PhantomCircuit 6 Posted July 3, 2020 Posted July 3, 2020 Hi, these are personal videos which get auto populated. i have to manually change it. what can i do to stop this from happening so that i can remove and reupload into the library? thanks
seanbuff 1353 Posted July 3, 2020 Posted July 3, 2020 Hi, Are you saying you don't want Emby to process these videos upon import? If so, you would just disable any metadata providers in the settings for this Library. Hope this helps, apologies if I did not understand your question correctly. 1
PhantomCircuit 6 Posted July 3, 2020 Author Posted July 3, 2020 thanks @seanbuff, yes - i have those option turned on and yes i do not want Emby to process these videos.
