muzicman0 85 Posted July 10, 2020 Posted July 10, 2020 Please see the attached photo. My wife is playing a TV episode through EmbyCon, but the dashboard shows that it is playing 2 times. Any ideas? Just want to make sure that I am not wasting system resources somehow.
TeamB 2440 Posted July 11, 2020 Posted July 11, 2020 Do you have both addons installed, try uninstalling emby for kodi and see what happens.
muzicman0 85 Posted July 11, 2020 Author Posted July 11, 2020 I disabled it. I use a 'random TV/Movie fan art' for my main menu background, and if I don't have Emby for Kodi, it just shows a black screen (or at least it used to). I can enable it every once and a while to update, then disable again, and everything works as it should. Thanks.
