Klatschzeitung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E08 - Harriets Klatschzeitung.mkv 2022-04-13 07:48:24.103 Info App: Beginning Episode Organization 2022-04-13 07:48:24.103 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E11-FKKTV\Unsere.kleine.Farm.S03E11.Wo.sind.die.Kinder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.104 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E11-FKKTV\Unsere.kleine.Farm.S03E11.Wo.sind.die.Kinder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E11 - Wo sind die Kinder.mkv 2022-04-13 07:48:24.347 Info App: Beginning Episode Organization 2022-04-13 07:48:24.347 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E15-FKKTV\Unsere.kleine.Farm.S04E15.Mary.geht.ihren.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.348 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E15-FKKTV\Unsere.kleine.Farm.S04E15.Mary.geht.ihren.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E15 - Mary geht ihren Weg.mkv 2022-04-13 07:48:24.608 Info App: Beginning Episode Organization 2022-04-13 07:48:24.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E04-FKKTV\Unsere.kleine.Farm.S06E04.Das.dritte.Wunder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E04-FKKTV\Unsere.kleine.Farm.S06E04.Das.dritte.Wunder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E04 - Das dritte Wunder.mkv 2022-04-13 07:48:24.855 Info App: Beginning Episode Organization 2022-04-13 07:48:24.855 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E07-FKKTV\Unsere.kleine.Farm.S04E07.Arzt.oder.Farmer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.855 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E07-FKKTV\Unsere.kleine.Farm.S04E07.Arzt.oder.Farmer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E07 - Arzt oder Farmer.mkv 2022-04-13 07:48:25.119 Info App: Beginning Episode Organization 2022-04-13 07:48:25.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E05-FKKTV\Unsere.kleine.Farm.S05E05.Heimweh.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.120 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E05-FKKTV\Unsere.kleine.Farm.S05E05.Heimweh.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E05 - Heimweh (1).mkv 2022-04-13 07:48:25.356 Info App: Beginning Episode Organization 2022-04-13 07:48:25.356 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E03-FKKTV\Unsere.kleine.Farm.S01E03.Weiter.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.357 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E03-FKKTV\Unsere.kleine.Farm.S01E03.Weiter.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E03 - Weiter Weg.mkv 2022-04-13 07:48:25.618 Info App: Beginning Episode Organization 2022-04-13 07:48:25.618 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E18-FKKTV\Unsere.kleine.Farm.S02E18.Der.lange.Weg.zurueck.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.619 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E18-FKKTV\Unsere.kleine.Farm.S02E18.Der.lange.Weg.zurueck.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E18 - Der lange Weg zurück.mkv 2022-04-13 07:48:25.875 Info App: Beginning Episode Organization 2022-04-13 07:48:25.875 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E01-FKKTV\Unsere.kleine.Farm.S04E01.Neue.Gesichter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.876 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E01-FKKTV\Unsere.kleine.Farm.S04E01.Neue.Gesichter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E01 - Neue Gesichter.mkv 2022-04-13 07:48:26.120 Info App: Beginning Episode Organization 2022-04-13 07:48:26.120 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E09-FKKTV\Unsere.kleine.Farm.S03E09.Die.ungleichen.Brueder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.121 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E09-FKKTV\Unsere.kleine.Farm.S03E09.Die.ungleichen.Brueder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E09 - Die ungleichen Brüder.mkv 2022-04-13 07:48:26.391 Info App: Beginning Episode Organization 2022-04-13 07:48:26.391 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E14-FKKTV\Unsere.kleine.Farm.S03E14.Die.Theaterauffuehrung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.392 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E14-FKKTV\Unsere.kleine.Farm.S03E14.Die.Theaterauffuehrung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E14 - Die Theateraufführung.mkv 2022-04-13 07:48:26.642 Info App: Beginning Episode Organization 2022-04-13 07:48:26.642 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E17-FKKTV\Unsere.kleine.Farm.S01E17.Spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.643 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E17-FKKTV\Unsere.kleine.Farm.S01E17.Spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E17 - Späte Liebe.mkv 2022-04-13 07:48:26.951 Info App: Beginning Episode Organization 2022-04-13 07:48:26.951 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E18-FKKTV\Unsere.kleine.Farm.S07E18.Sylvia.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.951 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E18-FKKTV\Unsere.kleine.Farm.S07E18.Sylvia.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E18 - Sylvia (2).mkv 2022-04-13 07:48:27.222 Info App: Beginning Episode Organization 2022-04-13 07:48:27.222 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E15-FKKTV\Unsere.kleine.Farm.S08E15.Der.reiche.Onkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:27.222 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E15-FKKTV\Unsere.kleine.Farm.S08E15.Der.reiche.Onkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E15 - Der reiche Onkel.mkv 2022-04-13 07:48:27.471 Info App: Beginning Episode Organization 2022-04-13 07:48:27.471 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E05-FKKTV\Unsere.kleine.Farm.S09E05.Ein.kleiner.grosser.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:27.472 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E05-FKKTV\Unsere.kleine.Farm.S09E05.Ein.kleiner.grosser.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E05 - Ein kleiner, großer Mann.mkv 2022-04-13 07:48:28.207 Info App: Beginning Episode Organization 2022-04-13 07:48:28.207 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E03-FKKTV\Unsere.kleine.Farm.S09E03.Buergermeisterwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:28.207 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E03-FKKTV\Unsere.kleine.Farm.S09E03.Buergermeisterwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E03 - Bürgermeisterwahl.mkv 2022-04-13 07:48:28.485 Info App: Beginning Episode Organization 2022-04-13 07:48:28.485 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E16-FKKTV\Unsere.kleine.Farm.S08E16.Ein.zweiter.Versuch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:28.486 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E16-FKKTV\Unsere.kleine.Farm.S08E16.Ein.zweiter.Versuch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E16 - Ein zweiter Versuch.mkv 2022-04-13 07:48:28.761 Info App: Beginning Episode Organization 2022-04-13 07:48:28.761 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E18-FKKTV\Unsere.kleine.Farm.S09E18.Kind.ohne.Namen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:28.761 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E18-FKKTV\Unsere.kleine.Farm.S09E18.Kind.ohne.Namen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E18 - Kind ohne Namen.mkv 2022-04-13 07:48:29.015 Info App: Beginning Episode Organization 2022-04-13 07:48:29.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E06-FKKTV\Unsere.kleine.Farm.S09E06.Der.wilde.Junge.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:29.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E06-FKKTV\Unsere.kleine.Farm.S09E06.Der.wilde.Junge.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E06 - Der wilde Junge (1).mkv 2022-04-13 07:48:29.271 Info App: Beginning Episode Organization 2022-04-13 07:48:29.271 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E15-FKKTV\Unsere.kleine.Farm.S09E15.Der.Autoren-Wettbewerb.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:29.272 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E15-FKKTV\Unsere.kleine.Farm.S09E15.Der.Autoren-Wettbewerb.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E15 - Der Autoren-Wettbewerb.mkv 2022-04-13 07:48:29.540 Info App: Beginning Episode Organization 2022-04-13 07:48:29.540 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E21-FKKTV\Unsere.kleine.Farm.S08E21.Warten.auf.ein.Wunder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:29.541 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E21-FKKTV\Unsere.kleine.Farm.S08E21.Warten.auf.ein.Wunder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E21 - Warten auf ein Wunder (1).mkv 2022-04-13 07:48:29.831 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/10/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:29.953 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=1&Season=10 2022-04-13 07:48:30.463 Warn App: No provider metadata found for Unsere kleine Farm season 10 episode 1 2022-04-13 07:48:30.464 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 10 episode 1 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:48:30.735 Info App: Beginning Episode Organization 2022-04-13 07:48:30.735 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E13-FKKTV\Unsere.kleine.Farm.S09E13.Der.Patriarch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:30.735 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E13-FKKTV\Unsere.kleine.Farm.S09E13.Der.Patriarch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E13 - Der Patriarch.mkv 2022-04-13 07:48:31.012 Info App: Beginning Episode Organization 2022-04-13 07:48:31.012 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E21-FKKTV\Unsere.kleine.Farm.S09E21.Universitaet.oder.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.012 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E21-FKKTV\Unsere.kleine.Farm.S09E21.Universitaet.oder.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E21 - Universität oder Hochzeit.mkv 2022-04-13 07:48:31.262 Info App: Beginning Episode Organization 2022-04-13 07:48:31.262 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E16-FKKTV\Unsere.kleine.Farm.S09E16.Gift.fuer.den.Koerper.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.263 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E16-FKKTV\Unsere.kleine.Farm.S09E16.Gift.fuer.den.Koerper.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E16 - Gift für den Körper (1).mkv 2022-04-13 07:48:31.522 Info App: Beginning Episode Organization 2022-04-13 07:48:31.522 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E22-FKKTV\Unsere.kleine.Farm.S08E22.Warten.auf.ein.Wunder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.523 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E22-FKKTV\Unsere.kleine.Farm.S08E22.Warten.auf.ein.Wunder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E22 - Warten auf ein Wunder (2).mkv 2022-04-13 07:48:31.824 Info App: Beginning Episode Organization 2022-04-13 07:48:31.824 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E19-FKKTV\Unsere.kleine.Farm.S08E19.Der.Patenonkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.825 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E19-FKKTV\Unsere.kleine.Farm.S08E19.Der.Patenonkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E19 - Der Patenonkel.mkv 2022-04-13 07:48:32.084 Info App: Beginning Episode Organization 2022-04-13 07:48:32.084 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E10-FKKTV\Unsere.kleine.Farm.S09E10.Edwards.spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:32.085 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E10-FKKTV\Unsere.kleine.Farm.S09E10.Edwards.spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E10 - Edwards späte Liebe.mkv 2022-04-13 07:48:32.360 Info App: Beginning Episode Organization 2022-04-13 07:48:32.360 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E09-FKKTV\Unsere.kleine.Farm.S09E09.Die.Eisenbahn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:32.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E09-FKKTV\Unsere.kleine.Farm.S09E09.Die.Eisenbahn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E09 - Die Eisenbahn.mkv 2022-04-13 07:48:32.631 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/10/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:32.757 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=3&Season=10 2022-04-13 07:48:33.275 Warn App: No provider metadata found for Unsere kleine Farm season 10 episode 3 2022-04-13 07:48:33.277 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 10 episode 3 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:48:33.513 Info App: Beginning Episode Organization 2022-04-13 07:48:33.513 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E22-FKKTV\Unsere.kleine.Farm.S09E22.Neuankoemmlinge.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:33.513 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E22-FKKTV\Unsere.kleine.Farm.S09E22.Neuankoemmlinge.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E22 - Neuankömmlinge.mkv 2022-04-13 07:48:33.772 Info App: Beginning Episode Organization 2022-04-13 07:48:33.772 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E17-FKKTV\Unsere.kleine.Farm.S08E17.Vom.Schicksal.gebeutelt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:33.773 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E17-FKKTV\Unsere.kleine.Farm.S08E17.Vom.Schicksal.gebeutelt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E17 - Vom Schicksal gebeutelt (1).mkv 2022-04-13 07:48:34.017 Info App: Beginning Episode Organization 2022-04-13 07:48:34.017 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E19-FKKTV\Unsere.kleine.Farm.S09E19.Der.letzte.Sommer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.018 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E19-FKKTV\Unsere.kleine.Farm.S09E19.Der.letzte.Sommer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E19 - Der letzte Sommer.mkv 2022-04-13 07:48:34.263 Info App: Beginning Episode Organization 2022-04-13 07:48:34.263 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E07-FKKTV\Unsere.kleine.Farm.S09E07.Der.wilde.Junge.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.265 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E07-FKKTV\Unsere.kleine.Farm.S09E07.Der.wilde.Junge.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E07 - Der wilde Junge (2).mkv 2022-04-13 07:48:34.516 Info App: Beginning Episode Organization 2022-04-13 07:48:34.516 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E01-FKKTV\Unsere.kleine.Farm.S09E01.Veraenderte.Zeiten.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.517 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E01-FKKTV\Unsere.kleine.Farm.S09E01.Veraenderte.Zeiten.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E01 - Veränderte Zeiten (1).mkv 2022-04-13 07:48:34.764 Info App: Beginning Episode Organization 2022-04-13 07:48:34.764 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E14-FKKTV\Unsere.kleine.Farm.S08E14.Ein.neuer.Beruf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.764 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E14-FKKTV\Unsere.kleine.Farm.S08E14.Ein.neuer.Beruf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E14 - Ein neuer Beruf.mkv 2022-04-13 07:48:35.023 Info App: Beginning Episode Organization 2022-04-13 07:48:35.023 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E04-FKKTV\Unsere.kleine.Farm.S09E04.Ein.Mann.fuehlt.sich.schuldig.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.024 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E04-FKKTV\Unsere.kleine.Farm.S09E04.Ein.Mann.fuehlt.sich.schuldig.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E04 - Ein Mann fühlt sich schuldig.mkv 2022-04-13 07:48:35.295 Info App: Beginning Episode Organization 2022-04-13 07:48:35.295 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E02-FKKTV\Unsere.kleine.Farm.S09E02.Veraenderte.Zeiten.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.295 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E02-FKKTV\Unsere.kleine.Farm.S09E02.Veraenderte.Zeiten.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E02 - Veränderte Zeiten (2).mkv 2022-04-13 07:48:35.556 Info App: Beginning Episode Organization 2022-04-13 07:48:35.556 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E17-FKKTV\Unsere.kleine.Farm.S09E17.Gift.fuer.den.Koerper.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.557 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E17-FKKTV\Unsere.kleine.Farm.S09E17.Gift.fuer.den.Koerper.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E17 - Gift für den Körper (2).mkv 2022-04-13 07:48:35.826 Info App: Beginning Episode Organization 2022-04-13 07:48:35.826 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E11-FKKTV\Unsere.kleine.Farm.S09E11.Eine.Ueberraschung.fuer.Reverend.Alden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.827 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E11-FKKTV\Unsere.kleine.Farm.S09E11.Eine.Ueberraschung.fuer.Reverend.Alden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E11 - Eine Überraschung für Reverend Alden.mkv 2022-04-13 07:48:36.059 Info App: Beginning Episode Organization 2022-04-13 07:48:36.059 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E14-FKKTV\Unsere.kleine.Farm.S09E14.Raeuber.sein.ist.schwer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.060 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E14-FKKTV\Unsere.kleine.Farm.S09E14.Raeuber.sein.ist.schwer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E14 - Räuber sein ist schwer.mkv 2022-04-13 07:48:36.303 Info App: Beginning Episode Organization 2022-04-13 07:48:36.304 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E20-FKKTV\Unsere.kleine.Farm.S08E20.Ein.Hilferuf.aus.der.Ferne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.305 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E20-FKKTV\Unsere.kleine.Farm.S08E20.Ein.Hilferuf.aus.der.Ferne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E20 - Ein Hilferuf aus der Ferne.mkv 2022-04-13 07:48:36.573 Info App: Beginning Episode Organization 2022-04-13 07:48:36.573 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E12-FKKTV\Unsere.kleine.Farm.S09E12.Doktor.Marvins.letzter.Patient.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.574 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E12-FKKTV\Unsere.kleine.Farm.S09E12.Doktor.Marvins.letzter.Patient.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E12 - Doktor Marvins letzter Patient.mkv 2022-04-13 07:48:36.852 Info App: Beginning Episode Organization 2022-04-13 07:48:36.852 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E20-FKKTV\Unsere.kleine.Farm.S09E20.Ein.ganz.besonderes.Maedchen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.852 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E20-FKKTV\Unsere.kleine.Farm.S09E20.Ein.ganz.besonderes.Maedchen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E20 - Ein ganz besonderes Mädchen.mkv 2022-04-13 07:48:37.098 Info App: Beginning Episode Organization 2022-04-13 07:48:37.098 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E18-FKKTV\Unsere.kleine.Farm.S08E18.Vom.Schicksal.gebeutelt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:37.098 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E18-FKKTV\Unsere.kleine.Farm.S08E18.Vom.Schicksal.gebeutelt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E18 - Vom Schicksal gebeutelt (2).mkv 2022-04-13 07:48:37.361 Info App: Beginning Episode Organization 2022-04-13 07:48:37.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E08-FKKTV\Unsere.kleine.Farm.S09E08.Nellie.und.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:37.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E08-FKKTV\Unsere.kleine.Farm.S09E08.Nellie.und.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E08 - Nellie und Nancy.mkv 2022-04-13 07:48:37.609 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/164541/all/de.zip 2022-04-13 07:48:38.607 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:38.748 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=2 2022-04-13 07:48:39.290 Info App: Beginning Episode Organization 2022-04-13 07:48:39.290 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:39.290 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E05 - Sauber.mkv 2022-04-13 07:48:39.931 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:40.086 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=2 2022-04-13 07:48:40.631 Info App: Beginning Episode Organization 2022-04-13 07:48:40.631 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:40.632 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E04 - Das rote Notizbuch.mkv 2022-04-13 07:48:40.937 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:41.117 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=2 2022-04-13 07:48:42.679 Info App: Beginning Episode Organization 2022-04-13 07:48:42.679 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:42.679 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E03 - Einzelkämpfer.mkv 2022-04-13 07:48:42.933 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:43.098 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=2 2022-04-13 07:48:43.650 Info App: Beginning Episode Organization 2022-04-13 07:48:43.650 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:43.651 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E02 - Ausgeschlossen.mkv 2022-04-13 07:48:43.899 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:44.052 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=2 2022-04-13 07:48:44.231 Info App: Beginning Episode Organization 2022-04-13 07:48:44.231 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:44.231 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E06 - Hausfriedensbruch.mkv 2022-04-13 07:48:44.516 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:44.676 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=2 2022-04-13 07:48:45.215 Info App: Beginning Episode Organization 2022-04-13 07:48:45.215 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:45.216 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E10 - Falsche Fährte.mkv 2022-04-13 07:48:45.493 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:45.652 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=2 2022-04-13 07:48:45.832 Info App: Beginning Episode Organization 2022-04-13 07:48:45.832 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:45.832 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E09 - Die Mumie.mkv 2022-04-13 07:48:46.101 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:46.249 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=2 2022-04-13 07:48:46.785 Info App: Beginning Episode Organization 2022-04-13 07:48:46.785 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:46.786 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E08 - Heilung.mkv 2022-04-13 07:48:47.034 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:47.227 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=2 2022-04-13 07:48:47.754 Info App: Beginning Episode Organization 2022-04-13 07:48:47.754 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:47.755 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E07 - Der Fluch der Geister.mkv 2022-04-13 07:48:47.969 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:48.130 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=4 2022-04-13 07:48:48.316 Info App: Beginning Episode Organization 2022-04-13 07:48:48.316 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:48.317 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E18 - Klassentreffen.mkv 2022-04-13 07:48:48.865 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:49.018 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=4 2022-04-13 07:48:49.206 Info App: Beginning Episode Organization 2022-04-13 07:48:49.206 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:49.207 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E17 - Unter der Oberfläche.mkv 2022-04-13 07:48:49.436 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:49.578 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=4 2022-04-13 07:48:50.118 Info App: Beginning Episode Organization 2022-04-13 07:48:50.118 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:50.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E16 - Das schwarze Einhorn.mkv 2022-04-13 07:48:50.338 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:50.605 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=4 2022-04-13 07:48:51.143 Info App: Beginning Episode Organization 2022-04-13 07:48:51.143 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:51.144 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E15 - Hinter der Wand.mkv 2022-04-13 07:48:51.371 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:51.536 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=4 2022-04-13 07:48:51.727 Info App: Beginning Episode Organization 2022-04-13 07:48:51.727 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:51.728 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E19 - Verschüttet.mkv 2022-04-13 07:48:51.988 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:52.142 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=2 2022-04-13 07:48:53.031 Info App: Beginning Episode Organization 2022-04-13 07:48:53.031 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:53.031 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E01 - Auf der Flucht.mkv 2022-04-13 07:48:53.276 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:53.431 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=4 2022-04-13 07:48:53.985 Info App: Beginning Episode Organization 2022-04-13 07:48:53.985 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:53.986 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E22 - Der fünfte Beatle.mkv 2022-04-13 07:48:54.247 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:54.401 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=4 2022-04-13 07:48:54.958 Info App: Beginning Episode Organization 2022-04-13 07:48:54.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:54.959 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E21 - Najib.mkv 2022-04-13 07:48:55.186 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:55.349 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=4 2022-04-13 07:48:55.889 Info App: Beginning Episode Organization 2022-04-13 07:48:55.889 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:55.890 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E20 - Gleich nebenan.mkv 2022-04-13 07:48:56.136 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:56.338 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=2 2022-04-13 07:48:56.513 Info App: Beginning Episode Organization 2022-04-13 07:48:56.513 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:56.514 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E23 - Vendetta.mkv 2022-04-13 07:48:56.731 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:56.902 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=2 2022-04-13 07:48:56.954 Info App: Beginning Episode Organization 2022-04-13 07:48:56.954 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:56.955 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E22 - Unter dem Radar.mkv 2022-04-13 07:48:57.222 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:57.371 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=2 2022-04-13 07:48:57.569 Info App: Beginning Episode Organization 2022-04-13 07:48:57.569 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:57.570 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E21 - Das Spiel mit dem Tod.mkv 2022-04-13 07:48:57.810 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:58.002 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=2 2022-04-13 07:48:58.549 Info App: Beginning Episode Organization 2022-04-13 07:48:58.549 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:58.550 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E20 - Ausgesetzt.mkv 2022-04-13 07:48:58.813 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:58.977 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=1 2022-04-13 07:48:59.517 Info App: Beginning Episode Organization 2022-04-13 07:48:59.517 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:59.518 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E24 - Verdächtig.mkv 2022-04-13 07:48:59.771 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:59.922 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=1 2022-04-13 07:49:00.145 Info App: Beginning Episode Organization 2022-04-13 07:49:00.145 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:00.146 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E20 - Fischschuppen.mkv 2022-04-13 07:49:00.366 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:00.519 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=1 2022-04-13 07:49:01.054 Info App: Beginning Episode Organization 2022-04-13 07:49:01.054 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:01.055 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E21 - Wolframstahl.mkv 2022-04-13 07:49:01.292 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:01.449 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=1 2022-04-13 07:49:01.987 Info App: Beginning Episode Organization 2022-04-13 07:49:01.987 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:01.988 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E22 - Das Ende der Lügen.mkv 2022-04-13 07:49:02.221 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:02.380 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=1 2022-04-13 07:49:02.964 Info App: Beginning Episode Organization 2022-04-13 07:49:02.965 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:02.965 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E23 - Der Hauch des Todes.mkv 2022-04-13 07:49:03.190 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:03.346 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=2 2022-04-13 07:49:03.897 Info App: Beginning Episode Organization 2022-04-13 07:49:03.897 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:03.898 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E14 - Das Päckchen.mkv 2022-04-13 07:49:04.157 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:04.354 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=2 2022-04-13 07:49:04.900 Info App: Beginning Episode Organization 2022-04-13 07:49:04.900 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:04.900 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E13 - Sex, Lügen und Video.mkv 2022-04-13 07:49:05.145 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:05.303 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=2 2022-04-13 07:49:05.860 Info App: Beginning Episode Organization 2022-04-13 07:49:05.860 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:05.861 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E12 - Der Mann im Bunker.mkv 2022-04-13 07:49:06.114 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:06.277 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=2 2022-04-13 07:49:06.806 Info App: Beginning Episode Organization 2022-04-13 07:49:06.806 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:06.807 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E11 - In der Falle.mkv 2022-04-13 07:49:07.072 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:07.233 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=2 2022-04-13 07:49:07.779 Info App: Beginning Episode Organization 2022-04-13 07:49:07.779 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:07.779 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E15 - Späte Rache.mkv 2022-04-13 07:49:08.021 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:08.168 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=2 2022-04-13 07:49:08.727 Info App: Beginning Episode Organization 2022-04-13 07:49:08.727 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:08.727 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E19 - Diamantenfieber.mkv 2022-04-13 07:49:08.969 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:09.124 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=2 2022-04-13 07:49:09.664 Info App: Beginning Episode Organization 2022-04-13 07:49:09.664 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:09.665 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E18 - Feuerwerk.mkv 2022-04-13 07:49:09.677 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:49:09.680 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:49:09.701 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:49:09.703 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 2ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:49:09.907 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:10.057 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=2 2022-04-13 07:49:10.243 Info App: Beginning Episode Organization 2022-04-13 07:49:10.