chef 3811 Posted March 29, 2022 Posted March 29, 2022 (edited) Currently we process the files to by the date added to the queue. Do you guys want to have the ability to edit the actual queue? The order in which we process many items? Edited March 29, 2022 by chef
GiGo 108 Posted March 29, 2022 Posted March 29, 2022 1 minute ago, chef said: Currently we process the files to by the date added to the queue. Do you guys want to have the ability to edit the actual queue? The order in which we process many items? I don't have the need to edit the queue, but having the ability to sort it by Name makes SO SO much more sense than by date added, will make it much easier to find files. 1
chef 3811 Posted March 29, 2022 Posted March 29, 2022 @Luke sorry to bother you sir. What is the equivalent of the "ConfigurationService" -> "System/Configuration" endpoint in the API? I need to get "PreferredMetadataLanguage",and "MetadataCountryCode": for the identify lookup in auto organize. There have been reports of the lookup returning English results when we're trying to get German ones. I'm pretty sure I've narrowed down the problematic code to this line in the movie organizer: var movieInfo = LibraryManager.IsVideoFile(path.AsSpan()) ? LibraryManager.ParseName(Path.GetFileName(path).AsSpan()) : new ItemLookupInfo() { MetadataCountryCode = "{Need some localization data here}", MetadataLanguage = "{... and here}" }; Many thanks sir.
chef 3811 Posted March 29, 2022 Posted March 29, 2022 8 minutes ago, chef said: @Luke sorry to bother you sir. What is the equivalent of the "ConfigurationService" -> "System/Configuration" endpoint in the API? I need to get "PreferredMetadataLanguage",and "MetadataCountryCode": for the identify lookup in auto organize. There have been reports of the lookup returning English results when we're trying to get German ones. I'm pretty sure I've narrowed down the problematic code to this line in the movie organizer: var movieInfo = LibraryManager.IsVideoFile(path.AsSpan()) ? LibraryManager.ParseName(Path.GetFileName(path).AsSpan()) : new ItemLookupInfo() { MetadataCountryCode = "{Need some localization data here}", MetadataLanguage = "{... and here}" }; Many thanks sir. Ops! nevermind I found "IServerConfigurationManager". carry on
chef 3811 Posted March 29, 2022 Posted March 29, 2022 (edited) Here is: 1.6.0.9 Sorting options can be accessed by selecting "Date", "Name" or "Status" at the top of the table column. clicking the column header swaps the direction. Sort by date (ascending/descending) Sort by name (ascending/descending) Group by Status Organization now starts off by attempting to determine the media type of the file by name, then accessing the appropriate organizer method. Example: This is a TV episode: AwesomeSeries.S01E01.1080p.WEB.mkv This also is a TV episode: AwesomeSeries.2022.S01E01.1080p.WEB.mkv This is a Movie: AwesomeMovie.2022.1080p.mkv Extra logging just in case. UI changes One "Settings" tab Settings page Item lookup now request localized results. We should see better lookup results in the proper language. However, if this isn't the case there are other lookup methods that need attention. It is possible that by consolidating the configuration, you will most likely have to re-enter your settings data. Double check that before attempting to sort new items. DOWNLOAD: I don't think I missed anything. Next I'll try and get multiple watched folders working properly, and see about removing the enable options for the organizer. They are pointless to have. Edited March 30, 2022 by chef 3
vaise 340 Posted March 29, 2022 Posted March 29, 2022 8 hours ago, chef said: For movies we can force a folder. NP. New series that are found the in the monitored folder also can be forced into a specific folder. But, any file that is found in the monitored folder, that belongs to an existing series, should automatically be sorted into that series folder. That isn't happening? It’s happening but in my two examples I posted, it’s picking the the wrong folder, likely the first one it finds or something, which in my 2 examples are the incorrect ones. 1
chef 3811 Posted March 29, 2022 Posted March 29, 2022 19 minutes ago, vaise said: It’s happening but in my two examples I posted, it’s picking the the wrong folder, likely the first one it finds or something, which in my 2 examples are the incorrect ones. I'll take a look
chef 3811 Posted March 29, 2022 Posted March 29, 2022 What if we had an option like this? 720p => R:/Folder_Of_Your_Choice/etc.... 1080p => R:/Folder_Of_Your_Choice/etc... 2160p=> you get the idea.... Would that help sorting?
AdrianW 1058 Posted March 30, 2022 Posted March 30, 2022 (edited) 10 hours ago, norbo80 said: it is possible to just add e.x. (1) instead to overwrite the file? Sometimes I download some versions of movie. Adding PROPER or REPACK would work for me. So, only overwriting IF one of the special words exists in the file name. Edited March 30, 2022 by AdrianW
chef 3811 Posted March 30, 2022 Posted March 30, 2022 5 minutes ago, AdrianW said: Adding PROPER or REPACK would work for me. So, only overwriting IF one of the special words exists in the file name. Yup! That is a good idea. I don't *think* that needs to be an option in the UI, but should be a condition used on the back end when calculating "overwrite existing items". Or should it be an option?
