zomboided 5 Posted July 31, 2020 Posted July 31, 2020 Hello, thanks for Emby and the plugin, it's really great and works brilliantly with Kodi. I have the usual Movie and TV library set up, but I also have a separate Documentaries library which has a mixed content. Everytime I boot I see this error appear, which I don't think was there before I had the Documentaries library. https://www.dropbox.com/s/rmt0qoi7l8hzg71/kodi.log?dl=0 It's not a big deal as I can browse and play the contents of the library, but as an addon dev myself I see this in the log all the time and have finally gotten around to reporting it ;-) Cheers
Luke 42234 Posted July 31, 2020 Posted July 31, 2020 Hi, is there an entry in the server log at the same time, like for instance the http server rejecting a request? Also what addon do you develop?
zomboided 5 Posted August 1, 2020 Author Posted August 1, 2020 Hey, I develop a popular VPN plugin for LibreELEC, plus I have some stuff I just use personally to help me manage Kodi against my family trying to break it. Here's the server log https://www.dropbox.com/s/xszxa2x9g226rwj/embyserver.txt?dl=0 it probably covers a number of restarts but one deliberate one at 08:18. In this example I'm running Emby and Kodi on the same Windows box (192.168.1.72), but I get the same problem on my RPi boxes too, connecting to the same Emby server. I restarted the client to recreate a couple times. He's the view from the client so you can see the time stamps which are within a few seconds. 2020-08-01 08:18:06.372 T:892 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 2020-08-01 08:18:06.373 T:892 NOTICE: Emby.emby.client -> state cannot be empty 2020-08-01 08:18:06.544 T:892 NOTICE: EMBY.entrypoint.default -> path: ?type=mixed&mode=browse&id=f7b93310b9e773b95c46ee83d72464bc&reload= params: { "type": "mixed", "mode": "browse", "id": "f7b93310b9e773b95c46ee83d72464bc" } 2020-08-01 08:18:06.546 T:892 NOTICE: EMBY.entrypoint.default -> --[ v:f7b93310b9e773b95c46ee83d72464bc/mixed ] None 2020-08-01 08:18:06.595 T:9492 NOTICE: ZTools : (service.py) Starting Zomboided Tools service, version is 0.7.2 2020-08-01 08:18:06.595 T:9492 NOTICE: ZTools : (service.py) Kodi build is 18.7 Git:20200520-f14f7a84e3 2020-08-01 08:18:06.624 T:892 NOTICE: EMBY.default -> ERROR:: 'Device name cannot be null' Traceback (most recent call last): File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 41, in <module> Events() File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\entrypoint\default.py", line 150, in __init__ browse(params.get('type'), params.get('id'), params.get('folder'), server) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\entrypoint\default.py", line 391, in browse view = EMBY['api'].get_item(view_id) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 138, in get_item return self.users("/Items/%s" % item_id) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 86, in users return self._get("Users/{UserId}%s" % handler, params) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 53, in _get return self._http("GET", handler, {'params': params}) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 50, in _http return self.client.request(request) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\http.py", line 86, in request data = self._request(data) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\http.py", line 190, in _request self._get_header(data) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\http.py", line 228, in _get_header self._authorization(data) File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\http.py", line 235, in _authorization raise KeyError("Device name cannot be null") KeyError: 'Device name cannot be null' 2020-08-01 08:18:06.625 T:892 NOTICE: EMBY.default -> ---<[ default ] 2020-08-01 08:18:06.773 T:9276 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby/?type=mixed&mode=browse&id=f7b93310b9e773b95c46ee83d72464bc&reload=
zomboided 5 Posted August 12, 2020 Author Posted August 12, 2020 Hey, any ideas with this one, do you need any more debug?
