Luke 42251 Posted April 22, 2022 Posted April 22, 2022 Just now, tribugames said: Hi dont work now? Hi there, can you please describe your issue in more detail? Thanks.
Sau64 0 Posted April 28, 2022 Posted April 28, 2022 Hi, great work with the plugin. In my case (i'm running it on a mac mini) works most of the time, but in some cases like the following https://www.subdivx.com/X66XNjM5MzU0X-resident-alien-s02e05.html it gets downloaded like this... Mac OS X 2cïATTRï»Õ»Ü%com.apple.metadata:kMDItemWhereFromsNGcom.apple.quarantinebplist00¢_-https://www.tusubtitulo.com/updated/6/84735/1_%https://www.tusubtitulo.com/show/4205;cq/0081;6217a298;Microsoft\x20Edge;D61377FB-2A95-48DC-A9D2-1B801FBD47A848 Somos muy buenos cambiando los recuerdos de una persona. 7 00:00:12,449 --> 00:00:15,874 FBI. El asesino no es Harry Vanderspeigle. com.apple.quarantine is some tag apple add for user confirmation afaik. weird thing is that happens with specifics subs, idk why. Resident.Alien.S02E05.1080p.WEB.h264-GOSSIP.es.srt
lvitti 17 Posted April 28, 2022 Author Posted April 28, 2022 15 hours ago, Sau64 said: Hi, great work with the plugin. In my case (i'm running it on a mac mini) works most of the time, but in some cases like the following https://www.subdivx.com/X66XNjM5MzU0X-resident-alien-s02e05.html it gets downloaded like this... Mac OS X 2cïATTRï»Õ»Ü%com.apple.metadata:kMDItemWhereFromsNGcom.apple.quarantinebplist00¢_-https://www.tusubtitulo.com/updated/6/84735/1_%https://www.tusubtitulo.com/show/4205;cq/0081;6217a298;Microsoft\x20Edge;D61377FB-2A95-48DC-A9D2-1B801FBD47A848 Somos muy buenos cambiando los recuerdos de una persona. 7 00:00:12,449 --> 00:00:15,874 FBI. El asesino no es Harry Vanderspeigle. com.apple.quarantine is some tag apple add for user confirmation afaik. weird thing is that happens with specifics subs, idk why. Resident.Alien.S02E05.1080p.WEB.h264-GOSSIP.es.srt 58.13 kB · 0 downloads Hi, I think i found the issue Can you try this version and let me know if it's fixed ? Version 1.0.7 Thanks !
Sau64 0 Posted April 28, 2022 Posted April 28, 2022 1 hour ago, lvitti said: Hi, I think i found the issue Can you try this version and let me know if it's fixed ? Version 1.0.7 Thanks ! Hi, i tried it but still happening.
victor@vialy.com 9 Posted June 15, 2022 Posted June 15, 2022 Hi! It worked PERFECTLY for me... until Emby 4.7 Are there plans to make it work on this new version?
Luke 42251 Posted June 15, 2022 Posted June 15, 2022 It should be an easy fix, just update to a 4.7 nuget package and then recompile.
lvitti 17 Posted June 15, 2022 Author Posted June 15, 2022 2 hours ago, victor@vialy.com said: Hi! It worked PERFECTLY for me... until Emby 4.7 Are there plans to make it work on this new version? 51 minutes ago, Luke said: It should be an easy fix, just update to a 4.7 nuget package and then recompile. Thanks Luke, will do it tomorrow I wasn't aware of the change on the dependencies. 1
lvitti 17 Posted June 15, 2022 Author Posted June 15, 2022 18 hours ago, victor@vialy.com said: Hi! It worked PERFECTLY for me... until Emby 4.7 Are there plans to make it work on this new version? Can you please try the new version? https://github.com/lvitti/emby-SubdivX/releases/tag/1.0.9
Luke 42251 Posted June 15, 2022 Posted June 15, 2022 16 hours ago, lvitti said: Thanks Luke, will do it tomorrow I wasn't aware of the change on the dependencies. Just in case, here's an example from another plugin; https://github.com/MediaBrowser/Podnapisi/commit/4eb5896bb78586d266da1ea4bb12be6c9cdfaec2 1
victor@vialy.com 9 Posted June 16, 2022 Posted June 16, 2022 5 hours ago, lvitti said: Can you please try the new version? https://github.com/lvitti/emby-SubdivX/releases/tag/1.0.9 Correct me if I am wrong. - I uninstalled the plugin from EMBY PLUGINS page. -Confirmed that the DLL was deleted from the emby plugins folder -Reset emby -Check SUBDIVX plugin is not in the system - I downloaded the zip, and placed the new DLL on the EMBY Plugins folder - Still see the plugin as version 1.0.6 - Still does not work, and EMBY log says it is running version 1.0.6 instead of 1.0.9 Am I doing something wrong?
