amaga 4 Posted July 29, 2020 Posted July 29, 2020 Hi I'm trying to connect to my Emby server from an external network but I can't seem to get it working. Connecting through the internal network is fine. I am using two different ports for Emby - 8096 for the internal network and 8067 for the external network. Port forwarding on my network is working, because when I run port listener on the emby server machine, I am able to access port 8067 from outside. I have also created rules in windows firewall to allow connections to the port I'm using, and also tried disabling the firwall entirely, but that didn't seem to work. When I try using emby connect, it works when I'm connected to the internal network, but not when I try to access from the outside. I really ran out of ideas, since this just seems to be an issue with emby listening at the configured port. I'm attaching the latest server logs with debugging on below. If anybody has any ideas, they are really welcome. 2020-07-28 23:42:00.970 Info Main: Application path: C:\Users\Andre\AppData\Roaming\Emby-Server\system\EmbyServer.dll 2020-07-28 23:42:01.187 Info Main: Emby Command line: C:\Users\Andre\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/Andre/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.4 Processor count: 4 Program data path: C:\Users\Andre\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Andre\AppData\Roaming\Emby-Server\system 2020-07-28 23:42:01.188 Info Main: Tray icon path: C:\Users\Andre\AppData\Roaming\Emby-Server\system\embytray 2020-07-28 23:42:01.213 Info App: Application version: 4.4.3.0 2020-07-28 23:42:01.213 Info App: Loading assemblies 2020-07-28 23:42:01.229 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\AudioDb.dll has version 1.0.11.0 2020-07-28 23:42:01.230 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\AudioDb.dll has version 1.0.10.0 2020-07-28 23:42:01.230 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\BlurayMounter.dll has version 1.0.0.0 2020-07-28 23:42:01.230 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\BlurayMounter.dll has version 1.0.0.0 2020-07-28 23:42:01.231 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\DvdMounter.dll has version 1.0.0.0 2020-07-28 23:42:01.231 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\DvdMounter.dll has version 1.0.0.0 2020-07-28 23:42:01.232 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Dlna.dll has version 1.0.38.0 2020-07-28 23:42:01.232 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\Emby.Dlna.dll has version 1.0.38.0 2020-07-28 23:42:01.233 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.PortMapper.dll has version 1.0.4.0 2020-07-28 23:42:01.233 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\Emby.PortMapper.dll has version 1.0.4.0 2020-07-28 23:42:01.234 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Server.CinemaMode.dll has version 1.0.33.0 2020-07-28 23:42:01.234 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\Emby.Server.CinemaMode.dll has version 1.0.32.0 2020-07-28 23:42:01.234 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Webhooks.dll has version 1.0.12.0 2020-07-28 23:42:01.235 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\Emby.Webhooks.dll has version 1.0.12.0 2020-07-28 23:42:01.235 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Fanart.dll has version 1.0.8.0 2020-07-28 23:42:01.235 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\Fanart.dll has version 1.0.8.0 2020-07-28 23:42:01.236 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\MovieDb.dll has version 1.3.5.0 2020-07-28 23:42:01.236 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\MovieDb.dll has version 1.3.4.0 2020-07-28 23:42:01.237 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\MusicBrainz.dll has version 1.0.13.0 2020-07-28 23:42:01.237 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\MusicBrainz.dll has version 1.0.13.0 2020-07-28 23:42:01.237 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\NfoMetadata.dll has version 1.0.31.0 2020-07-28 23:42:01.238 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\NfoMetadata.dll has version 1.0.30.0 2020-07-28 23:42:01.238 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\OMDb.dll has version 1.0.10.0 2020-07-28 23:42:01.238 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\OMDb.dll has version 1.0.9.0 2020-07-28 23:42:01.239 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\OpenSubtitles.dll has version 1.0.27.0 2020-07-28 23:42:01.239 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\OpenSubtitles.dll has version 1.0.27.0 2020-07-28 23:42:01.239 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\StudioImages.dll has version 1.0.3.0 2020-07-28 23:42:01.239 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\StudioImages.dll has version 1.0.3.0 2020-07-28 23:42:01.240 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Tvdb.dll has version 1.0.34.0 2020-07-28 23:42:01.240 Info App: File C:\Users\Andre\AppData\Roaming\Emby-Server\system\plugins\Tvdb.dll has version 1.0.32.0 2020-07-28 23:42:01.711 Info App: Loading AudioDb, Version=1.0.11.