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:10.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E17 - Sinneswandel.mkv 2022-04-13 07:49:10.473 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:10.645 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=2 2022-04-13 07:49:11.188 Info App: Beginning Episode Organization 2022-04-13 07:49:11.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:11.189 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E16 - Die Abrechnung.mkv 2022-04-13 07:49:11.447 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:11.604 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=4 2022-04-13 07:49:12.136 Info App: Beginning Episode Organization 2022-04-13 07:49:12.136 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:12.137 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E14 - Reingelegt.mkv 2022-04-13 07:49:12.362 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:12.522 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=3 2022-04-13 07:49:13.075 Info App: Beginning Episode Organization 2022-04-13 07:49:13.075 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:13.076 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E11 - Steve Junior.mkv 2022-04-13 07:49:13.306 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:13.463 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=3 2022-04-13 07:49:14.011 Info App: Beginning Episode Organization 2022-04-13 07:49:14.011 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:14.012 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E23 - Mission Impossible.mkv 2022-04-13 07:49:14.269 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:14.418 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=3 2022-04-13 07:49:14.954 Info App: Beginning Episode Organization 2022-04-13 07:49:14.954 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:14.955 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E12 - Schatten und Licht.mkv 2022-04-13 07:49:15.217 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:15.433 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=3 2022-04-13 07:49:15.613 Info App: Beginning Episode Organization 2022-04-13 07:49:15.613 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:15.614 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E22 - Gefangen.mkv 2022-04-13 07:49:15.863 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:16.017 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=3 2022-04-13 07:49:16.074 Info App: Beginning Episode Organization 2022-04-13 07:49:16.074 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:16.075 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E24 - Kono.mkv 2022-04-13 07:49:16.302 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:16.464 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=4 2022-04-13 07:49:16.996 Info App: Beginning Episode Organization 2022-04-13 07:49:16.997 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:16.997 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E02 - Ray, Texas Ranger.mkv 2022-04-13 07:49:17.243 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:17.392 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=3 2022-04-13 07:49:17.930 Info App: Beginning Episode Organization 2022-04-13 07:49:17.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:17.931 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E09 - Kleine Beute.mkv 2022-04-13 07:49:18.167 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:18.312 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=4 2022-04-13 07:49:18.846 Info App: Beginning Episode Organization 2022-04-13 07:49:18.846 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:18.847 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E01 - Voller Einsatz.mkv 2022-04-13 07:49:19.078 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:19.289 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=3 2022-04-13 07:49:19.825 Info App: Beginning Episode Organization 2022-04-13 07:49:19.825 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:19.826 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E10 - Allzeit bereit.mkv 2022-04-13 07:49:20.083 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:20.283 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=3 2022-04-13 07:49:20.817 Info App: Beginning Episode Organization 2022-04-13 07:49:20.817 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:20.817 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E19 - Seemannsgarn.mkv 2022-04-13 07:49:21.056 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:21.217 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=3 2022-04-13 07:49:21.399 Info App: Beginning Episode Organization 2022-04-13 07:49:21.399 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:21.400 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E16 - Kein Wort.mkv 2022-04-13 07:49:21.668 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:21.872 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=3 2022-04-13 07:49:22.407 Info App: Beginning Episode Organization 2022-04-13 07:49:22.407 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:22.408 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E17 - Der zwölfte Mann.mkv 2022-04-13 07:49:22.679 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:22.850 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=3 2022-04-13 07:49:23.386 Info App: Beginning Episode Organization 2022-04-13 07:49:23.386 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:23.387 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E18 - Doppelleben.mkv 2022-04-13 07:49:23.683 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:23.878 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=3 2022-04-13 07:49:24.412 Info App: Beginning Episode Organization 2022-04-13 07:49:24.412 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:24.416 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E15 - Die verlorenen Hände.mkv 2022-04-13 07:49:24.641 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:24.809 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=3 2022-04-13 07:49:25.361 Info App: Beginning Episode Organization 2022-04-13 07:49:25.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:25.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E13 - Block A.mkv 2022-04-13 07:49:25.614 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:25.799 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=3 2022-04-13 07:49:26.345 Info App: Beginning Episode Organization 2022-04-13 07:49:26.345 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:26.346 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E21 - Hautnah.mkv 2022-04-13 07:49:26.578 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:26.734 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=3 2022-04-13 07:49:27.268 Info App: Beginning Episode Organization 2022-04-13 07:49:27.268 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:27.269 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E14 - Ein guter Freund.mkv 2022-04-13 07:49:27.541 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:27.824 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=3 2022-04-13 07:49:28.018 Info App: Beginning Episode Organization 2022-04-13 07:49:28.018 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:28.019 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E20 - Das Versprechen.mkv 2022-04-13 07:49:28.253 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:28.407 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=3 2022-04-13 07:49:28.592 Info App: Beginning Episode Organization 2022-04-13 07:49:28.592 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:28.593 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E02 - Ein alter Bekannter.mkv 2022-04-13 07:49:28.843 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:29.112 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=4 2022-04-13 07:49:29.655 Info App: Beginning Episode Organization 2022-04-13 07:49:29.655 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:29.656 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E08 - Ärger im Gepäck.mkv 2022-04-13 07:49:29.919 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:30.075 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=3 2022-04-13 07:49:30.616 Info App: Beginning Episode Organization 2022-04-13 07:49:30.616 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:30.616 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E03 - Zwei Männer, ein Boot.mkv 2022-04-13 07:49:30.915 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:31.062 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=4 2022-04-13 07:49:31.599 Info App: Beginning Episode Organization 2022-04-13 07:49:31.599 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:31.600 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E07 - Drei Männer und ein Baby.mkv 2022-04-13 07:49:31.834 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:31.985 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=4 2022-04-13 07:49:32.522 Info App: Beginning Episode Organization 2022-04-13 07:49:32.522 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:32.523 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E09 - Streng Geheim.mkv 2022-04-13 07:49:32.771 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:32.921 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=4 2022-04-13 07:49:33.460 Info App: Beginning Episode Organization 2022-04-13 07:49:33.460 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:33.461 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E12 - Auf Sand gebaut.mkv 2022-04-13 07:49:33.728 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:33.913 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=4 2022-04-13 07:49:34.467 Info App: Beginning Episode Organization 2022-04-13 07:49:34.468 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:34.468 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E11 - Bei Einbruch Mord.mkv 2022-04-13 07:49:34.714 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:34.991 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=3 2022-04-13 07:49:35.174 Info App: Beginning Episode Organization 2022-04-13 07:49:35.174 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:35.174 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E01 - Shelburne.mkv 2022-04-13 07:49:35.409 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:35.576 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=4 2022-04-13 07:49:36.130 Info App: Beginning Episode Organization 2022-04-13 07:49:36.130 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:36.131 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E04 - Bis dass der Tod.mkv 2022-04-13 07:49:36.384 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:36.540 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=3 2022-04-13 07:49:37.083 Info App: Beginning Episode Organization 2022-04-13 07:49:37.083 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:37.084 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E07 - Ahnungslos.mkv 2022-04-13 07:49:37.331 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:37.524 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=4 2022-04-13 07:49:38.056 Info App: Beginning Episode Organization 2022-04-13 07:49:38.056 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:38.057 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E03 - Die Ringe der Medici.mkv 2022-04-13 07:49:38.303 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:38.456 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=3 2022-04-13 07:49:38.995 Info App: Beginning Episode Organization 2022-04-13 07:49:38.995 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:38.996 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E08 - Mangosta.mkv 2022-04-13 07:49:39.252 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:39.410 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=3 2022-04-13 07:49:39.957 Info App: Beginning Episode Organization 2022-04-13 07:49:39.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:39.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E06 - Grace.mkv 2022-04-13 07:49:40.181 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:40.344 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=3 2022-04-13 07:49:40.525 Info App: Beginning Episode Organization 2022-04-13 07:49:40.525 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:40.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E04 - Der kopflose Reiter.mkv 2022-04-13 07:49:40.784 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:40.931 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=3 2022-04-13 07:49:41.479 Info App: Beginning Episode Organization 2022-04-13 07:49:41.479 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:41.480 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E05 - Das Ritual.mkv 2022-04-13 07:49:41.724 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:41.888 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=4 2022-04-13 07:49:42.428 Info App: Beginning Episode Organization 2022-04-13 07:49:42.428 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:42.429 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E05 - Spione.mkv 2022-04-13 07:49:42.653 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:42.666 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=9 2022-04-13 07:49:43.233 Info App: Beginning Episode Organization 2022-04-13 07:49:43.233 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:43.234 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E03 - Hitzewelle.mkv 2022-04-13 07:49:43.514 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:43.527 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=9 2022-04-13 07:49:44.080 Info App: Beginning Episode Organization 2022-04-13 07:49:44.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:44.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E02 - Der Mann, der vom Himmel fiel.mkv 2022-04-13 07:49:44.319 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:44.329 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=9 2022-04-13 07:49:44.864 Info App: Beginning Episode Organization 2022-04-13 07:49:44.864 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:44.865 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E01 - Der gigantische Kokon.mkv 2022-04-13 07:49:45.091 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/25?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:45.241 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=25&Season=5 2022-04-13 07:49:45.771 Info App: Beginning Episode Organization 2022-04-13 07:49:45.771 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E25.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:45.772 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E25.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E25 - Waikikikalypse.mkv 2022-04-13 07:49:46.401 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:46.411 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=9 2022-04-13 07:49:46.961 Info App: Beginning Episode Organization 2022-04-13 07:49:46.961 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:46.962 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E07 - Große Träume.mkv 2022-04-13 07:49:47.188 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:47.197 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=9 2022-04-13 07:49:48.091 Info App: Beginning Episode Organization 2022-04-13 07:49:48.091 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:48.092 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E06 - Nach eigenen Regeln.mkv 2022-04-13 07:49:48.354 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:48.365 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=9 2022-04-13 07:49:48.907 Info App: Beginning Episode Organization 2022-04-13 07:49:48.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:48.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E05 - Eine schaurige Nacht.mkv 2022-04-13 07:49:49.171 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:49.183 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=9 2022-04-13 07:49:49.734 Info App: Beginning Episode Organization 2022-04-13 07:49:49.734 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:49.735 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E04 - Aus der Versenkung.mkv 2022-04-13 07:49:50.000 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:50.165 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=5 2022-04-13 07:49:51.728 Info App: Beginning Episode Organization 2022-04-13 07:49:51.728 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:51.729 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E24 - Untergetaucht.mkv 2022-04-13 07:49:51.953 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:52.095 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=5 2022-04-13 07:49:52.645 Info App: Beginning Episode Organization 2022-04-13 07:49:52.646 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:52.647 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E19 - Haarscharf.mkv 2022-04-13 07:49:52.897 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:53.058 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=5 2022-04-13 07:49:54.188 Info App: Beginning Episode Organization 2022-04-13 07:49:54.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:54.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E18 - Gleiches Recht für alle.mkv 2022-04-13 07:49:54.449 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:54.620 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=5 2022-04-13 07:49:55.145 Info App: Beginning Episode Organization 2022-04-13 07:49:55.145 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:55.146 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E17 - Auf der Lauer.mkv 2022-04-13 07:49:55.385 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:55.589 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=5 2022-04-13 07:49:55.776 Info App: Beginning Episode Organization 2022-04-13 07:49:55.776 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:55.777 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E16 - Wer ist Melissa Armstrong.mkv 2022-04-13 07:49:56.004 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:56.160 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=5 2022-04-13 07:49:57.051 Info App: Beginning Episode Organization 2022-04-13 07:49:57.051 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:57.051 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E23 - Im Auge des Sturms.mkv 2022-04-13 07:49:57.287 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:57.456 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=5 2022-04-13 07:49:58.005 Info App: Beginning Episode Organization 2022-04-13 07:49:58.005 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:58.006 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E22 - Hangover.mkv 2022-04-13 07:49:58.299 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:58.478 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=5 2022-04-13 07:49:58.664 Info App: Beginning Episode Organization 2022-04-13 07:49:58.665 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:58.665 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E21 - Der King ist tot.mkv 2022-04-13 07:49:58.932 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:59.090 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=5 2022-04-13 07:49:59.617 Info App: Beginning Episode Organization 2022-04-13 07:49:59.617 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:59.617 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E20 - Verdächtig unverdächtig.mkv 2022-04-13 07:49:59.870 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:59.880 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=9 2022-04-13 07:50:00.418 Info App: Beginning Episode Organization 2022-04-13 07:50:00.418 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:00.418 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E08 - Streithähne.mkv 2022-04-13 07:50:00.665 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:00.674 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=9 2022-04-13 07:50:01.218 Info App: Beginning Episode Organization 2022-04-13 07:50:01.218 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:01.218 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E21 - Katzenjammer.mkv 2022-04-13 07:50:01.479 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:01.489 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=9 2022-04-13 07:50:02.037 Info App: Beginning Episode Organization 2022-04-13 07:50:02.037 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:02.038 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E20 - Von Hand zu Hand.mkv 2022-04-13 07:50:02.291 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:02.300 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=9 2022-04-13 07:50:02.488 Info App: Beginning Episode Organization 2022-04-13 07:50:02.488 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:02.488 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E19 - Der falsche Fensterputzer.mkv 2022-04-13 07:50:02.749 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:02.759 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=9 2022-04-13 07:50:03.298 Info App: Beginning Episode Organization 2022-04-13 07:50:03.299 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:03.299 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E18 - Schwiegermutter zu Besuch.mkv 2022-04-13 07:50:03.534 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:03.543 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=9 2022-04-13 07:50:04.081 Info App: Beginning Episode Organization 2022-04-13 07:50:04.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:04.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E22 - Noelani.mkv 2022-04-13 07:50:04.328 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:04.337 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=9 2022-04-13 07:50:04.526 Info App: Beginning Episode Organization 2022-04-13 07:50:04.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:04.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E23 - Mord ist Ihr Hobby.mkv 2022-04-13 07:50:04.806 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:04.821 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=9 2022-04-13 07:50:05.009 Info App: Beginning Episode Organization 2022-04-13 07:50:05.009 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:05.010 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E24 - Die Schuldfrage.mkv 2022-04-13 07:50:05.256 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/25?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:05.267 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=25&Season=9 2022-04-13 07:50:05.816 Info App: Beginning Episode Organization 2022-04-13 07:50:05.816 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E25.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:05.816 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E25.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E25 - Das Leben geht weiter.mkv 2022-04-13 07:50:06.058 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:06.070 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=9 2022-04-13 07:50:06.608 Info App: Beginning Episode Organization 2022-04-13 07:50:06.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:06.609 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E17 - Zerrissen.mkv 2022-04-13 07:50:06.839 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:06.848 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=9 2022-04-13 07:50:07.397 Info App: Beginning Episode Organization 2022-04-13 07:50:07.397 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:07.398 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E12 - Ohana.mkv 2022-04-13 07:50:07.658 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:07.830 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=9 2022-04-13 07:50:08.379 Info App: Beginning Episode Organization 2022-04-13 07:50:08.379 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:08.380 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E11 - Der Anfang vom Ende.mkv 2022-04-13 07:50:08.641 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:08.652 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=9 2022-04-13 07:50:09.183 Info App: Beginning Episode Organization 2022-04-13 07:50:09.183 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:09.184 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E10 - Marokko.mkv 2022-04-13 07:50:09.446 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:09.460 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=9 2022-04-13 07:50:09.651 Info App: Beginning Episode Organization 2022-04-13 07:50:09.651 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:09.652 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E09 - Das letzte Kapitel.mkv 2022-04-13 07:50:09.698 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:50:09.702 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 4ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:50:09.721 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:50:09.724 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:50:09.884 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:09.895 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=9 2022-04-13 07:50:10.431 Info App: Beginning Episode Organization 2022-04-13 07:50:10.431 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:10.432 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E16 - Die tote Meerjungfrau.mkv 2022-04-13 07:50:10.689 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:10.698 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=9 2022-04-13 07:50:11.250 Info App: Beginning Episode Organization 2022-04-13 07:50:11.250 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:11.251 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E15 - Sturm im Paradies.mkv 2022-04-13 07:50:11.496 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:11.506 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=9 2022-04-13 07:50:12.065 Info App: Beginning Episode Organization 2022-04-13 07:50:12.065 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:12.066 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E14 - Ein Zeichen.mkv 2022-04-13 07:50:12.293 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:12.302 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=9 2022-04-13 07:50:12.863 Info App: Beginning Episode Organization 2022-04-13 07:50:12.