Kim DJ 0 Posted July 15, 2014 Posted July 15, 2014 Hello, When i try to install(reinstall) Mediabrowser server i get this box And this are the details: PLATFORM VERSION INFO Windows : 6.1.7601.65536 (Win32NT) Common Language Runtime : 4.0.30319.18444 System.Deployment.dll : 4.0.30319.18408 built by: FX451RTMGREL clr.dll : 4.0.30319.18444 built by: FX451RTMGDR dfdll.dll : 4.0.30319.18408 built by: FX451RTMGREL dfshim.dll : 4.0.41209.0 (Main.041209-0000) SOURCES Deployment url : http://www.mb3admin.com/downloads/release/server/MediaBrowser.Server.Installer.application Server : cloudflare-nginx IDENTITIES Deployment Identity : MediaBrowser.Server.Installer.application, Version=3.0.1.23, Culture=neutral, PublicKeyToken=4b9d5f30d771bc4d, processorArchitecture=x86 APPLICATION SUMMARY * Online only application. ERROR SUMMARY Below is a summary of the errors, details of these errors are listed later in the log. * Activation of http://www.mb3admin.com/downloads/release/server/MediaBrowser.Server.Installer.application resulted in exception. Following failure messages were detected: + Value does not fall within the expected range. COMPONENT STORE TRANSACTION FAILURE SUMMARY No transaction error was detected. WARNINGS There were no warnings during this operation. OPERATION PROGRESS STATUS * [15/07/2014 8:14:04] : Activation of http://www.mb3admin.com/downloads/release/server/MediaBrowser.Server.Installer.application has started. * [15/07/2014 8:14:05] : Processing of deployment manifest has successfully completed. ERROR DETAILS Following errors were detected during this operation. * [15/07/2014 8:14:05] System.ArgumentException - Value does not fall within the expected range. - Source: System.Deployment - Stack trace: at System.Deployment.Application.NativeMethods.CorLaunchApplication(UInt32 hostType, String applicationFullName, Int32 manifestPathsCount, String[] manifestPaths, Int32 activationDataCount, String[] activationData, PROCESS_INFORMATION processInformation) at System.Deployment.Application.ComponentStore.ActivateApplication(DefinitionAppId appId, String activationParameter, Boolean useActivationParameter) at System.Deployment.Application.SubscriptionStore.ActivateApplication(DefinitionAppId appId, String activationParameter, Boolean useActivationParameter) at System.Deployment.Application.ApplicationActivator.Activate(DefinitionAppId appId, AssemblyManifest appManifest, String activationParameter, Boolean useActivationParameter) at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl) at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state) COMPONENT STORE TRANSACTION DETAILS * Transaction at [15/07/2014 8:14:05] + System.Deployment.Internal.Isolation.StoreOperationSetDeploymentMetadata - Status: Set - HRESULT: 0x0 + System.Deployment.Internal.Isolation.StoreTransactionOperationType (27) - HRESULT: 0x0 Anny idee what it can be? Regards, and thanks. Kim
arctic4x4 0 Posted September 18, 2014 Posted September 18, 2014 I am having the same problem even after trying the Clear ClickOnce Cache. Here is my details PLATFORM VERSION INFO Windows : 6.1.7601.65536 (Win32NT) Common Language Runtime : 4.0.30319.18444 System.Deployment.dll : 4.0.30319.18408 built by: FX451RTMGREL clr.dll : 4.0.30319.18444 built by: FX451RTMGDR dfdll.dll : 4.0.30319.18408 built by: FX451RTMGREL dfshim.dll : 4.0.41209.0 (Main.041209-0000)SOURCES Deployment url : http://www.mb3admin.com/downloads/release/server/MediaBrowser.Server.Installer.applicationERROR SUMMARY Below is a summary of the errors, details of these errors are listed later in the log. * Activation of http://www.mb3admin.com/downloads/release/server/MediaBrowser.Server.Installer.application resulted in exception. Following failure messages were detected: + The system cannot find the file specified. (Exception from HRESULT: 0x80070002)COMPONENT STORE TRANSACTION FAILURE SUMMARY No transaction error was detected.WARNINGS There were no warnings during this operation.OPERATION PROGRESS STATUS * [18/09/2014 3:51:20 PM] : Activation of http://www.mb3admin.com/downloads/release/server/MediaBrowser.Server.Installer.application has started. ERROR DETAILS Following errors were detected during this operation. * [18/09/2014 3:51:20 PM] System.IO.FileNotFoundException - The system cannot find the file specified. (Exception from HRESULT: 0x80070002) - Source: System.Deployment - Stack trace: at System.Deployment.Internal.Isolation.IsolationInterop.GetUserStore(UInt32 Flags, IntPtr hToken, Guid& riid) at System.Deployment.Application.ComponentStore..ctor(ComponentStoreType storeType, SubscriptionStore subStore) at System.Deployment.Application.SubscriptionStore..ctor(String deployPath, String tempPath, ComponentStoreType storeType) at System.Deployment.Application.SubscriptionStore.get_CurrentUser() at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl) at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)COMPONENT STORE TRANSACTION DETAILS No transaction information is available. Any ideas on what else I can do to fix this as I really want to run Mediabrowser.
ebr 16306 Posted September 18, 2014 Posted September 18, 2014 Something inside the clickonce deployment stuff is corrupted. When the simple clear cache doesn't work, I've read that re-creating your user profile usually does. 1
arctic4x4 0 Posted September 18, 2014 Posted September 18, 2014 ok thanks, I will give that a shot, hopefully it works.
ebr 16306 Posted September 18, 2014 Posted September 18, 2014 Okay, please let us know either way and we will get you going somehow.
