jriker1 21 Posted July 10, 2020 Author Posted July 10, 2020 34 minutes ago, FrostByte said: I do believe Emby is working correctly I'll play around with my audio a bit on my receiver but wouldn't working correctly be that it isn't transcoding it at all? Can't speak for the limitations of the Exoplayer. Would think with VLC it's not trancoding at all no? Didn't even think VLC did transcoding as a player. Thought it just had every codec and the kitchen sink.
ebr 16338 Posted July 10, 2020 Posted July 10, 2020 Just now, jriker1 said: but wouldn't working correctly be that it isn't transcoding it at all No, Emby as a system is designed to play all of your content on all of your devices regardless of whether those devices directly support that content. So the system (including the server) can convert your items "on the fly" so that it will play. That is what the system is doing now. Transcoding is not "bad" - it is actually a huge feature of the Emby ecosystem. Having said that, if you have server constraints that cause problems (which it doesn't seem that you do) then you can provide your media in a format that is widely compatible with a lot of devices to minimize the necessity of conversion.
FrostByte 5454 Posted July 10, 2020 Posted July 10, 2020 BTW: I can duplicate this using the following settings Which is why I asked if your transcoding options were all set earlier 1
jriker1 21 Posted July 11, 2020 Author Posted July 11, 2020 (edited) Can you clarify I can duplicate this? Are you talking no sound? For the above, is that set per client? I see this in the windows client under the user settings but not on the Shield. Should I have it as you have above or all boxes checked? If I go to the user settings for my login I see: Edited July 11, 2020 by jriker1
jriker1 21 Posted July 11, 2020 Author Posted July 11, 2020 (edited) Also tweaked some settings on my receiver, which I'm not convinced is related, and sound is working now. I'm still not happy it's transcoding as I think some of us feel the Shield can play this content natively and as FrostByte mentioned the picture isn't the greatest after transcoding. One other item I noted with the shield. Not sure if it's these videos but when I go back to the list of movies, in this case the three Rush Hour movies, and try to click on one of them nothing happens. Then suddenly the screen goes blank and I can't get back in. Then eventually it will try reload and will do so but after excessive spinning. Not sure if this is related, but there are hundreds of the same entries in the embyserver.txt log milliseconds apart and other various errors about bad formatting and Void MoveNext(): I attached my log. Also my app is version 1.8.10g is that the latest? Not sure how I pull it up but sometimes it shows the version of the server on the bottom left and the version of the client on the bottom right and the bottom right says Retired or something like that after the version number which I thought was odd. embyserver.txt Edited July 11, 2020 by jriker1
ebr 16338 Posted July 11, 2020 Posted July 11, 2020 10 hours ago, jriker1 said: Also tweaked some settings on my receiver, which I'm not convinced is related, and sound is working now. That's great news and does sound related. 10 hours ago, jriker1 said: I'm still not happy it's transcoding as I think some of us feel the Shield can play this content natively You are taking a video format designed over a decade ago for Windows Media Center and feeding it to a modern streaming device. Google (developers of Android and the player we use) simply have not accounted for this. 10 hours ago, jriker1 said: and try to click on one of them nothing happens. Then suddenly the screen goes blank and I can't get back in. Then eventually it will try reload and will do so but after excessive spinning. Right at that point (after getting back in the app) can you please send a log from the app? 10 hours ago, jriker1 said: Not sure how I pull it up but sometimes it shows the version of the server on the bottom left and the version of the client on the bottom right and the bottom right says Retired or something like that That is on the app settings page and what it says is "Registered" which means you either have Premiere or have unlocked the app.
jriker1 21 Posted July 12, 2020 Author Posted July 12, 2020 On 7/11/2020 at 9:58 AM, ebr said: hat is on the app settings page and what it says is "Registered" which means you either have Premiere or have unlocked the app. Just found where it is again. Says Expired. When you are on the main page of Emby and you click on the gear on the top right the bottom of that page shows the version of the server on the bottom left and the version of the app on the bottom right. Version installed is just from the Google Play store.
ebr 16338 Posted July 12, 2020 Posted July 12, 2020 1 hour ago, jriker1 said: Just found where it is again. Says Expired. If it says "Expired" then playback should not be working at all...
jriker1 21 Posted July 13, 2020 Author Posted July 13, 2020 Here's what I get and on all my NVidia Shield's:
Carlo 4561 Posted July 13, 2020 Posted July 13, 2020 Do you block domains or do any filtering on your router? Specifically mb3admin.com. If so unblock that domain.
jriker1 21 Posted July 13, 2020 Author Posted July 13, 2020 Nope I have not setup any restrictions. I assume you are talking outbound communication. If so nothing outbound gets blocked. Obviously everything inbound is restricted due to NAT. In a browser I paste in mb3admin.com and it redirects to emby.media
Carlo 4561 Posted July 13, 2020 Posted July 13, 2020 I just added "jriker1" to a test account on my system with one test library visible. Try logging in using Emby Connect and let us know if it still shows as Expired after connecting to my server.
jriker1 21 Posted July 16, 2020 Author Posted July 16, 2020 On 7/14/2020 at 9:19 AM, ebr said: What happens when you play something? It plays movies and recorded tv shows.
ebr 16338 Posted July 16, 2020 Posted July 16, 2020 2 hours ago, jriker1 said: It plays movies and recorded tv shows. Can you please play something for just a few seconds and then immediately send a log from the app? Thanks.