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:12.864 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E13 - Unter Wasser.mkv 2022-04-13 07:50:13.097 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:13.248 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=5 2022-04-13 07:50:13.804 Info App: Beginning Episode Organization 2022-04-13 07:50:13.804 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:13.805 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E15 - Der Mann, der zu viel wusste.mkv 2022-04-13 07:50:14.046 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:14.266 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=5 2022-04-13 07:50:14.808 Info App: Beginning Episode Organization 2022-04-13 07:50:14.808 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:14.809 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E05 - Ehrensache.mkv 2022-04-13 07:50:15.049 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:15.221 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=1 2022-04-13 07:50:15.766 Info App: Beginning Episode Organization 2022-04-13 07:50:15.766 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:15.767 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E09 - Die Schöne und das Biest.mkv 2022-04-13 07:50:16.020 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:16.163 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=5 2022-04-13 07:50:16.702 Info App: Beginning Episode Organization 2022-04-13 07:50:16.702 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:16.703 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E04 - Ein größerer Typ.mkv 2022-04-13 07:50:16.967 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:17.130 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=1 2022-04-13 07:50:17.666 Info App: Beginning Episode Organization 2022-04-13 07:50:17.666 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:17.667 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E10 - Auf die Plätze, fertig, Mord!.mkv 2022-04-13 07:50:17.936 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:18.176 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=5 2022-04-13 07:50:18.695 Info App: Beginning Episode Organization 2022-04-13 07:50:18.695 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:18.696 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E07 - Verkehrte Welt.mkv 2022-04-13 07:50:18.936 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:19.108 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=1 2022-04-13 07:50:19.660 Info App: Beginning Episode Organization 2022-04-13 07:50:19.660 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:19.661 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E07 - Der einzige Verdächtige.mkv 2022-04-13 07:50:19.913 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:20.054 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=5 2022-04-13 07:50:20.607 Info App: Beginning Episode Organization 2022-04-13 07:50:20.607 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:20.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E06 - Leichen pflastern seinen Weg.mkv 2022-04-13 07:50:20.874 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:21.066 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=1 2022-04-13 07:50:21.606 Info App: Beginning Episode Organization 2022-04-13 07:50:21.606 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:21.607 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E08 - Wo Rauch ist.mkv 2022-04-13 07:50:21.853 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:22.012 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=5 2022-04-13 07:50:22.188 Info App: Beginning Episode Organization 2022-04-13 07:50:22.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:22.189 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E01 - Das fliegende Auge.mkv 2022-04-13 07:50:22.426 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:22.575 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=1 2022-04-13 07:50:23.108 Info App: Beginning Episode Organization 2022-04-13 07:50:23.108 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:23.108 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E13 - Strichmännchen.mkv 2022-04-13 07:50:23.352 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:23.515 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=1 2022-04-13 07:50:23.702 Info App: Beginning Episode Organization 2022-04-13 07:50:23.702 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:23.702 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E15 - Alarm im Pazifik.mkv 2022-04-13 07:50:23.954 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:24.101 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=1 2022-04-13 07:50:24.644 Info App: Beginning Episode Organization 2022-04-13 07:50:24.644 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:24.644 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E14 - Die Straßen von Honolulu.mkv 2022-04-13 07:50:24.909 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:25.096 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=5 2022-04-13 07:50:25.273 Info App: Beginning Episode Organization 2022-04-13 07:50:25.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:25.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E03 - Endloser Sommer.mkv 2022-04-13 07:50:25.521 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:25.712 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=1 2022-04-13 07:50:26.243 Info App: Beginning Episode Organization 2022-04-13 07:50:26.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:26.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E11 - Tödliche Flitterwochen.mkv 2022-04-13 07:50:26.546 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:26.753 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=5 2022-04-13 07:50:26.806 Info App: Beginning Episode Organization 2022-04-13 07:50:26.806 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:26.807 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E02 - Wenn alles auseinander bricht.mkv 2022-04-13 07:50:27.081 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:27.243 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=1 2022-04-13 07:50:27.448 Info App: Beginning Episode Organization 2022-04-13 07:50:27.448 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:27.449 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E12 - Die Bombe.mkv 2022-04-13 07:50:27.684 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/LiveTv/Channels?userId=04cfcd788b4a4a17ae56b54d7d4a58f3&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=ChannelNumber,SortName&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:50:27.696 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 11ms. http://citycobra89.dynaccess.de/emby/LiveTv/Channels?userId=04cfcd788b4a4a17ae56b54d7d4a58f3&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=ChannelNumber,SortName&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:50:27.697 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:27.847 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=1 2022-04-13 07:50:28.023 Info App: Beginning Episode Organization 2022-04-13 07:50:28.023 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:28.024 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E02 - Ein Sicherheitsrisiko.mkv 2022-04-13 07:50:28.264 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:28.439 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=5 2022-04-13 07:50:28.967 Info App: Beginning Episode Organization 2022-04-13 07:50:28.967 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:28.968 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E12 - Wailea.mkv 2022-04-13 07:50:29.223 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:29.379 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=1 2022-04-13 07:50:29.926 Info App: Beginning Episode Organization 2022-04-13 07:50:29.926 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:29.926 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E03 - In den besten Familien.mkv 2022-04-13 07:50:30.157 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:30.332 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=5 2022-04-13 07:50:30.390 Info App: Beginning Episode Organization 2022-04-13 07:50:30.390 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:30.391 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E11 - Das Meisterwerk.mkv 2022-04-13 07:50:30.641 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:30.818 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=1 2022-04-13 07:50:30.995 Info App: Beginning Episode Organization 2022-04-13 07:50:30.996 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:30.996 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E19 - Von Helden und Schurken.mkv 2022-04-13 07:50:31.272 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:31.503 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=5 2022-04-13 07:50:32.034 Info App: Beginning Episode Organization 2022-04-13 07:50:32.034 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:32.035 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E14 - Das Phantom.mkv 2022-04-13 07:50:32.293 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:32.445 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=1 2022-04-13 07:50:32.984 Info App: Beginning Episode Organization 2022-04-13 07:50:32.984 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:32.984 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E01 - Aloha, Steve McGarrett.mkv 2022-04-13 07:50:33.235 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:33.395 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=5 2022-04-13 07:50:33.571 Info App: Beginning Episode Organization 2022-04-13 07:50:33.571 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:33.572 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E13 - Das Virus.mkv 2022-04-13 07:50:33.818 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:33.988 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=1 2022-04-13 07:50:34.532 Info App: Beginning Episode Organization 2022-04-13 07:50:34.532 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:34.533 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E18 - Der lange Abschied.mkv 2022-04-13 07:50:34.784 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:34.969 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=1 2022-04-13 07:50:35.506 Info App: Beginning Episode Organization 2022-04-13 07:50:35.506 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:35.506 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E16 - Hart am Wind.mkv 2022-04-13 07:50:35.764 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:35.926 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=1 2022-04-13 07:50:36.466 Info App: Beginning Episode Organization 2022-04-13 07:50:36.466 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:36.466 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E05 - Die Vertrauensfrage.mkv 2022-04-13 07:50:36.723 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:36.899 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=5 2022-04-13 07:50:37.433 Info App: Beginning Episode Organization 2022-04-13 07:50:37.433 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:37.433 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E08 - Schein und Sein.mkv 2022-04-13 07:50:37.706 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:37.885 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=1 2022-04-13 07:50:38.432 Info App: Beginning Episode Organization 2022-04-13 07:50:38.432 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:38.433 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E06 - Gefährliche Brandung.mkv 2022-04-13 07:50:38.663 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:38.838 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=1 2022-04-13 07:50:39.026 Info App: Beginning Episode Organization 2022-04-13 07:50:39.026 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:39.026 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E04 - Der Millionengewinn.mkv 2022-04-13 07:50:39.278 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:39.456 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=5 2022-04-13 07:50:40.003 Info App: Beginning Episode Organization 2022-04-13 07:50:40.003 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:40.003 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E09 - Ein Cowboy auf dem Mars.mkv 2022-04-13 07:50:40.255 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:40.438 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=1 2022-04-13 07:50:40.632 Info App: Beginning Episode Organization 2022-04-13 07:50:40.632 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:40.633 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E17 - Piraten.mkv
GiGo 108 Posted April 13, 2022 Posted April 13, 2022 2 hours ago, TheUrbanXplorer said: For me, unfortunately, everything is the same. It says it moves the file, but unfortunately nothing happens. 2022-04-13 07:47:36.849 Info App: Beginning Episode Organization 2022-04-13 07:47:36.849 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E15-FKKTV\Unsere.kleine.Farm.S02E15.Die.Blutvergiftung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:36.850 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E15-FKKTV\Unsere.kleine.Farm.S02E15.Die.Blutvergiftung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E15 - Die Blutvergiftung.mkv 2022-04-13 07:47:38.237 Info App: Beginning Episode Organization 2022-04-13 07:47:38.237 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E13-FKKTV\Unsere.kleine.Farm.S04E13.Flucht.in.die.Freiheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:38.237 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E13-FKKTV\Unsere.kleine.Farm.S04E13.Flucht.in.die.Freiheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E13 - Flucht in die Freiheit.mkv 2022-04-13 07:47:38.842 Info App: Beginning Episode Organization 2022-04-13 07:47:38.842 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E11-FKKTV\Unsere.kleine.Farm.S01E11.Eine.Glocke.fuer.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:38.843 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E11-FKKTV\Unsere.kleine.Farm.S01E11.Eine.Glocke.fuer.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E11 - Eine Glocke für Walnut Grove.mkv 2022-04-13 07:47:39.470 Info App: Beginning Episode Organization 2022-04-13 07:47:39.470 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E19-FKKTV\Unsere.kleine.Farm.S06E19.Feuersbrunst.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:39.470 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E19-FKKTV\Unsere.kleine.Farm.S06E19.Feuersbrunst.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E19 - Die Feuersbrunst (2).mkv 2022-04-13 07:47:40.080 Info App: Beginning Episode Organization 2022-04-13 07:47:40.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E07-FKKTV\Unsere.kleine.Farm.S08E07.Die.Moechtegern-Ganoven.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:40.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E07-FKKTV\Unsere.kleine.Farm.S08E07.Die.Moechtegern-Ganoven.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E07 - Die Möchtegern-Ganoven.mkv 2022-04-13 07:47:40.683 Info App: Beginning Episode Organization 2022-04-13 07:47:40.683 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E09-FKKTV\Unsere.kleine.Farm.S02E09.Eine.neue.Familie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:40.684 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E09-FKKTV\Unsere.kleine.Farm.S02E09.Eine.neue.Familie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E09 - Der Ausflug.mkv 2022-04-13 07:47:40.975 Info App: Beginning Episode Organization 2022-04-13 07:47:40.975 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E02-FKKTV\Unsere.kleine.Farm.S06E02.Schulanfang.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:40.976 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E02-FKKTV\Unsere.kleine.Farm.S06E02.Schulanfang.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E02 - Schulanfang (2).mkv 2022-04-13 07:47:41.251 Info App: Beginning Episode Organization 2022-04-13 07:47:41.251 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E06-FKKTV\Unsere.kleine.Farm.S01E06.Geburtstagsfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:41.251 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E06-FKKTV\Unsere.kleine.Farm.S01E06.Geburtstagsfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E06 - Geburtstagsfeier.mkv 2022-04-13 07:47:41.514 Info App: Beginning Episode Organization 2022-04-13 07:47:41.514 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E15-FKKTV\Unsere.kleine.Farm.S07E15.Ein.Lied.fuer.Hester.Sue.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:41.515 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E15-FKKTV\Unsere.kleine.Farm.S07E15.Ein.Lied.fuer.Hester.Sue.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E15 - Ein Lied für Hester Sue.mkv 2022-04-13 07:47:42.169 Info App: Beginning Episode Organization 2022-04-13 07:47:42.169 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E03-FKKTV\Unsere.kleine.Farm.S05E03.Der.beste.Spieler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:42.171 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E03-FKKTV\Unsere.kleine.Farm.S05E03.Der.beste.Spieler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E03 - Der beste Spieler.mkv 2022-04-13 07:47:42.778 Info App: Beginning Episode Organization 2022-04-13 07:47:42.778 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E04-FKKTV\Unsere.kleine.Farm.S04E04.Ein.unerwarteter.Helfer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:42.778 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E04-FKKTV\Unsere.kleine.Farm.S04E04.Ein.unerwarteter.Helfer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E04 - Ein unerwarteter Helfer.mkv 2022-04-13 07:47:43.070 Info App: Beginning Episode Organization 2022-04-13 07:47:43.070 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E20-FKKTV\Unsere.kleine.Farm.S03E20.Klassensprecherwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:43.070 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E20-FKKTV\Unsere.kleine.Farm.S03E20.Klassensprecherwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E20 - Klassensprecherwahl.mkv 2022-04-13 07:47:43.685 Info App: Beginning Episode Organization 2022-04-13 07:47:43.685 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E09-FKKTV\Unsere.kleine.Farm.S07E09.Der.Zweikampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:43.686 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E09-FKKTV\Unsere.kleine.Farm.S07E09.Der.Zweikampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E09 - Der Zweikampf.mkv 2022-04-13 07:47:43.946 Info App: Beginning Episode Organization 2022-04-13 07:47:43.946 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E01-FKKTV\Unsere.kleine.Farm.S08E01.Die.neue.Nellie.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:43.946 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E01-FKKTV\Unsere.kleine.Farm.S08E01.Die.neue.Nellie.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E01 - Die neue Nellie (1).mkv 2022-04-13 07:47:44.226 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/77921/all/de.zip 2022-04-13 07:47:44.742 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/1/episode/0?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:47:44.880 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=0&Season=1 2022-04-13 07:47:45.403 Warn App: No provider metadata found for Unsere kleine Farm season 1 episode 0 2022-04-13 07:47:45.404 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 1 episode 0 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:47:45.662 Info App: Beginning Episode Organization 2022-04-13 07:47:45.662 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E12-FKKTV\Unsere.kleine.Farm.S03E12.Ich.reite.mit.dem.Wind.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:45.662 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E12-FKKTV\Unsere.kleine.Farm.S03E12.Ich.reite.mit.dem.Wind.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E12 - Ich reite mit dem Wind.mkv 2022-04-13 07:47:45.904 Info App: Beginning Episode Organization 2022-04-13 07:47:45.904 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E21-FKKTV\Unsere.kleine.Farm.S02E21.Der.verlorene.Sohn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:45.905 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E21-FKKTV\Unsere.kleine.Farm.S02E21.Der.verlorene.Sohn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E21 - Der verlorene Sohn.mkv 2022-04-13 07:47:46.158 Info App: Beginning Episode Organization 2022-04-13 07:47:46.159 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E16-FKKTV\Unsere.kleine.Farm.S04E16.Erinnerungen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.159 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E16-FKKTV\Unsere.kleine.Farm.S04E16.Erinnerungen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E16 - Erinnerungen.mkv 2022-04-13 07:47:46.412 Info App: Beginning Episode Organization 2022-04-13 07:47:46.412 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E13-FKKTV\Unsere.kleine.Farm.S08E13.Lauras.Obstgarten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.412 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E13-FKKTV\Unsere.kleine.Farm.S08E13.Lauras.Obstgarten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E13 - Lauras Obstgarten.mkv 2022-04-13 07:47:46.689 Info App: Beginning Episode Organization 2022-04-13 07:47:46.689 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E21-FKKTV\Unsere.kleine.Farm.S07E21.Die.Waisenkinder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.690 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E21-FKKTV\Unsere.kleine.Farm.S07E21.Die.Waisenkinder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E21 - Die Waisenkinder (1).mkv 2022-04-13 07:47:46.957 Info App: Beginning Episode Organization 2022-04-13 07:47:46.957 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E18-FKKTV\Unsere.kleine.Farm.S05E18.Kinderstimmen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:46.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E18-FKKTV\Unsere.kleine.Farm.S05E18.Kinderstimmen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E18 - Kinderstimmen.mkv 2022-04-13 07:47:47.245 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/10/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:47:47.366 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=5&Season=10 2022-04-13 07:47:47.884 Warn App: No provider metadata found for Unsere kleine Farm season 10 episode 5 2022-04-13 07:47:47.886 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 10 episode 5 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:47:48.115 Info App: Beginning Episode Organization 2022-04-13 07:47:48.115 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E13-FKKTV\Unsere.kleine.Farm.S02E13.Die.Sprechmaschine.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.116 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E13-FKKTV\Unsere.kleine.Farm.S02E13.Die.Sprechmaschine.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E13 - Die Sprechmaschine.mkv 2022-04-13 07:47:48.361 Info App: Beginning Episode Organization 2022-04-13 07:47:48.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E06-FKKTV\Unsere.kleine.Farm.S05E06.Heimweh.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E06-FKKTV\Unsere.kleine.Farm.S05E06.Heimweh.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E06 - Heimweh (2).mkv 2022-04-13 07:47:48.627 Info App: Beginning Episode Organization 2022-04-13 07:47:48.627 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E10-FKKTV\Unsere.kleine.Farm.S04E10.Der.Preisboxer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.628 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E10-FKKTV\Unsere.kleine.Farm.S04E10.Der.Preisboxer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E10 - Der Preisboxer.mkv 2022-04-13 07:47:48.897 Info App: Beginning Episode Organization 2022-04-13 07:47:48.897 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E04-FKKTV\Unsere.kleine.Farm.S08E04.Der.schwarze.Gelehrte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:48.898 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E04-FKKTV\Unsere.kleine.Farm.S08E04.Der.schwarze.Gelehrte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E04 - Der schwarze Gelehrte.mkv 2022-04-13 07:47:49.141 Info App: Beginning Episode Organization 2022-04-13 07:47:49.141 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E13-FKKTV\Unsere.kleine.Farm.S07E13.Nellies.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.142 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E13-FKKTV\Unsere.kleine.Farm.S07E13.Nellies.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E13 - Nellies Baby.mkv 2022-04-13 07:47:49.384 Info App: Beginning Episode Organization 2022-04-13 07:47:49.384 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E02-FKKTV\Unsere.kleine.Farm.S04E02.Die.Zeiten.aendern.sich.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.385 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E02-FKKTV\Unsere.kleine.Farm.S04E02.Die.Zeiten.aendern.sich.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E02 - Die Zeiten ändern sich.mkv 2022-04-13 07:47:49.627 Info App: Beginning Episode Organization 2022-04-13 07:47:49.627 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E15-FKKTV\Unsere.kleine.Farm.S05E15.Der.Kunsttischler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.628 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E15-FKKTV\Unsere.kleine.Farm.S05E15.Der.Kunsttischler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E15 - Der Kunsttischler.mkv 2022-04-13 07:47:49.906 Info App: Beginning Episode Organization 2022-04-13 07:47:49.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E23-FKKTV\Unsere.kleine.Farm.S01E23.Die.grosse.weite.Welt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e23.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:49.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E23-FKKTV\Unsere.kleine.Farm.S01E23.Die.grosse.weite.Welt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e23.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E23 - Die große, weite Welt.mkv 2022-04-13 07:47:50.167 Info App: Beginning Episode Organization 2022-04-13 07:47:50.167 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E21-FKKTV\Unsere.kleine.Farm.S04E21.Mary.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.168 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E21-FKKTV\Unsere.kleine.Farm.S04E21.Mary.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E21 - Mary (1).mkv 2022-04-13 07:47:50.437 Info App: Beginning Episode Organization 2022-04-13 07:47:50.437 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E21-FKKTV\Unsere.kleine.Farm.S06E21.Mr.Olesons.zweiter.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.438 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E21-FKKTV\Unsere.kleine.Farm.S06E21.Mr.Olesons.zweiter.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E21 - Mr. Olesons zweiter Frühling.mkv 2022-04-13 07:47:50.700 Info App: Beginning Episode Organization 2022-04-13 07:47:50.700 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E16-FKKTV\Unsere.kleine.Farm.S02E16.Abenteuerliche.Fahrt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.701 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E16-FKKTV\Unsere.kleine.Farm.S02E16.Abenteuerliche.Fahrt.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E16 - Abenteuerliche Fahrt.mkv 2022-04-13 07:47:50.943 Info App: Beginning Episode Organization 2022-04-13 07:47:50.943 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E12-FKKTV\Unsere.kleine.Farm.S01E12.Der.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:50.943 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E12-FKKTV\Unsere.kleine.Farm.S01E12.Der.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E12 - Der Preis.mkv 2022-04-13 07:47:51.254 Info App: Beginning Episode Organization 2022-04-13 07:47:51.254 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E07-FKKTV\Unsere.kleine.Farm.S03E07.Grossvater.kehrt.heim.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:51.255 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E07-FKKTV\Unsere.kleine.Farm.S03E07.Grossvater.kehrt.heim.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E07 - Großvater kehrt heim (2).mkv 2022-04-13 07:47:51.503 Info App: Beginning Episode Organization 2022-04-13 07:47:51.503 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E10-FKKTV\Unsere.kleine.Farm.S08E10.Die.Restaurantkette.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:51.504 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E10-FKKTV\Unsere.kleine.Farm.S08E10.Die.Restaurantkette.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E10 - Die Restaurantkette.mkv 2022-04-13 07:47:51.779 Info App: Beginning Episode Organization 2022-04-13 07:47:51.779 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E10-FKKTV\Unsere.kleine.Farm.S02E10.Am.Ende.des.Regenbogens.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:51.780 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E10-FKKTV\Unsere.kleine.Farm.S02E10.Am.Ende.des.Regenbogens.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E10 - Am Ende des Regenbogens.mkv 2022-04-13 07:47:52.053 Info App: Beginning Episode Organization 2022-04-13 07:47:52.053 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E16-FKKTV\Unsere.kleine.Farm.S07E16.Auf.Wiedersehen.Mrs.Wilder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.054 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E16-FKKTV\Unsere.kleine.Farm.S07E16.Auf.Wiedersehen.Mrs.Wilder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E16 - Auf Wiedersehen Mrs. Wilder.mkv 2022-04-13 07:47:52.303 Info App: Beginning Episode Organization 2022-04-13 07:47:52.303 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E01-FKKTV\Unsere.kleine.Farm.S03E01.Der.Mann.des.Himmels.