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\AudioDb.dll 2020-07-28 23:42:01.711 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\BlurayMounter.dll 2020-07-28 23:42:01.711 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\DvdMounter.dll 2020-07-28 23:42:01.711 Info App: Loading Emby.Dlna, Version=1.0.38.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Dlna.dll 2020-07-28 23:42:01.711 Info App: Loading Emby.PortMapper, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.PortMapper.dll 2020-07-28 23:42:01.711 Info App: Loading Emby.Server.CinemaMode, Version=1.0.33.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Server.CinemaMode.dll 2020-07-28 23:42:01.711 Info App: Loading Emby.Webhooks, Version=1.0.12.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Webhooks.dll 2020-07-28 23:42:01.711 Info App: Loading Fanart, Version=1.0.8.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Fanart.dll 2020-07-28 23:42:01.711 Info App: Loading MovieDb, Version=1.3.5.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\MovieDb.dll 2020-07-28 23:42:01.711 Info App: Loading MusicBrainz, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\MusicBrainz.dll 2020-07-28 23:42:01.711 Info App: Loading NfoMetadata, Version=1.0.31.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\NfoMetadata.dll 2020-07-28 23:42:01.711 Info App: Loading OMDb, Version=1.0.10.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\OMDb.dll 2020-07-28 23:42:01.711 Info App: Loading OpenSubtitles, Version=1.0.27.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\OpenSubtitles.dll 2020-07-28 23:42:01.711 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\StudioImages.dll 2020-07-28 23:42:01.711 Info App: Loading Tvdb, Version=1.0.34.0, Culture=neutral, PublicKeyToken=null from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\plugins\Tvdb.dll 2020-07-28 23:42:01.711 Info App: Loading Emby.Api, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Web, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading MediaBrowser.Model, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading MediaBrowser.Common, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading MediaBrowser.Controller, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Providers, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Photos, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Server.Implementations, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.LiveTV, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.ActivityLog, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Server.MediaEncoding, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.LocalMetadata, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Notifications, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Codecs.Dxva, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Codecs, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Server.Connect, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading Emby.Server.Sync, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.711 Info App: Loading EmbyServer, Version=4.4.3.0, Culture=neutral, PublicKeyToken=null 2020-07-28 23:42:01.810 Info SqliteUserRepository: Sqlite version: 3.30.1 2020-07-28 23:42:01.811 Info SqliteUserRepository: Sqlite compiler options: COMPILER=msvc-1500,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_RTREE,ENABLE_STMTVTAB,MAX_TRIGGER_DEPTH=100,TEMP_STORE=1,THREADSAFE=1 2020-07-28 23:42:01.821 Info SqliteUserRepository: Default journal_mode for C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\users.db is wal 2020-07-28 23:42:01.849 Info AuthenticationRepository: Default journal_mode for C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\authentication.db is wal 2020-07-28 23:42:01.864 Info ActivityRepository: Default journal_mode for C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\activitylog.db is wal 2020-07-28 23:42:01.867 Info SqliteDisplayPreferencesRepository: Default journal_mode for