jscoys 147 Posted July 17, 2014 Posted July 17, 2014 Hello, If i'm right, currently screen saver starts even if MBT is open, hiding the beautiful screen saver integrated into MBT. Could you please prevent it from starting?
psykix 97 Posted July 24, 2014 Posted July 24, 2014 I just disable the Windows screensaver anyway - no idea what purpose it's supposed to serve these days. The MBT screensaver on the other hand is great - several times we have seen a movie and thought "oh, we must watch that!"
Luke 42237 Posted July 25, 2014 Posted July 25, 2014 i imagine there will eventually be configuration settings for it
jscoys 147 Posted July 26, 2014 Author Posted July 26, 2014 It's because I want to get the MBT screensaver activated even if I forget to launch MBT. So I use a screensaver program launcher starting on 2 minutes inactivity and launching mediabrowser theatre. So if I let my windows on desktop or on start screen (windows 8), it Will launch MBT! The problem is when MBT is already launched, it's a big mess because it launch MBT already running... And it's really anoying if i want to read long text into 2 minutes... So this feature would be really useful!
jscoys 147 Posted July 27, 2014 Author Posted July 27, 2014 Ok guys solved my problem meanwhile this feature is implemented... I've used eventghost. I put two events : 1) When Mediabrowser starts, I place a Python script deactivating screensaver, preventing my screensaver launcher to relaunch MBT 2) When Mediabrowser ends, I place a Python script activating screensaver, allowing my screensaver to launch MBT. Thanks!
A8HTPC 38 Posted August 1, 2014 Posted August 1, 2014 (edited) Wish I knew how to write python scripts. I used event ghost for awhile but couldn't get it bullet proof. If I could write python scripts im sure I could make it a lot better. Can u share the scripts? Edited August 1, 2014 by A8HTPC
jscoys 147 Posted August 2, 2014 Author Posted August 2, 2014 Ok here we are : You need to add two Events : - When process MediaBrowser is Created : Containing a Python Script with the code you can see on the top right windows. To copy/Paste : import win32gui, win32con win32gui.SystemParametersInfo(win32con.SPI_SETSCREENSAVEACTIVE,False) - When process MediaBrowser is Destroyed and Main.Init is raised : Containing a Python Script with the code you can see on the top right windows, but on line 3, you need to change the second parameter from FALSE to TRUE. To copy/paste : import win32gui, win32con win32gui.SystemParametersInfo(win32con.SPI_SETSCREENSAVEACTIVE,True) Why on Main.Init? Because if for any problems (PC Crash, Windows Blue screen followed by a reboot...) and the event process destroyed of MediaBrowser is not raised, your ScreenSaver won't be reactivated. So on the next boot of your PC the Event Main.Init coming for EventGhost app launching is raised and you're sure that the Screensaver is always reactivated! Hope this helped!
