davesurfer 18 Posted July 18, 2020 Author Posted July 18, 2020 On 7/16/2020 at 7:19 PM, Happy2Play said: That is one disadvantage of a admin update/modifying a post and we have no idea. But it looks like June 17 was about the last update. Ok good to know it's being updated. I'm guessing when newer versions come up, if needed, I just copy over existing files? On 7/16/2020 at 8:23 PM, sooty234 said: For all to be aware. The test build is using libmpv as the default renderer. Under electron, it has limited functionality. Most notably, it will break HDR playback on Windows 10, if you run it in HDR mode. You have to switch to the GPU renderer for HDR playback, which will bring back all the existing overlay (and some uncommon playback) issues. And not to confuse you too much, you can force it to tone map, if you don't enable HDR in Windows 10. But that is probably confusing some of you. It will also break some of the hardware acceleration options. Just set that to auto, and most of you will be fine. This is also the reason why HDR won't work, but I won't get into that... No I don't use HDR playback in W10, not sure how that would even be enabled with the Intel 530 graphics and my TV doesn't support it either.
Happy2Play 9811 Posted July 18, 2020 Posted July 18, 2020 25 minutes ago, davesurfer said: Ok good to know it's being updated. I'm guessing when newer versions come up, if needed, I just copy over existing files? Normally the software will auto update. But yes from a test version standpoint.
davesurfer 18 Posted July 19, 2020 Author Posted July 19, 2020 3 hours ago, Happy2Play said: Normally the software will auto update. But yes from a test version standpoint. Is there a way to know when I can use the normal version again? Like what was happening with something interfering with the rendering or the overlay issue? Or should I disable automatic updates on the server so that things don't change for a while?
Happy2Play 9811 Posted July 19, 2020 Posted July 19, 2020 Just now, davesurfer said: Is there a way to know when I can use the normal version again? Like what was happening with something interfering with the rendering or the overlay issue? Or should I disable automatic updates on the server so that things don't change for a while? It is personal preference, but to me the next auto update would have all the fixes from the test version.
davesurfer 18 Posted July 19, 2020 Author Posted July 19, 2020 3 hours ago, Happy2Play said: Normally the software will auto update. But yes from a test version standpoint. Ok thanks I'll keep that in mind.
sooty234 266 Posted July 19, 2020 Posted July 19, 2020 Follow the release updates on Git https://github.com/MediaBrowser/emby-theater-windows/releases
davesurfer 18 Posted July 20, 2020 Author Posted July 20, 2020 On 7/18/2020 at 7:30 PM, sooty234 said: Follow the release updates on Git https://github.com/MediaBrowser/emby-theater-windows/releases Ok so this is the "MPV" releases? like the one I'm using now?
sooty234 266 Posted July 20, 2020 Posted July 20, 2020 It is mpv, and the test build you're using is more recent. The app is being redeveloped. The test build is an intermediate between the current release and what is yet to come.
