ErelyesNZ 3 Posted July 31, 2020 Posted July 31, 2020 I have a compilation album (various artists), musicbrainz release is here. Emby flat out insists on recording the album artist as 'The Prodigy'. The files are in a various artists folder, I have set all the mp3 tags manually, I have tried deleting both the artist (The Prodigy) and the album's .nfo tags.... still, whenever Emby scrapes this album, it can't get the correct data, and sets it to album artist : The Prodigy. I can't manually edit the album artist either. Can we please have the ability to manually set the 'album artist' for an album. (This has been an issue for a while I think)
Steven 159 Posted August 6, 2020 Posted August 6, 2020 As long as the files are in the album title folder within the Various Artists folder you should be able to enter the MusicBrainz Id's to fix it: MusicBrainz Album Id: a024d2bb-40e3-4033-b540-9409b8c771ec MusicBrainz Album Artist Id: 89ad4ac3-39f7-470e-963a-56509c546377 MusicBrainz Release Group Id: 94f70739-7f3f-489e-b138-d7f4fe36759a Hope this helps.
Luke 42210 Posted August 9, 2020 Posted August 9, 2020 Or use the identify feature. Have you tried that?
Guest Posted August 10, 2020 Posted August 10, 2020 20 hours ago, Luke said: Or use the identify feature. Have you tried that? I have literally never got anything other than a blank page when trying to use this. I have looked in the knowledge base but still nothing.
Carlo 4561 Posted August 10, 2020 Posted August 10, 2020 1 hour ago, jlambie said: I have literally never got anything other than a blank page when trying to use this. I have looked in the knowledge base but still nothing. Can you give us an example of a movie or tv show that can't identify?
Guest Posted August 10, 2020 Posted August 10, 2020 34 minutes ago, cayars said: Can you give us an example of a movie or tv show that can't identify? Hi - it was music (albums) it wouldn't identify. Thanks
Steven 159 Posted August 10, 2020 Posted August 10, 2020 (edited) Same here, I don’t get any results which is why I recommended entering the info. Edited August 10, 2020 by Steven
Guest Posted August 10, 2020 Posted August 10, 2020 2 minutes ago, Steven said: Same here, I don’t get any results which is why I recommended entering the info. Yes, I do end up doing that. I just wasn't sure if others did tend to find it gave suggestions - seems so for other media, but not music, sounds like.
Happy2Play 9802 Posted August 10, 2020 Posted August 10, 2020 We would need specific examples with folder structure. Also what embedded tags the tracks already contain. If no embedded tags, then the specific naming scheme. 1
Luke 42210 Posted August 22, 2020 Posted August 22, 2020 On 8/10/2020 at 3:41 PM, jlambie said: I have literally never got anything other than a blank page when trying to use this. I have looked in the knowledge base but still nothing. @jlambie can you please go over an example and attach the emby server log? thanks.
