nvenc not being detected (Emby 4.4.3.0, Ubuntu 20.04, 1050Ti)
Karunamon
Hi all,
I'm running inside an ESXi VM with the 1050Ti passed through, emby installed using the .debĀ file from the download page. Using the Nvidia drivers v450.57.
No nvenc encoders/decoders are visible on the server > transcoding page, and all transcoding appears to be happening through the CPU when playback is attempted.
The hardware detection log shows nvenc being detected successfully at its end, and I can also see it being found if I manually run:
/opt/emby-server/bin/ffdetect -hide_banner -show_program_version -loglevel 99 -show_error -show_log 99 -print_format json nvencdec
(attached as well).
This is a fresh install on a fresh system.
I'm kinda at the end of my rope here. Any ideas what I need to do to get this activated?
Thanks!
hardware_detection-63731380471.txt embyserver.txt ffdetect.txt
Edited by Karunamon
Premiere?
Karunamon
42 minutes ago, speechles said:
Premiere?
Yep.
Karunamon
Found the solution here.
I noticed that nvidia-smi was returning an error:
'Unable to determine the device handle for GPU 0000:03:00.0: Unknown Error'
To fix this under ESXi, an option has to be added to the VMX file for the VM, which prevents the Nvidia driver from realizing that it's being run under a VM:
hypervisor.cpuid.v0 = "FALSE"
After this, nvidia-smi shows the information as expected, and the hardware transcoding settings page is populated, and all my videos now playback gloriously fast :)
Thanks for the feedback !