C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\displaypreferences.db is wal 2020-07-28 23:42:01.872 Info App: Adding HttpListener prefix http://+:8096/ 2020-07-28 23:42:01.936 Info SqliteItemRepository: Default journal_mode for C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\library.db is wal 2020-07-28 23:42:02.780 Info Skia: SkiaSharp version: 1.68.0.0 2020-07-28 23:42:02.843 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 07/29/2020 09:00:00, which is 557.9526130333334 minutes from now. 2020-07-28 23:42:02.847 Info TaskManager: Daily trigger for Rotate log file set to fire at 07/29/2020 00:00:00, which is 17.952534178333334 minutes from now. 2020-07-28 23:42:02.851 Info App: ServerId: 982345e3be1645a3bf99daeae10c96e5 2020-07-28 23:42:02.887 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2020-07-28 23:42:02.960 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 2020-07-28 23:42:03.046 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.1593048 seconds 2020-07-28 23:42:03.046 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2020-07-28 23:42:03.047 Info App: Loading data from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\connect.txt 2020-07-28 23:42:03.049 Info App: Loading data from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\wan.dat 2020-07-28 23:42:03.052 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0055528 seconds 2020-07-28 23:42:03.052 Info App: Core startup complete 2020-07-28 23:42:03.052 Info App: Post-init migrations complete 2020-07-28 23:42:03.052 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2020-07-28 23:42:03.052 Info App: Init BeginReceive on 0.0.0.0 2020-07-28 23:42:03.052 Info App: Init BeginReceive on 192.168.1.119 2020-07-28 23:42:03.052 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.0001626 seconds 2020-07-28 23:42:03.052 Info App: Starting entry point Emby.Security.PluginSecurityManager 2020-07-28 23:42:03.052 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.74E-05 seconds 2020-07-28 23:42:03.052 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2020-07-28 23:42:03.052 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 9.56E-05 seconds 2020-07-28 23:42:03.052 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint 2020-07-28 23:42:03.053 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.0006432 seconds 2020-07-28 23:42:03.053 Info App: Starting entry point NfoMetadata.EntryPoint 2020-07-28 23:42:03.053 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.0001055 seconds 2020-07-28 23:42:03.053 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2020-07-28 23:42:03.053 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 8.5E-06 seconds 2020-07-28 23:42:03.053 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2020-07-28 23:42:03.053 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.0004782 seconds 2020-07-28 23:42:03.053 Info App: Starting entry point Emby.Server.Implementations.Playlists.PlaylistsEntryPoint 2020-07-28 23:42:03.054 Info App: Entry point completed: Emby.Server.Implementations.Playlists.PlaylistsEntryPoint. Duration: 0.0003335 seconds 2020-07-28 23:42:03.054 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2020-07-28 23:42:03.054 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 2.36E-05 seconds 2020-07-28 23:42:03.054 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2020-07-28 23:42:03.054 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 4.83E-05 seconds 2020-07-28 23:42:03.054 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2020-07-28 23:42:03.165 Info LibraryMonitor: Watching directory D:\Fluminense 2020-07-28 23:42:03.165 Info LibraryMonitor: Watching directory D:\Home Videos 2020-07-28 23:42:03.165 Info LibraryMonitor: Watching directory D:\Movies - Sofia, Cecilia e Thiago 2020-07-28 23:42:03.166 Info LibraryMonitor: Watching directory D:\Movies\Movies D 2020-07-28 23:42:03.166 Info LibraryMonitor: Watching directory D:\Movies\Movies B 2020-07-28 23:42:03.166 Info LibraryMonitor: Watching directory D:\Movies\Movies 0-9 2020-07-28 23:42:03.167 Info LibraryMonitor: Watching directory D:\Movies\Movies E 2020-07-28 23:42:03.167 Info LibraryMonitor: Watching directory D:\Movies\Movies C 2020-07-28 23:42:03.167 Info LibraryMonitor: Watching directory D:\Movies\Movies H 2020-07-28 23:42:03.168 Info LibraryMonitor: Watching directory D:\Movies\Movies A 2020-07-28 23:42:03.168 Info LibraryMonitor: Watching directory D:\Movies\Movies I 2020-07-28 23:42:03.168 Info LibraryMonitor: Watching directory D:\Movies\Movies J 2020-07-28 23:42:03.169 Info