notpiika 1 Posted July 12, 2020 Posted July 12, 2020 Hi, I'm trying to block as much phoning home from all my applications as possible, and I was wondering if there were any domains other than `mb3admin.com` I need to block from my network. I'm aware this will result in drastically reduced functionality, and many things will not work: but that's okay for me, since everything I need Emby to do works without those features (plugin store, etc.) Thanks!
Carlo 4561 Posted July 12, 2020 Posted July 12, 2020 Set a rule for Emby to allow all traffic to pass. Emby uses a lot of outbound requests for different things like meta-data but that is to support your media/content.
notpiika 1 Posted July 12, 2020 Author Posted July 12, 2020 6 minutes ago, cayars said: Set a rule for Emby to allow all traffic to pass. Emby uses a lot of outbound requests for different things like meta-data but that is to support your media/content. I'm aware that it makes requests to metadata agents and such, but I'm talking about specifically things that only Emby uses, such as `mb3admin.com`
Happy2Play 9802 Posted July 12, 2020 Posted July 12, 2020 Emby alone should be mb3admin and github. You should see everything via debug logging. Note debug logging requires a restart to enable and disable this option. Dashboard-Logs 2020-07-11 01:08:56.503 Debug TaskManager: IntervalTrigger fired for task: Check for application updates 2020-07-11 01:08:56.503 Debug TaskManager: Queueing task SystemUpdateTask 2020-07-11 01:08:56.503 Debug TaskManager: Executing Check for application updates 2020-07-11 01:08:56.503 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2020-07-11 01:08:57.221 Debug TaskManager: IntervalTrigger fired for task: Check for plugin updates 2020-07-11 01:08:57.221 Debug TaskManager: Queueing task PluginUpdateTask 2020-07-11 01:08:57.221 Debug TaskManager: Executing Check for plugin updates 2020-07-11 01:08:57.222 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2020-07-11 01:08:58.488 Debug TaskManager: Check for plugin updates Completed after 0 minute(s) and 1 seconds
notpiika 1 Posted July 12, 2020 Author Posted July 12, 2020 1 minute ago, Happy2Play said: Emby alone should be mb3admin and github. You should see everything via debug logging. Note debug logging requires a restart to enable and disable this option. Dashboard-Logs 2020-07-11 01:08:56.503 Debug TaskManager: IntervalTrigger fired for task: Check for application updates 2020-07-11 01:08:56.503 Debug TaskManager: Queueing task SystemUpdateTask 2020-07-11 01:08:56.503 Debug TaskManager: Executing Check for application updates 2020-07-11 01:08:56.503 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2020-07-11 01:08:57.221 Debug TaskManager: IntervalTrigger fired for task: Check for plugin updates 2020-07-11 01:08:57.221 Debug TaskManager: Queueing task PluginUpdateTask 2020-07-11 01:08:57.221 Debug TaskManager: Executing Check for plugin updates 2020-07-11 01:08:57.222 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2020-07-11 01:08:58.488 Debug TaskManager: Check for plugin updates Completed after 0 minute(s) and 1 seconds Oh yeah, that works too. Thanks! Is there any other reason Emby requests to mb3admin other than: - License checks - Requesting plugin list ? For example, some periodic telemetry upload about the media in libraries? Thanks again!
Happy2Play 9802 Posted July 12, 2020 Posted July 12, 2020 1 minute ago, notpiika said: Oh yeah, that works too. Thanks! Is there any other reason Emby requests to mb3admin other than: - License checks - Requesting plugin list ? For example, some periodic telemetry upload about the media in libraries? Thanks again! Not that I am aware of. 2
notpiika 1 Posted July 12, 2020 Author Posted July 12, 2020 10 minutes ago, Happy2Play said: Not that I am aware of. Cool, thanks again!
