falsyana 1 Posted July 12, 2020 Posted July 12, 2020 Hi, I am trying to validate if my hardware acceleration is being used or not. I am using the emby/embyserver container (under podman) and I manage to get Emby to recognize the videocard when browsing to Server -> Transcoding When I download a movie from an Android tablet it must transcode, and when I look in the logs it seems it's using the videocard: # cat ffmpeg-transcode-7a8a2ddb-fbcc-4934-9fa3-90147def8929_1.txt [ ... snip ... ] >>>>>> Affected codecs Encoder NVENC GeForce GT 710 - H.264 (AVC) Adapter #0: 'GeForce GT 710' ComputeCapability: 3.5 Frame Sizes: max 4096x4096 - Width Alignment: 2 - Height Alignment: 2 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) Decoder NVDEC GeForce GT 710 - H.264 (AVC) Adapter #0: 'GeForce GT 710' ComputeCapability: 3.5 Frame Sizes: 48x16...4096x4096 - Width Alignment: 2 - Height Alignment: 2 Profiles: Constrained Baseline Profile (Level 6), Baseline Profile (Level 6), Main Profile (Level 6), High Profile (Level 6), Constrained High Profile (Level 6), Progressive High Profile (Level 6) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Automatic Info Checking: 'NVENC GeForce GT 710 - H.264 (AVC)' Info Check successful - selecting 'NVENC GeForce GT 710 - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: h264, Mode: Automatic Info Checking: 'NVDEC GeForce GT 710 - H.264 (AVC)' Info Check successful - selecting 'NVDEC GeForce GT 710 - H.264 (AVC)' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info NVDEC GeForce GT 710 - H.264 (AVC) >> True True Hardware Codec Info VideoInput >> True True Matching hardware context Info VideoOutput >> True True Hardware encoder Info NVENC GeForce GT 710 - H.264 (AVC) >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Next Info h264_cuvid >> CUDA cuda nv12 >> >>>>> Legacy Command /bin/ffmpeg -re -hwaccel cuda -hwaccel_device 0 -hwaccel_output_format cuda -c:v h264_cuvid -f matroska -i file:"/mnt/movies/movieX.mkv" -map 0:0 -map 0:1 -map 0:2 -map 0:5 -c:v:0 h264_nvenc -force_key_frames "expr:gte(t,n_forced*5)" -b:v:0 3232000 -maxrate 3232000 -bufsize 6464000 -profile:v:0 high -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -filter:a:0 "volume=2" -codec:a:1 aac -metadata:s:a:1 language=dut -disposition:a:1 none -ac:a:1 2 -ab:a:1 192000 -filter:a:1 "volume=2" -codec:s:0 copy -disposition:s:0 default -y "/config/sync/1/1/7a8a2ddb-fbcc-4934-9fa3-90147def8929.mkv" >>>>> Actual Command /bin/ffmpeg -loglevel +timing -y -print_graphs_file /config/logs/ffmpeg-transcode-7a8a2ddb-fbcc-4934-9fa3-90147def8929_1graph.txt -copyts -start_at_zero -f matroska,webm -re -c:v:0 h264_cuvid -hwaccel:v:0 cuda -hwaccel_device:v:0 0 -hwaccel_output_format:v:0 cuda -i "/mnt/movies/movieX.mkv" -map 0:0 -map 0:1 -map 0:2 -map 0:5 -c:v:0 h264_nvenc -b:v:0 3232000 -g:v:0 144 -maxrate:v:0 3232000 -bufsize:v:0 6464000 -sc_threshold:v:0 0 -keyint_min:v:0 144 -profile:v:0 main -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -c:a:1 aac -ab:a:1 192000 -ac:a:1 2 -metadata:s:a:1 language=dut -filter:a:1 "volume=2" -disposition:a:1 0 -c:s:0 copy -disposition:s:0 default -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "/config/sync/1/1/7a8a2ddb-fbcc-4934-9fa3-90147def8929.mkv" [ ... snip ... ] The actual transcoding is going quite slow, but of course that could be because of the videocard is quite old. But the CPU usage of the 'ffmpeg' process on the host is quite low (+/- 4%). 