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.355 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E01-FKKTV\Unsere.kleine.Farm.S03E01.Der.Mann.des.Himmels.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E01 - Der Mann des Himmels.mkv 2022-04-13 07:47:52.611 Info App: Beginning Episode Organization 2022-04-13 07:47:52.611 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E02-FKKTV\Unsere.kleine.Farm.S08E02.Die.neue.Nellie.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.612 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E02-FKKTV\Unsere.kleine.Farm.S08E02.Die.neue.Nellie.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E02 - Die neue Nellie (2).mkv 2022-04-13 07:47:52.866 Info App: Beginning Episode Organization 2022-04-13 07:47:52.866 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E24-FKKTV\Unsere.kleine.Farm.S06E24.Er.liebt.mich.er.liebt.mich.nicht.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e24.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:52.867 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E24-FKKTV\Unsere.kleine.Farm.S06E24.Er.liebt.mich.er.liebt.mich.nicht.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e24.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E24 - Er liebt mich, er liebt mich nicht (2).mkv 2022-04-13 07:47:53.135 Info App: Beginning Episode Organization 2022-04-13 07:47:53.135 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E17-FKKTV\Unsere.kleine.Farm.S06E17.Freundschaft.ohne.Worte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.135 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E17-FKKTV\Unsere.kleine.Farm.S06E17.Freundschaft.ohne.Worte.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E17 - Freundschaft ohne Worte.mkv 2022-04-13 07:47:53.376 Info App: Beginning Episode Organization 2022-04-13 07:47:53.376 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E10-FKKTV\Unsere.kleine.Farm.S07E10.Das.Licht.des.Himmels.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.376 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E10-FKKTV\Unsere.kleine.Farm.S07E10.Das.Licht.des.Himmels.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E10 - Das Licht des Himmels (1).mkv 2022-04-13 07:47:53.646 Info App: Beginning Episode Organization 2022-04-13 07:47:53.646 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E13-FKKTV\Unsere.kleine.Farm.S05E13.Die.Reise.nach.Walnut.Grove.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.647 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E13-FKKTV\Unsere.kleine.Farm.S05E13.Die.Reise.nach.Walnut.Grove.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E13 - Die Reise nach Walnut Grove (2).mkv 2022-04-13 07:47:53.880 Info App: Beginning Episode Organization 2022-04-13 07:47:53.880 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E07-FKKTV\Unsere.kleine.Farm.S02E07.Der.Fruehlingstanz.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:53.881 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E07-FKKTV\Unsere.kleine.Farm.S02E07.Der.Fruehlingstanz.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E07 - Mit einem Lächeln.mkv 2022-04-13 07:47:54.125 Info App: Beginning Episode Organization 2022-04-13 07:47:54.125 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E22-FKKTV\Unsere.kleine.Farm.S02E22.Zurueck.nach.Wisconsin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.126 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E22-FKKTV\Unsere.kleine.Farm.S02E22.Zurueck.nach.Wisconsin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E22 - Zurück nach Wisconsin.mkv 2022-04-13 07:47:54.398 Info App: Beginning Episode Organization 2022-04-13 07:47:54.398 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E20-FKKTV\Unsere.kleine.Farm.S01E20.Graham.hat.Sorgen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.399 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E20-FKKTV\Unsere.kleine.Farm.S01E20.Graham.hat.Sorgen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E20 - Graham hat Sorgen.mkv 2022-04-13 07:47:54.672 Info App: Beginning Episode Organization 2022-04-13 07:47:54.672 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E07-FKKTV\Unsere.kleine.Farm.S07E07.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.672 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E07-FKKTV\Unsere.kleine.Farm.S07E07.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E07 - Lauras Eifersucht.mkv 2022-04-13 07:47:54.923 Info App: Beginning Episode Organization 2022-04-13 07:47:54.923 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E11-FKKTV\Unsere.kleine.Farm.S06E11.Der.Grossvater.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:54.923 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E11-FKKTV\Unsere.kleine.Farm.S06E11.Der.Grossvater.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E11 - Der Großvater.mkv 2022-04-13 07:47:55.199 Info App: Beginning Episode Organization 2022-04-13 07:47:55.200 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E22-FKKTV\Unsere.kleine.Farm.S07E22.Die.Waisenkinder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.200 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E22-FKKTV\Unsere.kleine.Farm.S07E22.Die.Waisenkinder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E22 - Die Waisenkinder (2).mkv 2022-04-13 07:47:55.441 Info App: Beginning Episode Organization 2022-04-13 07:47:55.441 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E01-FKKTV\Unsere.kleine.Farm.S02E01.Der.reichste.Mann.in.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.442 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E01-FKKTV\Unsere.kleine.Farm.S02E01.Der.reichste.Mann.in.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E01 - Der reichste Mann in Walnut Grove.mkv 2022-04-13 07:47:55.709 Info App: Beginning Episode Organization 2022-04-13 07:47:55.709 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E09-FKKTV\Unsere.kleine.Farm.S01E09.Die.Aushilfslehrerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.709 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E09-FKKTV\Unsere.kleine.Farm.S01E09.Die.Aushilfslehrerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E09 - Die Aushilfslehrerin.mkv 2022-04-13 07:47:55.972 Info App: Beginning Episode Organization 2022-04-13 07:47:55.972 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E04-FKKTV\Unsere.kleine.Farm.S03E04.Ein.kleines.Maedchen.geht.verloren.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:55.973 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E04-FKKTV\Unsere.kleine.Farm.S03E04.Ein.kleines.Maedchen.geht.verloren.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E04 - Ein kleines Mädchen geht verloren.mkv 2022-04-13 07:47:56.254 Info App: Beginning Episode Organization 2022-04-13 07:47:56.254 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E01-FKKTV\Unsere.kleine.Farm.S07E01.Laura.und.Almanzo.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:56.254 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E01-FKKTV\Unsere.kleine.Farm.S07E01.Laura.und.Almanzo.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E01 - Laura und Almanzo (1).mkv 2022-04-13 07:47:56.530 Info App: Beginning Episode Organization 2022-04-13 07:47:56.530 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E21-FKKTV\Unsere.kleine.Farm.S05E21.Licht.und.Schatten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:56.531 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E21-FKKTV\Unsere.kleine.Farm.S05E21.Licht.und.Schatten.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E21 - Licht und Schatten.mkv 2022-04-13 07:47:56.802 Info App: Beginning Episode Organization 2022-04-13 07:47:56.802 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E16-FKKTV\Unsere.kleine.Farm.S05E16.Der.kleine.Schwindler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:56.802 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E16-FKKTV\Unsere.kleine.Farm.S05E16.Der.kleine.Schwindler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E16 - Der kleine Schwindler.mkv 2022-04-13 07:47:57.081 Info App: Beginning Episode Organization 2022-04-13 07:47:57.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E22-FKKTV\Unsere.kleine.Farm.S04E22.Mary.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.082 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E22-FKKTV\Unsere.kleine.Farm.S04E22.Mary.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E22 - Mary (2).mkv 2022-04-13 07:47:57.345 Info App: Beginning Episode Organization 2022-04-13 07:47:57.345 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E22-FKKTV\Unsere.kleine.Farm.S06E22.Mit.16.faengt.das.Leben.an.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.345 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E22-FKKTV\Unsere.kleine.Farm.S06E22.Mit.16.faengt.das.Leben.an.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E22 - Mit 16 fängt das Leben an.mkv 2022-04-13 07:47:57.593 Info App: Beginning Episode Organization 2022-04-13 07:47:57.593 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E14-FKKTV\Unsere.kleine.Farm.S06E14.Der.Werwolf.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.594 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E14-FKKTV\Unsere.kleine.Farm.S06E14.Der.Werwolf.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E14 - Der Werwolf von Walnut Grove.mkv 2022-04-13 07:47:57.863 Info App: Beginning Episode Organization 2022-04-13 07:47:57.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E19-FKKTV\Unsere.kleine.Farm.S04E19.Glueckliches.Landleben.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:57.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E19-FKKTV\Unsere.kleine.Farm.S04E19.Glueckliches.Landleben.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E19 - Glückliches Landleben.mkv 2022-04-13 07:47:58.171 Info App: Beginning Episode Organization 2022-04-13 07:47:58.171 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E10-FKKTV\Unsere.kleine.Farm.S05E10.Vaeter.und.Soehne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.171 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E10-FKKTV\Unsere.kleine.Farm.S05E10.Vaeter.und.Soehne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E10 - Väter und Söhne.mkv 2022-04-13 07:47:58.403 Info App: Beginning Episode Organization 2022-04-13 07:47:58.403 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E04-FKKTV\Unsere.kleine.Farm.S02E04.Walnut.Grove.gegen.Sleepy.Eye.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.403 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E04-FKKTV\Unsere.kleine.Farm.S02E04.Walnut.Grove.gegen.Sleepy.Eye.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E04 - Walnut Grove gegen Sleepy Eye.mkv 2022-04-13 07:47:58.658 Info App: Beginning Episode Organization 2022-04-13 07:47:58.658 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E08-FKKTV\Unsere.kleine.Farm.S06E08.Zeig.mir.den.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.658 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E08-FKKTV\Unsere.kleine.Farm.S06E08.Zeig.mir.den.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E08 - Zeig mir den Weg.mkv 2022-04-13 07:47:58.920 Info App: Beginning Episode Organization 2022-04-13 07:47:58.920 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E04-FKKTV\Unsere.kleine.Farm.S07E04.Der.Football.Trainer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:58.921 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E04-FKKTV\Unsere.kleine.Farm.S07E04.Der.Football.Trainer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E04 - Der Football-Trainer.mkv 2022-04-13 07:47:59.209 Info App: Beginning Episode Organization 2022-04-13 07:47:59.209 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E09-FKKTV\Unsere.kleine.Farm.S05E09.Die.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:59.209 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E09-FKKTV\Unsere.kleine.Farm.S05E09.Die.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E09 - Die Hochzeit.mkv 2022-04-13 07:47:59.472 Info App: Beginning Episode Organization 2022-04-13 07:47:59.472 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E13E14-FKKTV\Unsere.kleine.Farm.S01E13E14.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e13e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:59.473 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E13E14-FKKTV\Unsere.kleine.Farm.S01E13E14.Lauras.Eifersucht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e13e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E13-E14 - Lauras Eifersucht (1), Lauras Eifersucht (2).mkv 2022-04-13 07:47:59.729 Info App: Beginning Episode Organization 2022-04-13 07:47:59.729 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E24-FKKTV\Unsere.kleine.Farm.S05E24.Die.Reise.ans.Meer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e24.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:47:59.729 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E24-FKKTV\Unsere.kleine.Farm.S05E24.Die.Reise.ans.Meer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e24.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E24 - Die Reise ans Meer.mkv 2022-04-13 07:48:00.021 Info App: Beginning Episode Organization 2022-04-13 07:48:00.021 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E02-FKKTV\Unsere.kleine.Farm.S03E02.Mein.Pferd.Bunny.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.022 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E02-FKKTV\Unsere.kleine.Farm.S03E02.Mein.Pferd.Bunny.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E02 - Mein Pferd Bunny.mkv 2022-04-13 07:48:00.277 Info App: Beginning Episode Organization 2022-04-13 07:48:00.277 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E05-FKKTV\Unsere.kleine.Farm.S06E05.Annabelle.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.278 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E05-FKKTV\Unsere.kleine.Farm.S06E05.Annabelle.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E05 - Annabelle.mkv 2022-04-13 07:48:00.526 Info App: Beginning Episode Organization 2022-04-13 07:48:00.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E18-FKKTV\Unsere.kleine.Farm.S03E18.Solomons.Weisheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.527 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E18-FKKTV\Unsere.kleine.Farm.S03E18.Solomons.Weisheit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E18 - Solomons Weisheit.mkv 2022-04-13 07:48:00.776 Info App: Beginning Episode Organization 2022-04-13 07:48:00.776 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E19-FKKTV\Unsere.kleine.Farm.S02E19.Ein.Geschenk.fuer.Mutter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:00.777 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E19-FKKTV\Unsere.kleine.Farm.S02E19.Ein.Geschenk.fuer.Mutter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E19 - Ein Geschenk für Mutter.mkv 2022-04-13 07:48:01.021 Info App: Beginning Episode Organization 2022-04-13 07:48:01.021 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E12-FKKTV\Unsere.kleine.Farm.S06E12.Falsch.verbunden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.021 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E12-FKKTV\Unsere.kleine.Farm.S06E12.Falsch.verbunden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E12 - Falsch verbunden.mkv 2022-04-13 07:48:01.270 Info App: Beginning Episode Organization 2022-04-13 07:48:01.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E02-FKKTV\Unsere.kleine.Farm.S02E02.Brillenschlange.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E02-FKKTV\Unsere.kleine.Farm.S02E02.Brillenschlange.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E02 - Brillenschlange.mkv 2022-04-13 07:48:01.538 Info App: Beginning Episode Organization 2022-04-13 07:48:01.538 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E15-FKKTV\Unsere.kleine.Farm.S03E15.Indianerfreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.540 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E15-FKKTV\Unsere.kleine.Farm.S03E15.Indianerfreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E15 - Indianerfreunde.mkv 2022-04-13 07:48:01.771 Info App: Beginning Episode Organization 2022-04-13 07:48:01.771 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E19-FKKTV\Unsere.kleine.Farm.S07E19.Adam.in.Not.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:01.771 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E19-FKKTV\Unsere.kleine.Farm.S07E19.Adam.in.Not.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E19 - Adam in Not.mkv 2022-04-13 07:48:02.006 Info App: Beginning Episode Organization 2022-04-13 07:48:02.006 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E02-FKKTV\Unsere.kleine.Farm.S07E02.Laura.und.Almanzo.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.007 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E02-FKKTV\Unsere.kleine.Farm.S07E02.Laura.und.Almanzo.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E02 - Laura und Almanzo (2).mkv 2022-04-13 07:48:02.272 Info App: Beginning Episode Organization 2022-04-13 07:48:02.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E08-FKKTV\Unsere.kleine.Farm.S04E08.Die.Kopfgeldjaeger.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E08-FKKTV\Unsere.kleine.Farm.S04E08.Die.Kopfgeldjaeger.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E08 - Die Kopfgeldjäger.mkv 2022-04-13 07:48:02.538 Info App: Beginning Episode Organization 2022-04-13 07:48:02.538 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E22-FKKTV\Unsere.kleine.Farm.S05E22.Ein.kleines.bisschen.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.539 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E22-FKKTV\Unsere.kleine.Farm.S05E22.Ein.kleines.bisschen.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E22 - Ein kleines bißchen Liebe.mkv 2022-04-13 07:48:02.804 Info App: Beginning Episode Organization 2022-04-13 07:48:02.804 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E03-FKKTV\Unsere.kleine.Farm.S06E03.Der.Stammbaum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:02.805 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E03-FKKTV\Unsere.kleine.Farm.S06E03.Der.Stammbaum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E03 - Der Stammbaum.mkv 2022-04-13 07:48:03.080 Info App: Beginning Episode Organization 2022-04-13 07:48:03.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E07-FKKTV\Unsere.kleine.Farm.S01E07.Meine.Party.deine.Party.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E07-FKKTV\Unsere.kleine.Farm.S01E07.Meine.Party.deine.Party.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E07 - Meine Party - deine Party.mkv 2022-04-13 07:48:03.333 Info App: Beginning Episode Organization 2022-04-13 07:48:03.333 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E05-FKKTV\Unsere.kleine.Farm.S04E05.Ein.Welpe.fuer.Andy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.333 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E05-FKKTV\Unsere.kleine.Farm.S04E05.Ein.Welpe.fuer.Andy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E05 - Ein Welpe für Andy.mkv 2022-04-13 07:48:03.577 Info App: Beginning Episode Organization 2022-04-13 07:48:03.577 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E18-FKKTV\Unsere.kleine.Farm.S01E18.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.577 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E18-FKKTV\Unsere.kleine.Farm.S01E18.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E18 - Die Seuche.mkv 2022-04-13 07:48:03.850 Info App: Beginning Episode Organization 2022-04-13 07:48:03.850 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E01-FKKTV\Unsere.kleine.Farm.S01E01.Das.neue.Land.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:03.850 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E01-FKKTV\Unsere.kleine.Farm.S01E01.Das.neue.Land.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E01 - Das neue Land.mkv 2022-04-13 07:48:04.118 Info App: Beginning Episode Organization 2022-04-13 07:48:04.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E08-FKKTV\Unsere.kleine.Farm.S08E08.Chicago.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E08-FKKTV\Unsere.kleine.Farm.S08E08.Chicago.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E08 - Chicago.mkv 2022-04-13 07:48:04.349 Info App: Beginning Episode Organization 2022-04-13 07:48:04.349 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E13-FKKTV\Unsere.kleine.Farm.S03E13.Die.Epidemie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.349 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E13-FKKTV\Unsere.kleine.Farm.S03E13.Die.Epidemie.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E13 - Die Epidemie.mkv 2022-04-13 07:48:04.598 Info App: Beginning Episode Organization 2022-04-13 07:48:04.598 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E17-FKKTV\Unsere.kleine.Farm.S04E17.Zwei.Muetter.fuer.ein.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.598 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E17-FKKTV\Unsere.kleine.Farm.S04E17.Zwei.Muetter.fuer.ein.Baby.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E17 - Zwei Mütter für ein Baby.mkv 2022-04-13 07:48:04.845 Info App: Beginning Episode Organization 2022-04-13 07:48:04.845 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E15-FKKTV\Unsere.kleine.Farm.S01E15.Tausche.Pony.gegen.Ofen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:04.846 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E15-FKKTV\Unsere.kleine.Farm.S01E15.Tausche.Pony.gegen.Ofen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E15 - Tausche Pony gegen Ofen.mkv 2022-04-13 07:48:05.078 Info App: Beginning Episode Organization 2022-04-13 07:48:05.078 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E19-FKKTV\Unsere.kleine.Farm.S05E19.Das.Seeungeheuer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.079 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E19-FKKTV\Unsere.kleine.Farm.S05E19.Das.Seeungeheuer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E19 - Das Seeungeheuer.mkv 2022-04-13 07:48:05.337 Info App: Beginning Episode Organization 2022-04-13 07:48:05.337 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E06-FKKTV\Unsere.kleine.Farm.S06E06.Kirchliche.Trauung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.337 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E06-FKKTV\Unsere.kleine.Farm.S06E06.Kirchliche.Trauung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E06 - Kirchliche Trauung.mkv 2022-04-13 07:48:05.585 Info App: Beginning Episode Organization 2022-04-13 07:48:05.585 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E07-FKKTV\Unsere.kleine.Farm.S05E07.Mein.Kaelbchen.Fagin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.586 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E07-FKKTV\Unsere.kleine.Farm.S05E07.Mein.Kaelbchen.Fagin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E07 - Mein Kälbchen Fagin.mkv 2022-04-13 07:48:05.834 Info App: Beginning Episode Organization 2022-04-13 07:48:05.834 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E11-FKKTV\Unsere.kleine.Farm.S04E11.Das.Volksfest.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:05.835 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E11-FKKTV\Unsere.kleine.Farm.S04E11.Das.Volksfest.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E11 - Das Volksfest.mkv 2022-04-13 07:48:06.109 Info App: Beginning Episode Organization 2022-04-13 07:48:06.109 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E05-FKKTV\Unsere.kleine.Farm.S08E05.Die.Bildungsreise.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.110 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E05-FKKTV\Unsere.kleine.Farm.S08E05.Die.Bildungsreise.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E05 - Die Bildungsreise.mkv 2022-04-13 07:48:06.362 Info App: Beginning Episode Organization 2022-04-13 07:48:06.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E03-FKKTV\Unsere.kleine.Farm.S04E03.Der.Badeunfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.363 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E03-FKKTV\Unsere.kleine.Farm.S04E03.Der.Badeunfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E03 - Der Badeunfall.mkv 2022-04-13 07:48:06.613 Info App: Beginning Episode Organization 2022-04-13 07:48:06.613 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E04-FKKTV\Unsere.kleine.Farm.S01E04.Der.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.613 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E04-FKKTV\Unsere.kleine.Farm.S01E04.Der.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E04 - Der Freund.mkv 2022-04-13 07:48:06.859 Info App: Beginning Episode Organization 2022-04-13 07:48:06.859 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E01-FKKTV\Unsere.kleine.Farm.S05E01.Die.Stadt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:06.860 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E01-FKKTV\Unsere.kleine.Farm.S05E01.Die.Stadt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E01 - Die Stadt (1).mkv 2022-04-13 07:48:07.139 Info App: Beginning Episode Organization 2022-04-13 07:48:07.139 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E16-FKKTV\Unsere.kleine.Farm.S03E16.Die.Bedrohung.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.139 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E16-FKKTV\Unsere.kleine.Farm.S03E16.Die.Bedrohung.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E16 - Die Bedrohung (1).mkv 2022-04-13 07:48:07.400 Info App: Beginning Episode Organization 2022-04-13 07:48:07.401 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E17-FKKTV\Unsere.kleine.Farm.S02E17.Der.Stoerenfried.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.401 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E17-FKKTV\Unsere.kleine.Farm.S02E17.Der.Stoerenfried.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E17 - Der Störenfried.mkv 2022-04-13 07:48:07.636 Info App: Beginning Episode Organization 2022-04-13 07:48:07.636 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E10-FKKTV\Unsere.kleine.Farm.S03E10.Verletzt.in.der.Wildnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.637 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E10-FKKTV\Unsere.kleine.Farm.S03E10.Verletzt.in.der.Wildnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E10 - Verletzt in der Wildnis.mkv 2022-04-13 07:48:07.901 Info App: Beginning Episode Organization 2022-04-13 07:48:07.901 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E14-FKKTV\Unsere.kleine.Farm.S04E14.Rivalinnen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:07.901 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E14-FKKTV\Unsere.kleine.Farm.S04E14.Rivalinnen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E14 - Rivalinnen.mkv 2022-04-13 07:48:08.147 Info App: Beginning Episode Organization 2022-04-13 07:48:08.147 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E11-FKKTV\Unsere.kleine.Farm.S08E11.Eine.unvergessliche.Weihnacht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.147 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E11-FKKTV\Unsere.kleine.Farm.S08E11.Eine.unvergessliche.Weihnacht.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E11 - Eine unvergessliche Weihnacht.mkv 2022-04-13 07:48:08.402 Info App: Beginning Episode Organization 2022-04-13 07:48:08.402 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E11-FKKTV\Unsere.kleine.Farm.S02E11.Die.Wundermedizin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.403 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E11-FKKTV\Unsere.kleine.Farm.S02E11.Die.Wundermedizin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E11 - Die Wundermedizin.mkv 2022-04-13 07:48:08.670 Info App: Beginning Episode Organization 2022-04-13 07:48:08.670 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E17-FKKTV\Unsere.kleine.Farm.S07E17.Sylvia.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.670 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E17-FKKTV\Unsere.kleine.Farm.S07E17.Sylvia.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E17 - Sylvia (1).mkv 2022-04-13 07:48:08.947 Info App: Beginning Episode Organization 2022-04-13 07:48:08.947 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E06-FKKTV\Unsere.kleine.Farm.S04E06.Der.Dieb.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:08.948 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E06-FKKTV\Unsere.kleine.Farm.S04E06.Der.Dieb.von.Walnut.Grove.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E06 - Der Dieb von Walnut Grove.mkv 2022-04-13 07:48:09.221 Info App: Beginning Episode Organization 2022-04-13 07:48:09.221 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E04-FKKTV\Unsere.kleine.Farm.S05E04.Der.dicke.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:09.224 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E04-FKKTV\Unsere.kleine.Farm.S05E04.Der.dicke.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E04 - Der dicke Mann.mkv 2022-04-13 07:48:09.503 Info App: Beginning Episode Organization 2022-04-13 07:48:09.503 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E03-FKKTV\Unsere.kleine.Farm.S08E03.Kein.Platz.fuer.James.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:09.504 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E03-FKKTV\Unsere.kleine.Farm.S08E03.Kein.Platz.fuer.James.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E03 - Kein Platz für James.mkv 2022-04-13 07:48:09.676 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:48:09.679 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:48:09.695 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:48:09.698 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:48:09.780 Info App: Beginning Episode Organization 2022-04-13 07:48:09.780 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E02-FKKTV\Unsere.kleine.Farm.S01E02.Der.erste.Schultag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:09.780 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E02-FKKTV\Unsere.kleine.Farm.S01E02.Der.erste.Schultag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E02 - Der erste Schultag.mkv 2022-04-13 07:48:10.052 Info App: Beginning Episode Organization 2022-04-13 07:48:10.052 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E11-FKKTV\Unsere.kleine.Farm.S07E11.Das.Licht.des.Himmels.