messoud 0 Posted July 26, 2020 Posted July 26, 2020 (edited) I had been running Emby on Windows Server 2016 for some time and watching movies and TV shows on my Mi Box S (MiBox4) Android box on Kodi with Emby plugin without any problem. Last week I migrated my PC to Windows 10 Pro and reinstalled Emby server on it, also did a fresh install of Kodi on my Android box to re-sync everything. Since then, it's been a debugging nightmare for me as no matter what video, large and small, high bit-rate and crap sd, video playback stops randomly every few minutes! First I thought that it might be my router configs (It's a 2.4GHz running at 40MHz wide channel 150Mbps N)... I kept playing with the configs, replaced DD-WRT with OpenWRT, then with the original D-Link firmware, then back to the latest version of DD-WRT; no matter what I did the videos kept stopping. Then I started messing with Kodi on Android's advancedsettings.xml's cache/buffer values, I even installed Emby's Android app, still the same, video drops randomly, sometimes with the "source too slow" message. I then came to my PC, changed the Realtek NIC's configs, Windows registry values, Firewall settings, routes, even reinstalled and reconfigured Emby numerous times, it even got worse! Now I come to thee completely exhausted and out of ideas, looking for help... Any ideas? Here's the most usual error on Emby's logs: 2020-07-20 10:20:55.583 Info HttpServer: HTTP Response 206 to 192.168.0.155. Time: 162278ms. http://192.168.0.125:8096/emby/Videos/1939/stream?static=true&MediaSourceId=72b02541420c7e39fc9d4796d965a2df 2020-07-20 10:21:26.604 Info SessionManager: Session 8b7b1e843b7e2410fdd159d7908f4244 has gone idle while playing 2020-07-20 10:21:26.604 Info SessionManager: Playback stopped reported by app Kodi 4.1.19 playing Deeper, Deeper, Deeper Still. Stopped at 713000 ms I bet it's some kind of f*-up on Microsoft's side as I did not have ANY problem with the same PC, Router, and Box on Windows Server 2016 even with playing very-high-bitrate 30GB 1080p 4-hour movies! If it needs mentioning, there's no problem playing videos on Emby server localhost. Edited July 26, 2020 by messoud
Luke 42234 Posted July 26, 2020 Posted July 26, 2020 Hi there, can you please attach the emby server log? Thanks !
messoud 0 Posted July 26, 2020 Author Posted July 26, 2020 34 minutes ago, Luke said: Hi there, can you please attach the emby server log? Thanks ! Here you go embyserverlog.zip
