Papsi5781 0 Posted July 28, 2020 Posted July 28, 2020 Hi guys I tried uninstall and re-install on my imac but the series recording will just not work, they just start and run for a few minutes then they just stop resulting in show only having 5 or 4 minutes, I have gone in to the recordings after they stop and just hit record that show and that will work but the series just keep stopping. I'm not at my server right now but I just checking if anyone may have an idea of what is going on so I can try when I'm back at my server.
Luke 42240 Posted July 29, 2020 Posted July 29, 2020 Hi there @edford can we please go over an example? Can you attach the emby server log ? Thanks.
Papsi5781 0 Posted July 29, 2020 Author Posted July 29, 2020 Hi Luke here are a few logs for you. ffmpeg-directstream-b1e17127-923b-42f3-9ff5-2b5da791e9e4_1.txt ffmpeg-transcode-333a604b-2066-4c84-b60f-b32ffd03939d_1.txt ffmpeg-transcode-39eb8b48-63a6-4cc8-996e-9d571f02812f_1.txt ffmpeg-transcode-f3d324b0-9c8b-4e6d-a9f3-0aafd17c7d8d_1.txt hardware_detection-63731521108.txt ffmpeg-directstream-2c527a3a-7b16-451c-a204-0dd8219bc43b_1.txt ffmpeg-directstream-d3590205-421a-4ae9-9ed2-7c76e9089beb_1.txt ffmpeg-directstream-a6e28925-2a81-4d76-9f22-ebe820421f97_1.txt
Luke 42240 Posted July 30, 2020 Posted July 30, 2020 Hi, these are playback logs. I thought the issue was that the recording was not completing?
Papsi5781 0 Posted July 31, 2020 Author Posted July 31, 2020 I can not find where the recording logs are, can tell me where I can find them please?
Papsi5781 0 Posted July 31, 2020 Author Posted July 31, 2020 Ok just to be sure so I know what I am looking for, I sent ones that say ffmpeg-transcode and ffmpeg-directstream before, so I should see ones in that same log folder that say something like ffmpeg-recording or have recording somewhere in the name correct, if not what is it called?
Luke 42240 Posted August 2, 2020 Posted August 2, 2020 No, it would be a log starting with embyserver. Thanks.