LibraryMonitor: Watching directory D:\Movies\Movies G 2020-07-28 23:42:03.169 Info LibraryMonitor: Watching directory D:\Movies\Movies L 2020-07-28 23:42:03.169 Info LibraryMonitor: Watching directory D:\Movies\Movies M 2020-07-28 23:42:03.170 Info LibraryMonitor: Watching directory D:\Movies\Movies F 2020-07-28 23:42:03.170 Info LibraryMonitor: Watching directory D:\Movies\Movies K 2020-07-28 23:42:03.170 Info LibraryMonitor: Watching directory D:\Movies\Movies N 2020-07-28 23:42:03.170 Info LibraryMonitor: Watching directory D:\Movies\Movies O 2020-07-28 23:42:03.171 Info LibraryMonitor: Watching directory D:\Movies\Movies Q 2020-07-28 23:42:03.178 Info LibraryMonitor: Watching directory D:\Movies\Movies R 2020-07-28 23:42:03.178 Info LibraryMonitor: Watching directory D:\Movies\Movies P 2020-07-28 23:42:03.178 Info LibraryMonitor: Watching directory D:\Movies\Movies S 2020-07-28 23:42:03.179 Info LibraryMonitor: Watching directory D:\Movies\Movies U 2020-07-28 23:42:03.179 Info LibraryMonitor: Watching directory D:\Movies\Movies T 2020-07-28 23:42:03.180 Info LibraryMonitor: Watching directory D:\Movies\Movies W 2020-07-28 23:42:03.180 Info LibraryMonitor: Watching directory D:\Movies\Movies X 2020-07-28 23:42:03.181 Info LibraryMonitor: Watching directory D:\Movies\Movies Z 2020-07-28 23:42:03.182 Info LibraryMonitor: Watching directory D:\Movies\Movies Y 2020-07-28 23:42:03.182 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.1280204 seconds 2020-07-28 23:42:03.182 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2020-07-28 23:42:03.182 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 8.23E-05 seconds 2020-07-28 23:42:03.182 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2020-07-28 23:42:03.182 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 2.68E-05 seconds 2020-07-28 23:42:03.182 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2020-07-28 23:42:03.182 Info LibraryMonitor: Watching directory D:\Music Concerts 2020-07-28 23:42:03.182 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0002594 seconds 2020-07-28 23:42:03.182 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2020-07-28 23:42:03.183 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0001142 seconds 2020-07-28 23:42:03.183 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2020-07-28 23:42:03.183 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 6.31E-05 seconds 2020-07-28 23:42:03.183 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2020-07-28 23:42:03.183 Info LibraryMonitor: Watching directory D:\New Movies 2020-07-28 23:42:03.183 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 2.32E-05 seconds 2020-07-28 23:42:03.183 Info LibraryMonitor: Watching directory D:\TV 2020-07-28 23:42:03.183 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2020-07-28 23:42:03.183 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 5.19E-05 seconds 2020-07-28 23:42:03.183 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2020-07-28 23:42:03.184 Info LibraryMonitor: Watching directory D:\Movies\Movies V 2020-07-28 23:42:03.184 Info LibraryMonitor: Watching directory D:\TV - Sofia, Cecilia e Thiago 2020-07-28 23:42:03.184 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0008023 seconds 2020-07-28 23:42:03.184 Info App: Starting entry point Emby.LiveTV.EntryPoint 2020-07-28 23:42:03.185 Info LiveTV: Loading live tv data from C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\data\livetv\timers 2020-07-28 23:42:03.190 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.0053144 seconds 2020-07-28 23:42:03.190 Info App: Starting entry point Emby.LiveTV.LiveTVEntryPoint 2020-07-28 23:42:03.190 Info App: Entry point completed: Emby.LiveTV.LiveTVEntryPoint. Duration: 2.35E-05 seconds 2020-07-28 23:42:03.190 Info App: Starting entry point Emby.LiveTV.RecordingNotifier 2020-07-28 23:42:03.190 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 8.54E-05 seconds 2020-07-28 23:42:03.190 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint 2020-07-28 23:42:03.190 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.0003006 seconds 2020-07-28 23:42:03.190 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint 2020-07-28 23:42:03.190 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.0002357 seconds 2020-07-28 23:42:03.190 Info App: Starting entry point Emby.Notifications.Notifications 2020-07-28 23:42:03.190 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 8.09E-05 seconds 2020-07-28 23:42:03.190 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2020-07-28 23:42:03.193 