tmedia 0 Posted July 17, 2020 Posted July 17, 2020 (edited) Hi guys, I was very excited to hook up my Apple TV 4K today and I was really hoping that I would be able to direct play most of my library. Unfortunately, I am seeing that it is not the case. My server and the client are both fully up to date. Everything I throw at it that is HEVC requires server transcoding. I had a look at this page and it seems like it should be able to direct play. Here are some stats from a file that I thought would direct play. Can you guys give me any pointers? Thank you! EDIT: I forgot to mention MPV is ON. Video Title 1080p HEVC Codec HEVC Codec Tag hev1 Profile Main 10 Level 120 Resolution 1916x808 Aspect Ratio 479:202 Anamorphic No Interlaced No Framerate 23.976 Bitrate 555 kbps Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1 Audio Title English AAC stereo (Default) Language English Codec AAC Codec Tag mp4a Profile LC Layout stereo Channels 2 ch Bitrate 128 kbps Sample Rate 48,000 Hz Default Yes Container mp4 Edited July 17, 2020 by tmedia Additional info
Happy2Play 9811 Posted July 17, 2020 Posted July 17, 2020 (edited) Please post server and ffmpeg logs. But Dashboard Active device info or stats for nerds during playback should tell you why it is transcoding. Edited July 17, 2020 by Happy2Play
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 ffmpeg-transcode-acb22e54-803c-4cd0-bac5-680b31a1f62d_1.txtembyserver.txt I am attaching the two log files as requested. The Apple TV info will be almost at the end because I just got everything hooked up this evening. Most of it is video codec not supported. In the example I posted above I thought everything looked like it should direct play?
Happy2Play 9811 Posted July 17, 2020 Posted July 17, 2020 Someone more familiar with Apple will have to step in here but basically the returned support information basically says h265 isn't supported. &VideoCodec=h264&AudioCodec=aac,eac3,ac3,mp3
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 That's what I noticed as well. I have no idea right now...
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 Everything I throw at Infuse 6 direct plays on the Apple TV 4K. I wonder if there's something needed for the Emby app to work properly then?
Happy2Play 9811 Posted July 17, 2020 Posted July 17, 2020 (edited) To me this is why compared to your tag (hev1 vs hvc1), but do not know enough about the device. Google points to Apple not really liking hev1. Quote 2020-07-16 17:43:26.086 Info MediaInfoService: Profile: VideoCodecProfile, DirectPlay=false. Reason=Unnamed.VideoCodecTag Condition: Equals. ConditionValue: hvc1. IsRequired: True. Path: /mnt/user/Media/movies/Clementine (2019)/Clementine (2019) WEBDL-1080p.mp4 Edited July 17, 2020 by Happy2Play
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 Hmmmm..... I use ffmpeg to convert files to hevc. Now I'm wondering how to tag as hvc1 rather than hev1. Also, why does Infuse work for EVERY file regardless of container/codec etc? Maybe it uses the Apple TV to transcode? I'm hoping someone can weigh in that has experience with this issue. Thank you for your help so far Happy2Play and also for pointing out that tag problem that I missed!
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 It looks like you can add -tag:v hvc1 to your ffmpeg command. I'm going to try this tomorrow and see if I get better results.
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 (edited) I direct play SDR HEVC content using MPV player, are you sure you have MPV player enabled? HDR content is not supported at this time. MP4 HEVC should also direct played using native player as direct streaming is not required, but requires hvc1 tag in your mp4 file. But again, that tag is only required when you are using native player. Edited July 17, 2020 by vdatanet
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 (edited) Maybe you have enabled MPV but it requires to restart the app for the changes to take effect: https://www.iphonefaq.org/archives/974917 Edited July 17, 2020 by vdatanet
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 BTW I take the opportunity to send a friendly reminder, please add support to MPV player for automatic matching of dynamic range and refresh rate, like Plex, Infuse, MrMC ... and add support for direct playback of MKVs HEVC HDR.
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 5 hours ago, vdatanet said: Maybe you have enabled MPV but it requires to restart the app for the changes to take effect: https://www.iphonefaq.org/archives/974917 I have made sure to restart the app and yes it is enabled. I think it has to do with the tag as discussed above. My files have hev1 tag rather than hvc1. I'm trying to add the proper tag now on some test files but it seems that my code from above does not work to add the proper tag.
Carlo 4561 Posted July 17, 2020 Posted July 17, 2020 I haven't tried this but I'd think you could use ffmpeg to accomplish this pretty quickly doing something similar to this: ffmpeg -i input.mp4 -vcodec copy -acodec copy -tag:v hvc1 output.mp4 check and adjust if subtitles get copied
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 16 minutes ago, cayars said: I haven't tried this but I'd think you could use ffmpeg to accomplish this pretty quickly doing something similar to this: ffmpeg -i input.mp4 -vcodec copy -acodec copy -tag:v hvc1 output.mp4 check and adjust if subtitles get copied That code worked for me, but I wasn't aware that MPV also needed that tag. I no longer have any MP4 without that tag to test.
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 OK for me I had to use -vtag hvc1 rather than -tag:v hvc1 Now I just need to process a few files and see what happens. Thanks for the feedback and suggestions
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 (edited) I confirm MPV player can direct play MP4 HEVC without hvc1 tag. That tag is only required using native player: Edited July 17, 2020 by vdatanet
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 26 minutes ago, vdatanet said: I confirm MPV player can direct play MP4 HEVC without hvc1 tag. That tag is only required using native player: So I see a few differences in your file compared to my test file. I use 10 bit / Main 10 and it looks like you are using 8 bit. I wonder if you have some different server/client settings than me and that is making a difference? I have re-verified MPV is ON and it still does not direct play that file. When I get home later I am going to try it out on a remuxed version that changes the codec id tag to hvc1.
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 (edited) This also direct plays using MPV player The only problem I have using MPV player is HDR content. HDR content look awful. Edited July 17, 2020 by vdatanet
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 Do you mind sharing your settings on your actual Apple TV regarding video/audio?
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 (edited) I don't think settings in Apple TV are forcing transcode. Can you share a sample of your media? I will try it in my server. Edited July 17, 2020 by vdatanet
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 OK, your settings look like mine from what I can tell. If reworking the codec id tag doesn't help with mine I'll try to put together a sample for you to try out.
tmedia 0 Posted July 17, 2020 Author Posted July 17, 2020 It seems strange that Infuse 6 can direct play every single file I've thrown at it regardless of codec/container and the Emby app cannot. I wonder what's going on under the hood?
vdatanet 1619 Posted July 17, 2020 Posted July 17, 2020 (edited) Infuse and Emby for Apple TV (mpv player) are similar, both use an MPV implementation for Apple TV, but Infuse implementation is far away from Emby implementation. The worst part is that the Emby mpv player has practically not evolved in the last year and there are no prospects for improvements in the short or medium term. Edited July 17, 2020 by vdatanet 1
Happy2Play 9811 Posted July 17, 2020 Posted July 17, 2020 @vdatanet could it be a stable vs beta difference? Looks like tvOS 1.4.5.24 vs 1.4.6.8
