New to emby, remote connection issues
Hello everyone,
I finally got everything working fine locally, but can’t figure out remotely.
For my plex server, I had to log into the ATT modem/router combo and port forward TCP/UDP and it fixed the remote connection issues.
I tried the same for Emby (but 8096), and it didn’t work.
locally I can login from any app or device. i port forwarded thru my firewall (which solved my previous local connection issues), but can’t think of anything else.
on a side note, I tried Emby connect also but something strange happens. When I add an Emby connect user on my server, it accepts the username, but when I try changing to the email instead (associated with the same username) I get an error.
I can’t get Emby connect to tie to my server so I can just login and it’ll automatically connect to my server.
Edited by WesamH
Please delete. I solved both of my issues. Sorry for the thread.
Glad you got it worked out.  Was just about to try and help.
What was the solution?
