joelang6126 10 Posted July 9, 2020 Posted July 9, 2020 Is it possible to give emby a username and password for access NAS drives from within emby? I can mount the share using the default admin profile but i'd like to have handle its own login.
sfatula 208 Posted July 9, 2020 Posted July 9, 2020 (edited) As far as I know, you'd have to make it anonymous access, then it should work. i.e., no user and password. You could use autofs possibly, sort of what you want as it will only mount on demand. Edited July 9, 2020 by sfatula
joelang6126 10 Posted July 9, 2020 Author Posted July 9, 2020 Thanks for the reply. I thought that was the case. The system that hosts emby connects using its own logon which i guess will have to do for now.
