horstepipe 423 Posted November 1, 2021 Posted November 1, 2021 hey thank you again for taking the time to fix that, this is really appreciated! Unfortunately there is still an issue: Copy over the files work now. But if you first organize Series - S01E01 - Test1.strm with content Test1 and the organize Series - S01E01 - Test2.strm with content Test2 the file gets replaced, but the old name stays, so it is still Series - S01E01 - Test1.strm but with Test2 content. Hopefully you can fix that to get quality upgrades evident. Best regards
chef 3811 Posted November 1, 2021 Posted November 1, 2021 5 hours ago, horstepipe said: hey thank you again for taking the time to fix that, this is really appreciated! Unfortunately there is still an issue: Copy over the files work now. But if you first organize Series - S01E01 - Test1.strm with content Test1 and the organize Series - S01E01 - Test2.strm with content Test2 the file gets replaced, but the old name stays, so it is still Series - S01E01 - Test1.strm but with Test2 content. Hopefully you can fix that to get quality upgrades evident. Best regards Right, because the target episode was found in your library, so the new version was copied over and replaced the old episode in the library. That is to be expected is it not?
horstepipe 423 Posted November 1, 2021 Posted November 1, 2021 Hum okay, I can just say about my own use case - here it is not expected/the behavior I want. As these exchanges only happen on a quality upgrade, so this upgrade should be reflected in the file name (here)
Carlo 4561 Posted November 1, 2021 Posted November 1, 2021 20 hours ago, chef said: Also, right now we'll move the old target file to the recycle bin, until we know it works and we are all good. Then we'll remove it all together. It might be better to just rename the file vs the recycle bin. This way on failure you can rename it back and on a success just delete it.
chef 3811 Posted November 1, 2021 Posted November 1, 2021 1 hour ago, horstepipe said: Hum okay, I can just say about my own use case - here it is not expected/the behavior I want. As these exchanges only happen on a quality upgrade, so this upgrade should be reflected in the file name (here) Bare with me, I'm trying to understand, so I can code it. What does your Episode naming pattern look like on the 'TV' options page: Have you tried using: %fn to maintain the original file name? Would that fix anything? Could I see the .strm file names, so I know how they change, and what to look for in the name? Then maybe we can figure out a way to handle it.
horstepipe 423 Posted November 1, 2021 Posted November 1, 2021 14 minutes ago, chef said: Bare with me, I'm trying to understand, so I can code it. What does your Episode naming pattern look like on the 'TV' options page: Have you tried using: %fn to maintain the original file name? Would that fix anything? Could I see the .strm file names, so I know how they change, and what to look for in the name? Then maybe we can figure out a way to handle it. I am happy to hear that So yes I'm already using %fn so the file name keeps as it is. I hope you really understand. I just do not want the new file to be named like the old file. So first upload is e.g. NCIS - Los Angeles (2009) - S12E08 - Love Kills 1 [WEBDL-1080p][8bit][h264][EAC3 5.1]-NTb.strm This episode is English yet, as soon as it gets replaced, the new episode title would look like NCIS - Los Angeles (2009) - S12E08 - Love Kills 1 [WEBDL-1080p][8bit][x264][EAC3 5.1][DE+EN]-wayne.strm So basically I need the prefixes at the end to keep intact 1
kingy444 117 Posted November 2, 2021 Posted November 2, 2021 12 hours ago, horstepipe said: I am happy to hear that So yes I'm already using %fn so the file name keeps as it is. I hope you really understand. I just do not want the new file to be named like the old file. So first upload is e.g. NCIS - Los Angeles (2009) - S12E08 - Love Kills 1 [WEBDL-1080p][8bit][h264][EAC3 5.1]-NTb.strm This episode is English yet, as soon as it gets replaced, the new episode title would look like NCIS - Los Angeles (2009) - S12E08 - Love Kills 1 [WEBDL-1080p][8bit][x264][EAC3 5.1][DE+EN]-wayne.strm So basically I need the prefixes at the end to keep intact Clarifyting here for @chef - you are saying that when sorting a file, and you already have the file in your library - you would want the current file removed and then new file moved in using the naming pattern - is that correct ? 1
