bugmafia007 12 Posted July 11, 2020 Posted July 11, 2020 Hi, I have some movies documentaries in my EMBY library that simply don't want to get the info and cover after scan ,metadata refresh and even manually intervention Steps : Movie after scan: Manually intervention : I press ok and replace metadata ..and the results are : logs attached embyserver (2).txt Any ideas ? Thank You Ps: i have like 8 movies documentaries with this issues ..this is one of them ,i evn remove the movie from the library and re added ..didn't helped
Riggs 312 Posted July 11, 2020 Posted July 11, 2020 Check that all artwork providers are selected in the library settings. That image is shows but seems to me that the provider is not selected. Use all providers, TMDV Fanart, etc
bugmafia007 12 Posted July 11, 2020 Author Posted July 11, 2020 15 minutes ago, Riggs said: Check that all artwork providers are selected in the library settings. That image is shows but seems to me that the provider is not selected. Use all providers, TMDV Fanart, etc i have all that in the library settings:
bugmafia007 12 Posted July 11, 2020 Author Posted July 11, 2020 8 minutes ago, Riggs said: delete the .nfo and refresh done..now running scan and metadata search ..will update soon
Riggs 312 Posted July 11, 2020 Posted July 11, 2020 (edited) the bif can be deleted too and refresh all, if the .nfo do not work BTW, what language you set for that library? Edited July 11, 2020 by Riggs
Riggs 312 Posted July 11, 2020 Posted July 11, 2020 Ohh I think That I saw the problem. You put that documentary inside a TV Shows library, and that documentary should be treated as a movie 1
bugmafia007 12 Posted July 11, 2020 Author Posted July 11, 2020 new files created after scan and metadata search : same results : logs : embyserver (3).txt
bugmafia007 12 Posted July 11, 2020 Author Posted July 11, 2020 Just now, Riggs said: Ohh I think That I saw the problem. You put that documentary inside a TV Shows library, and that documentary should be treated as a movie hmmmm ..but lest say Planet Earth series ..cannot be a movie no ? u have like 10 episodes
Riggs 312 Posted July 11, 2020 Posted July 11, 2020 (edited) 9 minutes ago, bugmafia007 said: hmmmm ..but lest say Planet Earth series ..cannot be a movie no ? u have like 10 episodes Nope, it is cataloged how movie https://www.themoviedb.org/movie/14002-baraka So delete the covers bif and nfo again in your file manager and try doing a movie library. You can named something like "Documentaries" Planet Earth have many content, some are in series mode, and some are in movie mode. Nevermind if they come from a TV aired program. Edited July 11, 2020 by Riggs
Riggs 312 Posted July 11, 2020 Posted July 11, 2020 And check if Emby have permissions to read and write on that directory too, just in case.
Riggs 312 Posted July 11, 2020 Posted July 11, 2020 Baraka's "sequel" is Samsara, however they are not treated as a collection either. Both were directed by Ron Fricke, however they are not Planet Earth material, although they have aired as such, neither is.
Solution bugmafia007 12 Posted July 11, 2020 Author Solution Posted July 11, 2020 In the end the solution was to create libraries named docu1 and docu2 docu 1 -movies (baraka recognized only like a movie ) docu 2 -series (planet earth\blue planet recognized only if is a tv series ) Thanks for your help @Riggs 2
Carlo 4561 Posted July 11, 2020 Posted July 11, 2020 BTW, no need to delete bif files if the movie file hasn't changed. That will just cause Emby to regenerate it again when it didn't need to. 1
Riggs 312 Posted July 12, 2020 Posted July 12, 2020 20 hours ago, bugmafia007 said: In the end the solution was to create libraries named docu1 and docu2 docu 1 -movies (baraka recognized only like a movie ) docu 2 -series (planet earth\blue planet recognized only if is a tv series ) Thanks for your help @Riggs I'm glad I was able to help you with that. Good luck and take care
bugmafia007 12 Posted July 12, 2020 Author Posted July 12, 2020 8 hours ago, Riggs said: I'm glad I was able to help you with that. Good luck and take care Thanks man ..my library looks amazingggggggggggggggggggggggg Love EMBY 1
Riggs 312 Posted July 15, 2020 Posted July 15, 2020 On 7/12/2020 at 3:54 PM, bugmafia007 said: Thanks man ..my library looks amazingggggggggggggggggggggggg Love EMBY Look's awesome! Congrats! 1