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.053 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E11-FKKTV\Unsere.kleine.Farm.S07E11.Das.Licht.des.Himmels.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E11 - Das Licht des Himmels (2).mkv 2022-04-13 07:48:10.305 Info App: Beginning Episode Organization 2022-04-13 07:48:10.305 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E08-FKKTV\Unsere.kleine.Farm.S03E08.Fred.der.Ziegenbock.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.305 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E08-FKKTV\Unsere.kleine.Farm.S03E08.Fred.der.Ziegenbock.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E08 - Fred, der Ziegenbock.mkv 2022-04-13 07:48:10.547 Info App: Beginning Episode Organization 2022-04-13 07:48:10.547 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E21-FKKTV\Unsere.kleine.Farm.S01E21.Goldene.Saat.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.548 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E21-FKKTV\Unsere.kleine.Farm.S01E21.Goldene.Saat.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E21 - Goldene Saat.mkv 2022-04-13 07:48:10.769 Info App: Beginning Episode Organization 2022-04-13 07:48:10.769 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E16-FKKTV\Unsere.kleine.Farm.S01E16.Ehekrach.bei.Oleson.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:10.770 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E16-FKKTV\Unsere.kleine.Farm.S01E16.Ehekrach.bei.Oleson.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E16 - Ehekrach bei Oleson.mkv 2022-04-13 07:48:11.013 Info App: Beginning Episode Organization 2022-04-13 07:48:11.013 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E14-FKKTV\Unsere.kleine.Farm.S02E14.Nur.Zweite.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.013 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E14-FKKTV\Unsere.kleine.Farm.S02E14.Nur.Zweite.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E14 - Nur Zweite.mkv 2022-04-13 07:48:11.261 Info App: Beginning Episode Organization 2022-04-13 07:48:11.261 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E12-FKKTV\Unsere.kleine.Farm.S04E12.Ein.Hoch.auf.die.Braeute.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.263 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E12-FKKTV\Unsere.kleine.Farm.S04E12.Ein.Hoch.auf.die.Braeute.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E12 - Ein Hoch auf die Bräute.mkv 2022-04-13 07:48:11.480 Info App: Beginning Episode Organization 2022-04-13 07:48:11.480 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E21E22-FKKTV\Unsere.kleine.Farm.S03E21E22.Goldsucher.unterwegs.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e21e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.481 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E21E22-FKKTV\Unsere.kleine.Farm.S03E21E22.Goldsucher.unterwegs.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e21e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E21-E22 - Goldsucher unterwegs (1), Goldsucher unterwegs (2).mkv 2022-04-13 07:48:11.740 Info App: Beginning Episode Organization 2022-04-13 07:48:11.740 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E10-FKKTV\Unsere.kleine.Farm.S01E10.Der.Waschbaer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:11.741 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E10-FKKTV\Unsere.kleine.Farm.S01E10.Der.Waschbaer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E10 - Der Waschbär.mkv 2022-04-13 07:48:12.011 Info App: Beginning Episode Organization 2022-04-13 07:48:12.011 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E05-FKKTV\Unsere.kleine.Farm.S03E05.Geisterstunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.011 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E05-FKKTV\Unsere.kleine.Farm.S03E05.Geisterstunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E05 - Geisterstunde.mkv 2022-04-13 07:48:12.288 Info App: Beginning Episode Organization 2022-04-13 07:48:12.288 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E18-FKKTV\Unsere.kleine.Farm.S06E18.Feuersbrunst.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.288 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E18-FKKTV\Unsere.kleine.Farm.S06E18.Feuersbrunst.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E18 - Die Feuersbrunst (1).mkv 2022-04-13 07:48:12.578 Info App: Beginning Episode Organization 2022-04-13 07:48:12.578 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E06-FKKTV\Unsere.kleine.Farm.S08E06.Der.grosse.Gambini.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.578 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E06-FKKTV\Unsere.kleine.Farm.S08E06.Der.grosse.Gambini.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E06 - Der große Gambini.mkv 2022-04-13 07:48:12.870 Info App: Beginning Episode Organization 2022-04-13 07:48:12.870 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E08-FKKTV\Unsere.kleine.Farm.S02E08.Mit.einem.Laecheln.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:12.871 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E08-FKKTV\Unsere.kleine.Farm.S02E08.Mit.einem.Laecheln.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E08 - Eine neue Familie.mkv 2022-04-13 07:48:13.157 Info App: Beginning Episode Organization 2022-04-13 07:48:13.157 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E14-FKKTV\Unsere.kleine.Farm.S07E14.Die.Neffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.158 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E14-FKKTV\Unsere.kleine.Farm.S07E14.Die.Neffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E14 - Die Neffen.mkv 2022-04-13 07:48:13.384 Info App: Beginning Episode Organization 2022-04-13 07:48:13.384 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E02-FKKTV\Unsere.kleine.Farm.S05E02.Die.Stadt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.384 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E02-FKKTV\Unsere.kleine.Farm.S05E02.Die.Stadt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E02 - Die Stadt (2).mkv 2022-04-13 07:48:13.631 Info App: Beginning Episode Organization 2022-04-13 07:48:13.631 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E17-FKKTV\Unsere.kleine.Farm.S05E17.Tobys.Romanze.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.632 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E17-FKKTV\Unsere.kleine.Farm.S05E17.Tobys.Romanze.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E17 - Tobys Romanze.mkv 2022-04-13 07:48:13.863 Info App: Beginning Episode Organization 2022-04-13 07:48:13.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E08-FKKTV\Unsere.kleine.Farm.S07E08.Brieffreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:13.864 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E08-FKKTV\Unsere.kleine.Farm.S07E08.Brieffreunde.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E08 - Brieffreunde.mkv 2022-04-13 07:48:14.139 Info App: Beginning Episode Organization 2022-04-13 07:48:14.139 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E24-FKKTV\Unsere.kleine.Farm.S01E24.Gruendungstag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e24.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.140 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E24-FKKTV\Unsere.kleine.Farm.S01E24.Gruendungstag.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e24.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E24 - Gründungstag.mkv 2022-04-13 07:48:14.390 Info App: Beginning Episode Organization 2022-04-13 07:48:14.390 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E23-FKKTV\Unsere.kleine.Farm.S06E23.Er.liebt.mich.er.liebt.mich.nicht.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e23.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.391 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E23-FKKTV\Unsere.kleine.Farm.S06E23.Er.liebt.mich.er.liebt.mich.nicht.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e23.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E23 - Er liebt mich, er liebt mich nicht (1).mkv 2022-04-13 07:48:14.645 Info App: Beginning Episode Organization 2022-04-13 07:48:14.645 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E15-FKKTV\Unsere.kleine.Farm.S06E15.Das.verdorbene.Klassentreffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.645 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E15-FKKTV\Unsere.kleine.Farm.S06E15.Das.verdorbene.Klassentreffen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E15 - Das verdorbene Klassentreffen.mkv 2022-04-13 07:48:14.929 Info App: Beginning Episode Organization 2022-04-13 07:48:14.929 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E11-FKKTV\Unsere.kleine.Farm.S05E11.Schummeleien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:14.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E11-FKKTV\Unsere.kleine.Farm.S05E11.Schummeleien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E11 - Schummeleien.mkv 2022-04-13 07:48:15.194 Info App: Beginning Episode Organization 2022-04-13 07:48:15.194 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E05-FKKTV\Unsere.kleine.Farm.S02E05.Das.verwunschene.Haus.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.194 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E05-FKKTV\Unsere.kleine.Farm.S02E05.Das.verwunschene.Haus.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E05 - Das verwunschene Haus.mkv 2022-04-13 07:48:15.439 Info App: Beginning Episode Organization 2022-04-13 07:48:15.439 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E09-FKKTV\Unsere.kleine.Farm.S06E09.Milos.letzter.Kampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.439 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E09-FKKTV\Unsere.kleine.Farm.S06E09.Milos.letzter.Kampf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E09 - Milos letzter Kampf.mkv 2022-04-13 07:48:15.705 Info App: Beginning Episode Organization 2022-04-13 07:48:15.705 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E20-FKKTV\Unsere.kleine.Farm.S02E20.Die.Jahrhundertfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.706 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E20-FKKTV\Unsere.kleine.Farm.S02E20.Die.Jahrhundertfeier.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E20 - Die Jahrhundertfeier.mkv 2022-04-13 07:48:15.930 Info App: Beginning Episode Organization 2022-04-13 07:48:15.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E05-FKKTV\Unsere.kleine.Farm.S07E05.Der.stumme.Schrei.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:15.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E05-FKKTV\Unsere.kleine.Farm.S07E05.Der.stumme.Schrei.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E05 - Der stumme Schrei.mkv 2022-04-13 07:48:16.189 Info App: Beginning Episode Organization 2022-04-13 07:48:16.189 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E12-FKKTV\Unsere.kleine.Farm.S08E12.Ein.echter.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.190 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E12-FKKTV\Unsere.kleine.Farm.S08E12.Ein.echter.Freund.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E12 - Ein echter Freund.mkv 2022-04-13 07:48:16.431 Info App: Beginning Episode Organization 2022-04-13 07:48:16.431 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E20-FKKTV\Unsere.kleine.Farm.S07E20.Die.zweite.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.432 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E20-FKKTV\Unsere.kleine.Farm.S07E20.Die.zweite.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E20 - Die zweite Hochzeit.mkv 2022-04-13 07:48:16.684 Info App: Beginning Episode Organization 2022-04-13 07:48:16.684 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E12-FKKTV\Unsere.kleine.Farm.S02E12.Das.Jagdgewehr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.684 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E12-FKKTV\Unsere.kleine.Farm.S02E12.Das.Jagdgewehr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E12 - Das Jagdgewehr.mkv 2022-04-13 07:48:16.922 Info App: Beginning Episode Organization 2022-04-13 07:48:16.922 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E03-FKKTV\Unsere.kleine.Farm.S03E03.Das.Rennen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:16.923 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E03-FKKTV\Unsere.kleine.Farm.S03E03.Das.Rennen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E03 - Das Rennen.mkv 2022-04-13 07:48:17.205 Info App: Beginning Episode Organization 2022-04-13 07:48:17.205 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E19-FKKTV\Unsere.kleine.Farm.S03E19.Die.Spieluhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.206 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E19-FKKTV\Unsere.kleine.Farm.S03E19.Die.Spieluhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E19 - Die Spieluhr.mkv 2022-04-13 07:48:17.478 Info App: Beginning Episode Organization 2022-04-13 07:48:17.478 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E12-FKKTV\Unsere.kleine.Farm.S07E12.Aufstand.der.Frauen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.478 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E12-FKKTV\Unsere.kleine.Farm.S07E12.Aufstand.der.Frauen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E12 - Aufstand der Frauen.mkv 2022-04-13 07:48:17.755 Info App: Beginning Episode Organization 2022-04-13 07:48:17.755 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E14-FKKTV\Unsere.kleine.Farm.S05E14.Die.Maerchenschwester.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.756 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E14-FKKTV\Unsere.kleine.Farm.S05E14.Die.Maerchenschwester.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E14 - Die Märchenschwester.mkv 2022-04-13 07:48:17.983 Info App: Beginning Episode Organization 2022-04-13 07:48:17.983 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E22-FKKTV\Unsere.kleine.Farm.S01E22.Schneesturm.im.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:17.984 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E22-FKKTV\Unsere.kleine.Farm.S01E22.Schneesturm.im.Fruehling.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E22 - Schneesturm im Frühling.mkv 2022-04-13 07:48:18.229 Info App: Beginning Episode Organization 2022-04-13 07:48:18.229 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E20-FKKTV\Unsere.kleine.Farm.S04E20.Das.schoenste.Geschenk.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:18.229 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E20-FKKTV\Unsere.kleine.Farm.S04E20.Das.schoenste.Geschenk.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E20 - Das schönste Geschenk.mkv 2022-04-13 07:48:18.491 Info App: Beginning Episode Organization 2022-04-13 07:48:18.491 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E20-FKKTV\Unsere.kleine.Farm.S06E20.Almanzos.Bruder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:18.491 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E20-FKKTV\Unsere.kleine.Farm.S06E20.Almanzos.Bruder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E20 - Almanzos Bruder.mkv 2022-04-13 07:48:18.763 Info App: Beginning Episode Organization 2022-04-13 07:48:18.763 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E13-FKKTV\Unsere.kleine.Farm.S06E13.Die.gestohlene.Uhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:18.764 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E13-FKKTV\Unsere.kleine.Farm.S06E13.Die.gestohlene.Uhr.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E13 - Die gestohlene Uhr.mkv 2022-04-13 07:48:19.015 Info App: Beginning Episode Organization 2022-04-13 07:48:19.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E03-FKKTV\Unsere.kleine.Farm.S02E03.Der.Geizhals.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E03-FKKTV\Unsere.kleine.Farm.S02E03.Der.Geizhals.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E03 - Der Geizhals.mkv 2022-04-13 07:48:19.265 Info App: Beginning Episode Organization 2022-04-13 07:48:19.265 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E06-FKKTV\Unsere.kleine.Farm.S03E06.Grossvater.kehrt.heim.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.265 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E06-FKKTV\Unsere.kleine.Farm.S03E06.Grossvater.kehrt.heim.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E06 - Großvater kehrt heim (1).mkv 2022-04-13 07:48:19.536 Info App: Beginning Episode Organization 2022-04-13 07:48:19.536 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E03-FKKTV\Unsere.kleine.Farm.S07E03.Hilfssheriff.wider.Willen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.537 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E03-FKKTV\Unsere.kleine.Farm.S07E03.Hilfssheriff.wider.Willen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E03 - Hilfssheriff wider Willen.mkv 2022-04-13 07:48:19.789 Info App: Beginning Episode Organization 2022-04-13 07:48:19.789 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E09-FKKTV\Unsere.kleine.Farm.S04E09.Ein.hoher.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:19.790 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E09-FKKTV\Unsere.kleine.Farm.S04E09.Ein.hoher.Preis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E09 - Ein hoher Preis.mkv 2022-04-13 07:48:20.036 Info App: Beginning Episode Organization 2022-04-13 07:48:20.036 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E23-FKKTV\Unsere.kleine.Farm.S05E23.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e23.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.037 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E23-FKKTV\Unsere.kleine.Farm.S05E23.Die.Seuche.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e23.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E23 - Die Seuche.mkv 2022-04-13 07:48:20.270 Info App: Beginning Episode Organization 2022-04-13 07:48:20.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E16-FKKTV\Unsere.kleine.Farm.S06E16.Der.Ueberfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.270 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E16-FKKTV\Unsere.kleine.Farm.S06E16.Der.Ueberfall.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E16 - Der Überfall.mkv 2022-04-13 07:48:20.502 Info App: Beginning Episode Organization 2022-04-13 07:48:20.502 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E19-FKKTV\Unsere.kleine.Farm.S01E19.Der.Gaukler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.503 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E19-FKKTV\Unsere.kleine.Farm.S01E19.Der.Gaukler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E19 - Der Gaukler.mkv 2022-04-13 07:48:20.790 Info App: Beginning Episode Organization 2022-04-13 07:48:20.790 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E12-FKKTV\Unsere.kleine.Farm.S05E12.Die.Reise.nach.Walnut.Grove.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:20.791 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E12-FKKTV\Unsere.kleine.Farm.S05E12.Die.Reise.nach.Walnut.Grove.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E12 - Die Reise nach Walnut Grove (1).mkv 2022-04-13 07:48:21.035 Info App: Beginning Episode Organization 2022-04-13 07:48:21.035 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E06-FKKTV\Unsere.kleine.Farm.S02E06.Der.Ausflug.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.035 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E06-FKKTV\Unsere.kleine.Farm.S02E06.Der.Ausflug.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E06 - Der Frühlingstanz.mkv 2022-04-13 07:48:21.315 Info App: Beginning Episode Organization 2022-04-13 07:48:21.315 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E06-FKKTV\Unsere.kleine.Farm.S07E06.Die.blinde.Malerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.318 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E06-FKKTV\Unsere.kleine.Farm.S07E06.Die.blinde.Malerin.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E06 - Die blinde Malerin.mkv 2022-04-13 07:48:21.557 Info App: Beginning Episode Organization 2022-04-13 07:48:21.557 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E10-FKKTV\Unsere.kleine.Farm.S06E10.Der.Wunderheiler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.558 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E10-FKKTV\Unsere.kleine.Farm.S06E10.Der.Wunderheiler.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E10 - Der Wunderheiler.mkv 2022-04-13 07:48:21.844 Info App: Beginning Episode Organization 2022-04-13 07:48:21.844 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E09-FKKTV\Unsere.kleine.Farm.S08E09.Aus.Liebe.zu.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:21.844 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E09-FKKTV\Unsere.kleine.Farm.S08E09.Aus.Liebe.zu.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E09 - Aus Liebe zu Nancy.mkv 2022-04-13 07:48:22.083 Info App: Beginning Episode Organization 2022-04-13 07:48:22.083 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E08-FKKTV\Unsere.kleine.Farm.S01E08.Mutter.macht.Ferien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.084 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E08-FKKTV\Unsere.kleine.Farm.S01E08.Mutter.macht.Ferien.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E08 - Mutter macht Ferien.mkv 2022-04-13 07:48:22.351 Info App: Beginning Episode Organization 2022-04-13 07:48:22.351 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E07-FKKTV\Unsere.kleine.Farm.S06E07.Alberts.Indianertraum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.352 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E07-FKKTV\Unsere.kleine.Farm.S06E07.Alberts.Indianertraum.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E07 - Alberts Indianertraum.mkv 2022-04-13 07:48:22.614 Info App: Beginning Episode Organization 2022-04-13 07:48:22.614 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E20-FKKTV\Unsere.kleine.Farm.S05E20.Spaetes.Gestaendnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.615 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E20-FKKTV\Unsere.kleine.Farm.S05E20.Spaetes.Gestaendnis.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E20 - Spätes Geständnis.mkv 2022-04-13 07:48:22.866 Info App: Beginning Episode Organization 2022-04-13 07:48:22.866 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E01-FKKTV\Unsere.kleine.Farm.S06E01.Schulanfang.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:22.867 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E01-FKKTV\Unsere.kleine.Farm.S06E01.Schulanfang.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E01 - Schulanfang (1).mkv 2022-04-13 07:48:23.101 Info App: Beginning Episode Organization 2022-04-13 07:48:23.101 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E05-FKKTV\Unsere.kleine.Farm.S01E05.Erste.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.102 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E05-FKKTV\Unsere.kleine.Farm.S01E05.Erste.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E05 - Erste Liebe.mkv 2022-04-13 07:48:23.388 Info App: Beginning Episode Organization 2022-04-13 07:48:23.388 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E18-FKKTV\Unsere.kleine.Farm.S04E18.Die.Erbschaft.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.389 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E18-FKKTV\Unsere.kleine.Farm.S04E18.Die.Erbschaft.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E18 - Die Erbschaft.mkv 2022-04-13 07:48:23.608 Info App: Beginning Episode Organization 2022-04-13 07:48:23.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E17-FKKTV\Unsere.kleine.Farm.S03E17.Die.Bedrohung.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E17-FKKTV\Unsere.kleine.Farm.S03E17.Die.Bedrohung.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E17 - Die Bedrohung (2).mkv 2022-04-13 07:48:23.863 Info App: Beginning Episode Organization 2022-04-13 07:48:23.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E08-FKKTV\Unsere.kleine.Farm.S05E08.Harriets.Klatschzeitung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:23.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E08-FKKTV\Unsere.kleine.Farm.S05E08.Harriets.Klatschzeitung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E08 - Harriets Klatschzeitung.mkv 2022-04-13 07:48:24.103 Info App: Beginning Episode Organization 2022-04-13 07:48:24.103 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E11-FKKTV\Unsere.kleine.Farm.S03E11.Wo.sind.die.Kinder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.104 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E11-FKKTV\Unsere.kleine.Farm.S03E11.Wo.sind.die.Kinder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E11 - Wo sind die Kinder.mkv 2022-04-13 07:48:24.347 Info App: Beginning Episode Organization 2022-04-13 07:48:24.347 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E15-FKKTV\Unsere.kleine.Farm.S04E15.Mary.geht.ihren.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.348 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E15-FKKTV\Unsere.kleine.Farm.S04E15.Mary.geht.ihren.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E15 - Mary geht ihren Weg.mkv 2022-04-13 07:48:24.608 Info App: Beginning Episode Organization 2022-04-13 07:48:24.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E04-FKKTV\Unsere.kleine.Farm.S06E04.Das.dritte.Wunder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS06E04-FKKTV\Unsere.kleine.Farm.S06E04.Das.dritte.Wunder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s06e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 06\Unsere kleine Farm - S06E04 - Das dritte Wunder.mkv 2022-04-13 07:48:24.855 Info App: Beginning Episode Organization 2022-04-13 07:48:24.855 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E07-FKKTV\Unsere.kleine.Farm.S04E07.Arzt.oder.Farmer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:24.855 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E07-FKKTV\Unsere.kleine.Farm.S04E07.Arzt.oder.Farmer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E07 - Arzt oder Farmer.mkv 2022-04-13 07:48:25.119 Info App: Beginning Episode Organization 2022-04-13 07:48:25.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E05-FKKTV\Unsere.kleine.Farm.S05E05.Heimweh.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.120 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS05E05-FKKTV\Unsere.kleine.Farm.S05E05.Heimweh.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s05e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 05\Unsere kleine Farm - S05E05 - Heimweh (1).mkv 2022-04-13 07:48:25.356 Info App: Beginning Episode Organization 2022-04-13 07:48:25.356 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E03-FKKTV\Unsere.kleine.Farm.S01E03.Weiter.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.357 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E03-FKKTV\Unsere.kleine.Farm.S01E03.Weiter.Weg.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E03 - Weiter Weg.mkv 2022-04-13 07:48:25.618 Info App: Beginning Episode Organization 2022-04-13 07:48:25.618 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E18-FKKTV\Unsere.kleine.Farm.S02E18.Der.lange.Weg.zurueck.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.619 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS02E18-FKKTV\Unsere.kleine.Farm.S02E18.Der.lange.Weg.zurueck.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s02e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 02\Unsere kleine Farm - S02E18 - Der lange Weg zurück.mkv 2022-04-13 07:48:25.875 Info App: Beginning Episode Organization 2022-04-13 07:48:25.875 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E01-FKKTV\Unsere.kleine.Farm.S04E01.Neue.Gesichter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:25.876 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS04E01-FKKTV\Unsere.kleine.Farm.S04E01.Neue.Gesichter.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s04e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 04\Unsere kleine Farm - S04E01 - Neue Gesichter.mkv 2022-04-13 07:48:26.120 Info App: Beginning Episode Organization 2022-04-13 07:48:26.120 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E09-FKKTV\Unsere.kleine.Farm.S03E09.Die.ungleichen.Brueder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.121 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E09-FKKTV\Unsere.kleine.Farm.S03E09.Die.ungleichen.Brueder.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E09 - Die ungleichen Brüder.mkv 2022-04-13 07:48:26.391 Info App: Beginning Episode Organization 2022-04-13 07:48:26.391 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E14-FKKTV\Unsere.kleine.Farm.S03E14.Die.Theaterauffuehrung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.392 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS03E14-FKKTV\Unsere.kleine.Farm.S03E14.Die.Theaterauffuehrung.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s03e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 03\Unsere kleine Farm - S03E14 - Die Theateraufführung.mkv 2022-04-13 07:48:26.642 Info App: Beginning Episode Organization 2022-04-13 07:48:26.642 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E17-FKKTV\Unsere.kleine.Farm.S01E17.Spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.643 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS01E17-FKKTV\Unsere.kleine.Farm.S01E17.Spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s01e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 01\Unsere kleine Farm - S01E17 - Späte Liebe.mkv 2022-04-13 07:48:26.951 Info App: Beginning Episode Organization 2022-04-13 07:48:26.951 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E18-FKKTV\Unsere.kleine.Farm.S07E18.Sylvia.