embilly 2 Posted July 25, 2020 Posted July 25, 2020 Hi when you go into the emby app then go to the music folder that has peeb created when you play a song it plays but what does it play on. what music player does it uses as i could not stop once it started
pwhodges 2033 Posted July 25, 2020 Posted July 25, 2020 The player is integrated. When you play a song, the while-playing bar appears just above the bottom of the screen - if you touch the icon at the right-hand end of this it opens out to a full screen, which includes a stop button. You can also expand the current song listing at the bottom of this screen to a full listing of the album, at the cost of the album art. In any case, if you kill the Emby process, the playing stops. Paul
Luke 42244 Posted July 26, 2020 Posted July 26, 2020 Hi, what do you mean by Quote that has peeb created