Luke 42234 Posted August 12, 2020 Posted August 12, 2020 Hi, not yet, sorry. It's on our backlog for review. 1
zomboided 5 Posted August 12, 2020 Author Posted August 12, 2020 Ok, no problem, thanks for the reply. This isn't a big deal for me, I was just wandering.
quickmic 1709 Posted August 15, 2020 Posted August 15, 2020 (edited) I have the same problem, but with "homevideos". You can try as follows: open file: /home/quickmic/.kodi/addons/plugin.video.emby/resources/lib/entrypoint/default.py (modify path to your actual kodi installation folder) search and replace this line: "browse(params.get('type'), params.get('id'), params.get('folder'), server)" with that one: "browse(params.get('type'), params.get('id'), params.get('folder'), params.get('server'))" I'm still testing this fix, but at least the kodi.log is now clean. Update: This fix does not address the core issue. I'm working on that, but for the moment you can use it as a dirty workaround. Edited August 15, 2020 by quickmic
zomboided 5 Posted August 16, 2020 Author Posted August 16, 2020 Thanks @quickmic I tried it and I get the same assert as previously. Thanks for the suggestion though.
quickmic 1709 Posted August 17, 2020 Posted August 17, 2020 Thanks, for the feedback, I'll try with "mixed content". Hoping I can find the actual problem. 1
quickmic 1709 Posted August 27, 2020 Posted August 27, 2020 (edited) Still haven't found a proper solution, but I can tell you it's a timing issue and I know where the problem is located. e.g. If I deactivate Estuary-modv2 Skin, the one I'm using, no issue. NOTICE: EMBY.entrypoint.default -> path: ?type=mixed&mode=browse&id=f7b93310b9e773b95c46ee83d72464bc&reload= params: { "type": "mixed", "mode": "browse", "id": "f7b93310b9e773b95c46ee83d72464bc" } The log record comes from a very early event call, before emby-for-kodi plugin wasn't fully initialized. If I start with default skin, this event call will not be triggered. If I switch to mod-skin after booting with default skin, the event is also called, but as emby-for-kodi is fully loaded, the call doesn't raise the issue. I could skip the event call before emby-for-kodi is fully loaded, but this would be a dirty hack. Edited August 28, 2020 by quickmic
zomboided 5 Posted August 28, 2020 Author Posted August 28, 2020 Yeah, confirmed. I'm using the super clean Lyrebird skin, which maybe is dead/dying from a support perspective If I switched back to Estuary, the problem goes away. You think this is a problem with all mod skins or is this something that really needs fixing on a skin by skin basis?
quickmic 1709 Posted August 28, 2020 Posted August 28, 2020 Yesterday after my posting, I guess I found a propper solution. This should fix all possible issues related to that matter, but still testing it. I drop it here as soon as I'm confinced, it has no sideeffects. 1
quickmic 1709 Posted August 28, 2020 Posted August 28, 2020 (edited) try as follows... modify this file: /home/quickmic/.kodi/addons/plugin.video.emby/default.py replace this section: ################################################################################################# from entrypoint import Events ################################################################################################# with this code: ################################################################################################# from helper import window #Verify emby for kodi plugin is fully loaded, timeout after 30 seconds EmbyOnline = False for i in range(60): if window('emby_online.bool'): EmbyOnline = True from entrypoint import Events break else: xbmc.sleep(500) if not EmbyOnline: exit() ################################################################################################# Please let me know, if this fixes the issue... thanks Edited August 28, 2020 by quickmic 1
