Carlo 4561 Posted February 13, 2021 Posted February 13, 2021 Yes, gamepad and like devices on Win10 (thanks MS) can cause issues. Also likely is some browser extension you might have installed. You can deactivate them and try again to see if this is the cause.
BOTICSELLI 1 Posted February 14, 2021 Posted February 14, 2021 20 hours ago, GrimReaper76 said: Do you maybe have any gaming peripherals attached? Gamepad, joystick, flight stick, pedals, wheel...? Negative. Nope. NO.
Happy2Play 9814 Posted February 14, 2021 Posted February 14, 2021 Since you same mobile works and FireFox works. Is the issue with localhost or IP/hostname connections (other lan connections)?
BOTICSELLI 1 Posted February 14, 2021 Posted February 14, 2021 I turned OFF all Chrome browser extensions, and tryed both localhost and IP based conections: Same results. Only Firefox works.
BOTICSELLI 1 Posted February 14, 2021 Posted February 14, 2021 (edited) All right, THANK YOU ALL for your kind helping hand! Problem solved! I'm used a wireless keyboard, with touchpad that was the problem... (maybe a driver issue, or something) With a wiered keyboard and mouse, the problem dissapeared. Edited February 14, 2021 by BOTICSELLI 1
platypusgravy 0 Posted February 24, 2021 Posted February 24, 2021 On 15/02/2021 at 03:57, BOTICSELLI said: I'm used a wireless keyboard, with touchpad that was the problem... (maybe a driver issue, or something) With a wiered keyboard and mouse, the problem dissapeared. I have the same issue on Chrome/Edge and my wireless Logitech keyboard does not have a touchpad.
GrimReaper 4926 Posted February 24, 2021 Posted February 24, 2021 On 2/13/2021 at 7:28 PM, GrimReaper76 said: Do you maybe have any gaming peripherals attached? Gamepad, joystick, flight stick, pedals, wheel...? On 2/13/2021 at 7:44 PM, cayars said: Yes, gamepad and like devices on Win10 (thanks MS) can cause issues. Also likely is some browser extension you might have installed. You can deactivate them and try again to see if this is the cause.
Forkboy2 0 Posted March 9, 2021 Posted March 9, 2021 I had the same issue. Finally figured out that it was some sort of conflict with smooth scrolling plugin for web browser. What would happen is drop down menus would work fine until I scrolled to the bottom of a page in EMBY. Once I hit the bottom of a page scrolling with mousewheel became very slow and drop down menus no longer worked. Disabling smooth scrolling plugin fixed it.
Luke 42288 Posted March 9, 2021 Posted March 9, 2021 39 minutes ago, Forkboy2 said: I had the same issue. Finally figured out that it was some sort of conflict with smooth scrolling plugin for web browser. What would happen is drop down menus would work fine until I scrolled to the bottom of a page in EMBY. Once I hit the bottom of a page scrolling with mousewheel became very slow and drop down menus no longer worked. Disabling smooth scrolling plugin fixed it. Hi, interesting, what plugin?
Atrelloo 1 Posted March 14, 2021 Posted March 14, 2021 On 13/02/2021 at 18:28, GrimReaper76 said: Do you maybe have any gaming peripherals attached? Gamepad, joystick, flight stick, pedals, wheel...? I had my x-55 rhino joystick plugged in, this was causing the issue, also caused an issue where jellyfin would constantly scrub to the end of the video. 1
hackenbecker 2 Posted October 6, 2021 Posted October 6, 2021 I had the exact same issue. It is a Chrome/Edge problem. While in Chrome type chrome://flags into the address bar. Look for the entry that reads 'Touch UI Layout' and disable it. The browser will relaunch and hopefully solve the issue. This fix may be an issue if your are using a touch screen! 2
Luke 42288 Posted October 6, 2021 Posted October 6, 2021 8 hours ago, hackenbecker said: I had the exact same issue. It is a Chrome/Edge problem. While in Chrome type chrome://flags into the address bar. Look for the entry that reads 'Touch UI Layout' and disable it. The browser will relaunch and hopefully solve the issue. This fix may be an issue if your are using a touch screen! That's interesting. Thanks for the feedback.
SwanStream 64 Posted October 14, 2021 Posted October 14, 2021 (edited) On 10/6/2021 at 12:06 AM, hackenbecker said: While in Chrome type chrome://flags into the address bar. Look for the entry that reads 'Touch UI Layout' and disable it. Same issue, not a touch screen, but this worked first pull down I tried it on after restarting chrome, then it didn't work no mo... Problem exists in chrome, edge, opera... I happen to be working on home screen layouts if that matters. No extensions in any browser. BTW, I'm on synology x64 version 4.7.0.13 beta. It does seem a little random. One thing that seems to help, maybe... set display mode to TV (used to be Auto, also tried PC without a diff) and the drop downs seem to behave better, but as I said, it does seem random ish. It's tough to test as each time I set it back to desktop it doesn't drop down the drop down, so I cant set it bac k to tv to test if that fixes it.... Edited October 14, 2021 by SwanStream
Luke 42288 Posted October 14, 2021 Posted October 14, 2021 Oddly enough I do occasionally see this in chrome with other websites.
dwightturner36 0 Posted June 2, 2022 Posted June 2, 2022 (edited) not to beat a dead horse but i just installed Emby, couldnt select media type on the drop down box in chrome AND explorer. I installed firefox (which i cant stand) and it works in there. if i hadnt looked this up and tried firefox I would have said screw it and just stayed with plex and deleted emby... Surely there is something that can fix this. It relaly turned me off of emby. Edited June 2, 2022 by dwightturner36
SwanStream 64 Posted June 2, 2022 Posted June 2, 2022 annoying, yup. I see this in Opera, chrome, edge and firefox too.... don't see that behavior with any other apps. Restarting the browser sometimes fixes the issue. Don't think anyone is actively working the issue, so I've stopped paying attention or reporting... but it's still an active bug.
Luke 42288 Posted June 2, 2022 Posted June 2, 2022 I'm currently not able to reproduce, but we'll take another look. Thanks.
Carlo 4561 Posted June 2, 2022 Posted June 2, 2022 4 hours ago, dwightturner36 said: not to beat a dead horse but i just installed Emby, couldnt select media type on the drop down box in chrome AND explorer. I installed firefox (which i cant stand) and it works in there. if i hadnt looked this up and tried firefox I would have said screw it and just stayed with plex and deleted emby... 1 hour ago, SwanStream said: annoying, yup. I see this in Opera, chrome, edge and firefox too.... don't see that behavior with any other apps. Restarting the browser sometimes fixes the issue. Just checking because it wasn't clear. Did both of you have game controllers attached?
Carlo 4561 Posted June 2, 2022 Posted June 2, 2022 I ask because this is almost always hardware or driver related based on other threads and helping people. Are either of the keyboard & mouse wireless? Do you happen to have another keyboard and mouse you could try on this computer?
dwightturner36 0 Posted June 2, 2022 Posted June 2, 2022 (edited) just as a note I have no other devices hooked to my pc and a wired keyboard / mouse , firefox works as intended Edited June 2, 2022 by dwightturner36
Carlo 4561 Posted June 2, 2022 Posted June 2, 2022 Have you tried turning off all plugins in Chrome or Edge? Also try this. In Chrome enter this for the URL chrome://flags/ search for "Touch UI Layout" Change it to disabled. Reboot PC I'm trying to verify if you have the same issues others have had or if this is something different.
visproduction 338 Posted June 2, 2022 Posted June 2, 2022 Check that accessability auto click is off in Chrome? https://support.google.com/chromebook/answer/9441453?hl=en
