rb0135 2 Posted July 16, 2014 Posted July 16, 2014 Hi All, I started a topic in the Media Browser Classic forum as I have been having issues with the Trailers not playing, or if they do, really odd behaviour (such as how they were buffering, would play fine once, play them again straight away and there would be stuttering. I think I fixed the stuttering by increasing the Remote MBPS to 30 in the MBC3 config. However, there seems to be a bigger issue and it was suggested I create a topic here, so I am. The issue is that after 4-5 trailers (viewing in a row) and subsequent trailers when viewed (when the PLAY is clicked/selected) produces a black play screen and nothing happens, even leaving it for 1-2 minutes, there is nothing. I opened the log and watched what was happening. When playing a trailer, the log fills up with information, showing it is going to the external website to stream the trailer, etc. When I play a trailer and get a BLACK screen, the log is empty. There are no commands sent to the external website requesting the trailer, there is no information a trailer was select, or any commands issued by MBC3. etc. However, if I close MBC3, then reopen it, and try the trailer again, it works fine, until I play a few more, then it does the same BLACK screen. I have the latest plugin version (don't have that in front of me atm). The MBS and MBC are on the same PC. I don't view anything through the Web Interface from any other device, so I don't know if the trailers work fine that way. I am only interested in them working with the MBC3 plugin in Media Centre (Win7). Any ideas?
ebr 16334 Posted July 17, 2014 Posted July 17, 2014 The item I asked you to create a new topic in the plug-ins forum for was the one about downloading the wrong version of the trailers. This is a completely different issue and will require seeing a MBC log from when it happens. BTW - the bitrate settings should have no effect on trailer playback in the current version of MBC.
