sooty234 266 Posted August 2, 2020 Posted August 2, 2020 Your GTX 1050 shouldn't struggle. I have one in one of my machines. You may just need to dial in the configuration. What settings are you using in Theater? A screenshot would be helpful.
Wheemer 50 Posted August 2, 2020 Author Posted August 2, 2020 It's probably because of my CPU and motherboard which is older. With 12 bit I get micro stutters but with 8 bit it's perfect. Everything is set to auto right now. But like I said I tried all variations and no improvement. Nothing to do with my settings.
sooty234 266 Posted August 2, 2020 Posted August 2, 2020 mpv has many more options than what are shown in Theater. https://mpv.io/manual/master/
Wheemer 50 Posted August 3, 2020 Author Posted August 3, 2020 Wow... well for now I am happy with the performance and beautiful picture. So I won't mess with it anymore I guess. Thanks for the help. 1
blixt99 1 Posted August 18, 2020 Posted August 18, 2020 (edited) On 8/1/2020 at 4:04 PM, Wheemer said: I found this program https://github.com/bradgearon/hdr-switch/releases I have it running on startup in my tray. I made a ET.cmd with the following: "C:\Program Files\HDRSwitch\hdr_switch_tray.exe" hdr "C:\Users\Media\AppData\Roaming\Emby-Theater\system\Emby.Theater.exe" "C:\Program Files\HDRSwitch\hdr_switch_tray.exe" hdr I modified the Emby Theater shortcut to point to this file and I fixed the icon back to Emby. Now Emby Theater auto switches in and out of HDR. Pretty darn cool! Hey Wheemer, I tried doing exactly what you said above and it did not work for me. Now I am using Win 7 and all I got was a black screen saying "Playback Error - No compatible streams are currently available" and two error messages that said " HDR Switch Error Error seeing hdr mode: NVAPI_ERROR" This seems like it may be an Nvidia GPU issue. Also I did not fully grasp it when you said " I fixed the icon back to Emby." Edited August 18, 2020 by blixt99
Luke 42241 Posted August 19, 2020 Posted August 19, 2020 It enables a windows HDR option which doesn't exist in windows 7 so it's not going to work for you. 1
blixt99 1 Posted August 19, 2020 Posted August 19, 2020 I see. Thanks Luke. I still don't know what Wheemer meant by " I fixed the icon back to Emby." Can you explain?
Carlo 4561 Posted August 19, 2020 Posted August 19, 2020 (edited) He changed what the "shortcut" was pointing to in windows (the HDR script vs Emby) but then edited it to use the icon. So it would change the screen mode, launch Emby Theater then switch back on Theater exit with the Emby icon on the desktop. Edit: @blixt99 anyone ever tell you that you look a bit like Alex Lifeson of Rush? (at least your pic does if you weren't wearing glasses). You don't happen to know how to play La Villa Strangiato or Tom Sawyer on a Guitar by chance do you? LOL Edited August 19, 2020 by cayars 1
blixt99 1 Posted November 5, 2020 Posted November 5, 2020 (edited) I really appreciate Wheemer's help. But I have found that if I install MPC-HCx64 and MadVR and set them up with MPC to run in fullscreen and MadVR to passthrough the HDR metadata (as an external video player in Emby Theater), then when I play a 4K HDR video or movie in MPC it will minimize the Emby Theater screen and the HDR metadata WILL pass through to my LG 4K HDR monitor or TV, even in Win 7. Edited November 5, 2020 by blixt99
