jenpat 0 Posted July 7, 2020 Posted July 7, 2020 Hello. I have installed the addon Emby for Kodi. I´m using some clients today connecting with Emby connect over Wan to my PC that has a vpn connection. Port forwarding for my vpn connection is working, but not with the addon Emby for Kodi. When trying to connect I only get wrong usernamne and password. I´m using: Kodi version 18.7.1 Emby Server 4.4.3.0 Using latest addon for Kodi (not beta, same result with beta) 4.1.19, installed from repository https://kodi.emby.tv/ See my attached logfile and pictures. /Niklas error.log
Luke 42233 Posted July 8, 2020 Posted July 8, 2020 Hi, did you enter the same password that you use here on this forum?
jenpat 0 Posted July 8, 2020 Author Posted July 8, 2020 Yes. I tried almost eveything yesterday. But i don’t work. As i write, it is working fine from an android/Apple/browser. Thanks for a nice product, Emby is fantastic. /Niklas
Luke 42233 Posted July 10, 2020 Posted July 10, 2020 So you entered the same password as your forum password here?
SpaceballOne 0 Posted July 12, 2020 Posted July 12, 2020 (edited) @jenpat Is your emby account linked to your server username in the server users setting? Update, I tried to install Emby for Kodi also and am unable to login via connect and receive screens similar to above. I have my account linked on my server. Emby server beta 4.5.0.13 Kodi 18.7.1 Emby for Kodi beta 4.1.19 Edited July 22, 2020 by SpaceballOne
Watson19 0 Posted July 19, 2020 Posted July 19, 2020 (edited) On 7/8/2020 at 6:03 AM, Luke said: Hi, did you enter the same password that you use here on this forum? @Luke Hi I am also getting this problem using the correct user and pass to my Emby account. Any ideas how to fix this? Or a work around? Edited July 19, 2020 by Watson19
Luke 42233 Posted July 22, 2020 Posted July 22, 2020 It is resolved for the next update to the Emby for Kodi addon. Thanks. 1
Sparkinman 0 Posted August 2, 2020 Posted August 2, 2020 Is there anyway to get the fix now, or do we need to wait for whatever comes after 1.09 beta?
Luke 42233 Posted August 4, 2020 Posted August 4, 2020 Sorry for the delay. We'll try to get a new release of the add-on out ASAP. Thanks.
crvideoEmby 0 Posted August 14, 2020 Posted August 14, 2020 Same problem here. Does the old version have the same problem?
Luke 42233 Posted August 14, 2020 Posted August 14, 2020 1 minute ago, crvideoEmby said: Same problem here. Does the old version have the same problem? Yes. There's no old version that will help. We'll have a new release out soon to resolve this. Thanks.
Watson19 0 Posted August 16, 2020 Posted August 16, 2020 That’s great. Look forward to the next update. Would be awesome if it was able to be done from the phone by the code like the Emby Connect currently is on the app.
wuffer 0 Posted August 31, 2020 Posted August 31, 2020 Are there any timeframe for when this will be fixed?
Luke 42233 Posted September 1, 2020 Posted September 1, 2020 On 8/31/2020 at 3:46 AM, wuffer said: Are there any timeframe for when this will be fixed? Apologies for the delay. We are currently ramping up a new developer who will be working on this add-on and one of their first tasks will be testing the fix for this and getting a new release out. Thanks.
jdeacon 0 Posted September 3, 2020 Posted September 3, 2020 Ok, We will waiting for it. Thanks for your work.
quickmic 1709 Posted October 19, 2020 Posted October 19, 2020 (edited) 4.1.20 stable and 4.1.21 beta version are available for a couple of weeks. Both includes the fix, do you still have issues with embyconnect?? Edited October 19, 2020 by quickmic
