CharleyVarrick 284 Posted July 29, 2020 Posted July 29, 2020 (edited) Hi, first an overall picture of my setup pc#1, Emby server, pc#2, htpc running Emby for Kodi: no issues pc#3, pc running Emby for Kodi, has not updated new content since July 17 When I fire up Kodi, I get the Emby user greeting, but I don't see the library update animation. Is there anything you suggest I try ? EDIT: Having encountered this issue already, I looked up previous fix and toggled playback mode from Add-On to Native, then back to add on. This triggered a library sync of the "whole kind". This will take a while, and in the end, It'll very likely update libraries to speed. The real test will be tomorrow morning after a crop of new tv episodes. I'll report back then if library updates are back for good. Edited July 29, 2020 by jlr19
unibeta 7 Posted July 30, 2020 Posted July 30, 2020 Same with me a few days ago. Emby server shows the logged in Kodi user, but there are no databases in Kodi under the green emby button. If I start a film in Kodi it will be shown under "active devices". is displayed correctly.
unibeta 7 Posted July 31, 2020 Posted July 31, 2020 Since nothing happens here, I have deactivated the use of the Emby Companion and re-read the database. So for now it runs...
unibeta 7 Posted August 1, 2020 Posted August 1, 2020 There was no media coverage. The menu under the green emby button started at "Manage Databases", all items before that were not displayed. The local database still had the latest version and you could also start from it and this was also displayed on the emby server. The connection to the server works but somehow the media is missing. Under "Update databases" he displayed them but nothing happened, there was also no popup message
Luke 42234 Posted August 14, 2020 Posted August 14, 2020 @jlr19 @unibeta Are you still running into this?
unibeta 7 Posted September 4, 2020 Posted September 4, 2020 Unfortunately only now seen... In the meantime I could activate it again and it runs Thanks!
CharleyVarrick 284 Posted September 13, 2020 Author Posted September 13, 2020 On 14/08/2020 at 15:47, Luke said: @jlr19 @unibeta Are you still running into this? It happens once in a while, as recently as last week, but at least in my case, I discovered that if I leave Kodi opened long enough (as in multi hours), it eventually processes update.
