mofa2016 2 Posted July 19, 2020 Posted July 19, 2020 (edited) There‘re so many cases that I can not receive the right answer for the show I want to search, with my local language. The string I input is right in the tittle of that show, still no answer returned, it only works when I input the string beginning with the first characters. It doesn't make sense I still need to memorize the title from the beginning when a searching engine is right there. Example: 君主·埃尔梅罗二世事件簿 魔眼收集列车 Grace note No answer returned using words in the middle like "二世", “列车”, but the beginning word "君主" or English word "grace" which even is not at the beginning. Edited July 19, 2020 by mofa2016
Solution Luke 42198 Posted July 19, 2020 Solution Posted July 19, 2020 Hi, yes this is something that needs improvement. We are using sqlite and their full text searching features. We'll need to review how we're using it. Thanks. 1
mofa2016 2 Posted September 13, 2021 Author Posted September 13, 2021 Still get no improvement after 1year.
Luke 42198 Posted September 13, 2021 Posted September 13, 2021 Hi, we are looking into improving this. Thanks for the feedback. 1
mofa2016 2 Posted September 18, 2021 Author Posted September 18, 2021 On 9/13/2021 at 11:00 PM, Luke said: Hi, we are looking into improving this. Thanks for the feedback. Jellyfin did a good job on built-in searching engine, may be you can check about how they achieve that。
