chef 3810 Posted April 2, 2022 Posted April 2, 2022 (edited) @slevin7 Here is 1.6.1.4 You have to go into the settings page, and make sure that the "Default Library Path" is set for movies, and press the save button. I had accidentally did not updated the configuration, it was erring because the plugin couldnt find the Default path. Ops! It is working now. Emby.AutoOrganize_v1.6.1.4.zip Remember to clear browsing cache so the updated javascript code is refreshed Edited April 2, 2022 by chef 1
chef 3810 Posted April 2, 2022 Posted April 2, 2022 I was learning about "debouncing" in web development, and it occurred to me that it was possible to have a "Search" in some of my plugins. I applied what I had learned, and what'd'ya know! It works great! If your auto organize lists starts to get really long, there is a search there to get specific table results. LOL!
GiGo 108 Posted April 2, 2022 Posted April 2, 2022 In version 1.6.1.4 None of the my TV series files are automatically being sorted and saved. I have to search for them each time and manually do it. Not sure whats going, I do have 2 different directories for my library, not sure if that is causing an issue?
chef 3810 Posted April 2, 2022 Posted April 2, 2022 Just now, GiGo said: In version 1.6.1.4 None of the my TV series files are automatically being sorted and saved. I have to search for them each time and manually do it. Not sure whats going, I do have 2 different directories for my library, not sure if that is causing an issue? Okay. Give me a moment, I'll find the issue.
GiGo 108 Posted April 2, 2022 Posted April 2, 2022 Just now, chef said: Okay. Give me a moment, I'll find the issue. Thanks! Awesome work! Always so speedy with your bug fixes! Love the idea of searching BTW! Would help a lot when trying to find bulk imports of things!
chef 3810 Posted April 2, 2022 Posted April 2, 2022 1 hour ago, GiGo said: Thanks! Awesome work! Always so speedy with your bug fixes! Love the idea of searching BTW! Would help a lot when trying to find bulk imports of things! Sorry. I need to see a log file if I can. I'll have an easier time to diagnose the issue.
GiGo 108 Posted April 2, 2022 Posted April 2, 2022 Just now, chef said: Sorry. I need to see a log file if I can. I'll have an easier time to diagnose the issue. I'll sort a log out tomorrow, I'm in the UK so I'm off to bed. Thanks for your help
vaise 340 Posted April 3, 2022 Posted April 3, 2022 (edited) I suspect I am too used to the basic one built into emby. I had a stroke 6 months ago, and this may not be helping the situation either...... This is the first actual time i am using the enhanced version with some actual TV shows. note, I dont use it for movies, and only TV shows I have to manually download. I installed the new dll, restarted emby and flushed cache. I just added 4 shows to my embyautoorganize folder. Go to auto organize, I can see the last 4 shows. No start/go/run button or anywhere to start the process. In settings, I found a scheduled task option (mine set off), I had to enable the scheduled task (I always ran it manually so dont want this though). Then I have the 'Task last run' bit in the top right corner, and a clickable refresh thing ? - I click it, it spins, but nothig on the screen. Seems I have to refresh the browser windows to show the actual actions. This seems a step back - in the past, I could just manually hit go, and they would stream up the page. In summary : On the new enhanced version, I don't seem to have the same functionality as the default one built into emby - I believe there should be a manual go button if you don't tick the scheduling option (if its there, I cant find it), and I don't see them start to process and scroll up like they used to once you click the start 'thing' at the top to start the scheduled job. As it stands, my two issues are still there (episode naming when using 'S01E01' and picking incorrect library for TV shows if they exist in multiple locations). Edited April 3, 2022 by vaise
GiGo 108 Posted April 3, 2022 Posted April 3, 2022 9 hours ago, chef said: Sorry. I need to see a log file if I can. I'll have an easier time to diagnose the issue. Not sure whats going on TBH, seems to be taking AGES to do a scan and looking at the log there seems to be lots of errors that I have no understanding off! Log attached. Restarted the server before uploading so should make it easier to read. embyserver.txt 1
chef 3810 Posted April 3, 2022 Posted April 3, 2022 Hmmm... It would seem that the MovieDb doesn't have any data for Robot Wars. I'm going to double check that by looking at their site. What would be interesting to know is: Was Robot Wars the only series that was unable to be sorted properly? Was Robot Wars an existing series in your library, or was it a new series you were going to added to your library? Judging by the logs, it would seem that it was a new series. The plugin then attempted to match the name with the provider to try and create the new series, but the MovieDb wasn't able to provide the necessary data to identify the series. I did add some code which tried to request provider data using localization info. This may have indirectly caused issues. It is these log entries that explain the problem: 2022-04-03 07:33:22.637 Error ProviderManager: Error searching *** Error Report *** Version: 4.7.0.32 Command line: C:\Users\giles\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/giles/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\giles\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\giles\AppData\Roaming\Emby-Server\system System.NotImplementedException: System.NotImplementedException: The method or operation is not implemented. at MovieDb.MovieDbEpisodeProvider.GetMetadata(EpisodeInfo info, CancellationToken cancellationToken) at MovieDb.MovieDbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: MovieDb TargetSite: System.Threading.Tasks.Task`1[MediaBrowser.Controller.Providers.MetadataResult`1[MediaBrowser.Controller.Entities.TV.Episode]] GetMetadata(MediaBrowser.Controller.Providers.EpisodeInfo, System.Threading.CancellationToken) There is something strange happening there. I'm not sure if it is unavailable series data, or if it is how the series data is being requested. I'll be back! 1
GiGo 108 Posted April 3, 2022 Posted April 3, 2022 @chef Robot Wars series is/was not in my collection, I have added some of them manually via Auto Organize via TVDB but they remain unsorted. They are not the only things that remain unsorted/unrecognised. Everything is not sorting/recognised dispute being in my collection.
