GiGo 108 Posted March 30, 2022 Posted March 30, 2022 Also, transfer method doesn't seem to be sticking, it's seems to be stuck on Copy, I can't seem to set it to Move.
chef 3811 Posted March 30, 2022 Posted March 30, 2022 2 hours ago, GiGo said: Also, transfer method doesn't seem to be sticking, it's seems to be stuck on Copy, I can't seem to set it to Move. Okay, I'll take a look. Probably missed a event somewhere.
chef 3811 Posted March 30, 2022 Posted March 30, 2022 5 hours ago, GiGo said: Just trying v1.6.1.0 When clicking on Smart Matches, it appears to bring up the old settings, I have refreshed cache but still the same; Also, doesn't appear to have Default Series Library folders; That is strange. Why is the element showing as a select box. I'll be right back!! 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 6 hours ago, GiGo said: Just trying v1.6.1.0 When clicking on Smart Matches, it appears to bring up the old settings, I have refreshed cache but still the same; Also, doesn't appear to have Default Series Library folders; Ah! I didn't change the tabs on smart match. Ops! I have a fix here. Thanks @GiGo Brb 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 version 1.6.1.1 fixes all those issues up. need a null coalescence on the new config options. Ops! Emby.AutoOrganize_v1.6.1.1.zip 1
slevin7 86 Posted March 30, 2022 Posted March 30, 2022 TV works great. I created a folder and put a series (with 4 episodes) and a movie in it. Series he has super recognized. thank you. 1
GiGo 108 Posted March 30, 2022 Posted March 30, 2022 All appears to be working well Files are moving and being re-cognised. Great work chef! 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 I might update the GitHub if things continue to work as expected. It was a big change.
chef 3811 Posted March 30, 2022 Posted March 30, 2022 I have multiple watch folders working. That was easy. @vaise I'm wondering if we can extend the smart lists to help sort items into different folders based on resolutions. I'm pretty sure that is the way to do it. To start, if we end up with multiple possible destination folders, we'll wait for user input. The user input will be to create a rule in the smart lists. From that moment forward, we should move items appropriately.
vaise 340 Posted March 30, 2022 Posted March 30, 2022 1 hour ago, chef said: I have multiple watch folders working. That was easy. @vaise I'm wondering if we can extend the smart lists to help sort items into different folders based on resolutions. I'm pretty sure that is the way to do it. To start, if we end up with multiple possible destination folders, we'll wait for user input. The user input will be to create a rule in the smart lists. From that moment forward, we should move items appropriately. I will only ever be doing one folder though. The stuff I put in the auto organise monitor folder is only ever going to be hd and sd tv shows and hence I only want one folder. 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 20 minutes ago, vaise said: I will only ever be doing one folder though. The stuff I put in the auto organise monitor folder is only ever going to be hd and sd tv shows and hence I only want one folder. It's just I have to keep things somewhat generic, or configurable, for many different situations. Perhaps, we could try an ignore folder option.
vaise 340 Posted March 30, 2022 Posted March 30, 2022 13 minutes ago, chef said: It's just I have to keep things somewhat generic, or configurable, for many different situations. Perhaps, we could try an ignore folder option. I installed the latest version from above. But I am not seeing these changes ? I downloaded the zip, copied the dll to the plugins folder, replace the other one, restarted the docker container. Not sure where I am going wrong. Will try again later so as not to kick off users again. I fully agree with what you say. By being configurable you can cater for loads of peoples options/requirements. I am just a simple person with very simple requirements.
vaise 340 Posted March 31, 2022 Posted March 31, 2022 (edited) 10 hours ago, chef said: Perhaps a browser cache clear? Yeah - tried that, and two other browsers and clears there too. Going a bit crazy, even replaced the dll a few times too...... Edited March 31, 2022 by vaise
chef 3811 Posted March 31, 2022 Posted March 31, 2022 6 hours ago, vaise said: Yeah - tried that, and two other browsers and clears there too. Going a bit crazy, even replaced the dll a few times too...... Can I see a log @vaise
vaise 340 Posted March 31, 2022 Posted March 31, 2022 (edited) 9 hours ago, chef said: Can I see a log @vaise I ran autorganise, clicked a few tabs. but nothing is logged. Def seems like the old one : Edited March 31, 2022 by vaise
vaise 340 Posted March 31, 2022 Posted March 31, 2022 (edited) I stopped emby, renamed the dll to dlls, restarted - no autoorganize. I stopped emby, renamed it back to dll, started emby - its back but old release. Checked dll version : 1.6.1.1 2022-04-01 07:28:05.892 Info App: Loading Emby.AutoOrganize, Version=1.6.1.1, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.AutoOrganize.dll 2022-04-01 07:28:08.501 Info App: Starting entry point Emby.AutoOrganize.PluginEntryPoint 2022-04-01 07:28:08.503 Info App: Sqlite version: 3.35.5 2022-04-01 07:28:08.503 Info App: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_MATH_FUNCTIONS,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2022-04-01 07:28:08.506 Info App: Default journal_mode for /config/data/fileorganization.db is wal 2022-04-01 07:28:08.508 Info App: Entry point completed: Emby.AutoOrganize.PluginEntryPoint. Duration: 0.0075199 seconds Edited March 31, 2022 by vaise
chef 3811 Posted March 31, 2022 Posted March 31, 2022 (edited) @samuelqwe when side loading a plugin in emby on Linux, or in a docker container, was there a special trick to loading the new dll? Not to worry @vaise, Sam will know what to do Edited March 31, 2022 by chef
vaise 340 Posted March 31, 2022 Posted March 31, 2022 15 minutes ago, chef said: @samuelqwe when side loading a plugin in emby on Linux, or in a docker container, was there a special trick to loading the new dll? Not to worry @vaise, Sam will know what to do I have put other plugins in this way in the past, I have done testing for Luke on loads. So I am at a loss this time as to why it was not working. The first update from the base autoorganise to the one before this worked ok, as i have to do the database fix then....... Got me stumped.
chef 3811 Posted March 31, 2022 Posted March 31, 2022 Are you in beta server? Maybe I need to target a different mediabrowser.core? I will check on my beta install, if you are on beta server.
samuelqwe 317 Posted March 31, 2022 Posted March 31, 2022 23 minutes ago, chef said: @samuelqwe when side loading a plugin in emby on Linux, or in a docker container, was there a special trick to loading the new dll? Nope, simply put the plugin in the plugins folder of the mapped Emby config folder, then restart the container. It should work like on other platforms.
Happy2Play 9814 Posted March 31, 2022 Posted March 31, 2022 Have seen topics where you may have to verify permissions on custom plugins placed in plugin folder. 1
chef 3811 Posted March 31, 2022 Posted March 31, 2022 25 minutes ago, Happy2Play said: Have seen topics where you may have to verify permissions on custom plugins placed in plugin folder. Apparently, vaise was able to load a previous version of the plugin. This is very strange. Maybe the build was weird. I will post a new one....
