Bigmack3000 108 Posted August 1, 2020 Posted August 1, 2020 Could the alternate order option please be added? Right now, DVD order and absolute order can be selected, but Alternate is missing. Below is an example of a show on TVDB with an alternate order. Thanks! 5 4
Luke 42246 Posted August 1, 2020 Posted August 1, 2020 Hi there, yes it's something we can look at adding in future updates. Thanks. 1
Happy2Play 9813 Posted August 1, 2020 Posted August 1, 2020 This can not happen until TVDB updates to v4 as there current api does not return these new orders. Right now, alternate orders aren't exposed on the current API. We do plan to include this in the future, though. https://emby.media/community/index.php?/topic/84572-additional-thetvdb-display-orders/
Bigmack3000 108 Posted August 2, 2020 Author Posted August 2, 2020 Do you know if this is something they plan on doing?
Happy2Play 9813 Posted August 2, 2020 Posted August 2, 2020 3 hours ago, Bigmack3000 said: Do you know if this is something they plan on doing? According to posts on their forum yes in their next update. But no timeline of when that will be.
Outbound 1 Posted August 2, 2020 Posted August 2, 2020 is there a way to make custom ordering for different menu's? for example: "MCU" in the "MCU Collection" menu i would like to place them in proper timeline - but in the base "Movies" menu I would like to have them alphabetically. any suggestions?
Luke 42246 Posted August 4, 2020 Posted August 4, 2020 On 8/2/2020 at 4:46 PM, Red Devil Law said: is there a way to make custom ordering for different menu's? for example: "MCU" in the "MCU Collection" menu i would like to place them in proper timeline - but in the base "Movies" menu I would like to have them alphabetically. any suggestions? You could do that with a playlist, although it might not be presented in the way that you're looking for.
Bigmack3000 108 Posted November 18, 2020 Author Posted November 18, 2020 TheTVDB sent out an email today saying they are upgrading to "v4". Is this what was needed to make these other Episode orders work? Also, would it fix this type of situation, where the dvd order was labeled as "Extended" instead, but the page is locked to changes. https://thetvdb.com/series/long-way-down
Happy2Play 9813 Posted November 18, 2020 Posted November 18, 2020 5 minutes ago, Bigmack3000 said: TheTVDB sent out an email today saying they are upgrading to "v4". Is this what was needed to make these other Episode orders work? Also, would it fix this type of situation, where the dvd order was labeled as "Extended" instead, but the page is locked to changes. https://thetvdb.com/series/long-way-down Well v4 will requires a Subscription to TVDB and as of right now we do not know the fate of TVDB plugin in Emby. But I would guess it will be reworked for user to add their subscription pin to the plugin for it to work. Since old api versions are suppose to work until March 2021, I wouldn't expect any thing to change until then.
Bigmack3000 108 Posted November 18, 2020 Author Posted November 18, 2020 If a subscription is required, does that mean in March we can no longer retrieve any metadata from there without one?
Happy2Play 9813 Posted November 18, 2020 Posted November 18, 2020 Just now, Bigmack3000 said: If a subscription is required, does that mean in March we can no longer retrieve any metadata from there without one? Correct, unless they announce something different. There is some discussion here (last couple pages) as they appear to want thousands a month if the devs were to foot the bill vs users 12/yr.
Luke 42246 Posted February 2, 2023 Posted February 2, 2023 19 minutes ago, Bigmack3000 said: any update on this? Hi, not yet, sorry, but it's possible for future updates. Thanks.
GrimReaper 4902 Posted April 15, 2023 Posted April 15, 2023 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