horstepipe 423 Posted November 2, 2021 Posted November 2, 2021 17 minutes ago, kingy444 said: Clarifyting here for @chef - you are saying that when sorting a file, and you already have the file in your library - you would want the current file removed and then new file moved in using the naming pattern - is that correct ? Yes, that is what I want (and would have expected) if Episode name pattern is set to %f and “overwrite existing episode files” is checked. 1
TheUrbanXplorer 36 Posted November 2, 2021 Posted November 2, 2021 Hello @chef, the overwrite works for me on Windows now without problems. Have you thought about my request regarding the version extension? Topic Special Edition or Directors Cut as an example. I usually assign the movies manually anyway, because they are not yet in the database. Maybe you can create an additional field for the prefix? Then the result would be: Example (2021) - 1080p [Directors Cut].mkv That would be of course really great! I played with Photoshop and attached a picture, how something like this could look like, independent of the coding. P.S.: I know, I'm annoying...! But this is certainly very interesting for others, who not only file different resolutions, but also different cuts of the movies.
chef 3811 Posted November 2, 2021 Posted November 2, 2021 6 minutes ago, TheUrbanXplorer said: Hello @chef, the overwrite works for me on Windows now without problems. Have you thought about my request regarding the version extension? Topic Special Edition or Directors Cut as an example. I usually assign the movies manually anyway, because they are not yet in the database. Maybe you can create an additional field for the prefix? Then the result would be: Example (2021) - 1080p [Directors Cut].mkv That would be of course really great! I played with Photoshop and attached a picture, how something like this could look like, independent of the coding. P.S.: I know, I'm annoying...! But this is certainly very interesting for others, who not only file different resolutions, but also different cuts of the movies. Yes, I believe that I have some help to maintain the plugin. So, it looks like we can finally get some of these feature requests, that have piled up, implemented. I think this, subtitles, and the naming issues mentioned here should be priority. 2
TheUrbanXplorer 36 Posted November 2, 2021 Posted November 2, 2021 11 minutes ago, chef said: Yes, I believe that I have some help to maintain the plugin. So, it looks like we can finally get some of these feature requests, that have piled up, implemented. I think this, subtitles, and the naming issues mentioned here should be priority. That sounds good! Yes, that's right, subtitles would be equally important to implement. Hope that works both. Then the plugin would be perfect!!!
TheUrbanXplorer 36 Posted November 2, 2021 Posted November 2, 2021 27 minutes ago, chef said: Yes, I believe that I have some help to maintain the plugin. So, it looks like we can finally get some of these feature requests, that have piled up, implemented. I think this, subtitles, and the naming issues mentioned here should be priority. Believe me, if I could, I would help you, but that is beyond my knowledge. I can rewrite an XML, write a little PHP or a batch. But this is a bit more difficult... Unfortunately...
chef 3811 Posted November 2, 2021 Posted November 2, 2021 1 hour ago, TheUrbanXplorer said: Believe me, if I could, I would help you, but that is beyond my knowledge. I can rewrite an XML, write a little PHP or a batch. But this is a bit more difficult... Unfortunately... Not to worry my friend. @kingy444 is going to look over the code, and add his code to the project. It'll be like Avengers Assemble, or Forming Voltron. LOL 1 2
TheUrbanXplorer 36 Posted November 2, 2021 Posted November 2, 2021 29 minutes ago, chef said: Not to worry my friend. @kingy444 is going to look over the code, and add his code to the project. It'll be like Avengers Assemble, or Forming Voltron. LOL Sounds great! I am curious about the result.:-) (Admittedly a little impatient I am also ...)
horstepipe 423 Posted November 2, 2021 Posted November 2, 2021 so @chef is my assumption right that you agree to my naming episodes thing and you will implement it that way?
ttgapers 99 Posted November 4, 2021 Posted November 4, 2021 Updated and no visible issues as of yet! Thanks again. I am eagerly anticipating the release of the plugin that includes subtitle moves/copies as well!! Cheers to the Canucks in the house!
