Guest agola Posted July 29, 2020 Posted July 29, 2020 I'm using ServerWMC with Emby on my Roku and it works great, but I would love to have more channels displayed at a time in the guide. Is there a way to customize this? The default setting of 5 is just not enough.
Luke 42244 Posted July 29, 2020 Posted July 29, 2020 Hi, there's currently no option for this, but we'll probably try to improve it to show more rows in future updates. thanks for the feedback.
SHSPVR 125 Posted July 31, 2020 Posted July 31, 2020 On 7/29/2020 at 12:41 PM, Luke said: Hi, there's currently no option for this, but we'll probably try to improve it to show more rows in future updates. thanks for the feedback. No way I like it the way it is if have just add custom option for there's that want more row
blasta 2 Posted August 4, 2020 Posted August 4, 2020 Hi I actualy have the same question or maybe there's another answer ... In the mini guide How can i get my emby to show more row ? 2 is just not enough. Here's what i currently have Thanks !
ebr 16337 Posted August 4, 2020 Posted August 4, 2020 11 hours ago, blasta said: Hi I actualy have the same question or maybe there's another answer ... In the mini guide How can i get my emby to show more row ? 2 is just not enough. Here's what i currently have Thanks ! Hi. This screenshot is from what exact device?
blasta 2 Posted August 4, 2020 Posted August 4, 2020 (edited) Emby Android Tv from a dreamlink T2, (Downloaded from google play store) I've also tested it in Emby theater however there is no option to view the mini guide and same for the regular android app and directly from the web browser (Firefox). At the moment it's stopping me from changing my home config and switching to my home media server. I've discuss with the wife and this is a no go if i can't fix it. But i love emby so far Client : Android Box : dreamlink T2 Android version : 7.0 Software: Emby for Android TV (from google play store) 1.8.10g Server : Rasberry Pi 4 OS : Rasbian Emby Server Version : 4.4.3 / 4.5.0.16-beta / 4.5.0.15-beta beta (tested all of them) Thanks for following up ! Edited August 5, 2020 by blasta Additional information
ebr 16337 Posted August 5, 2020 Posted August 5, 2020 Okay, so that is an off-brand Android box. It isn't reporting its pixel density correctly. If you have any control over this in the settings, please try changing them (zoom, etc.). You can also turn on the "Compact Guide" option. 1
blasta 2 Posted August 5, 2020 Posted August 5, 2020 12 hours ago, ebr said: Okay, so that is an off-brand Android box. It isn't reporting its pixel density correctly. If you have any control over this in the settings, please try changing them (zoom, etc.). You can also turn on the "Compact Guide" option. Thank you for pointing me to the wright direction. I actually have try that on my remote but didn't work. I ended up going into the box Android setting and changed the Display settings 720UI to 1080ui (rebooted) Now i can see 5 channels EPG at the same time when i press my epg button on my remote. I'm glad you took the time to answer cause It could of be hard to find since it's not even SW related. Thanks again (but I guess That's why I love Emby so far !) 2
ebr 16337 Posted August 6, 2020 Posted August 6, 2020 Glad you got it figured out. Thanks for reporting back.
