clarkss12 304 Posted July 28, 2020 Posted July 28, 2020 1 hour ago, horstepipe said: Thanks. Do you know whether this device will be available in Europe / Germany? Not sure
clarkss12 304 Posted July 28, 2020 Posted July 28, 2020 I cranked up my Tivo 4k and NO firmware update to correct the HDR to SDR issue, so not usable for me at this time. Anyway, it is a mediocre media player, there is NO automatic frame rate adjustment and NO HD audio passthrough.... And like all of the Amlogic boxes, it will NOT natively play any BlueRay rips that are encoded with the Microsoft VC-1 codec. 1
cybergrimes 93 Posted July 31, 2020 Posted July 31, 2020 (edited) On 7/28/2020 at 2:19 PM, clarkss12 said: I cranked up my Tivo 4k and NO firmware update to correct the HDR to SDR issue, so not usable for me at this time. Anyway, it is a mediocre media player, there is NO automatic frame rate adjustment and NO HD audio passthrough.... And like all of the Amlogic boxes, it will NOT natively play any BlueRay rips that are encoded with the Microsoft VC-1 codec. They dropped a new update today, still no HDR fix... blocked user from accessing developer options and broke MPEG2 OTA playback. I've got a TV where I would really like Android TV that includes an input button on the remote and can be programmed to control soundbar volume (no HDMI CEC). TiVo was checking those boxes but now this. I recently setup a Roku Ultra for in-laws using a "One For All Streamer remote" that is surprisingly nice-- it's backlit, input button, play/pause and the buttons aren't all the same shape/size so you have to look each time you use it. It's controlling audio from an optical connected soundbar which the Roku remote can't do. Might try programming one with the old Jetstream 4K box... What other Android TV boxes (certified for Netflix/Prime/etc) have IR control... 2015 Shield? Edited July 31, 2020 by cybergrimes
Sammy 791 Posted August 6, 2020 Posted August 6, 2020 On 7/31/2020 at 9:04 AM, cybergrimes said: They dropped a new update today, still no HDR fix... blocked user from accessing developer options and broke MPEG2 OTA playback. I've got a TV where I would really like Android TV that includes an input button on the remote and can be programmed to control soundbar volume (no HDMI CEC). TiVo was checking those boxes but now this. I recently setup a Roku Ultra for in-laws using a "One For All Streamer remote" that is surprisingly nice-- it's backlit, input button, play/pause and the buttons aren't all the same shape/size so you have to look each time you use it. It's controlling audio from an optical connected soundbar which the Roku remote can't do. Might try programming one with the old Jetstream 4K box... What other Android TV boxes (certified for Netflix/Prime/etc) have IR control... 2015 Shield? Is that an IR remote? What make and model is it?
Sammy 791 Posted August 6, 2020 Posted August 6, 2020 On 7/20/2020 at 1:11 PM, cayars said: The latest firmware has an issue playing back mpeg2 for some people. So until they get that fixed it's hit or miss for Live TV depending if your channels use mpeg2 or h.264. I'm one of those people. It may be possible for Emby to fix. @softworkz seems to know the key but doesn't possess the time.. Maybe @ebr will find the time. I have beer! And it ain't no crappy light beer either. It's a nice laced Hazy IPA..
Luke 42238 Posted August 6, 2020 Posted August 6, 2020 Can you try the mobile app on the same device and see how that compares?
cybergrimes 93 Posted August 7, 2020 Posted August 7, 2020 20 hours ago, Luke said: Can you try the mobile app on the same device and see how that compares? It's the same (used the APK from https://emby.media/emby-for-android-mobile.html) They seem to have broken it device-wide. OTA doesn't work on Channels DVR, Google's Live Channels, HDHomeRun app, etc
RanmaCanada 502 Posted August 8, 2020 Posted August 8, 2020 Sadly as others have said, your options are extremely limited. If you want that lovely DRM, the Shield, the MiBox, or an Amazon device are pretty much your only options. Formuler did recently get L1 certified, and released new firmware for the Z8, but it's using an H6 chipset, which is ancient, and the box is also priced at Shield levels. The 4k firestick does support AFR, but the Netflix app as of 2019 did not. https://www.avforums.com/threads/24hz-with-netflix-films-via-fire-tv-stick-4k.2211199/
BAlGaInTl 288 Posted September 1, 2020 Posted September 1, 2020 If you haven't found anything yet, it looks like Google's new device is close to release. It's supposed to be ~$50, so may be worth holding off on. We'll see how good it is.
Carlo 4561 Posted September 1, 2020 Posted September 1, 2020 28 minutes ago, BAlGaInTl said: If you haven't found anything yet, it looks like Google's new device is close to release. It's supposed to be ~$50, so may be worth holding off on. We'll see how good it is. Got a link or two for the device you mentioned?
vdatanet 1619 Posted September 1, 2020 Posted September 1, 2020 (edited) Do you mean the upcoming Chromecast Sabrina? https://www.tomsguide.com/news/googles-android-tv-sabrina-launch-looks-imminent-heres-why Edited September 1, 2020 by vdatanet
BAlGaInTl 288 Posted September 1, 2020 Posted September 1, 2020 13 minutes ago, vdatanet said: Do you mean the upcoming Chromecast Sabrina? https://www.tomsguide.com/news/googles-android-tv-sabrina-launch-looks-imminent-heres-why @cayars@vdatanet Yes, that's the one. I don't know if it's "eminent" or if they will hold it until their Fall hardware event.