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:26.951 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS07E18-FKKTV\Unsere.kleine.Farm.S07E18.Sylvia.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s07e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 07\Unsere kleine Farm - S07E18 - Sylvia (2).mkv 2022-04-13 07:48:27.222 Info App: Beginning Episode Organization 2022-04-13 07:48:27.222 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E15-FKKTV\Unsere.kleine.Farm.S08E15.Der.reiche.Onkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:27.222 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E15-FKKTV\Unsere.kleine.Farm.S08E15.Der.reiche.Onkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E15 - Der reiche Onkel.mkv 2022-04-13 07:48:27.471 Info App: Beginning Episode Organization 2022-04-13 07:48:27.471 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E05-FKKTV\Unsere.kleine.Farm.S09E05.Ein.kleiner.grosser.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e05.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:27.472 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E05-FKKTV\Unsere.kleine.Farm.S09E05.Ein.kleiner.grosser.Mann.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e05.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E05 - Ein kleiner, großer Mann.mkv 2022-04-13 07:48:28.207 Info App: Beginning Episode Organization 2022-04-13 07:48:28.207 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E03-FKKTV\Unsere.kleine.Farm.S09E03.Buergermeisterwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e03.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:28.207 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E03-FKKTV\Unsere.kleine.Farm.S09E03.Buergermeisterwahl.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e03.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E03 - Bürgermeisterwahl.mkv 2022-04-13 07:48:28.485 Info App: Beginning Episode Organization 2022-04-13 07:48:28.485 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E16-FKKTV\Unsere.kleine.Farm.S08E16.Ein.zweiter.Versuch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:28.486 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E16-FKKTV\Unsere.kleine.Farm.S08E16.Ein.zweiter.Versuch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E16 - Ein zweiter Versuch.mkv 2022-04-13 07:48:28.761 Info App: Beginning Episode Organization 2022-04-13 07:48:28.761 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E18-FKKTV\Unsere.kleine.Farm.S09E18.Kind.ohne.Namen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:28.761 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E18-FKKTV\Unsere.kleine.Farm.S09E18.Kind.ohne.Namen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E18 - Kind ohne Namen.mkv 2022-04-13 07:48:29.015 Info App: Beginning Episode Organization 2022-04-13 07:48:29.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E06-FKKTV\Unsere.kleine.Farm.S09E06.Der.wilde.Junge.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e06.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:29.015 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E06-FKKTV\Unsere.kleine.Farm.S09E06.Der.wilde.Junge.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e06.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E06 - Der wilde Junge (1).mkv 2022-04-13 07:48:29.271 Info App: Beginning Episode Organization 2022-04-13 07:48:29.271 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E15-FKKTV\Unsere.kleine.Farm.S09E15.Der.Autoren-Wettbewerb.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e15.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:29.272 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E15-FKKTV\Unsere.kleine.Farm.S09E15.Der.Autoren-Wettbewerb.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e15.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E15 - Der Autoren-Wettbewerb.mkv 2022-04-13 07:48:29.540 Info App: Beginning Episode Organization 2022-04-13 07:48:29.540 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E21-FKKTV\Unsere.kleine.Farm.S08E21.Warten.auf.ein.Wunder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:29.541 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E21-FKKTV\Unsere.kleine.Farm.S08E21.Warten.auf.ein.Wunder.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E21 - Warten auf ein Wunder (1).mkv 2022-04-13 07:48:29.831 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/10/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:29.953 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=1&Season=10 2022-04-13 07:48:30.463 Warn App: No provider metadata found for Unsere kleine Farm season 10 episode 1 2022-04-13 07:48:30.464 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 10 episode 1 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:48:30.735 Info App: Beginning Episode Organization 2022-04-13 07:48:30.735 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E13-FKKTV\Unsere.kleine.Farm.S09E13.Der.Patriarch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e13.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:30.735 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E13-FKKTV\Unsere.kleine.Farm.S09E13.Der.Patriarch.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e13.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E13 - Der Patriarch.mkv 2022-04-13 07:48:31.012 Info App: Beginning Episode Organization 2022-04-13 07:48:31.012 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E21-FKKTV\Unsere.kleine.Farm.S09E21.Universitaet.oder.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e21.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.012 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E21-FKKTV\Unsere.kleine.Farm.S09E21.Universitaet.oder.Hochzeit.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e21.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E21 - Universität oder Hochzeit.mkv 2022-04-13 07:48:31.262 Info App: Beginning Episode Organization 2022-04-13 07:48:31.262 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E16-FKKTV\Unsere.kleine.Farm.S09E16.Gift.fuer.den.Koerper.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e16.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.263 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E16-FKKTV\Unsere.kleine.Farm.S09E16.Gift.fuer.den.Koerper.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e16.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E16 - Gift für den Körper (1).mkv 2022-04-13 07:48:31.522 Info App: Beginning Episode Organization 2022-04-13 07:48:31.522 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E22-FKKTV\Unsere.kleine.Farm.S08E22.Warten.auf.ein.Wunder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.523 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E22-FKKTV\Unsere.kleine.Farm.S08E22.Warten.auf.ein.Wunder.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E22 - Warten auf ein Wunder (2).mkv 2022-04-13 07:48:31.824 Info App: Beginning Episode Organization 2022-04-13 07:48:31.824 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E19-FKKTV\Unsere.kleine.Farm.S08E19.Der.Patenonkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:31.825 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E19-FKKTV\Unsere.kleine.Farm.S08E19.Der.Patenonkel.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E19 - Der Patenonkel.mkv 2022-04-13 07:48:32.084 Info App: Beginning Episode Organization 2022-04-13 07:48:32.084 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E10-FKKTV\Unsere.kleine.Farm.S09E10.Edwards.spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e10.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:32.085 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E10-FKKTV\Unsere.kleine.Farm.S09E10.Edwards.spaete.Liebe.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e10.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E10 - Edwards späte Liebe.mkv 2022-04-13 07:48:32.360 Info App: Beginning Episode Organization 2022-04-13 07:48:32.360 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E09-FKKTV\Unsere.kleine.Farm.S09E09.Die.Eisenbahn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e09.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:32.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E09-FKKTV\Unsere.kleine.Farm.S09E09.Die.Eisenbahn.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e09.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E09 - Die Eisenbahn.mkv 2022-04-13 07:48:32.631 Info HttpClient: GET https://api.themoviedb.org/3/tv/1781/season/10/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:32.757 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0071007&Episode=3&Season=10 2022-04-13 07:48:33.275 Warn App: No provider metadata found for Unsere kleine Farm season 10 episode 3 2022-04-13 07:48:33.277 Error App: Error organizing file *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system Emby.AutoOrganize.Core.OrganizationException: Emby.AutoOrganize.Core.OrganizationException: No provider metadata found for Unsere kleine Farm season 10 episode 3 at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.CreateNewEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.GetMatchingEpisode(Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpiosdeNumber, FileOrganizationResult result, Nullable`1 premiereDate, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, Series series, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeEpisode(Nullable`1 requestToMoveFile, String sourcePath, String seriesName, Nullable`1 seriesYear, Nullable`1 seasonNumber, Nullable`1 episodeNumber, Nullable`1 endingEpisodeNumber, Nullable`1 premiereDate, AutoOrganizeOptions options, Boolean rememberCorrection, FileOrganizationResult result, CancellationToken cancellationToken) at Emby.AutoOrganize.Core.FileOrganization.EpisodeOrganizer.OrganizeFile(Nullable`1 requestToOverwriteExistingFile, String path, AutoOrganizeOptions options, CancellationToken cancellationToken) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 07:48:33.513 Info App: Beginning Episode Organization 2022-04-13 07:48:33.513 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E22-FKKTV\Unsere.kleine.Farm.S09E22.Neuankoemmlinge.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e22.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:33.513 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E22-FKKTV\Unsere.kleine.Farm.S09E22.Neuankoemmlinge.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e22.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E22 - Neuankömmlinge.mkv 2022-04-13 07:48:33.772 Info App: Beginning Episode Organization 2022-04-13 07:48:33.772 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E17-FKKTV\Unsere.kleine.Farm.S08E17.Vom.Schicksal.gebeutelt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:33.773 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E17-FKKTV\Unsere.kleine.Farm.S08E17.Vom.Schicksal.gebeutelt.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E17 - Vom Schicksal gebeutelt (1).mkv 2022-04-13 07:48:34.017 Info App: Beginning Episode Organization 2022-04-13 07:48:34.017 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E19-FKKTV\Unsere.kleine.Farm.S09E19.Der.letzte.Sommer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e19.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.018 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E19-FKKTV\Unsere.kleine.Farm.S09E19.Der.letzte.Sommer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e19.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E19 - Der letzte Sommer.mkv 2022-04-13 07:48:34.263 Info App: Beginning Episode Organization 2022-04-13 07:48:34.263 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E07-FKKTV\Unsere.kleine.Farm.S09E07.Der.wilde.Junge.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e07.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.265 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E07-FKKTV\Unsere.kleine.Farm.S09E07.Der.wilde.Junge.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e07.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E07 - Der wilde Junge (2).mkv 2022-04-13 07:48:34.516 Info App: Beginning Episode Organization 2022-04-13 07:48:34.516 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E01-FKKTV\Unsere.kleine.Farm.S09E01.Veraenderte.Zeiten.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e01.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.517 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E01-FKKTV\Unsere.kleine.Farm.S09E01.Veraenderte.Zeiten.Teil.1.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e01.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E01 - Veränderte Zeiten (1).mkv 2022-04-13 07:48:34.764 Info App: Beginning Episode Organization 2022-04-13 07:48:34.764 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E14-FKKTV\Unsere.kleine.Farm.S08E14.Ein.neuer.Beruf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:34.764 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E14-FKKTV\Unsere.kleine.Farm.S08E14.Ein.neuer.Beruf.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E14 - Ein neuer Beruf.mkv 2022-04-13 07:48:35.023 Info App: Beginning Episode Organization 2022-04-13 07:48:35.023 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E04-FKKTV\Unsere.kleine.Farm.S09E04.Ein.Mann.fuehlt.sich.schuldig.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e04.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.024 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E04-FKKTV\Unsere.kleine.Farm.S09E04.Ein.Mann.fuehlt.sich.schuldig.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e04.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E04 - Ein Mann fühlt sich schuldig.mkv 2022-04-13 07:48:35.295 Info App: Beginning Episode Organization 2022-04-13 07:48:35.295 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E02-FKKTV\Unsere.kleine.Farm.S09E02.Veraenderte.Zeiten.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e02.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.295 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E02-FKKTV\Unsere.kleine.Farm.S09E02.Veraenderte.Zeiten.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e02.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E02 - Veränderte Zeiten (2).mkv 2022-04-13 07:48:35.556 Info App: Beginning Episode Organization 2022-04-13 07:48:35.556 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E17-FKKTV\Unsere.kleine.Farm.S09E17.Gift.fuer.den.Koerper.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e17.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.557 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E17-FKKTV\Unsere.kleine.Farm.S09E17.Gift.fuer.den.Koerper.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e17.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E17 - Gift für den Körper (2).mkv 2022-04-13 07:48:35.826 Info App: Beginning Episode Organization 2022-04-13 07:48:35.826 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E11-FKKTV\Unsere.kleine.Farm.S09E11.Eine.Ueberraschung.fuer.Reverend.Alden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e11.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:35.827 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E11-FKKTV\Unsere.kleine.Farm.S09E11.Eine.Ueberraschung.fuer.Reverend.Alden.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e11.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E11 - Eine Überraschung für Reverend Alden.mkv 2022-04-13 07:48:36.059 Info App: Beginning Episode Organization 2022-04-13 07:48:36.059 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E14-FKKTV\Unsere.kleine.Farm.S09E14.Raeuber.sein.ist.schwer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e14.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.060 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E14-FKKTV\Unsere.kleine.Farm.S09E14.Raeuber.sein.ist.schwer.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e14.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E14 - Räuber sein ist schwer.mkv 2022-04-13 07:48:36.303 Info App: Beginning Episode Organization 2022-04-13 07:48:36.304 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E20-FKKTV\Unsere.kleine.Farm.S08E20.Ein.Hilferuf.aus.der.Ferne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.305 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E20-FKKTV\Unsere.kleine.Farm.S08E20.Ein.Hilferuf.aus.der.Ferne.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E20 - Ein Hilferuf aus der Ferne.mkv 2022-04-13 07:48:36.573 Info App: Beginning Episode Organization 2022-04-13 07:48:36.573 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E12-FKKTV\Unsere.kleine.Farm.S09E12.Doktor.Marvins.letzter.Patient.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e12.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.574 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E12-FKKTV\Unsere.kleine.Farm.S09E12.Doktor.Marvins.letzter.Patient.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e12.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E12 - Doktor Marvins letzter Patient.mkv 2022-04-13 07:48:36.852 Info App: Beginning Episode Organization 2022-04-13 07:48:36.852 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E20-FKKTV\Unsere.kleine.Farm.S09E20.Ein.ganz.besonderes.Maedchen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e20.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:36.852 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E20-FKKTV\Unsere.kleine.Farm.S09E20.Ein.ganz.besonderes.Maedchen.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e20.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E20 - Ein ganz besonderes Mädchen.mkv 2022-04-13 07:48:37.098 Info App: Beginning Episode Organization 2022-04-13 07:48:37.098 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E18-FKKTV\Unsere.kleine.Farm.S08E18.Vom.Schicksal.gebeutelt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e18.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:37.098 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS08E18-FKKTV\Unsere.kleine.Farm.S08E18.Vom.Schicksal.gebeutelt.Teil.2.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s08e18.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 08\Unsere kleine Farm - S08E18 - Vom Schicksal gebeutelt (2).mkv 2022-04-13 07:48:37.361 Info App: Beginning Episode Organization 2022-04-13 07:48:37.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E08-FKKTV\Unsere.kleine.Farm.S09E08.Nellie.und.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e08.mkv into series D:\Videos\Serien\Unsere kleine Farm (1974) 2022-04-13 07:48:37.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\#Unsere kleine Farm\72BD-UnserekleineFarmS09E08-FKKTV\Unsere.kleine.Farm.S09E08.Nellie.und.Nancy.German.DUBBED.DL.FS.720p.BluRay.x264-FKKTV\fkktv-lhotp720-s09e08.mkv to new path D:\Videos\Serien\Unsere kleine Farm (1974)\Staffel 09\Unsere kleine Farm - S09E08 - Nellie und Nancy.mkv 2022-04-13 07:48:37.609 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/164541/all/de.zip 2022-04-13 07:48:38.607 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:38.748 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=2 2022-04-13 07:48:39.290 Info App: Beginning Episode Organization 2022-04-13 07:48:39.290 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:39.290 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E05 - Sauber.mkv 2022-04-13 07:48:39.931 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:40.086 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=2 2022-04-13 07:48:40.631 Info App: Beginning Episode Organization 2022-04-13 07:48:40.631 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:40.632 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E04 - Das rote Notizbuch.mkv 2022-04-13 07:48:40.937 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:41.117 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=2 2022-04-13 07:48:42.679 Info App: Beginning Episode Organization 2022-04-13 07:48:42.679 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:42.679 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E03 - Einzelkämpfer.mkv 2022-04-13 07:48:42.933 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:43.098 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=2 2022-04-13 07:48:43.650 Info App: Beginning Episode Organization 2022-04-13 07:48:43.650 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:43.651 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E02 - Ausgeschlossen.mkv 2022-04-13 07:48:43.899 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:44.052 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=2 2022-04-13 07:48:44.231 Info App: Beginning Episode Organization 2022-04-13 07:48:44.231 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:44.231 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E06 - Hausfriedensbruch.mkv 2022-04-13 07:48:44.516 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:44.676 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=2 2022-04-13 07:48:45.215 Info App: Beginning Episode Organization 2022-04-13 07:48:45.215 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:45.216 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E10 - Falsche Fährte.mkv 2022-04-13 07:48:45.493 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:45.652 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=2 2022-04-13 07:48:45.832 Info App: Beginning Episode Organization 2022-04-13 07:48:45.832 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:45.832 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E09 - Die Mumie.mkv 2022-04-13 07:48:46.101 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:46.249 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=2 2022-04-13 07:48:46.785 Info App: Beginning Episode Organization 2022-04-13 07:48:46.785 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:46.786 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E08 - Heilung.mkv 2022-04-13 07:48:47.034 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:47.227 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=2 2022-04-13 07:48:47.754 Info App: Beginning Episode Organization 2022-04-13 07:48:47.754 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:47.755 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E07 - Der Fluch der Geister.mkv 2022-04-13 07:48:47.969 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:48.130 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=4 2022-04-13 07:48:48.316 Info App: Beginning Episode Organization 2022-04-13 07:48:48.316 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:48.317 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E18 - Klassentreffen.mkv 2022-04-13 07:48:48.865 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:49.018 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=4 2022-04-13 07:48:49.206 Info App: Beginning Episode Organization 2022-04-13 07:48:49.206 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:49.207 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E17 - Unter der Oberfläche.mkv 2022-04-13 07:48:49.436 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:49.578 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=4 2022-04-13 07:48:50.118 Info App: Beginning Episode Organization 2022-04-13 07:48:50.118 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:50.119 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E16 - Das schwarze Einhorn.mkv 2022-04-13 07:48:50.338 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:50.605 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=4 2022-04-13 07:48:51.143 Info App: Beginning Episode Organization 2022-04-13 07:48:51.143 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:51.144 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E15 - Hinter der Wand.mkv 2022-04-13 07:48:51.371 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:51.536 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=4 2022-04-13 07:48:51.727 Info App: Beginning Episode Organization 2022-04-13 07:48:51.727 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:51.728 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E19 - Verschüttet.mkv 2022-04-13 07:48:51.988 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:52.142 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=2 2022-04-13 07:48:53.031 Info App: Beginning Episode Organization 2022-04-13 07:48:53.031 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:53.031 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E01 - Auf der Flucht.mkv 2022-04-13 07:48:53.276 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:53.431 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=4 2022-04-13 07:48:53.985 Info App: Beginning Episode Organization 2022-04-13 07:48:53.985 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:53.986 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E22 - Der fünfte Beatle.mkv 2022-04-13 07:48:54.247 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:54.401 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=4 2022-04-13 07:48:54.958 Info App: Beginning Episode Organization 2022-04-13 07:48:54.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:54.959 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E21 - Najib.mkv 2022-04-13 07:48:55.186 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:55.349 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=4 2022-04-13 07:48:55.889 Info App: Beginning Episode Organization 2022-04-13 07:48:55.889 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:55.890 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E20 - Gleich nebenan.mkv 2022-04-13 07:48:56.136 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:56.338 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=2 2022-04-13 07:48:56.513 Info App: Beginning Episode Organization 2022-04-13 07:48:56.513 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:56.514 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E23 - Vendetta.mkv 2022-04-13 07:48:56.731 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:56.902 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=2 2022-04-13 07:48:56.954 Info App: Beginning Episode Organization 2022-04-13 07:48:56.954 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:56.955 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E22 - Unter dem Radar.mkv 2022-04-13 07:48:57.222 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:57.371 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=2 2022-04-13 07:48:57.569 Info App: Beginning Episode Organization 2022-04-13 07:48:57.569 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:57.570 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E21 - Das Spiel mit dem Tod.mkv 2022-04-13 07:48:57.810 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:58.002 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=2 2022-04-13 07:48:58.549 Info App: Beginning Episode Organization 2022-04-13 07:48:58.549 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:58.550 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E20 - Ausgesetzt.mkv 2022-04-13 07:48:58.813 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:58.977 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=1 2022-04-13 07:48:59.517 Info App: Beginning Episode Organization 2022-04-13 07:48:59.517 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:48:59.518 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E24 - Verdächtig.mkv 2022-04-13 07:48:59.771 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:48:59.922 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=1 2022-04-13 07:49:00.145 Info App: Beginning Episode Organization 2022-04-13 07:49:00.145 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:00.146 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E20 - Fischschuppen.mkv 2022-04-13 07:49:00.366 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:00.519 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=1 2022-04-13 07:49:01.054 Info App: Beginning Episode Organization 2022-04-13 07:49:01.054 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:01.055 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E21 - Wolframstahl.mkv 2022-04-13 07:49:01.292 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:01.449 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=1 2022-04-13 07:49:01.987 Info App: Beginning Episode Organization 2022-04-13 07:49:01.987 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:01.988 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E22 - Das Ende der Lügen.mkv 2022-04-13 07:49:02.221 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:02.380 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=1 2022-04-13 07:49:02.964 Info App: Beginning Episode Organization 2022-04-13 07:49:02.965 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:02.965 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E23 - Der Hauch des Todes.mkv 2022-04-13 07:49:03.190 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:03.346 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=2 2022-04-13 07:49:03.897 Info App: Beginning Episode Organization 2022-04-13 07:49:03.897 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:03.898 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E14 - Das Päckchen.mkv 2022-04-13 07:49:04.157 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:04.354 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=2 2022-04-13 07:49:04.900 Info App: Beginning Episode Organization 2022-04-13 07:49:04.900 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:04.900 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E13 - Sex, Lügen und Video.mkv 2022-04-13 07:49:05.145 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:05.303 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=2 2022-04-13 07:49:05.860 Info App: Beginning Episode Organization 2022-04-13 07:49:05.860 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:05.861 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E12 - Der Mann im Bunker.mkv 2022-04-13 07:49:06.114 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:06.277 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=2 2022-04-13 07:49:06.806 Info App: Beginning Episode Organization 2022-04-13 07:49:06.806 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:06.807 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E11 - In der Falle.mkv 2022-04-13 07:49:07.072 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:07.233 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=2 2022-04-13 07:49:07.779 Info App: Beginning Episode Organization 2022-04-13 07:49:07.779 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:07.779 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E15 - Späte Rache.mkv 2022-04-13 07:49:08.021 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:08.168 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=2 2022-04-13 07:49:08.727 Info App: Beginning Episode Organization 2022-04-13 07:49:08.727 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:08.727 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E19 - Diamantenfieber.mkv 2022-04-13 07:49:08.969 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:09.124 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=2 2022-04-13 07:49:09.664 Info App: Beginning Episode Organization 2022-04-13 07:49:09.664 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:09.665 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E18 - Feuerwerk.mkv 2022-04-13 07:49:09.677 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:49:09.680 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:49:09.701 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:49:09.703 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 2ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:49:09.907 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:10.057 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=2 2022-04-13 07:49:10.243 Info App: Beginning Episode Organization 2022-04-13 07:49:10.