tre4b 4 Posted July 7, 2020 Posted July 7, 2020 I am trying to get Emby running on its own address however just setting the Local IP Address in the network settings does not seem to work. Do I need to take additional steps on QNAP to make this work? Trev
Luke 42241 Posted July 9, 2020 Posted July 9, 2020 Hi, what do you mean by on it's own address? What exactly is the problem?
Happy2Play 9811 Posted July 9, 2020 Posted July 9, 2020 Are you saying you want Emby Server to run on a different ip then the device it is installed on?
tre4b 4 Posted July 9, 2020 Author Posted July 9, 2020 I would like to run the server on a different IP Address to the QNAP box, if there is a way to achieve that.
Luke 42241 Posted July 10, 2020 Posted July 10, 2020 Emby server doesn't create a network connection, rather it uses the one that is available. Why do you think you need this anyway?