Info App: SyncRepository Initialize taking write lock 2020-07-28 23:42:03.193 Info App: SyncRepository Initialize write lock taken 2020-07-28 23:42:03.193 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0025672 seconds 2020-07-28 23:42:03.193 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2020-07-28 23:42:03.193 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0001711 seconds 2020-07-28 23:42:03.193 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint 2020-07-28 23:42:03.213 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 0.0198147 seconds 2020-07-28 23:42:03.213 Info App: All entry points have started 2020-07-28 23:42:03.563 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2020-07-28 23:42:05.855 Info FfmpegManager: FFMpeg: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffmpeg.exe 2020-07-28 23:42:05.855 Info FfmpegManager: FFProbe: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffprobe.exe 2020-07-28 23:42:05.855 Info FfmpegManager: FFDetect: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffdetect.exe 2020-07-28 23:42:05.856 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2020-07-28 23:42:05.860 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffmpeg.exe -hide_banner -version 2020-07-28 23:42:05.909 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Process exited with code 0 2020-07-28 23:42:05.985 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2020-07-28 23:42:05.985 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2020-07-28 23:42:05.985 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2020-07-28 23:42:05.985 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2020-07-28 23:42:05.985 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2020-07-28 23:42:05.988 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2020-07-28 23:42:05.988 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2020-07-28 23:42:05.988 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2020-07-28 23:42:05.988 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2020-07-28 23:42:05.988 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2020-07-28 23:42:05.989 Info Dx11VaCodecProvider: Start GetCodecList() 2020-07-28 23:42:09.140 Info Dx11VaCodecProvider: End GetCodecList() 2020-07-28 23:42:09.142 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Execute: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffdetect.exe -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 qsvencdec -print_format json -disable_dx11 2020-07-28 23:42:09.501 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Process exited with code 0 2020-07-28 23:42:09.567 Info QuickSyncDx11CodecProvider: ProcessRun 'ffdetect_qsvencdec' Execute: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffdetect.exe -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 qsvencdec -print_format json 2020-07-28 23:42:09.677 Info QuickSyncDx11CodecProvider: ProcessRun 'ffdetect_qsvencdec' Process exited with code 0 2020-07-28 23:42:09.730 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Execute: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffdetect.exe -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json -disable_dx11 2020-07-28 23:42:09.768 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Process exited with code 1 2020-07-28 23:42:09.824 Info AmfCodecProvider: ProcessRun 'ffdetect_amfenc' Execute: C:\Users\Andre\AppData\Roaming\Emby-Server\system\ffdetect.exe -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 amfenc -print_format json 2020-07-28 23:42:09.968 Info AmfCodecProvider: ProcessRun 'ffdetect_amfenc' Process exited with code 0 2020-07-28 23:42:10.027 Info AmfCodecProvider: Adapter #0: 'AMD Radeon(TM) Vega 8 Graphics' Id:5597 (Driver: , Vendor: 4098) D3D11 2020-07-28 23:42:39.970 Info HttpServer: WS http://localhost:8096/embywebsocket?api_key=ffdea368be564d2d8ed16d9b60888bb6&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc4LjAuMzkwNC44NyBTYWZhcmkvNTM3LjM2fDE1NzMwMDAxMDQxMDI1. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.086 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.107 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-07-28T02%3A42%3A40.102Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.107 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-07-22T02%3A42%3A40.103Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.119 Info HttpServer: HTTP Response 200 to ::1. Time: 12ms. http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-07-22T02%3A42%3A40.103Z&hasUserId=false 2020-07-28 23:42:40.127 Info HttpServer: HTTP Response 200 to ::1. Time: 21ms. http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-07-28T02%3A42%3A40.102Z&hasUserId=true 2020-07-28 23:42:40.149 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.152 Info HttpServer: HTTP GET http://localhost:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=e6b5b4f92e054e8798876ced499a3453&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.157 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=5ae88cf7ca019bd57b94d40aa02d7593. