James2901uk 1 Posted July 9, 2020 Posted July 9, 2020 I've just installed embycon add-on into kodi and connected to my server, however when i go into embycon, then libraries the only two it is showing is music and trailers...there's no movie or tv folders showing. It doesn't matter what skin i use they don't appear, the only time kodi seems to shows the content of these folders is when i clone the kodi default skin...why don't these folders show up when i enter the embycon add-on?
TeamB 2440 Posted July 9, 2020 Posted July 9, 2020 If you are entering EmbyCon -> Emby libraries -> your libraries here Then that should show your movie and TV libraries. You should see the same libraries you see on the Web client using the same user. If you don't turn on EmbyCon debug logging in the EmbyCon addon settings under advanced, restart Kodi and navigate to the EmbyCon emby libraries area again, pm me the log.
James2901uk 1 Posted July 11, 2020 Author Posted July 11, 2020 Hi teamB, thanks for the reply, so I have done the above, however being new to kodi and the embycon addon....i'm not sure where to find the log so i can send it to you....but since i last posted, here's what i have done...so i thought that it was something that i may have done wrong in setting it up...so i completely uninstalled kodi, and made sure there was no remains of it on my system, i then reinstalled just kodi(no addons) and before adding anything else i installed the embycon addon...i let it do its thing of finding my server, logged into it....but yet again...entering embycon....>emby Libraries...>your libraries here....only two things appear....music and trailers...no tv shows...no movies...
TeamB 2440 Posted July 11, 2020 Posted July 11, 2020 Do you see the libraries using the same user in the Web Client? (can I get a screen shot) Are you sure you are using the correct user when logging into Kodi EmbyCon? Here is some info about the log log location in Kodi: https://kodi.wiki/view/Log_file
James2901uk 1 Posted July 11, 2020 Author Posted July 11, 2020 hi teambB, Attached screenshot of the emby web browser....as you see all libraries are showing and emby is working fine on everything else...just not kodi...and as i'm the only user at the moment...i'm positive i'm logged into the correct account, double checked this morning also checked i.p of server, even deleted server from embycon and re-added....also attached is a screenshot from within a clean kodi install with only embycon added...and from inside the embycon addon's libraries
TeamB 2440 Posted July 11, 2020 Posted July 11, 2020 yep that is weird, PM me the log and I will take a look.
James2901uk 1 Posted July 11, 2020 Author Posted July 11, 2020 (edited) Hi TeamB, Attached is the kodi log....what i will also say is that this has happened even installing embycon on my nvidia shield tv....so it's not just my pc kodi not showing these libraries its my android device also...(very Strange) in advance thank you for your help with this kodi.log Edited July 11, 2020 by TRON29 file attachment added
TeamB 2440 Posted July 11, 2020 Posted July 11, 2020 @Luke have you removed CollectionType from the responce to /Views?
Luke 42234 Posted July 11, 2020 Posted July 11, 2020 No, it should be there. When it's null it means mixed content.
TeamB 2440 Posted July 11, 2020 Posted July 11, 2020 7 minutes ago, Luke said: No, it should be there. When it's null it means mixed content. From what I can see in the log file above it is just absent, if it is null would it just be missing? @TRON29 If that is the case then yes, if you have mixed content libraries they will not show up in kodi as kodi does not know how to display mixed content.
James2901uk 1 Posted July 11, 2020 Author Posted July 11, 2020 I'm using the latest version of emby server 4.4.3....
pünktchen 1410 Posted July 11, 2020 Posted July 11, 2020 I'm using the latest version of emby server 4.4.3....Have you used the Server Configuration Backup plugin recently to restore your settings?
James2901uk 1 Posted July 11, 2020 Author Posted July 11, 2020 not recently i think it was about 2 weeks ago.....before i decided to install kodi and try my hand at building a htpc pünktchen
pünktchen 1410 Posted July 11, 2020 Posted July 11, 2020 not recently i think it was about 2 weeks ago.....before i decided to install kodi and try my hand at building a htpc pünktchenThat's the reason. The plugin is broken since the beginning of the year and always restores Mixed Content libraries instead of Movies and TVShows. There's a long thread with a manual workaround here in the forum. Somehow the Emby devs don't care.@Luke
James2901uk 1 Posted July 11, 2020 Author Posted July 11, 2020 Ah....so I'll uninstall emby server and start afresh....hopefully then it'll work.....I'd like to thank ALL you guys for your help it's seriously appreciated...thank you
pünktchen 1410 Posted July 11, 2020 Posted July 11, 2020 No need to reinstall Emby. Just recreate your libraries with the proper content type.
James2901uk 1 Posted July 11, 2020 Author Posted July 11, 2020 you are an absolute star pünktchen....just recreated the libraries....and all are now appearing in embycon....i now know not to use the server configuration backup....again thank you