AdrianW 1058 Posted March 30, 2022 Posted March 30, 2022 In Metabrowser there was a field where you enter a semi-colon separated list of words that would allow overwriting. If the field was empty then nothing would be overwritten. Then it's up to the user what words to use. 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 11 minutes ago, AdrianW said: In Metabrowser there was a field where you enter a semi-colon separated list of words that would allow overwriting. If the field was empty then nothing would be overwritten. Then it's up to the user what words to use. Cool. We'll show an input when that option is turned on. So, if the item doesn't contain any of the key words, and the option is on, then we'll do nothing, and mark the item as "existing item", and wait for user input?
AdrianW 1058 Posted March 30, 2022 Posted March 30, 2022 I don't think you even need an option toggle. An empty field would mean it's off. 1
vaise 340 Posted March 30, 2022 Posted March 30, 2022 1 hour ago, chef said: What if we had an option like this? 720p => R:/Folder_Of_Your_Choice/etc.... 1080p => R:/Folder_Of_Your_Choice/etc... 2160p=> you get the idea.... Would that help sorting? And a catch all if none of those are present. 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 Does the input description make sense? "Overwrite existing files with the following key words".... "Overwrite existing files with files with the following key words"... "Overwrite library items with files containing the following key words" ?? <= this one? I can code the thing, I'm just awful at explaining what it does.
AdrianW 1058 Posted March 30, 2022 Posted March 30, 2022 How about "Overwrite library items when files contain the following key words: "
vaise 340 Posted March 30, 2022 Posted March 30, 2022 13 minutes ago, chef said: Does the input description make sense? "Overwrite existing files with the following key words".... "Overwrite existing files with files with the following key words"... "Overwrite library items with files containing the following key words" ?? <= this one? I can code the thing, I'm just awful at explaining what it does. I best not comment on this - I have no idea what this is for. I have simple requirements, but the tools direction is to be an all singing all dancing thing - great for the people that ONLY use this for media movement/management, but sonarr/radarr does > 95% of my media naming/moving/management, this tool is only for the limited download of obscure UK TV Shows I have to get from other sources. My only requirements over the base autoorganize in emby are : 1)- name the file correctly if > 9 seasons 2)- move the file into the correct target folder, not pick one that is finds that it has seen before My operation of it is thus - 1) download the file 2) copy it to the embyautoorganise folder (on my server) 3) run the autoorganise process In the last run of this, as I reported - two issues - Googlebox went to the RecordedTVSSD folder/library instead of the TVShows linrary (as it has been in both), and Dynasties wento to 4KTVShows instead of TVShows (as it exists in both). I think you are onto that issue with the version process you plan for. 1
AdrianW 1058 Posted March 30, 2022 Posted March 30, 2022 Does that screenshot indicate that: Toggle is ON: overwrite regardless of naming. Toggle is OFF: overwrite only when names contain any of the specified words. If so, then that is perfect.
chef 3811 Posted March 30, 2022 Posted March 30, 2022 Like magic! //Do we have any key words? if (options.OverwriteExistingItemsKeyWords.Any()) { //Do those key words appear in our file name? if (options.OverwriteExistingItemsKeyWords.Any(word => result.OriginalFileName.ToUpperInvariant().Contains(word.ToUpperInvariant()))) { //Yup! overwrite the library item. PerformFileSorting(options, result, cancellationToken); } } //Nope! No key words, or key words don't appear in the file name, not going to sort it. User should eventually delte this file in the UI.
chef 3811 Posted March 30, 2022 Posted March 30, 2022 2 minutes ago, AdrianW said: Does that screenshot indicate that: Toggle is ON: overwrite regardless of naming. Toggle is OFF: overwrite only when names contain any of the specified words. If so, then that is perfect. Hmm... well... yeah it could do that... So if the user doesn't want the option at all. The toggle would be off, and the input would be empty. Yes that is better... Brb.
AdrianW 1058 Posted March 30, 2022 Posted March 30, 2022 2 minutes ago, chef said: So if the user doesn't want the option at all. The toggle would be off, and the input would be empty. Yes, exactly. 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 (edited) okay. just so there is no confusion with the two options. When the toggle is ON, and we are set to move any files in the watched folder, and overwrite library items I have hidden the input. But, if the toggle is OFF, the input appears because we are not going to move any items, only items that match the keywords. If the toggle is off, and the input is empty, we do nothing. Good? Does that make sense @vaise By the way, do you still see strange naming: S010E02? I'm working on finding the proper folders as we speak. Edited March 30, 2022 by chef
AdrianW 1058 Posted March 30, 2022 Posted March 30, 2022 4 minutes ago, chef said: If the toggle is off, and the input is empty, we do nothing. Good? Yes, I like it. Makes it clear. 1
chef 3811 Posted March 30, 2022 Posted March 30, 2022 (edited) Cool, version 1.6.1.0 does that. Currently only for TV episodes. I'll have to write the code for movies next. But I have to jump over to IntroSkip for a bit. LOL! Edited March 30, 2022 by chef 1
GiGo 108 Posted March 30, 2022 Posted March 30, 2022 (edited) Just trying v1.6.1.0 When clicking on Smart Matches, it appears to bring up the old settings, I have refreshed cache but still the same; Also, doesn't appear to have Default Series Library folders; Edited March 30, 2022 by GiGo