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.167 Info HttpServer: HTTP Response 200 to ::1. Time: 81ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453 2020-07-28 23:42:40.167 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=a1df94bd68e9b4cc7dcd2a659cbade26. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.231 Info HttpServer: HTTP Response 200 to ::1. Time: 74ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=5ae88cf7ca019bd57b94d40aa02d7593 2020-07-28 23:42:40.231 Info HttpServer: HTTP Response 200 to ::1. Time: 83ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2020-07-28 23:42:40.231 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=c2257bbd84a4b4bb4f9f4e16cd641326. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.231 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=767bffe4f11c93ef34b805451a696a4e. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.255 Info HttpServer: HTTP Response 200 to ::1. Time: 24ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=c2257bbd84a4b4bb4f9f4e16cd641326 2020-07-28 23:42:40.255 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f4415c72cc16920fce19d78d636a3ce7. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.257 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f4415c72cc16920fce19d78d636a3ce7 2020-07-28 23:42:40.257 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=3a86b5528455726643d6ab9a560efcdd. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.264 Info HttpServer: HTTP Response 200 to ::1. Time: 7ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=3a86b5528455726643d6ab9a560efcdd 2020-07-28 23:42:40.264 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:40.265 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453 2020-07-28 23:42:40.271 Info HttpServer: HTTP Response 200 to ::1. Time: 120ms. http://localhost:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=e6b5b4f92e054e8798876ced499a3453&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2020-07-28 23:42:40.287 Info HttpServer: HTTP Response 200 to ::1. Time: 120ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=a1df94bd68e9b4cc7dcd2a659cbade26 2020-07-28 23:42:40.293 Info HttpServer: HTTP Response 200 to ::1. Time: 61ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=767bffe4f11c93ef34b805451a696a4e 2020-07-28 23:42:43.604 Info HttpServer: HTTP GET http://localhost:8096/emby/Sessions?ActiveWithinSeconds=300. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.605 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.605 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.607 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-07-28T02%3A42%3A43.599Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.617 Info HttpServer: HTTP Response 200 to ::1. Time: 12ms. http://localhost:8096/emby/System/Info 2020-07-28 23:42:43.617 Info HttpServer: HTTP GET http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.621 Info HttpServer: HTTP Response 200 to ::1. Time: 14ms. http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-07-28T02%3A42%3A43.599Z&hasUserId=true 2020-07-28 23:42:43.621 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-07-22T02%3A42%3A43.601Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.623 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-07-22T02%3A42%3A43.601Z&hasUserId=false 2020-07-28 23:42:43.624 Info HttpServer: HTTP Response 200 to ::1. Time: 7ms. http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4 2020-07-28 23:42:43.625 Info HttpServer: HTTP Response 200 to ::1. Time: 19ms. http://localhost:8096/emby/ScheduledTasks 2020-07-28 23:42:43.631 Info HttpServer: HTTP GET http://localhost:8096/emby/LiveTv/Recordings?UserId=e6b5b4f92e054e8798876ced499a3453&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.633 Info HttpServer: HTTP GET http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:42:43.639 Info HttpServer: HTTP Response 200 to ::1. Time: 35ms. http://localhost:8096/emby/Sessions?ActiveWithinSeconds=300 2020-07-28 23:42:43.642 Info HttpServer: HTTP Response 200 to ::1. Time: 