zomboided 5 Posted August 28, 2020 Author Posted August 28, 2020 Excellent job, thanks! Don't see any issues - here's the log from the boot time. It's not barfing after it finds that mixed content library any more. 2020-08-28 17:06:38.918 T:6660 NOTICE: EMBY.patch -> --->[ patch ] 2020-08-28 17:06:38.919 T:11436 NOTICE: EMBY.hooks.webservice -> --->[ webservice/57578 ] 2020-08-28 17:06:38.932 T:6660 NOTICE: EMBY.patch -> --[ check updates/181167264 ] 2020-08-28 17:06:40.730 T:6660 NOTICE: EMBY.patch -> --<[ objects/181167264 ] 2020-08-28 17:06:41.474 T:6660 NOTICE: EMBY.service -> -->[ service ] 2020-08-28 17:06:41.476 T:6660 NOTICE: EMBY.service -> Delay startup by 0 seconds. 2020-08-28 17:06:42.428 T:336 NOTICE: EMBY.entrypoint.service -> --->>>[ EMBY ] 2020-08-28 17:06:42.435 T:336 NOTICE: EMBY.entrypoint.service -> Version: 4.1.19 2020-08-28 17:06:42.437 T:336 NOTICE: EMBY.entrypoint.service -> KODI Version: 18.7 Git:20200520-f14f7a84e3 2020-08-28 17:06:42.449 T:336 NOTICE: EMBY.entrypoint.service -> Platform: Windows 2020-08-28 17:06:42.465 T:336 NOTICE: EMBY.entrypoint.service -> OS: Kodi/7893MB 2020-08-28 17:06:42.467 T:336 NOTICE: EMBY.entrypoint.service -> Python Version: 2.7.13 (default, Jul 14 2017, 17:41:26) [MSC v.1900 64 bit (AMD64)] 2020-08-28 17:06:42.490 T:336 NOTICE: EMBY.entrypoint.service -> Using dynamic paths: True 2020-08-28 17:06:42.491 T:336 NOTICE: EMBY.entrypoint.service -> Log Level: 1 2020-08-28 17:06:42.969 T:336 NOTICE: EMBY.entrypoint.service -> ---[ db/None ] 2020-08-28 17:06:45.528 T:336 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 2020-08-28 17:06:47.586 T:336 NOTICE: EMBY.views -> Unable to retrieve libraries: NotConnected 2020-08-28 17:06:47.736 T:336 NOTICE: EMBY.client -> DeviceId loaded: 2A5B40E92A6745628638475FF16AAD99 2020-08-28 17:06:47.813 T:2624 NOTICE: EMBY.hooks.monitor -> --->[ listener ] 2020-08-28 17:06:47.819 T:728 NOTICE: Emby -> ---[ STOPPED EMBYCLIENT: default ]--- 2020-08-28 17:06:47.830 T:728 NOTICE: EMBY.connect -> --[ server/default ] 2020-08-28 17:06:47.887 T:728 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 2020-08-28 17:06:47.947 T:728 NOTICE: Emby.emby.core.connection_manager -> Begin connect 2020-08-28 17:06:49.842 T:728 NOTICE: Emby.emby.core.connection_manager -> Found Servers: [{u'Name': u'Emby', u'Id': u'5d91b4cf32f741bab43949e651dea575', u'Address': u'http://{emby-server}'}] 2020-08-28 17:06:49.914 T:728 NOTICE: Emby.emby.core.connection_manager -> Begin connectToServers, with 1 servers 2020-08-28 17:06:49.915 T:728 NOTICE: Emby.emby.core.connection_manager -> testing connection mode 0 with server Emby 2020-08-28 17:06:49.915 T:728 NOTICE: Emby.emby.core.connection_manager -> tryConnect url: http://{emby-server}/emby/system/info/public 2020-08-28 17:06:50.298 T:728 NOTICE: Emby.emby.core.connection_manager -> calling onSuccessfulConnection with connection mode 0 with server Emby 2020-08-28 17:06:50.780 T:728 NOTICE: Emby.emby.client -> User is authenticated. 