level20peon 12 Posted July 11, 2020 Posted July 11, 2020 When I try to playback a video file (any video file) that has an OGG Vorbis audio stream, it doesn't start the playback but "hangs" at 0:00. If I put the movie file onto an USB stick and try to play it on the TV directly without emby, it tells me that there's no audio in that file. According to the logs, emby tries to do a direct playback (without transcoding) so I think emby should default to transcode the audio on the LG App if vorbis is detected. So, there's no error log I can provide since emby just does the "normal" direct playback.
SamES 1084 Posted July 13, 2020 Posted July 13, 2020 On 7/11/2020 at 7:52 PM, level20peon said: When I try to playback a video file (any video file) that has an OGG Vorbis audio stream, it doesn't start the playback but "hangs" at 0:00. If I put the movie file onto an USB stick and try to play it on the TV directly without emby, it tells me that there's no audio in that file. According to the logs, emby tries to do a direct playback (without transcoding) so I think emby should default to transcode the audio on the LG App if vorbis is detected. So, there's no error log I can provide since emby just does the "normal" direct playback. Can you please attach the media info for one of your ogg files and I'll check and remove this if required? Thanks
level20peon 12 Posted July 13, 2020 Author Posted July 13, 2020 I found out that some vorbis files work after all; 2 channel files seem to be played just fine. But 6 channel files don't work. Please find both examples attached. 2Ch.mkv 6Ch.mkv