09:10:04.054 frame= 10 fps=0.0 q=14.0 size= 1kB time=00:00:00.79 bitrate=N/A throttle=off speed= 0x 09:10:04.559 frame= 22 fps= 22 q=14.0 size= 1kB time=00:00:01.30 bitrate= 19.2kbits/s throttle=off speed=0.51x 09:10:05.064 frame= 34 fps= 23 q=14.0 size= 1kB time=00:00:01.81 bitrate= 9.6kbits/s throttle=off speed=0.678x 09:10:05.573 frame= 46 fps= 23 q=14.0 size= 1kB time=00:00:02.32 bitrate= 6.4kbits/s throttle=off speed=0.761x 09:10:06.080 frame= 58 fps= 23 q=14.0 size= 1kB time=00:00:02.81 bitrate= 4.9kbits/s throttle=off speed=0.802x 09:10:06.588 frame= 70 fps= 23 q=14.0 size= 1kB time=00:00:03.32 bitrate= 3.9kbits/s throttle=off speed=0.836x 09:10:07.096 frame= 86 fps= 24 q=14.0 size= 1kB time=00:00:03.84 bitrate= 3.2kbits/s throttle=off speed=0.861x [ ... snip ... ] 09:38:06.858 frame=40358 fps= 24 q=18.0 size= 661830kB time=00:28:03.60 bitrate=3221.8kbits/s throttle=off speed= 1x 09:38:07.364 frame=40369 fps= 24 q=19.0 size= 661830kB time=00:28:04.11 bitrate=3220.8kbits/s throttle=off speed= 1x 09:38:07.872 frame=40381 fps= 24 q=19.0 size= 661830kB time=00:28:04.60 bitrate=3219.9kbits/s throttle=off speed= 1x 09:38:08.380 frame=40394 fps= 24 q=19.0 size= 663808kB time=00:28:05.11 bitrate=3228.5kbits/s throttle=off speed= 1x 09:38:08.889 frame=40406 fps= 24 q=18.0 size= 663808kB time=00:28:05.63 bitrate=3227.6kbits/s throttle=off speed= 1x 09:38:09.398 frame=40418 fps= 24 q=20.0 size= 664266kB time=00:28:06.14 bitrate=3228.8kbits/s throttle=off speed= 1x 09:38:09.907 frame=40430 fps= 24 q=21.0 size= 664266kB time=00:28:06.65 bitrate=3227.8kbits/s throttle=off speed= 1x 09:38:10.416 frame=40442 fps= 24 q=21.0 size= 664266kB time=00:28:07.16 bitrate=3226.8kbits/s throttle=off speed= 1x 09:38:10.923 frame=40454 fps= 24 q=21.0 size= 664266kB time=00:28:07.65 bitrate=3225.9kbits/s throttle=off speed= 1x 09:38:11.424 frame=40470 fps= 24 q=22.0 size= 664266kB time=00:28:08.17 bitrate=3224.9kbits/s throttle=off speed= 1x 09:38:11.933 frame=40479 fps= 24 q=23.0 size= 664266kB time=00:28:08.68 bitrate=3223.9kbits/s throttle=off speed= 1x 09:38:12.443 frame=40491 fps= 24 q=21.0 size= 664266kB time=00:28:09.19 bitrate=3223.0kbits/s throttle=off speed= 1x When running nvidia-smi from the container I get a file not found error # podman exec -it emby sh / # ls -l /usr/bin/ total 1324 lrwxrwxrwx 1 root root 14 Jun 2 09:11 execlineb -> /bin/execlineb -rwxr-xr-x 1 root root 1661 Mar 21 2019 fix-attrs -rwxr-xr-x 1 root root 522 Mar 21 2019 logutil-newfifo -rwxr-xr-x 1 root root 331 Mar 21 2019 logutil-service -rwxr-xr-x 1 root root 364 Mar 21 2019 logutil-service-main -rwxr-xr-x 1 root root 84136 Jun 28 10:29 nvidia-cuda-mps-control -rwxr-xr-x 1 root root 61224 Jun 28 10:28 nvidia-cuda-mps-server -rwxr-xr-x 1 root root 250416 Jun 28 10:09 nvidia-debugdump -rwxr-xr-x 1 root root 291392 Jun 28 15:07 nvidia-persistenced -rwxr-xr-x 1 root root 628280 Jun 28 10:11 nvidia-smi -rwxr-xr-x 1 root root 650 Mar 21 2019 printcontenv -rwxr-xr-x 1 root root 203 Mar 21 2019 with-contenv -rwxr-xr-x 1 root root 426 Mar 21 2019 with-retries / # / # /usr/bin/nvidia-smi sh: /usr/bin/nvidia-smi: not found Before I upgrade the videocard I would like to be sure that it's being used, how can I validate this? Thanks!