2020-08-28 17:06:53.460 T:2044 NOTICE: EMBY.hooks.monitor -> -->[ q:monitor/LoadServer ] 2020-08-28 17:06:53.461 T:2044 NOTICE: EMBY.hooks.monitor -> --[ post capabilities/5d91b4cf32f741bab43949e651dea575 ] 2020-08-28 17:06:53.500 T:1472 NOTICE: Emby.emby.core.ws_client -> Websocket url: ws://{emby-server}/embywebsocket?api_key={emby-token}&device_id=2A5B40E92A6745628638475FF16AAD99 2020-08-28 17:06:53.737 T:728 NOTICE: EMBY.setup -> ---<[ setup ] 2020-08-28 17:06:53.821 T:10608 NOTICE: EMBY.library -> --->[ library ] 2020-08-28 17:06:54.383 T:336 NOTICE: EMBY.entrypoint.service -> [ onNotification/plugin.video.emby/ServerOnline ] 2020-08-28 17:06:54.384 T:1472 NOTICE: Emby.emby.core.ws_client -> --->[ websocket ] 2020-08-28 17:06:55.110 T:7596 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 2020-08-28 17:06:55.340 T:7596 NOTICE: EMBY.entrypoint.default -> path: ?type=mixed&mode=browse&id=f7b93310b9e773b95c46ee83d72464bc&reload= params: { "type": "mixed", "mode": "browse", "id": "f7b93310b9e773b95c46ee83d72464bc" } 2020-08-28 17:06:55.345 T:7596 NOTICE: EMBY.entrypoint.default -> --[ v:f7b93310b9e773b95c46ee83d72464bc/mixed ] None 2020-08-28 17:06:55.800 T:10608 NOTICE: EMBY.database -> [emby] 1 rows updated. 2020-08-28 17:06:57.220 T:10608 NOTICE: Previous line repeats 4 times. 2020-08-28 17:06:57.220 T:10608 NOTICE: EMBY.library -> --[ retrieve changes ] 2020-08-28T09:25:58z 2020-08-28 17:06:59.507 T:10608 NOTICE: EMBY.library -> --<[ retrieve changes ] 2020-08-28 17:06:59.523 T:10608 NOTICE: EMBY.library -> -->[ q:userdata/Episode/1972043205768 ] 2020-08-28 17:06:59.548 T:10608 NOTICE: EMBY.helper.utils -> ---[ screensaver/ ] {u'jsonrpc': u'2.0', u'id': 1, u'result': True} 2020-08-28 17:06:59.708 T:12028 NOTICE: EMBY.objects.core.tvshows -> USERDATA episode [569/569] 24522: Queen Thistle's Teapot 2020-08-28 17:07:00.723 T:12028 NOTICE: EMBY.database -> [emby] 1 rows updated. 2020-08-28 17:07:00.790 T:12028 NOTICE: EMBY.database -> [video] 1 rows updated. 2020-08-28 17:07:00.880 T:12028 NOTICE: EMBY.library -> --<[ q:userdata/1972043205768 ] 2020-08-28 17:07:02.734 T:10608 NOTICE: EMBY.library -> --[ sync/2020-08-28T16:05:02z ] 2020-08-28 17:07:02.746 T:10608 NOTICE: EMBY.helper.utils -> ---[ screensaver/ ] {u'jsonrpc': u'2.0', u'id': 1, u'result': True} 2020-08-28 17:07:02.823 T:11292 NOTICE: VideoInfoScanner: Starting scan .. 2020-08-28 17:07:02.825 T:11292 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00 2020-08-28 17:07:02.860 T:336 NOTICE: EMBY.hooks.monitor -> -->[ kodi scan/video ] 2020-08-28 17:07:02.860 T:336 NOTICE: EMBY.objects.monitor -> [ xbmc/VideoLibrary.OnScanStarted ] 2020-08-28 17:07:02.861 T:336 NOTICE: EMBY.hooks.monitor -> --<[ kodi scan/video ] 2020-08-28 17:07:02.861 T:336 NOTICE: EMBY.objects.monitor -> [ xbmc/VideoLibrary.OnScanFinished ] 2020-08-28 17:07:03.790 T:7596 NOTICE: EMBY.default -> ---<[ default ] 1
quickmic 1709 Posted September 5, 2020 Posted September 5, 2020 Just checking, did you had any issues with this fix?
zomboided 5 Posted September 7, 2020 Author Posted September 7, 2020 Hello, no issues at all on my Windows dev machine and I've restarted Kodi on that 10s of times since I made the change you suggested. I have not tried it on any of my 'live' Kodi Raspberry Pi boxes for fear of family reprisal if it didn't work. Do you want me to do try it there too, or am I good to wait for the update? It's no bother if this is worth doing to give you confidence. 1
quickmic 1709 Posted September 7, 2020 Posted September 7, 2020 Thanks for the feedback. No, you can wait for the update. Just checking, if you had issues with this fix so far. Actually it's very good, you have tested on Windows. I have only Linux systems, Raspberry Libreelec and Vero4K OSMC. 1
