NANA REMO 0 Posted July 19, 2020 Posted July 19, 2020 THERE IS ANY IPTV PLUGIN OTHER THAN THE PLUGIN STORE BECAUSE I CANNOT INSERT AN IPTV LIST I'M BRAZILIAN!!
Carlo 4561 Posted July 19, 2020 Posted July 19, 2020 If you're talking about an M3U file that contains a list of other stream you would likely want to use this with LiveTV and not the IPTV plugin. LiveTV will parse the M3U into different channels where the IPTV plugin expects to have individual streams added and not master lists.
NANA REMO 0 Posted July 19, 2020 Author Posted July 19, 2020 Ok, but is there an iptv plugin on the emby that i can put my iptv list on?
Carlo 4561 Posted July 19, 2020 Posted July 19, 2020 Live TV is normally where you would use m3U files. Live TV Setup
NANA REMO 0 Posted July 19, 2020 Author Posted July 19, 2020 Certo, mas isso precisaria da licença de estréia, certo? Estou procurando uma opção gratuita. você teria um plug-in gratuito ou uma incorporação com essa opção desbloqueada? Thanks for listening!!
Carlo 4561 Posted July 19, 2020 Posted July 19, 2020 Yes Live TV will need a Premiere License. Premiere is available as a lifetime license, yearly or monthly. The monthly license would allow you to test and see if it's worth it for you. The IPTV plugin could maybe be forced to work but you wouldn't have any kind of guide data and you would need to setup each channel by hand. It might do what you need.
NANA REMO 0 Posted July 19, 2020 Author Posted July 19, 2020 I found a plugin called "DVBLINK" I think it must be for iptv or not?
Carlo 4561 Posted July 19, 2020 Posted July 19, 2020 That's a plugin for Live TV that allows the Emby server to communicate with DVB. Any of the plugins listed in the Live TV section will require a Premiere license to use since they require Live TV which is part of Emby Premiere.
NANA REMO 0 Posted July 19, 2020 Author Posted July 19, 2020 Really? That there is no iptv plugin on the emby other than the one that has to put channel by channel? In the plugin store there are several plugins, some of them and iptv?
Carlo 4561 Posted July 19, 2020 Posted July 19, 2020 To the best of my knowledge there is only one plugin that may work for you and that's the IPTV plugin. With the exception of what that plugin allows you to do handling IPTV streams is a TV function and all the programming for such things is done in Live TV where it makes sense. The IPTV plugin is there for people not trying to duplicate TV functionality but to be able to use setup a few streams which can be handy for things like IP Cameras or Gaming live streams, etc