TheUrbanXplorer 36 Posted November 5, 2021 Posted November 5, 2021 On 11/2/2021 at 3:13 PM, chef said: Not to worry my friend. @kingy444 is going to look over the code, and add his code to the project. It'll be like Avengers Assemble, or Forming Voltron. LOL Morning @chef, I just wanted to nerve and ask what's the news from the front? Got a whole pack of movies with version and single subtitles just waiting for the test! 1
chef 3811 Posted November 5, 2021 Posted November 5, 2021 I'm going to work in this today. I need to brush up on some regular expressions, as well as attempt to code it. 2
TheUrbanXplorer 36 Posted November 10, 2021 Posted November 10, 2021 Hello @chef, is there already something new? 1
chef 3811 Posted November 10, 2021 Posted November 10, 2021 (edited) I've run into problems getting the sub files to copy into the right folder. They want to create their own... Kind of frustrating. I've got to follow the code backwards and find the right place to deal with subs. Luckily the movie Shang chi has many different types of sub files to deal with, so hopefully that will help. Edited November 10, 2021 by chef 2
TheUrbanXplorer 36 Posted November 10, 2021 Posted November 10, 2021 The title is actually based on the movie, isn't it? Accordingly, it should normally take the same directory, as with the different resolutions... I always say, computers have a life of their own...^^ Currently, the series and movies with me again and again takes the English name, not the German. But do not think that this is the plugin. Went yes all the time without problems. Then FFMPEG has apparently current problems with SD content (Anyway not your construction site), constantly the picture is gone, but the sound continues... Emby has her menstrual period. 1
TheUrbanXplorer 36 Posted November 20, 2021 Posted November 20, 2021 On 11/10/2021 at 3:20 PM, chef said: I've run into problems getting the sub files to copy into the right folder. They want to create their own... Kind of frustrating. I've got to follow the code backwards and find the right place to deal with subs. Luckily the movie Shang chi has many different types of sub files to deal with, so hopefully that will help. Hello @chef, since again quite a while has passed, I wanted to ask how it looks? Is anything ready yet?
chef 3811 Posted November 25, 2021 Posted November 25, 2021 (edited) I have been going over how to best handle these subtitles. I was able to add a list of found subtitles to the organization result. But, there is one big problem. Sometimes subtitle files are zipped up in a .rar/.zip files, and they also go 2 compressed files deep. That is a ordeal. It means that we have to extract them, make the connection between the extracted file, and the movie result, keep track of these file so we can successfully copy them, and then remove the extracted files in a file system clean up. It isn't impossible. But then I started thinking about emby's built in ability to download subtitles, and I started to wonder how important it is to organize these files. Most of my .mkv files also have subtitles inside the file. So, what should I do? Should I continue to work on this? Edited November 25, 2021 by chef 1
neik 874 Posted November 25, 2021 Posted November 25, 2021 5 minutes ago, chef said: It isn't impossible. But then I started thinking about emby's built in ability to download subtitles, and I started to wonder how important it is to organize these files. After playing with the skip intro, that will be the next playground for me: Auto-Downloading subs and sync them automatically if needed. 1
chef 3811 Posted November 25, 2021 Posted November 25, 2021 (edited) In the meantime, This is an updated version of Auto organize. But! inorder to use this version, you have to: 1. shut down the server 2. Open "Emby-Server/programdata/data" folder 3. Delete 'fileorganization.db' file 4. Spin up the server. It changes the database Emby.AutoOrganize.zip Edited November 25, 2021 by chef 1