chef 3810 Posted April 3, 2022 Posted April 3, 2022 14 hours ago, vaise said: I suspect I am too used to the basic one built into emby. I had a stroke 6 months ago, and this may not be helping the situation either...... This is the first actual time i am using the enhanced version with some actual TV shows. note, I dont use it for movies, and only TV shows I have to manually download. I installed the new dll, restarted emby and flushed cache. I just added 4 shows to my embyautoorganize folder. Go to auto organize, I can see the last 4 shows. No start/go/run button or anywhere to start the process. In settings, I found a scheduled task option (mine set off), I had to enable the scheduled task (I always ran it manually so dont want this though). Then I have the 'Task last run' bit in the top right corner, and a clickable refresh thing ? - I click it, it spins, but nothig on the screen. Seems I have to refresh the browser windows to show the actual actions. This seems a step back - in the past, I could just manually hit go, and they would stream up the page. In summary : On the new enhanced version, I don't seem to have the same functionality as the default one built into emby - I believe there should be a manual go button if you don't tick the scheduling option (if its there, I cant find it), and I don't see them start to process and scroll up like they used to once you click the start 'thing' at the top to start the scheduled job. As it stands, my two issues are still there (episode naming when using 'S01E01' and picking incorrect library for TV shows if they exist in multiple locations). I will make sure the identify button is showing at all times, when the auto feature is off. That is a good idea.
chef 3810 Posted April 3, 2022 Posted April 3, 2022 7 minutes ago, GiGo said: @chef Robot Wars series is/was not in my collection, I have added some of them manually via Auto Organize via TVDB but they remain unsorted. They are not the only things that remain unsorted/unrecognised. Everything is not sorting/recognised dispute being in my collection. Okay.
TheUrbanXplorer 36 Posted April 3, 2022 Posted April 3, 2022 Hello, neither the Watch Folder nor the Destination Folder Options can be saved. embyserver.txt
chef 3810 Posted April 3, 2022 Posted April 3, 2022 12 minutes ago, TheUrbanXplorer said: Hello, neither the Watch Folder nor the Destination Folder Options can be saved. embyserver.txt 43.73 kB · 0 downloads did you clear browser cache?
GiGo 108 Posted April 3, 2022 Posted April 3, 2022 Just looking at the list of shows, seems I have a lot of 'undefined' shows, what does this mean?
chef 3810 Posted April 3, 2022 Posted April 3, 2022 25 minutes ago, TheUrbanXplorer said: Hello, neither the Watch Folder nor the Destination Folder Options can be saved. embyserver.txt 43.73 kB · 0 downloads I found this problem, and I will fix it.
chef 3810 Posted April 3, 2022 Posted April 3, 2022 18 minutes ago, GiGo said: Just looking at the list of shows, seems I have a lot of 'undefined' shows, what does this mean? The production year is missing in the return data I'll fix it.
chef 3810 Posted April 3, 2022 Posted April 3, 2022 (edited) 1 hour ago, GiGo said: @chef Robot Wars series is/was not in my collection, I have added some of them manually via Auto Organize via TVDB but they remain unsorted. They are not the only things that remain unsorted/unrecognised. Everything is not sorting/recognised dispute being in my collection. I have also reproduced this error now. I will fix this. Edited April 3, 2022 by chef 1
chef 3810 Posted April 3, 2022 Posted April 3, 2022 This is very weird. The provider manager in emby keeps returning nothing. I know the provider data is accessible, because I am able to identify the item for sorting. But, for some reason requesting the new series to auto identify itself using the Emby API returns nothing from the Provider Managers remote search. What is this? I can't tell if it is auto organize, or if it is something happening in Emby's core.
TheUrbanXplorer 36 Posted April 3, 2022 Posted April 3, 2022 2 hours ago, chef said: did you clear browser cache? Yes, I also thought it was the cache, but unfortunately it doesn't change anything.
TheUrbanXplorer 36 Posted April 3, 2022 Posted April 3, 2022 I have also tried to write the config manually, but this is overwritten on the next reboot.
GiGo 108 Posted April 3, 2022 Posted April 3, 2022 (edited) Got another one for you chef Now I have a version of this in one directory (one of my online drives), however I want a version stored locally, when I press the identify button and search for the program and then select the root folder I want it to go in, it returns the below, which is what it did as when it initally identified it (please note this is a different server running v 1.6.1.0 of Auto Organize) Edited April 3, 2022 by GiGo 1