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:10.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E17 - Sinneswandel.mkv 2022-04-13 07:49:10.473 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/2/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:10.645 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=2 2022-04-13 07:49:11.188 Info App: Beginning Episode Organization 2022-04-13 07:49:11.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:11.189 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 2 (24 Folgen) german dl AC3 5.1 720p\abcde.HafueO.Staffel.2.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S02E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 02\Hawaii Five-0 - S02E16 - Die Abrechnung.mkv 2022-04-13 07:49:11.447 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:11.604 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=4 2022-04-13 07:49:12.136 Info App: Beginning Episode Organization 2022-04-13 07:49:12.136 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:12.137 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E14 - Reingelegt.mkv 2022-04-13 07:49:12.362 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:12.522 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=3 2022-04-13 07:49:13.075 Info App: Beginning Episode Organization 2022-04-13 07:49:13.075 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:13.076 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E11 - Steve Junior.mkv 2022-04-13 07:49:13.306 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:13.463 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=3 2022-04-13 07:49:14.011 Info App: Beginning Episode Organization 2022-04-13 07:49:14.011 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:14.012 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E23 - Mission Impossible.mkv 2022-04-13 07:49:14.269 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:14.418 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=3 2022-04-13 07:49:14.954 Info App: Beginning Episode Organization 2022-04-13 07:49:14.954 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:14.955 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E12 - Schatten und Licht.mkv 2022-04-13 07:49:15.217 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:15.433 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=3 2022-04-13 07:49:15.613 Info App: Beginning Episode Organization 2022-04-13 07:49:15.613 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:15.614 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E22 - Gefangen.mkv 2022-04-13 07:49:15.863 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:16.017 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=3 2022-04-13 07:49:16.074 Info App: Beginning Episode Organization 2022-04-13 07:49:16.074 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:16.075 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E24 - Kono.mkv 2022-04-13 07:49:16.302 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:16.464 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=4 2022-04-13 07:49:16.996 Info App: Beginning Episode Organization 2022-04-13 07:49:16.997 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:16.997 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E02 - Ray, Texas Ranger.mkv 2022-04-13 07:49:17.243 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:17.392 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=3 2022-04-13 07:49:17.930 Info App: Beginning Episode Organization 2022-04-13 07:49:17.930 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:17.931 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E09 - Kleine Beute.mkv 2022-04-13 07:49:18.167 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:18.312 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=4 2022-04-13 07:49:18.846 Info App: Beginning Episode Organization 2022-04-13 07:49:18.846 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:18.847 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E01 - Voller Einsatz.mkv 2022-04-13 07:49:19.078 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:19.289 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=3 2022-04-13 07:49:19.825 Info App: Beginning Episode Organization 2022-04-13 07:49:19.825 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:19.826 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E10 - Allzeit bereit.mkv 2022-04-13 07:49:20.083 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:20.283 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=3 2022-04-13 07:49:20.817 Info App: Beginning Episode Organization 2022-04-13 07:49:20.817 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:20.817 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E19 - Seemannsgarn.mkv 2022-04-13 07:49:21.056 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:21.217 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=3 2022-04-13 07:49:21.399 Info App: Beginning Episode Organization 2022-04-13 07:49:21.399 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:21.400 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E16 - Kein Wort.mkv 2022-04-13 07:49:21.668 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:21.872 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=3 2022-04-13 07:49:22.407 Info App: Beginning Episode Organization 2022-04-13 07:49:22.407 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:22.408 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E17 - Der zwölfte Mann.mkv 2022-04-13 07:49:22.679 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:22.850 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=3 2022-04-13 07:49:23.386 Info App: Beginning Episode Organization 2022-04-13 07:49:23.386 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:23.387 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E18 - Doppelleben.mkv 2022-04-13 07:49:23.683 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:23.878 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=3 2022-04-13 07:49:24.412 Info App: Beginning Episode Organization 2022-04-13 07:49:24.412 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:24.416 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E15 - Die verlorenen Hände.mkv 2022-04-13 07:49:24.641 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:24.809 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=3 2022-04-13 07:49:25.361 Info App: Beginning Episode Organization 2022-04-13 07:49:25.361 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:25.362 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E13 - Block A.mkv 2022-04-13 07:49:25.614 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:25.799 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=3 2022-04-13 07:49:26.345 Info App: Beginning Episode Organization 2022-04-13 07:49:26.345 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:26.346 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E21 - Hautnah.mkv 2022-04-13 07:49:26.578 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:26.734 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=3 2022-04-13 07:49:27.268 Info App: Beginning Episode Organization 2022-04-13 07:49:27.268 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:27.269 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E14 - Ein guter Freund.mkv 2022-04-13 07:49:27.541 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:27.824 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=3 2022-04-13 07:49:28.018 Info App: Beginning Episode Organization 2022-04-13 07:49:28.018 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:28.019 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E20 - Das Versprechen.mkv 2022-04-13 07:49:28.253 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:28.407 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=3 2022-04-13 07:49:28.592 Info App: Beginning Episode Organization 2022-04-13 07:49:28.592 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:28.593 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E02 - Ein alter Bekannter.mkv 2022-04-13 07:49:28.843 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:29.112 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=4 2022-04-13 07:49:29.655 Info App: Beginning Episode Organization 2022-04-13 07:49:29.655 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:29.656 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E08 - Ärger im Gepäck.mkv 2022-04-13 07:49:29.919 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:30.075 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=3 2022-04-13 07:49:30.616 Info App: Beginning Episode Organization 2022-04-13 07:49:30.616 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:30.616 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E03 - Zwei Männer, ein Boot.mkv 2022-04-13 07:49:30.915 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:31.062 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=4 2022-04-13 07:49:31.599 Info App: Beginning Episode Organization 2022-04-13 07:49:31.599 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:31.600 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E07 - Drei Männer und ein Baby.mkv 2022-04-13 07:49:31.834 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:31.985 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=4 2022-04-13 07:49:32.522 Info App: Beginning Episode Organization 2022-04-13 07:49:32.522 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:32.523 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E09 - Streng Geheim.mkv 2022-04-13 07:49:32.771 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:32.921 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=4 2022-04-13 07:49:33.460 Info App: Beginning Episode Organization 2022-04-13 07:49:33.460 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:33.461 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E12 - Auf Sand gebaut.mkv 2022-04-13 07:49:33.728 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:33.913 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=4 2022-04-13 07:49:34.467 Info App: Beginning Episode Organization 2022-04-13 07:49:34.468 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:34.468 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E11 - Bei Einbruch Mord.mkv 2022-04-13 07:49:34.714 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:34.991 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=3 2022-04-13 07:49:35.174 Info App: Beginning Episode Organization 2022-04-13 07:49:35.174 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:35.174 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E01 - Shelburne.mkv 2022-04-13 07:49:35.409 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:35.576 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=4 2022-04-13 07:49:36.130 Info App: Beginning Episode Organization 2022-04-13 07:49:36.130 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:36.131 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E04 - Bis dass der Tod.mkv 2022-04-13 07:49:36.384 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:36.540 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=3 2022-04-13 07:49:37.083 Info App: Beginning Episode Organization 2022-04-13 07:49:37.083 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:37.084 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E07 - Ahnungslos.mkv 2022-04-13 07:49:37.331 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:37.524 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=4 2022-04-13 07:49:38.056 Info App: Beginning Episode Organization 2022-04-13 07:49:38.056 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:38.057 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E03 - Die Ringe der Medici.mkv 2022-04-13 07:49:38.303 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:38.456 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=3 2022-04-13 07:49:38.995 Info App: Beginning Episode Organization 2022-04-13 07:49:38.995 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:38.996 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E08 - Mangosta.mkv 2022-04-13 07:49:39.252 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:39.410 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=3 2022-04-13 07:49:39.957 Info App: Beginning Episode Organization 2022-04-13 07:49:39.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:39.958 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E06 - Grace.mkv 2022-04-13 07:49:40.181 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:40.344 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=3 2022-04-13 07:49:40.525 Info App: Beginning Episode Organization 2022-04-13 07:49:40.525 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:40.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E04 - Der kopflose Reiter.mkv 2022-04-13 07:49:40.784 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/3/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:40.931 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=3 2022-04-13 07:49:41.479 Info App: Beginning Episode Organization 2022-04-13 07:49:41.479 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:41.480 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 3 (24 Folgen) german dl AC3 5.1 720p\bcdef.HafueO.Staffel.3.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S03E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 03\Hawaii Five-0 - S03E05 - Das Ritual.mkv 2022-04-13 07:49:41.724 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/4/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:41.888 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=4 2022-04-13 07:49:42.428 Info App: Beginning Episode Organization 2022-04-13 07:49:42.428 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:42.429 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 4 (22 Folgen) german dl AC3 5.1 720p\cdefg.HafueO.Staffel.4.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S04E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 04\Hawaii Five-0 - S04E05 - Spione.mkv 2022-04-13 07:49:42.653 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:42.666 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=9 2022-04-13 07:49:43.233 Info App: Beginning Episode Organization 2022-04-13 07:49:43.233 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:43.234 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E03 - Hitzewelle.mkv 2022-04-13 07:49:43.514 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:43.527 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=9 2022-04-13 07:49:44.080 Info App: Beginning Episode Organization 2022-04-13 07:49:44.080 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:44.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E02 - Der Mann, der vom Himmel fiel.mkv 2022-04-13 07:49:44.319 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:44.329 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=9 2022-04-13 07:49:44.864 Info App: Beginning Episode Organization 2022-04-13 07:49:44.864 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:44.865 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E01 - Der gigantische Kokon.mkv 2022-04-13 07:49:45.091 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/25?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:45.241 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=25&Season=5 2022-04-13 07:49:45.771 Info App: Beginning Episode Organization 2022-04-13 07:49:45.771 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E25.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:45.772 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E25.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E25 - Waikikikalypse.mkv 2022-04-13 07:49:46.401 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:46.411 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=9 2022-04-13 07:49:46.961 Info App: Beginning Episode Organization 2022-04-13 07:49:46.961 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:46.962 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E07 - Große Träume.mkv 2022-04-13 07:49:47.188 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:47.197 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=9 2022-04-13 07:49:48.091 Info App: Beginning Episode Organization 2022-04-13 07:49:48.091 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:48.092 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E06 - Nach eigenen Regeln.mkv 2022-04-13 07:49:48.354 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:48.365 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=9 2022-04-13 07:49:48.907 Info App: Beginning Episode Organization 2022-04-13 07:49:48.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:48.907 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E05 - Eine schaurige Nacht.mkv 2022-04-13 07:49:49.171 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:49.183 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=9 2022-04-13 07:49:49.734 Info App: Beginning Episode Organization 2022-04-13 07:49:49.734 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:49.735 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E04 - Aus der Versenkung.mkv 2022-04-13 07:49:50.000 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:50.165 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=5 2022-04-13 07:49:51.728 Info App: Beginning Episode Organization 2022-04-13 07:49:51.728 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:51.729 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E24 - Untergetaucht.mkv 2022-04-13 07:49:51.953 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:52.095 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=5 2022-04-13 07:49:52.645 Info App: Beginning Episode Organization 2022-04-13 07:49:52.646 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:52.647 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E19 - Haarscharf.mkv 2022-04-13 07:49:52.897 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:53.058 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=5 2022-04-13 07:49:54.188 Info App: Beginning Episode Organization 2022-04-13 07:49:54.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:54.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E18 - Gleiches Recht für alle.mkv 2022-04-13 07:49:54.449 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:54.620 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=5 2022-04-13 07:49:55.145 Info App: Beginning Episode Organization 2022-04-13 07:49:55.145 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:55.146 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E17 - Auf der Lauer.mkv 2022-04-13 07:49:55.385 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:55.589 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=5 2022-04-13 07:49:55.776 Info App: Beginning Episode Organization 2022-04-13 07:49:55.776 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:55.777 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E16 - Wer ist Melissa Armstrong.mkv 2022-04-13 07:49:56.004 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:56.160 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=5 2022-04-13 07:49:57.051 Info App: Beginning Episode Organization 2022-04-13 07:49:57.051 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:57.051 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E23 - Im Auge des Sturms.mkv 2022-04-13 07:49:57.287 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:57.456 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=5 2022-04-13 07:49:58.005 Info App: Beginning Episode Organization 2022-04-13 07:49:58.005 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:58.006 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E22 - Hangover.mkv 2022-04-13 07:49:58.299 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:58.478 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=5 2022-04-13 07:49:58.664 Info App: Beginning Episode Organization 2022-04-13 07:49:58.665 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:58.665 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E21 - Der King ist tot.mkv 2022-04-13 07:49:58.932 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:59.090 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=5 2022-04-13 07:49:59.617 Info App: Beginning Episode Organization 2022-04-13 07:49:59.617 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:49:59.617 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E20 - Verdächtig unverdächtig.mkv 2022-04-13 07:49:59.870 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:49:59.880 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=9 2022-04-13 07:50:00.418 Info App: Beginning Episode Organization 2022-04-13 07:50:00.418 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:00.418 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E08 - Streithähne.mkv 2022-04-13 07:50:00.665 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/21?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:00.674 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=21&Season=9 2022-04-13 07:50:01.218 Info App: Beginning Episode Organization 2022-04-13 07:50:01.218 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E21.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:01.218 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E21.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E21 - Katzenjammer.mkv 2022-04-13 07:50:01.479 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/20?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:01.489 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=20&Season=9 2022-04-13 07:50:02.037 Info App: Beginning Episode Organization 2022-04-13 07:50:02.037 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E20.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:02.038 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E20.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E20 - Von Hand zu Hand.mkv 2022-04-13 07:50:02.291 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:02.300 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=9 2022-04-13 07:50:02.488 Info App: Beginning Episode Organization 2022-04-13 07:50:02.488 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:02.488 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E19 - Der falsche Fensterputzer.mkv 2022-04-13 07:50:02.749 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:02.759 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=9 2022-04-13 07:50:03.298 Info App: Beginning Episode Organization 2022-04-13 07:50:03.299 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:03.299 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E18 - Schwiegermutter zu Besuch.mkv 2022-04-13 07:50:03.534 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/22?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:03.543 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=22&Season=9 2022-04-13 07:50:04.081 Info App: Beginning Episode Organization 2022-04-13 07:50:04.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E22.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:04.081 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E22.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E22 - Noelani.mkv 2022-04-13 07:50:04.328 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/23?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:04.337 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=23&Season=9 2022-04-13 07:50:04.526 Info App: Beginning Episode Organization 2022-04-13 07:50:04.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E23.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:04.526 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E23.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E23 - Mord ist Ihr Hobby.mkv 2022-04-13 07:50:04.806 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/24?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:04.821 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=24&Season=9 2022-04-13 07:50:05.009 Info App: Beginning Episode Organization 2022-04-13 07:50:05.009 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E24.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:05.010 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E24.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E24 - Die Schuldfrage.mkv 2022-04-13 07:50:05.256 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/25?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:05.267 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=25&Season=9 2022-04-13 07:50:05.816 Info App: Beginning Episode Organization 2022-04-13 07:50:05.816 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E25.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:05.816 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E25.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E25 - Das Leben geht weiter.mkv 2022-04-13 07:50:06.058 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:06.070 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=9 2022-04-13 07:50:06.608 Info App: Beginning Episode Organization 2022-04-13 07:50:06.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:06.609 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E17 - Zerrissen.mkv 2022-04-13 07:50:06.839 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:06.848 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=9 2022-04-13 07:50:07.397 Info App: Beginning Episode Organization 2022-04-13 07:50:07.397 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:07.398 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E12 - Ohana.mkv 2022-04-13 07:50:07.658 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:07.830 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=9 2022-04-13 07:50:08.379 Info App: Beginning Episode Organization 2022-04-13 07:50:08.379 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:08.380 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E11 - Der Anfang vom Ende.mkv 2022-04-13 07:50:08.641 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:08.652 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=9 2022-04-13 07:50:09.183 Info App: Beginning Episode Organization 2022-04-13 07:50:09.183 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:09.184 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E10 - Marokko.mkv 2022-04-13 07:50:09.446 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:09.460 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=9 2022-04-13 07:50:09.651 Info App: Beginning Episode Organization 2022-04-13 07:50:09.651 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:09.652 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E09 - Das letzte Kapitel.mkv 2022-04-13 07:50:09.698 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:50:09.702 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 4ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:50:09.721 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:50:09.724 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 3ms. http://citycobra89.dynaccess.de/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:50:09.884 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:09.895 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=9 2022-04-13 07:50:10.431 Info App: Beginning Episode Organization 2022-04-13 07:50:10.431 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:10.432 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E16 - Die tote Meerjungfrau.mkv 2022-04-13 07:50:10.689 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:10.698 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=9 2022-04-13 07:50:11.250 Info App: Beginning Episode Organization 2022-04-13 07:50:11.250 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:11.251 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E15 - Sturm im Paradies.mkv 2022-04-13 07:50:11.496 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:11.506 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=9 2022-04-13 07:50:12.065 Info App: Beginning Episode Organization 2022-04-13 07:50:12.065 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:12.066 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E14 - Ein Zeichen.mkv 2022-04-13 07:50:12.293 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/9/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:12.302 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=9 2022-04-13 07:50:12.863 Info App: Beginning Episode Organization 2022-04-13 07:50:12.863 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:12.864 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 9 (25 Folgen) german dl AC3 5.1 720p\mmm.HafueO.Staffel.9.25.Folgen.german.dl.AC3.51.720p.tvs.Santa.Archiv.Reup\Hawaii Five-0 (2010) - S09E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 09\Hawaii Five-0 - S09E13 - Unter Wasser.mkv 2022-04-13 07:50:13.097 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:13.248 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=5 2022-04-13 07:50:13.804 Info App: Beginning Episode Organization 2022-04-13 07:50:13.804 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:13.805 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E15 - Der Mann, der zu viel wusste.mkv 2022-04-13 07:50:14.046 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:14.266 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=5 2022-04-13 07:50:14.808 Info App: Beginning Episode Organization 2022-04-13 07:50:14.808 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:14.809 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E05 - Ehrensache.mkv 2022-04-13 07:50:15.049 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:15.221 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=1 2022-04-13 07:50:15.766 Info App: Beginning Episode Organization 2022-04-13 07:50:15.766 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:15.767 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E09 - Die Schöne und das Biest.mkv 2022-04-13 07:50:16.020 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:16.163 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=5 2022-04-13 07:50:16.702 Info App: Beginning Episode Organization 2022-04-13 07:50:16.702 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:16.703 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E04 - Ein größerer Typ.mkv 2022-04-13 07:50:16.967 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/10?