10ms. http://localhost:8096/emby/LiveTv/Recordings?UserId=e6b5b4f92e054e8798876ced499a3453&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2020-07-28 23:42:43.645 Info HttpServer: HTTP Response 200 to ::1. Time: 12ms. http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2020-07-28 23:44:08.403 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:44:08.420 Info HttpServer: HTTP Response 200 to ::1. Time: 17ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453 2020-07-28 23:44:08.480 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:44:08.490 Info HttpServer: HTTP Response 200 to ::1. Time: 11ms. http://localhost:8096/emby/System/Configuration 2020-07-28 23:44:08.492 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs?SortBy=IsFolder%2CSortName&SortOrder=Ascending&Fields=BasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:44:08.497 Info HttpServer: HTTP Response 200 to ::1. Time: 5ms. http://localhost:8096/emby/System/Logs?SortBy=IsFolder%2CSortName&SortOrder=Ascending&Fields=BasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0 2020-07-28 23:44:24.907 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:44:24.925 Info HttpServer: HTTP Response 200 to ::1. Time: 18ms. http://localhost:8096/emby/System/Logs/embyserver.txt 2020-07-28 23:44:24.977 Info HttpServer: HTTP GET http://localhost:8096/favicon.ico. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:44:24.979 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/favicon.ico 2020-07-28 23:52:58.762 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/hardware_detection-63731576530.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:52:58.768 Info HttpServer: HTTP Response 200 to ::1. Time: 6ms. http://localhost:8096/emby/System/Logs/hardware_detection-63731576530.txt 2020-07-28 23:53:14.165 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:53:14.168 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/System/Configuration 2020-07-28 23:53:14.174 Info HttpServer: HTTP POST http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:53:14.204 Info ServerConfigurationManager: Saving system configuration 2020-07-28 23:53:14.214 Info HttpServer: HTTP Response 204 to ::1. Time: 40ms. http://localhost:8096/emby/System/Configuration 2020-07-28 23:53:14.225 Debug PortMapper: Stopping NAT discovery 2020-07-28 23:53:14.225 Debug PortMapper: Stopping NAT discovery 2020-07-28 23:54:11.954 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:54:11.958 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/Users/e6b5b4f92e054e8798876ced499a3453 2020-07-28 23:54:12.008 Info HttpServer: HTTP GET http://localhost:8096/emby/Notifications/Types. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:54:12.010 Debug XmlSerializer: Deserializing file C:\Users\Andre\AppData\Roaming\Emby-Server\programdata\config\notifications.xml 2020-07-28 23:54:12.013 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/Notifications/Types 2020-07-28 23:54:12.662 Debug App: ActivityLogWebSocketListener stop transmitting over websocket to ::1 2020-07-28 23:54:12.662 Debug App: ActivityLogWebSocketListener stop transmitting over websocket to ::1 2020-07-28 23:54:12.666 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:54:12.670 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/System/Configuration 2020-07-28 23:54:12.676 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs?SortBy=IsFolder%2CSortName&SortOrder=Ascending&Fields=BasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:54:12.678 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/System/Logs?SortBy=IsFolder%2CSortName&SortOrder=Ascending&Fields=BasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0 2020-07-28 23:54:19.712 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 2020-07-28 23:54:19.725 Info HttpServer: HTTP Response 200 to ::1. Time: 13ms. http://localhost:8096/emby/System/Logs/embyserver.txt 2020-07-28 23:54:55.277 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36
Carlo 4561 Posted July 29, 2020 Posted July 29, 2020 @amaga If you have a few minutes free I can jump on with you in a remote meeting and help you set this up. Download and install Teamviewer if you don't have it from TeamViewer.com. Then launch the program and it will give you a user id and one-time use passcode. Send me a PM (click on my name then message) and send me the above credentials. I'll be available for a couple more hours tonight. Otherwise we can do it tomorrow or whenever you are ready. Alternately try and follow our knowledge base article and pay attention to the diagnostic section. https://support.emby.media/support/solutions/articles/44001849007-connectivity