lvitti 17 Posted June 16, 2022 Author Posted June 16, 2022 9 minutes ago, victor@vialy.com said: Correct me if I am wrong. - I uninstalled the plugin from EMBY PLUGINS page. -Confirmed that the DLL was deleted from the emby plugins folder -Reset emby -Check SUBDIVX plugin is not in the system - I downloaded the zip, and placed the new DLL on the EMBY Plugins folder - Still see the plugin as version 1.0.6 - Still does not work, and EMBY log says it is running version 1.0.6 instead of 1.0.9 Am I doing something wrong? Help me here @Luke, but i think you have 2 plugins folder, one in the programdata/plugins and the other one in system/plugins if you put the new dll in the system/plugins folder and restart the server, it should install the new one
Luke 42251 Posted June 16, 2022 Posted June 16, 2022 No don't mess with system/plugins. If you put anything there, remove it. Only touch the plugins folder under /programdata
victor@vialy.com 9 Posted June 16, 2022 Posted June 16, 2022 Well... Anyway, shuted down EMBY, searched whole drive for subdivx, deleted everything, started EMBY, checked NO subdivx Plugin installed. Placed 1.0.9 dll on Programdata/Plugins directory, started emby and it still says 1.0.6 with same errors when running Can you attach the DLL here?
lvitti 17 Posted June 16, 2022 Author Posted June 16, 2022 9 hours ago, victor@vialy.com said: Well... Anyway, shuted down EMBY, searched whole drive for subdivx, deleted everything, started EMBY, checked NO subdivx Plugin installed. Placed 1.0.9 dll on Programdata/Plugins directory, started emby and it still says 1.0.6 with same errors when running Can you attach the DLL here? Sorry, i think i push the wrong version to the release page. Please try again with this Release.v1.0.9.zip
victor@vialy.com 9 Posted June 16, 2022 Posted June 16, 2022 4 hours ago, lvitti said: Sorry, i think i push the wrong version to the release page. Please try again with this Release.v1.0.9.zip 8.06 kB · 2 downloads Thanks a lot! This one works perfectly. Thanks for your help and support.
Luke 42251 Posted February 24, 2024 Posted February 24, 2024 10 minutes ago, tribugames said: Hi now not working? Hi, please describe your issue in more detail: How to Report a Problem Thanks.
Luke 42251 Posted February 24, 2024 Posted February 24, 2024 3 hours ago, tribugames said: Hi dear don't find any subtitles HI there, please provide a specific example: How to Report a Problem This will help the developer of this plugin find the reason for the problem. Thanks.
Luke 42251 Posted February 25, 2024 Posted February 25, 2024 12 minutes ago, tribugames said: Hi dear dont show any subtitles OK, we are very happy to help, but how can we with the little information that you're providing? When you're able to provide a more detailed description of your problem by following: How to Report a Problem Then please come back, repost your message and we will do our very best to help you. Thanks.
abescalamis 88 Posted August 22, 2024 Posted August 22, 2024 Hello The plugin doesn't show any results when looking/searching for subtitles. embyserver.txt
lvitti 17 Posted August 29, 2024 Author Posted August 29, 2024 Hi, Thanks for the heads up ! it seems that they updated the page and the scrapping I was doing is no longer working. I'll try to update it in the next few days. Sorry for the delay but i wasn't receiving notification from this Topic dont know what happened
abescalamis 88 Posted August 31, 2024 Posted August 31, 2024 On 8/29/2024 at 11:38 AM, lvitti said: Hi, Thanks for the heads up ! it seems that they updated the page and the scrapping I was doing is no longer working. I'll try to update it in the next few days. Sorry for the delay but i wasn't receiving notification from this Topic dont know what happened I got home and was able to test and it works, since I use linux needed to put the plugin also on /var/lib/emby/plugins. 1 1