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:17.130 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=10&Season=1 2022-04-13 07:50:17.666 Info App: Beginning Episode Organization 2022-04-13 07:50:17.666 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E10.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:17.667 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E10.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E10 - Auf die Plätze, fertig, Mord!.mkv 2022-04-13 07:50:17.936 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:18.176 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=5 2022-04-13 07:50:18.695 Info App: Beginning Episode Organization 2022-04-13 07:50:18.695 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:18.696 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E07 - Verkehrte Welt.mkv 2022-04-13 07:50:18.936 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/7?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:19.108 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=7&Season=1 2022-04-13 07:50:19.660 Info App: Beginning Episode Organization 2022-04-13 07:50:19.660 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E07.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:19.661 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E07.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E07 - Der einzige Verdächtige.mkv 2022-04-13 07:50:19.913 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:20.054 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=5 2022-04-13 07:50:20.607 Info App: Beginning Episode Organization 2022-04-13 07:50:20.607 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:20.608 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E06 - Leichen pflastern seinen Weg.mkv 2022-04-13 07:50:20.874 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:21.066 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=1 2022-04-13 07:50:21.606 Info App: Beginning Episode Organization 2022-04-13 07:50:21.606 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:21.607 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E08 - Wo Rauch ist.mkv 2022-04-13 07:50:21.853 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:22.012 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=5 2022-04-13 07:50:22.188 Info App: Beginning Episode Organization 2022-04-13 07:50:22.188 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:22.189 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E01 - Das fliegende Auge.mkv 2022-04-13 07:50:22.426 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:22.575 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=1 2022-04-13 07:50:23.108 Info App: Beginning Episode Organization 2022-04-13 07:50:23.108 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:23.108 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E13 - Strichmännchen.mkv 2022-04-13 07:50:23.352 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/15?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:23.515 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=15&Season=1 2022-04-13 07:50:23.702 Info App: Beginning Episode Organization 2022-04-13 07:50:23.702 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E15.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:23.702 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E15.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E15 - Alarm im Pazifik.mkv 2022-04-13 07:50:23.954 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:24.101 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=1 2022-04-13 07:50:24.644 Info App: Beginning Episode Organization 2022-04-13 07:50:24.644 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:24.644 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E14 - Die Straßen von Honolulu.mkv 2022-04-13 07:50:24.909 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:25.096 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=5 2022-04-13 07:50:25.273 Info App: Beginning Episode Organization 2022-04-13 07:50:25.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:25.273 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E03 - Endloser Sommer.mkv 2022-04-13 07:50:25.521 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:25.712 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=1 2022-04-13 07:50:26.243 Info App: Beginning Episode Organization 2022-04-13 07:50:26.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:26.243 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E11 - Tödliche Flitterwochen.mkv 2022-04-13 07:50:26.546 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:26.753 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=5 2022-04-13 07:50:26.806 Info App: Beginning Episode Organization 2022-04-13 07:50:26.806 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:26.807 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E02 - Wenn alles auseinander bricht.mkv 2022-04-13 07:50:27.081 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:27.243 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=1 2022-04-13 07:50:27.448 Info App: Beginning Episode Organization 2022-04-13 07:50:27.448 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:27.449 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E12 - Die Bombe.mkv 2022-04-13 07:50:27.684 Info Server: http/1.1 GET http://citycobra89.dynaccess.de/emby/LiveTv/Channels?userId=04cfcd788b4a4a17ae56b54d7d4a58f3&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=ChannelNumber,SortName&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 2022-04-13 07:50:27.696 Info Server: http/1.1 Response 200 to 178.254.20.73. Time: 11ms. http://citycobra89.dynaccess.de/emby/LiveTv/Channels?userId=04cfcd788b4a4a17ae56b54d7d4a58f3&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=ChannelNumber,SortName&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=72b8fa1c-18f5-4bd9-9c74-20215fef1618&X-Emby-Client-Version=4.6.7.0 2022-04-13 07:50:27.697 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/2?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:27.847 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=2&Season=1 2022-04-13 07:50:28.023 Info App: Beginning Episode Organization 2022-04-13 07:50:28.023 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E02.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:28.024 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E02.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E02 - Ein Sicherheitsrisiko.mkv 2022-04-13 07:50:28.264 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/12?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:28.439 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=12&Season=5 2022-04-13 07:50:28.967 Info App: Beginning Episode Organization 2022-04-13 07:50:28.967 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E12.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:28.968 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E12.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E12 - Wailea.mkv 2022-04-13 07:50:29.223 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/3?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:29.379 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=3&Season=1 2022-04-13 07:50:29.926 Info App: Beginning Episode Organization 2022-04-13 07:50:29.926 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E03.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:29.926 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E03.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E03 - In den besten Familien.mkv 2022-04-13 07:50:30.157 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/11?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:30.332 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=11&Season=5 2022-04-13 07:50:30.390 Info App: Beginning Episode Organization 2022-04-13 07:50:30.390 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E11.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:30.391 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E11.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E11 - Das Meisterwerk.mkv 2022-04-13 07:50:30.641 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/19?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:30.818 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=19&Season=1 2022-04-13 07:50:30.995 Info App: Beginning Episode Organization 2022-04-13 07:50:30.996 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E19.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:30.996 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E19.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E19 - Von Helden und Schurken.mkv 2022-04-13 07:50:31.272 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/14?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:31.503 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=14&Season=5 2022-04-13 07:50:32.034 Info App: Beginning Episode Organization 2022-04-13 07:50:32.034 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E14.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:32.035 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E14.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E14 - Das Phantom.mkv 2022-04-13 07:50:32.293 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/1?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:32.445 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=1&Season=1 2022-04-13 07:50:32.984 Info App: Beginning Episode Organization 2022-04-13 07:50:32.984 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E01.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:32.984 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E01.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E01 - Aloha, Steve McGarrett.mkv 2022-04-13 07:50:33.235 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/13?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:33.395 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=13&Season=5 2022-04-13 07:50:33.571 Info App: Beginning Episode Organization 2022-04-13 07:50:33.571 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E13.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:33.572 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E13.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E13 - Das Virus.mkv 2022-04-13 07:50:33.818 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/18?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:33.988 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=18&Season=1 2022-04-13 07:50:34.532 Info App: Beginning Episode Organization 2022-04-13 07:50:34.532 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E18.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:34.533 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E18.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E18 - Der lange Abschied.mkv 2022-04-13 07:50:34.784 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/16?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:34.969 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=16&Season=1 2022-04-13 07:50:35.506 Info App: Beginning Episode Organization 2022-04-13 07:50:35.506 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E16.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:35.506 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E16.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E16 - Hart am Wind.mkv 2022-04-13 07:50:35.764 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/5?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:35.926 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=5&Season=1 2022-04-13 07:50:36.466 Info App: Beginning Episode Organization 2022-04-13 07:50:36.466 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E05.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:36.466 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E05.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E05 - Die Vertrauensfrage.mkv 2022-04-13 07:50:36.723 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:36.899 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=8&Season=5 2022-04-13 07:50:37.433 Info App: Beginning Episode Organization 2022-04-13 07:50:37.433 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E08.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:37.433 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E08.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E08 - Schein und Sein.mkv 2022-04-13 07:50:37.706 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/6?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:37.885 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=6&Season=1 2022-04-13 07:50:38.432 Info App: Beginning Episode Organization 2022-04-13 07:50:38.432 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E06.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:38.433 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E06.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E06 - Gefährliche Brandung.mkv 2022-04-13 07:50:38.663 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:38.838 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=4&Season=1 2022-04-13 07:50:39.026 Info App: Beginning Episode Organization 2022-04-13 07:50:39.026 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E04.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:39.026 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E04.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E04 - Der Millionengewinn.mkv 2022-04-13 07:50:39.278 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/5/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:39.456 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=9&Season=5 2022-04-13 07:50:40.003 Info App: Beginning Episode Organization 2022-04-13 07:50:40.003 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E09.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:40.003 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 5 (25 Folgen) german dl AC3 5.1 720p\defghh.HafueO.Staffel.5.24.Folgen.german.dl.AC3.51.720p.tvs.Santa,Archiv\Hawaii Five-0 (2010) - S05E09.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 5\Hawaii Five-0 - S05E09 - Ein Cowboy auf dem Mars.mkv 2022-04-13 07:50:40.255 Info HttpClient: GET https://api.themoviedb.org/3/tv/32798/season/1/episode/17?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=de&include_image_language=de,null,en 2022-04-13 07:50:40.438 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1600194&Episode=17&Season=1 2022-04-13 07:50:40.632 Info App: Beginning Episode Organization 2022-04-13 07:50:40.632 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E17.mkv into series D:\Videos\Serien\Hawaii Five-0 (2010) 2022-04-13 07:50:40.633 Info App: Sorting file D:\Videos\Neue Filme und Serien\Haw0S01-S10\Hawaii Five-0 S01-S10 Complete German DL AC3 5.1 720p\Hawaii Five-0 (20210) Staffel 1 (24 Folgen) german dl AC3 5.1 720p\HafueO.Staffel.1.24.Folgen.german.dl.AC3.51.720p.Santa,Archiv\Hawaii Five-0 (2010) - S01E17.mkv to new path D:\Videos\Serien\Hawaii Five-0 (2010)\Staffel 01\Hawaii Five-0 - S01E17 - Piraten.mkv Have you removed the .db file and refreshed the browser cache? It's working fine for me.
chef 3811 Posted April 13, 2022 Posted April 13, 2022 (edited) 6 hours ago, GiGo said: A new day and a new issue perhaps? Trying organise a new show called "Joe (2013)" I have enabled 'Auto create new shows', however as you can see from the screenshot it's trying to sort it to a recognised show "The Job Lot (2013)" This is after organizing the files, before any user intervention; Trying to identify one of the unidentified files; Results in no sorting dispite selecting the root folder; This is also the same result with a wrongfully identified file. This results on me not being able to sort these files at all? Part of the log below; 2022-04-13 06:00:58.699 Info App: Sorting file G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv into series G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013) 2022-04-13 06:00:58.700 Info App: Sorting file G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv to new path G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013)\Season1\The Job Lot.S01E01 - Under Pressure.mkv 2022-04-13 06:00:58.819 Info App: Plugin options: no overwrite episode 2022-04-13 06:00:58.820 Info App: File 'G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv' already exists as 'G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013)\Season1\The Job Lot.S01E01 - Under Pressure.mkv', stopping organization 2022-04-13 06:00:58.875 Error Server: Error processing request *** Error Report *** Version: 4.7.0.34 Command line: C:\Users\giles\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/giles/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\giles\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\giles\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: File 'G:\Shared drives\Backup1\_sort\Jo (2013) - S01E01 - Notre Dame.mkv' already exists as 'G:\Shared drives\Backup1\emby-primary\TV\The Job Lot (2013)\Season1\The Job Lot.S01E01 - Under Pressure.mkv', stopping organization at Emby.AutoOrganize.Core.InternalFileOrganizationService.PerformOrganization(EpisodeFileOrganizationRequest request) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 2022-04-13 06:00:58.894 Info Server: http/1.1 Response 500 to host1. Time: 264ms. http://192.168.1.67:8096/emby/Library/FileOrganizations/aed5d3baf2c1824fbf2a946e67504150/Episode/Organize?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json 2022-04-13 06:01:14.384 Info LibraryMonitor: The 70s Greatest... (2021) (G:\Shared drives\Backup1\emby-primary\TV\The 70s Greatest... (2021)) will be refreshed. 2022-04-13 06:01:16.424 Info Server: http/1.1 DELETE http://192.168.1.67:8096/emby/Library/FileOrganizations/Completed?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36 2022-04-13 06:01:16.433 Info Server: http/1.1 Response 204 to host1. Time: 9ms. http://192.168.1.67:8096/emby/Library/FileOrganizations/Completed?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34 2022-04-13 06:01:27.109 Info Server: http/1.1 POST http://192.168.1.67:8096/emby/Items/RemoteSearch/Series?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36 2022-04-13 06:01:27.111 Info HttpClient: GET https://api4.thetvdb.com/v4/search?type=series&q=Jo&year=2013 2022-04-13 06:01:28.600 Info App: MovieDbProvider: Finding id for item: Jo 2022-04-13 06:01:28.600 Info HttpClient: GET https://api.themoviedb.org/3/search/tv?api_key=x_secret1_x&query=Jo&language=en&first_air_date_year=2013 2022-04-13 06:01:29.106 Info HttpClient: GET https://private.omdbapi.com?apikey=x_secret2_x&plot=full&r=json&y=2013&s=Jo&type=series 2022-04-13 06:01:29.647 Info Server: http/1.1 Response 200 to host1. Time: 2538ms. http://192.168.1.67:8096/emby/Items/RemoteSearch/Series?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json 2022-04-13 06:01:37.698 Info LibraryMonitor: Derry Girls (G:\Shared drives\Backup1\emby-primary\TV\Derry Girls (2018)) will be refreshed. 2022-04-13 06:01:40.327 Info Server: http/1.1 POST http://192.168.1.67:8096/emby/Library/FileOrganizations/e72ceaacfcea57cc852a824937de4c1a/Episode/Organize?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=95a93ed9-11c7-4d0b-a6b5-fcb7c314d4d6&X-Emby-Client-Version=4.7.0.34&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36 2022-04-13 06:01:40.330 Info App: Beginning file organization with corrections: Jo to G:\Shared drives\Backup1\emby-primary\TV 2022-04-13 06:01:40.440 Error ProviderManager: Error searching *** Error Report *** Version: 4.7.0.34 Command line: C:\Users\giles\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/giles/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\giles\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\giles\AppData\Roaming\Emby-Server\system System.NotImplementedException: System.NotImplementedException: The method or operation is not implemented. at MovieDb.MovieDbEpisodeProvider.GetMetadata(EpisodeInfo info, CancellationToken cancellationToken) at MovieDb.MovieDbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: MovieDb TargetSite: System.Threading.Tasks.Task`1[MediaBrowser.Controller.Providers.MetadataResult`1[MediaBrowser.Controller.Entities.TV.Episode]] GetMetadata(MediaBrowser.Controller.Providers.EpisodeInfo, System.Threading.CancellationToken) 2022-04-13 06:01:40.440 Info HttpClient: GET https://private.omdbapi.com?apikey=x_secret2_x&plot=full&r=json&i=tt2885556&Episode=8&Season=1 2022-04-13 06:01:40.656 Warn App: No provider metadata found for The Job Lot season 1 episode 8 2022-04-13 06:01:40.663 Error Server: Error processing request *** Error Report *** Version: 4.7.0.34 Command line: C:\Users\giles\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/giles/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\giles\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\giles\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: No provider metadata found for The Job Lot season 1 episode 8 at Emby.AutoOrganize.Core.InternalFileOrganizationService.PerformOrganization(EpisodeFileOrganizationRequest request) Source: Emby.AutoOrganize TargetSite: Void MoveNext() Okay, let's start with this one. Then we'll look at @neik issue next. Then @TheUrbanXplorer. I believe they are connected. @GiGo, did the series "Joe (2013)" exist in your library prior to the sort? Or was it a new series? Edited April 13, 2022 by chef
TheUrbanXplorer 36 Posted April 13, 2022 Posted April 13, 2022 2 hours ago, GiGo said: Have you removed the .db file and refreshed the browser cache? It's working fine for me. Yes, I have already done everything. I already know the procedure. He just doesn't want to. 2022-04-13 14:05:51.954 Info App: Beginning file organization with corrections: X-Factor - Das Unfassbare kehrt zurück to D:\Videos\Dokus Serien 2022-04-13 14:05:51.962 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\Rico\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/Rico/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Rico\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Rico\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: Object reference not set to an instance of an object. at Emby.AutoOrganize.Core.InternalFileOrganizationService.PerformOrganization(EpisodeFileOrganizationRequest request) Source: Emby.AutoOrganize TargetSite: Void MoveNext()
chef 3811 Posted April 13, 2022 Posted April 13, 2022 7 hours ago, GiGo said: I notice that the "Remember corrections" check box is is not present in this screen shot. Is it just missing from the screen shot, or is it actually missing from the UI?
GiGo 108 Posted April 13, 2022 Posted April 13, 2022 2 hours ago, chef said: did the series "Joe (2013)" exist in your library prior to the sort? Or was it a new series? Hello, it is a new show for my collection. 1
daedalus 434 Posted April 13, 2022 Posted April 13, 2022 (edited) i have to revert my successfull meassage on the overwrite exceptions, partly if an exception is set, only files that fullfill it get sorted, all other files, duplicates and new ones, are not processed, but they all still get marked as completed in the overview S01E01 is a new one in the following exsample 2022-04-13 17:46:43.526 Info App: Beginning Episode Organization 2022-04-13 17:46:43.526 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E01 - Sassenach.mkv into series E:\Serien\Outlander (2014) 2022-04-13 17:46:43.526 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E01 - Sassenach.mkv to new path E:\Serien\Outlander (2014)\Season 01\S01E01 - Sassenach.mkv 2022-04-13 17:46:43.779 Info App: Beginning Episode Organization 2022-04-13 17:46:43.779 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E02 - Burg Leoch.repack.mkv into series E:\Serien\Outlander (2014) 2022-04-13 17:46:43.779 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E02 - Burg Leoch.repack.mkv to new path E:\Serien\Outlander (2014)\Season 01\S01E02 - Burg Leoch.mkv 2022-04-13 17:46:43.783 Info App: Perform Sorting 2022-04-13 17:46:43.783 Info App: Auto organize added E:\Serien\Outlander (2014)\Season 01\S01E02 - Burg Leoch.mkv to inprogress list 2022-04-13 17:46:43.784 Info App: Copying File --- with the exception removed, duplicates are marked correctly as such and new files are processed 2022-04-13 17:51:43.614 Info App: Beginning Episode Organization 2022-04-13 17:51:43.614 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E01 - Sassenach.mkv into series E:\Serien\Outlander (2014) 2022-04-13 17:51:43.614 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E01 - Sassenach.mkv to new path E:\Serien\Outlander (2014)\Season 01\S01E01 - Sassenach.mkv 2022-04-13 17:51:43.615 Info App: Plugin options: no overwrite episode 2022-04-13 17:51:43.615 Info App: Perform Sorting 2022-04-13 17:51:43.615 Info App: Auto organize added E:\Serien\Outlander (2014)\Season 01\S01E01 - Sassenach.mkv to inprogress list 2022-04-13 17:51:43.616 Info App: Moving File 2022-04-13 17:52:50.732 Info App: Beginning Episode Organization 2022-04-13 17:52:50.732 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E02 - Burg Leoch.mkv into series E:\Serien\Outlander (2014) 2022-04-13 17:52:50.732 Info App: Sorting file D:\SORT IT BITCH !!\video\Outlander - S01E02 - Burg Leoch.mkv to new path E:\Serien\Outlander (2014)\Season 01\S01E02 - Burg Leoch.mkv 2022-04-13 17:52:50.733 Info App: Plugin options: no overwrite episode 2022-04-13 17:52:50.733 Info App: File 'D:\SORT IT BITCH !!\video\Outlander - S01E02 - Burg Leoch.mkv' already exists as 'E:\Serien\Outlander (2014)\Season 01\S01E02 - Burg Leoch.mkv', stopping organization --- and the "delete empty folder" option is also not working any more (regardless the overwrite exception) Edited April 13, 2022 by daedalus 1
chef 3811 Posted April 13, 2022 Posted April 13, 2022 16 hours ago, neik said: chef, I just installed the latest plugin and seem to be having an issue when a file has more than one destination folder. The plugin is detecting it and stops sorting the file but whenever I try to bring up the fileorganizer pop-up nothing happens. I can see lots of these in the logs, might be unrelated though: 2022-04-13 07:52:43.228 Error Server: Error processing request *** Error Report *** Version: 4.7.0.33 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-88-generic (buildd@lgw01-amd64-008) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #99-Ubuntu SMP Thu Sep 23 17:29:00 UTC 2021 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamWithDirectStreamProvider(String id, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetState(StreamRequest request, Boolean requiresOutputPath, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() And also this in the console: I can reproduce this! So I can fix it. When the series is spread between multiple locations, the expected behavior would be, to stop organization and open the file organizer. However, we don't want to have to do this each time a series is spread out. I guess we create a smart list object which changes the location. After selecting the proper location, the smart list object is created, and from that point forward the series will sort into the chosen folder. Removing the smart list entry would cause the series to wait for use input again. Does that sound about right?
