speechles 2062 Posted July 29, 2020 Posted July 29, 2020 1 minute ago, Sammy said: So I tried truehd and truehd 71 and truehd 7.1 for a movie with a TrueHD 7.1 track and nothing spectacular happened; actually nothing happened at all. Was it transcoding? What does the stats for nerds show when the main item plays?
Sammy 791 Posted July 29, 2020 Author Posted July 29, 2020 I'm sure it was transcoding as I was playing this remotely on my computer at work (shh) or in a RDP session to my PC. I guess further testing will have to wait until later when I am home.
unisoft 355 Posted May 3, 2021 Posted May 3, 2021 On 29/07/2020 at 13:57, Sammy said: This Topic needs more examples to properly name codec intros.. All codec types need to be fully laid out. Codec Intros Codec intros allow you to create intros based on the media information of the main feature you are watching. For example, if you're watching a movie with AC3 audio, you can create an ac3 intro called ac3.mp4, and place this in your codec intro path. The following fields are used to determine a match: Video Codec Audio Codec Audio Profile Tags Here are some examples: A movie has h264 video, intro file is named "h264.mp4" A movie has ac3 audio, intro file is named "ac3.mkv" A movie has DTS-HD MA audio profile, intro file is named "dts-hd ma.avi" You've added a tag to a movie called "waffle", intro file is named "waffle.mpg". Does the waffle tag work for TV Shows or just movies? Is the tag name actually waffle or anything? If it doesn't apply to TV Shows, Luke can this be added? I'd like to show the original TV ident before a TV show based on filename in the tag, rather than have to recode a video to add it? Be cool if you could fire an end tag as well e.g. start tag is the video filename of the production company ident, end tag is the video filename of whatever video you want to fire at the end.
Aedes 8 Posted December 14, 2024 Posted December 14, 2024 Hi, I'm just trying to get codec intros to work with DTS:X content vs. DTS-HD MA 5.1 vs. DTS-HD 7.1. I've tried various different filenames but it seems that only 'dts' is recognised and it is selected for all of these codecs? Is this a known issue?
GrimEvil 73 Posted December 17, 2024 Posted December 17, 2024 On 14/12/2024 at 17:35, Aedes said: Hi, I'm just trying to get codec intros to work with DTS:X content vs. DTS-HD MA 5.1 vs. DTS-HD 7.1. I've tried various different filenames but it seems that only 'dts' is recognised and it is selected for all of these codecs? Is this a known issue? Can you try the ones I have attached, I think they are named correctly for each type, this is what I use? My Codec intro Pack