falsyana 1 Posted July 12, 2020 Author Posted July 12, 2020 After turning on debug logging and start a new job I see the following in the server logs: 2020-07-12 11:34:44.827 Info HttpServer: HTTP POST https://emby.lan:8920/Sync/Jobs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:78.0) Gecko/20100101 Firefox/78.0 2020-07-12 11:34:44.830 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 2724911, max bitrate: 320000 2020-07-12 11:34:44.830 Info App: Bitrate exceeds DirectStream limit: media bitrate: 2724911, max bitrate: 1500000 2020-07-12 11:34:44.830 Info HttpServer: HTTP Response 200 to 10.88.32.1. Time: 2ms. https://emby.lan:8920/Sync/Jobs 2020-07-12 11:34:44.831 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 2724911, max bitrate: 320000 2020-07-12 11:34:44.831 Info App: Bitrate exceeds DirectStream limit: media bitrate: 2724911, max bitrate: 1500000 2020-07-12 11:34:44.836 Info HttpServer: HTTP GET https://emby.lan:8920/Sync/Jobs?UserId=7111ca6ce36f4adc990fac714f09c7b7&ExcludeProviders=ConvertSyncProvider. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:78.0) Gecko/20100101 Firefox/78.0 2020-07-12 11:34:44.837 Info HttpServer: HTTP Response 200 to 10.88.32.1. Time: 1ms. https://emby.lan:8920/Sync/Jobs?UserId=7111ca6ce36f4adc990fac714f09c7b7&ExcludeProviders=ConvertSyncProvider 2020-07-12 11:34:44.848 Debug App: CodecValidation: FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Automatic 2020-07-12 11:34:44.848 Debug App: CodecValidation: Checking: 'NVENC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.848 Debug App: CodecValidation: Check successful - selecting 'NVENC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.848 Debug App: CodecValidation: FindVideoDecoder - MediaType: h264, Mode: Automatic 2020-07-12 11:34:44.848 Debug App: CodecValidation: Checking: 'NVDEC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.848 Debug App: CodecValidation: Check successful - selecting 'NVDEC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.848 Warn App: No filter behavior available for filter {0} 2020-07-12 11:34:44.848 Debug App: CodecValidation: Processing Plan 2020-07-12 11:34:44.848 Debug App: CodecValidation: Name CanDoInHardware WillDoInHardware Reason 2020-07-12 11:34:44.848 Debug App: CodecValidation: NVDEC GeForce GT 710 - H.264 (AVC) >> True True Hardware Codec 2020-07-12 11:34:44.848 Debug App: CodecValidation: VideoInput >> True True Matching hardware context 2020-07-12 11:34:44.848 Debug App: CodecValidation: Scaling >> True True 2020-07-12 11:34:44.848 Debug App: CodecValidation: VideoOutput >> True True Hardware encoder 2020-07-12 11:34:44.848 Debug App: CodecValidation: NVENC GeForce GT 710 - H.264 (AVC) >> True True Hardware Codec 2020-07-12 11:34:44.848 Debug App: CodecValidation: Projected Processing Formats 2020-07-12 11:34:44.848 Debug App: CodecValidation: Previous HW-Context Format SW-Format Next 2020-07-12 11:34:44.848 Debug App: CodecValidation: h264_cuvid >> CUDA cuda nv12 >> scale_cuda 2020-07-12 11:34:44.848 Debug App: CodecValidation: scale_cuda >> CUDA cuda nv12 >> setsar 2020-07-12 11:34:44.848 Debug App: CodecValidation: setsar >> CUDA cuda nv12 >> 2020-07-12 11:34:44.848 Debug App: CodecValidation: FindVideoDecoder - MediaType: h264, Mode: Automatic 2020-07-12 11:34:44.849 Debug App: CodecValidation: FindVideoDecoder - Checking: 'NVDEC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.849 Debug App: CodecValidation: FindVideoDecoder - Check successful - selecting 'NVDEC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.849 Debug App: CodecValidation: FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Automatic 2020-07-12 11:34:44.849 Debug App: CodecValidation: FindVideoEncoder - Checking: 'NVENC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.849 Debug App: CodecValidation: FindVideoEncoder - Check successful - selecting 'NVENC GeForce GT 710 - H.264 (AVC)' 2020-07-12 11:34:44.850 Info VideoEncoder: ProcessRun 'Encoding 1206aa' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file /config/logs/ffmpeg-transcode-1206aa7b-db20-4773-83cd-d3efcc123224_1graph.txt -copyts -start_at_zero -f matroska,webm -re -c:v:0 h264_cuvid -hwaccel:v:0 cuda -hwaccel_device:v:0 0 -hwaccel_output_format:v:0 cuda -i "/mnt/movies/movieX.mkv" -filter_complex "[0:0]scale_cuda@f1=w=720:h=390,setsar@f2=sar=sar[f2_out0]" -map [f2_out0] -map 0:1 -map 0:2 -c:v:0 h264_nvenc -b:v:0 1180000 -g:v:0 144 -maxrate:v:0 1180000 -bufsize:v:0 2360000 -sc_threshold:v:0 0 -keyint_min:v:0 144 -profile:v:0 main -c:a:0 copy -metadata:s:a:0 language=eng -disposition:a:0 default -c:s:0 copy -disposition:s:0 default -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "/config/sync/4/4/1206aa7b-db20-4773-83cd-d3efcc123224.mkv" 2020-07-12 11:34:44.851 Debug VideoEncoder: ProcessRun 'Encoding 1206aa' Started. Â Everything points that it is using the videocard, and that the videocard is just (extemely) slow. I keep getting a speed around 1x. As i final (and I should have started with this) test i just set 'Enable hardware acceleration when available' to 'No' and cpu usage went up to 15% and speed up to 10x. So yes it is using the videocard which is just extremely slow (and old ), time to see if an upgrade is getting me to better speeds than what the CPU does now. Â Thanks for taking your time to answer my question! Â
Luke 42246 Posted July 14, 2020 Posted July 14, 2020 Yes that appears to be using it. @softworkz may have some insight on why it's slower than cpu.
