vin91 3 Posted July 29, 2020 Posted July 29, 2020 Bonjour J'ai un problème avec l'extension: Auto Box Sets J'ai la collection de Bruce Lee et le film "Big boss" n'apparait pas, j'ai éssayer de renommer les fichiers mais sa change rien. Quelqu'un aurait il une idée ? Merci
Carlo 4561 Posted July 30, 2020 Posted July 30, 2020 I'm not seeing a Bruce Lee colletion on https://www.themoviedb.org/ Are you sure this isn't one you manually created?
vin91 3 Posted July 30, 2020 Author Posted July 30, 2020 No, the collection appeared just by doing a refresh of the addon. Besides, I believe that it is not possible to manually create a collection with "Auto box sets"
Carlo 4561 Posted July 30, 2020 Posted July 30, 2020 No you can't make a collection using Auto Box Sets but you can make manual collections. For example go to movies in the web browser and use the mutli-select and pick two or three movies. You'll get a new bar up top showing the number selected. Now over on the right is the 3 dot menu with a collections option. You can then add these movies to an existing collection or create a new collection. So you can create your own. Also never mentioned but if you search for Big boss and then click the 3 dot menu on the box cover you can add this to a collection. Just pick your existing Bruce Lee Collection and it will get added to it.
vin91 3 Posted July 30, 2020 Author Posted July 30, 2020 Ok, I didn't know it was possible to do it yourself. Thank you very much for the explanations 1
vin91 3 Posted July 30, 2020 Author Posted July 30, 2020 great, its working very well thank you so much 1
