Eusley_Paiva 1 Posted July 24, 2020 Posted July 24, 2020 EEstava testando modo usuário e vir que eles tem acesso a exclusão de arquivos pelo app da Emby. Isso e muito chato. Pós alguns arquivos foram apagado pelo mesmo
Carlo 4561 Posted July 24, 2020 Posted July 24, 2020 You control this from the web admin settings. Click on Users in the menu then select this user. Scroll down until you see this section "Allow Media Deletion From" Anything with a check is enabled and the user WILL be able to delete in that library.
