Gsuz 1 Posted July 14, 2020 Posted July 14, 2020 Can someone explain how Wake on Lan is setup on the Apple TV app? I see no setting in the app. My current setup is I have the Emby server running via docker on an ubuntu server 20.04. WOL is correctly setup on the server which I can wake up from my macbook. However it won't wake up from the emby app on the Apple TV. Should there be a setting or is there something I'm missing?
Luke 42241 Posted July 14, 2020 Posted July 14, 2020 Hi, we haven't added this to the apple tv app yet but it's planned for the future. Thanks.
Gsuz 1 Posted July 15, 2020 Author Posted July 15, 2020 @Luke thank you for explaining. Is this added on the iOS app for iPhone and/or iPad?
Gsuz 1 Posted July 16, 2020 Author Posted July 16, 2020 Thx, confirmed it working through iOS app. for future reference if anyone is running emby through docker you need to configure emby to run on host network for Wake on Lan to work properly. Here is and example docker-compose. emby: image: linuxserver/emby container_name: emby environment: - PUID=1000 - PGID=1000 - UMASK_SET=022 #optional volumes: - ./emby:/config - ./shared:/shared ports: - 8096:8096 restart: unless-stopped network_mode: host @Luke Can you give an insight on when the feature will be added to Apple Tv app?
Luke 42241 Posted July 21, 2020 Posted July 21, 2020 @Gsuz thanks, we will improve the Docker instructions. I don't have an ETA on adding wake on lan to the apple TV app, but it's in our backlog. Thanks for the feedback.
