Tataouine 1 Posted July 11, 2020 Posted July 11, 2020 (edited) Hello, I have an issue connecting my remote emby server to my amazon firestick 4K with the emby app. When i put it manually it tells me that there is en error connecting to the server. And when I use emby connect it tells me it can't reach the server and ask me if i want to delete it. (see screenshot, in french) The weird thing is when that when i use any browser it works perfectly. Even with the browser on the firestick, emby connect works fine. Any idea as to why the app doesn't connect ? Thanks Edited July 11, 2020 by Tataouine
ebr 16338 Posted July 11, 2020 Posted July 11, 2020 Hi. Are you trying to connect via https? Do you have a valid and recognized certificate if so?
Tataouine 1 Posted July 12, 2020 Author Posted July 12, 2020 Hi, Yes i use https and my certificate is valid, works fine on any browser.
ebr 16338 Posted July 12, 2020 Posted July 12, 2020 Is your server running on a Linux type OS? If so, it is probably due to how the certificate is being delivered. There is a post out here related to this (has to do with supplying the entire cert chain). I'll see if I can find it...
Tataouine 1 Posted July 13, 2020 Author Posted July 13, 2020 Hi, thanks for the answer. Yes I use the synology app with a let's encrypt pfx for the certificate. I managed to connect my firestick using http, (not s), i can't really test for the next two weeks, but i'll look into the post you quoted to see if i can make https work. I'll post it here if i manage to do it properly.
