Carlo 4561 Posted July 19, 2020 Posted July 19, 2020 12 minutes ago, horstepipe said: anybody? What kind of sound system do you?
horstepipe 423 Posted July 20, 2020 Posted July 20, 2020 Denon AVR-X2400H with a 5.1 setup. So the Box should handle multichannel output?
ebr 16338 Posted July 20, 2020 Posted July 20, 2020 12 hours ago, horstepipe said: Denon AVR-X2400H with a 5.1 setup. So the Box should handle multichannel output? How is it hooked up?
horstepipe 423 Posted July 20, 2020 Posted July 20, 2020 (edited) the usual "modern" way via hdmi (tv -> avr -> Mi Box) No issues on my apple tv 4k. But I read in some other thread that the emby theater version I was running could have caused the issue. I'll test again more intensive today, thanks. Edited July 20, 2020 by horstepipe 1
horstepipe 423 Posted July 20, 2020 Posted July 20, 2020 okay, can't tell what the problem was in my previous testings, but now everything is fine and works as expected. DD and DTS are being passed through, DTS-HD MA is being passed through as DTS (core), but I didn't expect HD audio formats to be passed through on such a cheap box. So with working frame rate matching and a quite good remote, this box seems to be the best bang for the buck Android TV device to me. Can anybody give a (menu smoothness) comparison to the Amazon Fire TV Stick 4K? Thanks and best regards
ebr 16338 Posted July 20, 2020 Posted July 20, 2020 You just need to be sure that your AVR is on before you wake up/turn on the Mi. Otherwise, it will get limited audio capabilities reported to it via the HDMI connection. 1
