guyhamawi 0 Posted August 7, 2020 Posted August 7, 2020 No not only on iOS. I tried from Android huawei and also from LG smart tv.
FSNTube 1 Posted August 11, 2020 Author Posted August 11, 2020 Hello @Luke sorry for the late reply, we've had a busy week due to the explosion we had in Beirut, i guess you've heard about it. Anyway, i took the logs while trying to watch from a huawei, the movie did not start this time, last time it was lagging same as it lags on my phone. I attached the logs for the server and for the ffmpeg. I tried 2 movies, one didnt start completely ( WHILE IT WORKS ON THE WEB FROM MY PC ) and other worked normally. If you want i can give you access to the server privately. log.txt FFMPEG.zip
FSNTube 1 Posted August 13, 2020 Author Posted August 13, 2020 Movie name : MILF USER : PATRICK PHONE: SAMSUNG S8+ Its lagging also. log.txt
Luke 42210 Posted August 25, 2020 Posted August 25, 2020 Please try removing the SamsungSmartThings plugin, then restart the server and see if that helps.
FSNTube 1 Posted August 26, 2020 Author Posted August 26, 2020 15 hours ago, Luke said: Please try removing the SamsungSmartThings plugin, then restart the server and see if that helps. Same issue.
Carlo 4561 Posted August 26, 2020 Posted August 26, 2020 Can you provide a fresh server log doing playback again without SamsungSmartThings installed? Your previous logs were full of errors caused by this (likely not configured). Thanks
FSNTube 1 Posted September 2, 2020 Author Posted September 2, 2020 Movie : MILF User watching : GEEZ device: iphone 7s plus. embyserver.txt
FSNTube 1 Posted September 2, 2020 Author Posted September 2, 2020 Just now, FSNTube said: Movie : MILF User watching : GEEZ device: iphone 7s plus. embyserver.txt 2.65 MB · 0 downloads @cayars this is a fresh server log while playing, movie is lagging also
Carlo 4561 Posted September 2, 2020 Posted September 2, 2020 Hi, You log is showing quite a few SocketException errors from that IP doing the remote play back. Are you playing back recordings?
FSNTube 1 Posted September 2, 2020 Author Posted September 2, 2020 Just now, cayars said: Hi, You log is showing quite a few SocketException errors from that IP doing the remote play back. Are you playing back recordings? Can you specify which user is playing back recordings? As i mentioned, user GEEZ players the movie MILF. I think another users are watching live tv at same time..
Carlo 4561 Posted September 2, 2020 Posted September 2, 2020 Not really anything interesting about this playback in the log.
FSNTube 1 Posted September 2, 2020 Author Posted September 2, 2020 Sorry for the question, what do you mean by playback ?
Carlo 4561 Posted September 2, 2020 Posted September 2, 2020 The logs showing any info about your user GEEZ playing MILF. Looks to be a direct play file which means this has nothing to do with Emby Server.
FSNTube 1 Posted September 2, 2020 Author Posted September 2, 2020 I am playing that movie from Emby application, on android and iphone, many movies are lagging, MILF is an example. if i play from web browser , it doesnt LAG. how can i know what is the problem??
Carlo 4561 Posted September 2, 2020 Posted September 2, 2020 Is this the web browser on the Android or iPhone you're referring to? Are these phone on the local LAN or REMOTE? Are they using the cell network or WIFI?
Luke 42210 Posted September 2, 2020 Posted September 2, 2020 1 hour ago, FSNTube said: I am playing that movie from Emby application, on android and iphone, many movies are lagging, MILF is an example. if i play from web browser , it doesnt LAG. how can i know what is the problem?? What version of the android app? What device and version of android?
FSNTube 1 Posted September 3, 2020 Author Posted September 3, 2020 I was testing on Emby application on android and ios. i will share the emby application version later. On PC web browser its working properly. yesterday i tried on the mobile browser and not through emby app, it worked properly.
Luke 42210 Posted September 4, 2020 Posted September 4, 2020 Ok thanks. Please let me know what version of the android app and what device and version of android.
