kelly.clubb 8 Posted July 7, 2020 Posted July 7, 2020 I am looking to see better parental controls that can filter content by checkmark in the following categories: • Individual Rating (Instead of saying all content above x rating should be blocked, I would like to see check boxes to distinguish things like R from TV-MA where checking a specific rating would block/allow said content. • Same form as the last but for Genre.
kelly.clubb 8 Posted July 7, 2020 Author Posted July 7, 2020 (edited) Also, could we make content searchable by rating and genre as well? If I add tags, the tags will pull up, but it would be much easier to not have to add tags to every single item I host. Edited July 7, 2020 by kelly.clubb
ebr 16339 Posted July 7, 2020 Posted July 7, 2020 Hi. I'm not sure I understand exactly what you are asking for but we already have some pretty fine-grained control over this. You can give your items a "Custom Rating" if you don't agree with the assigned rating and you can also use individual tags to allow or block specific items. Can you please explain how what you are suggesting would allow you more control than that? Thanks.