seanbuff 1353 Posted July 29, 2020 Posted July 29, 2020 (edited) Can you see both your LAN and WAN addresses and ports shown on your Dashboard? Are the IPs and Ports correct there? Also, try attaching the actual complete log file itself, rather than a copy/paste EDIT: Woops, @cayars has got this Edited July 29, 2020 by seanbuff 1
Carlo 4561 Posted July 29, 2020 Posted July 29, 2020 That was good information seanbuff. I think I'm going to rewrite the knowledge base article soon with a section specific to setting up remote access to make the steps clearer for those not used to networking. Explain the port forwarding a bit more in detail and the need to ALWAYS forward to the server's 8096 & 8920 ports (this gets some people), use a pic like you did above for checking what Emby thinks is the setup is and of course a bit of a walk through on setting up SSL if using CloudFlare. 1
seanbuff 1353 Posted July 29, 2020 Posted July 29, 2020 1 hour ago, cayars said: I think I'm going to rewrite the knowledge base article soon Yup, sounds like a good idea 1
Carlo 4561 Posted July 29, 2020 Posted July 29, 2020 Often times what people write in the forums and what the actual issue is can be quite different which is understandable especially if they really don't understand what to do or not a technical type of person. A side benefits of reaching out and helping people via TeamViewer is seeing the misunderstanding of articles or misconfiguration people do. Showing them how to do it and getting comments back like "why didn't it just say do this"! So using the knowledge of what I'm seeing as pain points for people I've been slowly improving many of our articles to clarify things, add detail when needed, rewrite overly complex articles or rewrite some things where more hand holding is needed. 2
pwhodges 2028 Posted July 29, 2020 Posted July 29, 2020 And not just documentation. When I was a programmer I enjoyed doing support because it critically informed the design of what I was writing. Paul
rbjtech 5337 Posted July 29, 2020 Posted July 29, 2020 (edited) 7 hours ago, cayars said: Often times what people write in the forums and what the actual issue is can be quite different which is understandable especially if they really don't understand what to do or not a technical type of person. A side benefits of reaching out and helping people via TeamViewer is seeing the misunderstanding of articles or misconfiguration people do. Showing them how to do it and getting comments back like "why didn't it just say do this"! So using the knowledge of what I'm seeing as pain points for people I've been slowly improving many of our articles to clarify things, add detail when needed, rewrite overly complex articles or rewrite some things where more hand holding is needed. In the wiki/KB, are there any options to feedback if the document helped you or if the user needed further assistance ? It's very easy to forget that people have very different levels of knowledge and experience on these forums - and assumptions for some people are important facts for others. Maybe the 'how to's' should reference this as prerequisites at the start - ie 'A basic level of Networking including Port Forwarding is assumed for this article'. edit To add to this - we also need a way to feedback if the documentation needs updating - as an example https://support.emby.media/support/solutions/articles/44001160086-secure-your-server .. is now out of date as 'sslforfree' is no more - it's now been commercialised Edited July 29, 2020 by rbjtech
Carlo 4561 Posted July 29, 2020 Posted July 29, 2020 There's a thing at the bottom that asks if you found this helpful, yes or no but that's it. I'm working on this week replacing how to setup remote access as mentioned above. If you see anything, anywhere in the knowledge base that looks, wrong, could be worded better, needs additions let me know as I'd love to improve it as I'm constantly making adjustments. If you ever want to write something yourself to have added to the knowledge base I'm all for that as well, just shoot me a PM with any info like that. Your expertise on all things Emby would be very welcome! 1
Carlo 4561 Posted July 30, 2020 Posted July 30, 2020 This is now resolved. We played tag trying to get TeamViewer session going with me having dinner, then him. But amaga realized he was using the wrong port and fixed it himself (chears!). I did a test from my house to verify for him and all is now good.
