byakuya32 24 Posted July 13, 2020 Posted July 13, 2020 Hi I have to do a rebuild of my server I have an m2000 and was wondering if a ryzen 3 3200g could handle sending 5+ 4k streams to my m2000 to transcode. Does anyone know or should I step up the cpu to a ryzen 5?
Sammy 791 Posted July 13, 2020 Posted July 13, 2020 3700x at least with a GTX 1040 minimum, probably even 2080 even for 5 4k streams if you need to transcode them.Sent from my SM-G960U1 using Tapatalk
byakuya32 24 Posted July 13, 2020 Author Posted July 13, 2020 Ryalzen 7 is out of my price range cpu budget is arround 200. Do you know how many 4k streams my quadro m2000 can handle?
Sammy 791 Posted July 18, 2020 Posted July 18, 2020 https://emby.media/community/index.php?/topic/75466-nvidia-gpu-transcoding-comparison-dataSent from my SM-G960U1 using Tapatalk
